praegune kellaaeg 19.05.2026 21:20:02
Laurungar
21.09.2017 20:22:56
Probleem arvutiga |
| Vahetasin täna vana arvuti casei uuema vastu,puhastasin ka vajalikud komponendid enne üle.Eelnevalt polnud arvutiga probleeme,ent nüüd kui mängin mängu siis ca 10ndal minutil lööb pildi eest mustaks ja restart.Ja nii pidevalt.Ei tea enam mida teha,vanarauda viia?
Zuumbox
21.09.2017 21:43:28
| Millised "vajalikud komponendid" ja millega puhastasid?
Laurungar
21.09.2017 21:58:32
Emaplaadi ja videokaarti(sealhulgas ventilaatorid).Kasutasin selleks suruõhku
tegin ka whocrashed analüüsi
On Thu 21.09.2017 20:02:54 your computer crashed
crash dump file: C:\Windows\Minidump\092117-17706-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4AF21C)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8003DB8038, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Thu 21.09.2017 17:42:22 your computer crashed
crash dump file: C:\Windows\Minidump\092117-18096-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8003DAD038, 0x0, 0x0)
enaber
22.09.2017 07:29:24
Pane uus Windows peale
_________________ Ostan, müün ja kahetsen. |
67 |
Zuumbox
22.09.2017 20:26:30
| Kui "raud" on piixus, siis see ei aita...
| Kommentaarid: 1154 loe/lisa |
724 |
