anubis
12.09.2018 13:47:20
https://www.theguardian.com/world/2018/sep/12/russia-linked-2014-wiretapping-scandal-poland
Concerns are growing in Poland about potential Russian involvement in a dramatic wiretapping scandal that rocked Polish politics in 2014, after reports emerged that the businessman convicted of organising the operation owed tens of millions of dollars to a Russian coal business.
The people recorded included the interior minister, the finance minister, the foreign minister and the transport minister, all from Poland’s pro-European Civic Platform party, and the heads of the national bank, the supreme audit office, the government protection bureau and the central anti-corruption bureau. Two waiters were also convicted for their part in the affair.
Questions have been raised about the extent to which political pressure from figures associated with PiS, a major beneficiary of the operation, may have hampered official investigations into potential Russian involvement. Neither government nor law enforcement officials have commented on the revelations.
A former intelligence officer who was serving in a senior role at the time of the scandal said: “The connections to Russia were numerous and obvious at the time, but they were never properly investigated."
PiS on vait nagu kult rukkis, venelaste kõrvad paistavad.
edit: https://www.nbcnews.com/news/latin-america/u-s-officials-suspect-russia-mystery-attacks-diplomats-cuba-china-n908141
WASHINGTON — Intelligence agencies investigating mysterious "attacks" that led to brain injuries in U.S. personnel in Cuba and China consider Russia to be the main suspect, three U.S. officials and two others briefed on the investigation tell NBC News.
The suspicion that Russia is likely behind the alleged attacks is backed up by evidence from communications intercepts, known in the spy world as signals intelligence, amassed during a lengthy and ongoing investigation involving the FBI, the CIA and other U.S. agencies. The officials declined to elaborate on the nature of the intelligence. |
283 |
MatchMaker
olavsu1
külaline
anubis
283 |
12.09.2018 22:17:12
Mis sest kaardist järeldada?
Tuul puhub eestis
anubis
12.09.2018 22:35:56
283 |
12.09.2018 22:38:43
Sügis pole alanudki veel. Võiks norida, et mingit ajavahemiku seal ei näidatud kaua need tormikesed tiirlevad. Lambist võivad kaduda
olavsu1
külaline
13.09.2018 00:26:29
sõltub sellest kui soe on vesi ookeani pinnakihis. vähemalt 27 kraadi peab olema vesi soe et selline torm tekiks. kõrgemal kui 25 laiuskraadi madalamal kui 5 laiuskraadi neid ei teki ( reegel see küll ei ole, kuna hetkel on üks kole ilm 35 laiuskraadil. öeldakse ei ei ole orkaan vai on lihtsalt troopiline torm).
seega mida soojem on vesi, seda hullemaks ta muutub.
13.09.2018 06:27:24
| olavsu1 kirjutas: |
seega mida soojem on vesi, seda hullemaks ta muutub. |
Nüüd lisasid normaalse info lisaks, mitte lihtsalt suvalise kaardi
anubis
283 |
-Koppel-
13.09.2018 15:17:02
Valesti ei ole arvutatud?
ca 4200 J energiat on vaja ühe liitri vee soojendamiseks 1°C võrra.
Üks liiter on 100x100x100 mm³ ehk miljon mm³
Ehk mm³ jaoks ei kulu mitte 4,2 J energiat (tuhat korda vähem) vaid miljon korda vähem ehk 0,0042 J
Ühes kuupkilomeetris on 10'000 x 10'000 x 10'000 liitrit vett. Ehk 10³ x 10³ x 10³ = 10^9
Energiat siis 4200 x 10^9 = 4,2 x 10^12 J ehk 4,2 TERA DŠAULI.
Kuupkilomeetreid on sul 4,25 x 10^6. Sellega veel läbi korrutades saame 17,85 x 10^18 J ehk tõesti ca 18 EXA DŠAULI... MY BAD.
Ma ei saanud aru, miks sul vahepeal kuupmillimeetrid on.
| 4,184J energiat kulub 1mm3 vee temperatuuri tõstmiseks 1C võrra. |
Et ei ole ju... kuupsentimeetri jaoks kulub niipalju.
| Kommentaarid: 10 loe/lisa |
10 |
anubis
13.09.2018 15:29:07
Kuupsentimeeter ja kuupmillimeeter läksid esimeses arvutuses vahetusse peas, millegipärast. Sellepärast tulekski ennast kontrollida.
1g vett = 1cm3 mitte 1mm3
1g vee temperatuuri tõstmine 1C võrra = 4,184J
edit: 1/3 Põhja Atlandi Ookeanist on hetkel ~3C soojem, ehk siis ~30 miljonit km2 +3C. Jällegi, kui võtta vaid ühe meetri paksune veekiht siis lisaenergiat jätkub millega toita neid tuulekesi.
Kiire arvutus näitab, et ~300EJ lisaenergiat.
viimati muutis anubis 13.09.2018 15:29:57, muudetud 1 kord |
283 |
villu70
13.09.2018 15:29:41
CNN näitab et ikka puhub natuke seal ameerikas
122 |
-Koppel-
13.09.2018 15:34:09
WiKi: Läänemere maht on 21 721 km3
Ehk selle Kariibimere osa ruumala ja läänemere ruumalade vahe on 195 korda. Ehk Selle 18 exadšauli energiaga saaks kogu Läänemere kaks korda nullist keema ajada.
viimati muutis -Koppel- 13.09.2018 15:35:19, muudetud 1 kord |
10 |
7 :: |
360 |
olavsu1
külaline
13.09.2018 16:08:10
lillatäpp.
viimati muutis olavsu1 13.09.2018 18:23:25, muudetud 1 kord |
13.09.2018 16:13:19
| olavsu1 kirjutas: |
videopilti saab ka
iseasi kui kaua. |
Tavaline tuulevaikne ilm hetkel ju
olavsu1
külaline
13.09.2018 16:37:08
| radari järgi pole see asi veel mandrile jõudnudki
-Koppel-
13.09.2018 16:50:51
| Need suuremahulised loodusõnnetused on muidugi väga majandust elavdavad. Kõik hävinenud majad tuleb taas üles ehitada. Ahela lõpus on seepärast ka kuskil pintslite valmistamise tehases inimestel tööd.
10 |
Anti112
13.09.2018 16:58:26
| olavsu1 kirjutas: |
| radari järgi pole see asi veel mandrile jõudnudki |
114 |
olavsu1
külaline
iir
13.09.2018 18:49:19
Mis veenuse ümber toimus? mendid pääste kiirabi... Lindid virus ja vana virus...
Savisaare maraton?
| Kommentaarid: 90 loe/lisa |
anubis
13.09.2018 20:55:02
http://www.ndc.nato.int/news/news.php?icode=995#
"The Handbook of Russian Information Warfare" is an introductory guide to Russia's doctrine and activities in this field, including elements of cyber warfare. The handbook’s target audience is NATO servicemen and officials who are unfamiliar with Russian principles of warfighting, but require an introduction to this essential element of how Russia projects state power.
Sisukamat lugemist idanaabri metoodika kohta.
283 |
softis
| Kommentaarid: 21 loe/lisa |
21 |
anubis
14.09.2018 09:27:52
| -Koppel- kirjutas: |
Et ei ole ju... kuupsentimeetri jaoks kulub niipalju. |
Ehh, hea lollpea olen ikka. Jäin mõtlema korraks ja muidugi oli mul viga sees arvutuses, lihtsalt ühel teisel real.
4,25M km2 x 0,001km (1m) = 4250km3 (veekogus 1m paksuse veekihi korral)
Lisaenergiat 1C korral mitte 17,782EJ vaid 17,782PJ
| anubis kirjutas: |
Kiire arvutus näitab, et ~300EJ lisaenergiat. |
*~300PJ*
283 |
