raitl
31.01.2018 09:28:25
| Rix, kuulasin enne tellimist natuke maad aga kõik reviewd ja mainimised mis leida suutsin olid positiivse alatooniga.
| Kommentaarid: 166 loe/lisa |
147 |
LKits
| Kommentaarid: 13 loe/lisa |
raitl
31.01.2018 12:47:08
Üle lombi andmeside kiirused ei ole just kõige paremad. Vähemalt võrreldes minu eelmise serveriga.
wget freevps.us/downloads/bench.sh -O - -o /dev/null|bash
System Info
Processor : Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
CPU Cores : 4
Frequency : 2199.998 MHz
Memory : 12019 MB
Swap : MB
Uptime : 2 days, 6:35,
OS : Debian GNU/Linux 9
Arch : x86_64 (64 Bit)
Kernel : 4.9.0-5-amd64
Speedtest (IPv4 only)
Location Provider Speed
CDN Cachefly 11.7MB/s
Atlanta, GA, US Coloat 717KB/s
Dallas, TX, US Softlayer 964KB/s
Seattle, WA, US Softlayer 1.63MB/s
San Jose, CA, US Softlayer 1.27MB/s
Washington, DC, US Softlayer 686KB/s
Tokyo, Japan Linode 1.36MB/s
Singapore Softlayer 1.08MB/s
Rotterdam, Netherlands id3.net 3.86MB/s
Haarlem, Netherlands Leaseweb 8.95MB/s
Disk Speed
I/O (1st run) : 129 MB/s
I/O (2nd run) : 107 MB/s
I/O (3rd run) : 107 MB/s
Average I/O : 114.333 MB/s
dd if=/dev/zero bs=1M count=1024 | md5sum
1024+0 records in
1024+0 records out
cd573cfaace07e7949bc0c46028904ff -
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 3.31027 s, 324 MB/s
dd bs=1M count=4096 if=/dev/zero of=test conv=fdatasync
4096+0 records in
4096+0 records out
4294967296 bytes (4.3 GB, 4.0 GiB) copied, 37.8324 s, 114 MB/s
sysbench --test=cpu --num-threads=4 --cpu-max-prime=9999 run
sysbench 0.4.12: multi-threaded system evaluation benchmark
Running the test with following options:
Number of threads: 4
Doing CPU performance benchmark
Threads started!
Done.
Maximum prime number checked in CPU test: 9999
Test execution summary:
total time: 4.3188s
total number of events: 10000
total time taken by event execution: 17.2600
per-request statistics:
min: 1.20ms
avg: 1.73ms
max: 25.44ms
approx. 95 percentile: 2.45ms
Threads fairness:
events (avg/stddev): 2500.0000/94.47
execution time (avg/stddev): 4.3150/0.00
sysbench --test=fileio --file-total-size=5G --file-test-mode=rndrw --init-rng=on --max-time=300 --max-requests=0 run
Number of threads: 1
Initializing random number generator from timer.
Extra file open flags: 0
128 files, 40Mb each
5Gb total file size
Block size 16Kb
Number of random requests for random IO: 0
Read/Write ratio for combined random IO test: 1.50
Periodic FSYNC enabled, calling fsync() each 100 requests.
Calling fsync() at the end of test, Enabled.
Using synchronous I/O mode
Doing random r/w test
Threads started!
Time limit exceeded, exiting...
Done.
Operations performed: 899220 Read, 599480 Write, 1918285 Other = 3416985 Total
Read 13.721Gb Written 9.1473Gb Total transferred 22.868Gb (78.056Mb/sec)
4995.61 Requests/sec executed
total time: 300.0034s
total number of events: 1498700
total time taken by event execution: 18.7294
min: 0.00ms
avg: 0.01ms
max: 17.12ms
approx. 95 percentile: 0.03ms
Threads fairness:
events (avg/stddev): 1498700.0000/0.00
execution time (avg/stddev): 18.7294/0.00
147 |
LKits
31.01.2018 13:25:39
| raitl kirjutas: |
System Info
CPU Cores : 4
Memory : 12019 MB
Swap : MB
Disk Speed
1024+0 records in
1024+0 records out
4096+0 records in
4096+0 records out
Threads started!
Done.
total time: 4.3188s
min: 1.20ms
avg: 1.73ms
max: 25.44ms
Threads fairness:
5Gb total file size
Block size 16Kb
Threads started!
Done.
min: 0.00ms
avg: 0.01ms
max: 17.12ms
Threads fairness:
Ookei - vägagi üllatavalt head tulemused... nüüd jääb vaid üle küsida - kuidas kurat nad seda teenust nii odavalt pakuvad, kui konkurendid on enam, kui 3x kallimad...
Aga tänud! Vaatasin veebiarhiivi ajaloost ning hinnad pole ka läbi aegade muutunud ehk äkki ei tule "järsku" midagi üllatavat.
napoleon
Unknown virus
31.01.2018 14:24:36
LKits, performance osas see contabo ei hiilga. Mul on seal muidugi see kõige odavam pakett kuna kasutan seda peamiselt backupi tegemiseks või siis kui on vaja mõnda välise ip otsas linuxi purki, millega võib vabalt kõke katsetda(loe: vahel ka piixu keerata) ilma et keegi kurjaks saaks. Aga kasvõi ubuntu uuendusi peale lastes on ikka näha, et jookseb kuidagi väga uimaselt. Ehk lühidalt mingi mees&koer OÜ veebi ja mailid võib seal majutada, lihtsalt hobikorras katsetamiseks sobib ka, aga midagi tõsisemat seal pigem ei jooksutaks.
Positiivse külje pealt võib öelda, et mul on see konto juba rohkem 2 aastat seal olnud ja uptime on väga hea, ühtegi nii pikka katkestust pole olnud, et oleksin seda märganud ja kuna backup jookseb sinna iga 20 minuti tagant, siis märkaksin suht ruttu.
| Kommentaarid: 77 loe/lisa |
60 |
Henry
23.02.2018 20:44:10
Huvitav, kas Zone hakkab jõudsalt Soome laienema oma .fi domeeniga?
_________________ Yeaaaaaaah |
| Kommentaarid: 80 loe/lisa |
73 |
25.02.2018 13:11:30
mul on ka contabos juba hea mitu aastat see kõige odavam.
Lihtsa wordpressi lehe jaoks piisab, ubuntut suudab ka jooksutada ning rusti serveri jooksutamisega kus sees 20 inimest ei jäänud ka hätta Ütleme nii, et selle 7€ eest kuus ikka päris hea diil, lisaks 500gb kettapinda, saab natukene asju hoida backupiks seal + uptime ei mäleta küll, et maas oleks käinud ja hoolduste puhul on ette teada antud kenasti ku peaks maas olema.
Enne seda sai igasugu x asju proovitud samas hinnaklassis ja no kui seal ei suuda 10mb failigi ilma 15x FTP ühendust katkestamata ära uploadida siis oleks palju lotoa et üldse miskit suudab
| Kommentaarid: 39 loe/lisa |
raitl
25.02.2018 18:12:21
| Esialgu olen oma Contaboga jätkuvalt rahul. Jooksutan seal nänni, mis regulaarselt prose kõik tuumad 100% peale veab (neural networking) ja ei ole ühtegi kitsaskohta täheldanud.
147 |
bjorn17
01.03.2018 15:10:49
Beehosting alates eile õhtust 20:00 maas. Enda lehe said päeval alles üles, kliendite asjad ikka maas, k.a. minu omad. Üle visanud - neil katkestusi ikka üle mõistuse palju.
Kuna mitu korda kolida ei ole plaanis, siis soovitage kelle poole pöörduda? 2 domeeni (üks foorum SMF baasil, üks lihtne e-pood Prestashopi peal). Mingit suurt liiklust ei toimu ning muid eritingimusi samuti ei ole. Kas Zone kõige lollikindlam valik Eestis?
P.S. Ega juhuslikult ei oska soovitada kindlat teenusepakkujat kes pakuks ühekordset tasuta nõustamist/abi kolimise osas?
| Kommentaarid: 16 loe/lisa |
15 |
napoleon
Unknown virus
01.03.2018 15:20:48
zone ja radicenter on jah kindla peale minek kui Eesti pakkujaid otsid.
Tasuta abi osas ei oska öelda kas pakuvad. Aga see kolimine ei tohiks mingi eriline raketiteadus olla, viskad baasi üle, kopeerid failid üle, muudad DNS kirjed ära ja siis on tõenäoliselt mõlemal konfifail, kus pead andmebaasi, document root jms. asjad seadistama. Kui ise kohe ei tea/oska, siis mõlemad on sul ju levinud asjad ehk peaks olema lihtsasti googeldatav kus ja mida muuta. Või kui kohe üldse ise sellega tegeleda ei taha, siis võid töövahenduse foorumisse soovi üles visata, sealt ikka mõne abivalmis AHV-i leiad, kes 1-2 6-paki eest selle ära teha aitab.
60 |
LKits
01.03.2018 15:26:11
| bjorn17 kirjutas: |
P.S. Ega juhuslikult ei oska soovitada kindlat teenusepakkujat kes pakuks ühekordset tasuta nõustamist/abi kolimise osas? |
Kui juba ei ole, siis soovitan domeeni registripidaja ning veebimajutaja eraldi hoida.
Mina soovitan Elkdata-t, veebimajutus.ee
bjorn17
01.03.2018 15:56:55
Mõni spetsiifiline põhjus miks registripidaja ja majutaja eraldi peaks olema?
EDIT: Veebimajutus.ee pakub ka sobivalt tasuta kolimise teenust. Üldiselt Google ja vastavate foorumite abiga olen ise ka asjad üles seadnud, kuid kolimine võiks toimuda ilma omakorda suurema "down time-ta" ning vältides tundidepikkuseid troubleshootimise saagasid
15 |
rex
01.03.2018 16:01:00
| LKits kirjutas: |
| Kui juba ei ole, siis soovitan domeeni registripidaja ning veebimajutaja eraldi hoida. |
Mis põhjusel?
226 |
napoleon
Unknown virus
01.03.2018 16:14:52
| rex kirjutas: |
| LKits kirjutas: |
Mis põhjusel? |
Väidetavalt juhuks kui hostingupakkuja huiama peaks hakkama. Sisust on lihtne backupi hoida ja see vajadusel mõne teise pakkuja juurde üles riputada, aga domeeni kättesaamine on keerukam kui registripidaja kohe üldse koostööaldis pole..... lõpuks saab muidugi kätte, aga asjaajamine võib päris pikalt venida ja kogu selle aja on sul leht maas.
Mina olen selle väite koha pealt suht kõhkleval seisukohal. Kui domeen mujal on, siis võib see mujal olev registripidaja hoopis huiama hakata ja on ikka sama jama..... ainult et siis on kaks teenusepakkujat ja ükskõik kummaga probleeme tekib, on leht niikaua maas kui teise lahenduse leiad.
Btw, kas kellelgi on näitena mõni reaalne Eestis toimunud pretsedent tuua, kus hostingupakkuja huiama hakkab. Mõtlen siis seda, kui tõesti hostingupakkuja huiab mitte seda kui klient ise huiab ehk jätab arved maksmata ja õigust jääb veel ülegi.
60 |
LKits
01.03.2018 18:23:24
Selles ongi asi, et kui domeen ja hosting on sama teenusepakkuja juures, siis hostingu teenusepakkujat saab üpris lihtsasti vahetada, aga tõenäoliselt on haldusliidesele ligipääs piiratud ning ei saa ka nimeservereid vahetada ja seetõttu oleks leht üpris pikalt maas.
Aga jah, üldjuhul põhjuseks on iseenda reeglitevastane tegevus.
EDIT: Pretsedent Netpoint kohapealt - mul kliendil pandi konto päevapealt kinni, kuna olid mõned erootilise sisuga pildid. Jah, lepingutingimuste rikkumine, kuid see oli ainult üks osa tema teenustest (aktifotograaf). Ja leht oli maas 4 päeva, klienditeenindus ei saanud asjaga hakkama. Domeen oli ka nende valduses ja ei saanud nimeservereid muuta.
Oleks domeen mujal olnud, oleks tõenäoliselt tundide küsimus (backup lahendused olid teenusepakkujast sõltumatud).
Eks igaühele oma ning lõpuks baseerub ikkagist isiklikele kogemustele.
viimati muutis LKits 01.03.2018 18:28:01, muudetud 1 kord |
SirShark
01.03.2018 18:23:39
| Mina elkdatat ei soovita.
| Kommentaarid: 35 loe/lisa |
29 |
Plugy
01.03.2018 20:29:38
| SirShark kirjutas: |
| Mina elkdatat ei soovita. |
Põhjus?
Ise olen ~4 aastat Veebimajutuse teenuseid kasutanud ja olen vägagi rahul. Isegi kui on mingi probleem olnud, saab lahenduse kiirelt telefoni teel aetud (kui on kerge viga), aga kui keerukam, siis neil admin vaatab üle ja fikseerinud vead automaatselt ise ning ka teavitanud sellest.
| Kommentaarid: 18 loe/lisa |
15 |
Renka
01.03.2018 20:58:56
Räägid nagu oleks probleemide (ma ei tea küll mida sa nende all mõtled täpselt) eksisteerimine teenuses täiesti normaalne igapäevane asi. Olen vist Zone pakutava stabiilse teenusega liialt ära harjunud, et seda normaalseks pidada?
Ma ei kujuta ette kui nende kümnekonna virtuaalserveri mida enamvähem aktiivselt haldan ja paarikümne mille probleemide puhul mulle teada antaks puhul peaks veel miski teenusepakkuja vigadega tegelema hakkama kas telefoni otsas või muul moel.
61 |
Plugy
01.03.2018 21:11:20
| Probleemide all pean silmas, midagi mis on läbi minu käe tekkinud, mitte nende poolne.
15 |
bjorn17
21.03.2018 15:28:17
| Küsimus laiale ringile - kas keegi teab kedagi kes oleks Beehosting OÜ-ga seotud? Tundub rohkem ühe mehe firma olema (Igor Šats või Shats), aga ehk on mingit lähemat kontakti. Nendega tõsine probleem ning enne eskaleerimist uuriks tausta ja olukorda kui kuskil tuttava tuttav istub ja infot saab jagada olukorra kohta riigis. Seniks aga ei soovita MITTE kellelgil antud ettevõttega tegemist teha.
15 |
ufo56
| Kommentaarid: 78 loe/lisa |
67 |
bjorn17
21.03.2018 16:09:20
| Hetkel veel avalikult ei arendaks teemat, loodan veel mõistlikule lõpplahendusele. Võin täpsemalt kirjutada PS-i, kui oled seotud või saad aidata Beehostingu osas.
15 |
ufo56
67 |
LKits
bjorn17
22.03.2018 08:02:05
| See juba vana teema. Hetkel on domeenivaidluse küsimus.
15 |
