uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Samsung Galaxy Note 4 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5
WäntWõll
make.believe
WäntWõll
sõnum 01.03.2017 20:18:02 vasta tsitaadiga
-RaiTz-
-RaiTz-
sõnum 01.03.2017 20:21:05 vasta tsitaadiga
jake28 kirjutas:
kas kellelgi on see problem,et telefon sureb 20% peal ara?olen teinud factori reset ja ostnud uue battery.sama ikka ja kogu aeg sulgeb 20% peal
Note 4 Switches off At 40% Battery Level
Problem: Hello Sir, I can’t understand what’s actually going on with my note 4 battery. My phone keeps switching off at 40% after fully charging it. The most puzzling part is it charges back up to 100% in about 30 minutes. I checked my battery statistics and noticed that Android system is draining it the most followed by screen. But what concerns me the most is why it keeps shutting off at 40%? Please help.
Solution: If this problem keeps on happening the first thing to check is if the problem is software related. Based on the battery statistics that you provided it appears to be normal as it is the Android OS that usually consumes the most battery life. This is followed by the screen if you constantly use the phone. There’s a possibility that some form of corrupt data in your phone is causing the problem. If you have a microSD card installed in your phone then try taking it out first then check if the issue still occurs. If it does, then I suggest you start your phone in recovery mode then wipe its cache partition. This deletes the temporary data in your phone which if corrupted can cause this type of problem. If wiping the cache partition does not fix the problem then I suggest you backup your phone data and do a factory reset.
Kui SD kaardi probleem pole ning, kui wipe/reset ei aita on ilmselt mingi riistvaraline probleem.
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
Lauri0112
Lauri0112
sõnum 02.03.2017 17:42:21 vasta tsitaadiga
Mul hakkas ka kusagil 40% juures restarte tegema. Ja jäigi tegema. Lõpuks oli asi niikaugel, et juba 80% juures hakkas restartidega pihta.
Aitas uus aku. Vana pidas vastu täpselt 2 aastat.
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 61
mikk55
mikk55
sõnum 24.10.2017 10:24:25 vasta tsitaadiga
EMMC error juba pea kõigil note 4 omanikel kaelas ?
Tegelen autovõtmete lisamisega (peamiselt BMW ja Mercedes) ja osade autode puhul ka plokkide kodeerimisega jne.
Kommentaarid: 53 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 51
Longero
sõnum 24.10.2017 18:20:04 vasta tsitaadiga
mikk55 kirjutas:
Mis see EMMC error on v millest tekib, Note 4 uuendustest või? Mul pole nagu mingit suurt jama olnud. Samas pole tükk aega uuendanud.
Eelmine tel SE Xperia pro "uuenduse nahka" läkski... kisas, et pole enam piisavalt mälu. Kuigi appe polnudki suurt midagi, paar brauserit, paar malemängu ja mõned väiksed asjad veel.
Win ISO'd ja uuendused
Artiklid jagatud
viimati muutis Longero 24.10.2017 18:24:48, muudetud 1 kord
Kommentaarid: 59 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 55
WäntWõll
make.believe
WäntWõll
sõnum 24.10.2017 18:22:15 vasta tsitaadiga
kõik pakutav peal, miiskit örrori ei ole.
910F on mudel
Märt.
Märt.
sõnum 25.10.2017 08:09:22 vasta tsitaadiga
Poisil ka seni töötab.
tramburai
tramburai
sõnum 25.10.2017 09:40:30 vasta tsitaadiga
Lauri0112 kirjutas:
Esimest Note 4 akut kasutasin nii, et midagi ei jälginud - kasutasin tühjaks, laadisin täis ja hoidsin üleöö aga kuskil seal 30...40% kandis hakkas lampi ära kustuma ja restarte tegema.
Teist akut teadlikult täiesti tühjaks ei kasutanud ja üritasin laadima hakata 20...25% peal aga laadis üleöö. Pikapeale hakkaski nende protsentide peal restarte tegema.
Kolmandat akut nüüd prooviks alla 5% ei lase ja üle 95% ei lae. Vaatan kaua see vastu peab. Tundub, et ükskõik mispidi ka akut ei ekspluateeriks, lõpuks hakkab ikka trikke tegema ehk küsimus pole selles kas hakkab trikke tegema vaid millal ja milliseid.
olafsand
olafsand
sõnum 28.10.2017 12:05:03 vasta tsitaadiga
See, et sulle täislaetuna kuvatakse 100% ja tühjaks saades 0%...see ei tähenda midagi, sest kontrollerid telefonis jälgivad ja laevad ise optimaalselt akut.
posthuman
posthuman
sõnum 03.01.2018 19:06:32 vasta tsitaadiga
Hakkas minulgi see "mmc_read failed" error külge. Täiesti lampi paar päeva tagasi jooksis telefon kokku telefoni kaustas pilte sirivdes. Jooksis nii kokku ära, et tegi ise automaatselt restardi.. mõtlesin, et noh okei ikka juhtub. juhtus aga see, et jäi loopima, pin koodi küsimiseni ei jõudnudki. No võtsin aku tagant ära paariks sekundiks ja panin tagasi ja voilaa mure murtud. Akut oli toona kuskil 20% ja viskasin ta kohe ühtlasi laadima ja lasin täiesti täis. Täna siis kui aku oli taas langenud 20-30% kanti viskas taas telefon pildi kotti ja hakkas loopima. Küll aga seekord enam aku tagant võtmine ei aidanud midagi.
Googlest selle info peale sain teada, et justkui oleks aku viga, et proovigu ma täiesti täis laadida, et kui üle 50% on akut siis telefon peaks töötama. Aitab uue aku ostmine..
Laadisin siis telefoni 100%, aga käima teda enam ei saanud. Mõtlesin endamisi viimast varianti, et viskan sügavkülma ta 5ks minutiks. Mõeldu tehtud ja oh üllatus, telefon võttis pildi ette... kahjuks aga seda senimaani kuna telefon taas toasoojaks sai ja loopimine võis alata. Vahel ka viskab ette boot screeni kus on siis kirjas "mmc_read failed".
Seda infot kuugeldades leiabki üksjagu infot, et pidi olema note4 tüüpviga. On kellelgi kogemusi selle veaga? Nagu aru saan võin telefoni prügikasti panna, kuna garantii aeg vist on mul ka läbi ja kui ei ole läbi, siis ekraani klaasil on mõra (juba aastake) ja siis ei võeta nkn garantiisse. Või...? Või on äkki Samsungil mingi ametlik teema selle erroriga, et vahetatakse olenamata garantiist ikkagi välja?
EDIT: Lootusetuna teda käima saada, viskasin telefoni 10ks minutiks uuesti sügavkülma ja oh imet, töötab nagu kellavärk, aga seda kuniks telefon saavutab toatemperatuuri.. Õnneks kontaktid ja pildid saan nüüd ära backuppida selle meetodiga icon_lol.gif
mikk55
mikk55
sõnum 03.01.2018 19:41:22 vasta tsitaadiga
posthuman, nii on, emaplaat emex omadega, nende note 4 maha suremine vaid aja küsimus...
posthuman
posthuman
sõnum 03.01.2018 23:43:16 vasta tsitaadiga
Note 4 bootloop, ehk lõputu restart ja error "mmc_read failed".
Igastahes panen siia kirja nüüd veidike infot neile, kellel hakkab ka Note4 ära surema. Lähtun hetkel terve päeva kogutud info põhjal inglisekeelsetelt saitidelt, kus aruteluks oli sama probleem.
Minu soovitused:
* Nii kui telefon hakkab kahtlastel tingimustel restarti tegema, siis mine ja tee oma andmetest kiirelt backup.
* Ole valmis, et telefon sureb lähiajal ära icon_neutral.gif Mine hangi kiirelt midagi asenduseks ajutiseks.
* Ära otsi tarkvaralisi vigu, ala viimati installitud appid, tarkvarauuendus vms.. (Ise ei ole appe installinud nädalaid, tarkvara värskendust ma ei mäletagi millal telefonile tehtud sai (viimane tuli vist oktoobris), kahtlastel saitidel ei kola ega viiruseid ei saa ja telefon ei ole kunagi rooditud olnud)
* Ära näe vaeva "formatiga" ehk factory reset/wipe data.
* Kui oled lootusetult hiljaks jäänud, pane telefon 5-10 minutiks külmkappi sügavkülma. Peale seda peaksid saama telefoni kasutada 5-10 min. Backupi tegemiseks sellest piisab, kui korrata protsessi mõned korrad.
Homme helistan samsungi ametlikku hooldusesse ja uurin ka võimaluste kohta.
Olen mõningaid õpetusi ja infot kogunud netist, aga ei hakka neid hetkel kirja panema, kuna pole neid ise läbi teinud ega pole kindel, kas õiged on.
(ühe eksreemsema variandina eMMC tinutamine emaplaadil).
Hoian kindlasti infoga kursis, mis telefonist saanud on.
mikk55
mikk55
sõnum 03.01.2018 23:48:53 vasta tsitaadiga
posthuman, hooldus laseb üle sind, mul oli garantii aja sees selline tsirkus, öeldi, et kuna telefonil kriimud pleki omast tasust kinni remont.
posthuman
posthuman
sõnum 04.01.2018 00:19:34 vasta tsitaadiga
mikk55 kirjutas:
Jep eks ole seda hooldust näha. Garantiipaberi ma leidsin ja seda veel jätkub. Küll aga kaitseklaasil on läbiv mõra juba aasta läbi, siis ma täiesti huvi pärast võtaks asja suuremalt üles, kui reaalselt on ju viga tootmises. Eks näis icon_smile.gif
Rollu89
sõnum 04.01.2018 17:55:10 vasta tsitaadiga
Mul on endal üks toimiv emaplaat pakkuda, millel ei ole seda viga küljes kui keegi soovib. icon_lol.gif
Kommentaarid: 57 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 51
sõnum 28.01.2018 23:33:44 vasta tsitaadiga
Mul siin 1 note käes, panic recovery..... kuidas korda saab?
Wipe data jne ei aita
Isend surnud?
E:
Sain lõpuks kuidagi samsa logo ette......1h samsa logo oli ees ja siis hakkas tööle icon_eek.gif
tarmo66
sõnum 23.05.2018 16:28:46 custom rom vasta tsitaadiga
Kas keegi on paigaldanud Note4-le mõnda custom rom-i (võimalikult stock android)? Millist?
Longero
sõnum 30.08.2018 18:14:49 vasta tsitaadiga
Heips.
Milles võiks asi olla, Note 4 ca viimase pooleteist kuuga kuidagi imelikuks muutunud nagu mingi lag oleks, kui tahan kaamera lahti võtta siis imelikult kaua viivitab või erinevate äppide vahel vahetades on tekkinud tuntav aeglus mida ennem polnud... vahepeal androidi uuendusi peale lasknud samuti pole.
Kas see võib mõjutada kui aku hakkab õhtale minema, samas on uimasus isegi siis kui laadimisjuhe järel?
Või on android ise juba fragmenteerund selle ajaga, ca 3,5 aastat?
Kas see on usaldusväärne leht uue ROM'i allalaadimiseks mudelile SM-N910C https://www.sammobile.com/firmwares/galaxy-note4/SM-N910C/SEB/ Imelik riigi valik, eeldan et pean valima "Baltic (SEB)"... mida see (SEB) tähendab?
Artiklid jagatud
mikk55
mikk55
sõnum 01.09.2018 10:25:53 vasta tsitaadiga
Emaplaat hakkab maha surema..
https://www.youtube.com/watch?v=5pJ7s9RBtdQ
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Samsung Galaxy Note 4 mine lehele eelmine  1, 2, 3, 4, 5
