praegune kellaaeg 25.11.2026 00:30:45
08.09.2017 12:32:27
"EK mängud "tavaliste" Plii-akudega": hüvasti, 150 aastat vana akutehnoloogia, tere tulemast AGM-tehnoloo |
Sissejuhatuseks - palju kirjutatakse Euroopa Komisjoni "mängudest" kuidas Tolmuimejate pealt elektrit kokku hoida
- kuid selle suure mängu-show varju on jäänud veel üks "mäng" ja see võib mõjutada väga paljusid kes autoakusid toodavad, müüvad ning kasutavad.
PS: Endal ongi juba vaikne plaan samamoodi "käia ajaga kaasas" ning siis "tavaakuga hüvasti jättes" ning AGM-aku asemele võttes.
Ja siis vaadata, et kas on nii hea nagu neid juba reklaamitakse.
Lühidalt:
- lõpetatakse järk-järgult tavapäraste, 150 aastat tuntud tehnoloogial, "avatud püttidega plii-happeakude" tootmine.
- ning minnakse siis üle AGM-akude ( absorbent glass mat) masstootmisele ning kasutamisele.
Paar linki kah:
1. vähemalt üks Suurtootja (Johnson Controls International (JCI) ) investeerib juba praegu üsna suuri summasid selleks, et siis Maailma ning Euroopa Komisjoni "AGM-akude tootmise soovidega" kaasas käia:
Johnson Controls Expands AGM Lead-Acid Battery Production
ALABC member and leading battery producer Johnson Controls International (JCI) recently announced an investment of $445 million to boost production of its absorbent glass mat (AGM) batteries worldwide.
The investment includes $245 million to double AGM output in North America by the year 2020 and $200 million to build a new battery plant in China. This expansion comes in response to an expected increase in lead battery demand (both AGM and EFB) by car manufacturers as start-stop systems become more commonplace in North America and China over the next several years.
Start-stop technology is currently offered in 5-10% of new vehicles in the U.S. and China, but according to JCI CEO Alex Molinaroli, that figure is expected to rise to 50% over the next five years. The technology is already widely present in Europe, comprising 60-65% of the current market, and that figure is expected to increase to 85% by 2020.
http://www.ila-lead.org/news/lead-in-the-news/2016-07-03/-johnson-controls-expands-agm-leadacid-battery-production
B. Ning siis EUROBAT-i teemakäsitlus samuti sellest, et "akuturul" on ees ootamas suured muudatused:
Towards a ‘2030 Battery Strategy for Europe’
24 February 2017
https://eurobat.org/sites/default/files/170224_eurobat_battery_strategy_for_europe.pdf
terminator
degreal
08.09.2017 15:22:47
| Miks see AGM siis parem on? Loen plusse ja miinuseid ja hetkel tundub, et vanakooli aku on ikka parem.
terminator
ninzor
08.09.2017 16:20:24
AGM aku on pea igati pidi parem kui vanakooli klots. Kallim ainult. Artiklis mainitud, et AGM ning EFB akude järgi on tulevikus suurem nõudlus. Rohkem autosid saab Start-Stop süsteemi ning selle korduva käivitamise-kiirlaadimise koormuse all vanakooli happeaku kaua ei kesta. Lisaks AGM akud kannatavad paremini tühjalt seismist ning püsivad kauem täis (isetühjenemine minimaalne). Külma kardavad vähem (väiksem võimalus, et külmub lõhki), vibratsioonile vähem-tundlikud ning autoga üle kuudi pannes ei voola hape välja. Samades kasutustingimustes sureb tavaline happeaku veidi varem kui AGM aku. Sama kaalu juures parem jõudlus. EFB akud on paremad kui tavalised happeakud aga mitte nii head kui AGM akud, hinnalt ka vahepealsed.
Lisaks AGM akud ei sulfateeru nii kergelt. Samas ülelaadimise vastu tundlikumad kui tavaakud. Kui plaadid kuivaks keeta, siis erinevalt tavalisest akust pole kust vett peale kallata.
Start-Stop'iga autodel tehasest AGM või EFB akud, mõndadel sportautodel pakutakse juba liitium käivitusakusid.
terminator
09.09.2017 12:59:11
Ja ega see, 60% AGM-akude nõue pole Euroopa Komisjonil ka veel ainus nõue ega "mängimine".
Ehk siis "Green-akude" show, kus "tavaliste" pliiakude korral nõutakse nii plii kui happe koguste vähendamist.
- ja samas nõutakse "oluliselt paremate tulemuste saavutamist".
- lisaks veel see, et nende akude korpused on tehtud mingist, väga pehmest, 2-3 ringi "kasutatud plastikust".
Ja see kõik on viinud akutootmise sinnamaani, et tuleb omada ikka neetult palju vaba aega - selleks, et lugeda mida siis tootja ise kirjutab oma uhke-vinge "Green-"pliiaku kohta.
Alates siis sellest, et soojas kliimas ning külmas kliimas tuleb valida erinev akulaadmisrežiim.
Näide:
Ehtne ja uhke, ultramoodne Smart(tark) akulaadija:
1, "tavalise" pliiaku Laadimispinge "sooja ilmaga":
14.49 DCV V
2. "tavalise" pliiaku laadimispinge "külma ilmaga":
15.24 DCV V
Või siis veel hullem versioon kus tootja ise Ametlikult teatab, et tema akut tuleb laadida:
- Ainult suure, võimsa, Real Power laadijaga
- ja et väikse võimsusega Smart Laadijad ei peagi tema akut üleüldse täis laadima.
Ja nii on see ka täiesti reaalselt:
On olemas uhiuus "tavaline plii" Green-autoaku ning sellega on täpselt nii, et:
- seda laeb ainult (vist 300W trafoga, pole sisse vaadanud) Real Power laadija, hetkel laeb vooluga 3A.
- ja seda konkreetset "Green"-akut ei lae mitte ükski väiketrafo-laadija, samuti mitte üks Smart Laadija.
sooty
11.09.2017 10:40:56
| terminator kirjutas: |
| Jep päris tavalaadijaga ei tohi AGM-i laadida-peaks olema kindlasti märge AGM toetuse kohta. |
Seletage palun see osa võhikule ära. Kus on kirjas, millisele autole tohib või siis milline seda ei toeta? Või räägite toas laadimisest ja autosse tohib suvalise õiges mõõdus aku panna?
05.12.2017 16:24:04
Ühe väikse lisaprobleemi võib veel juurde lisada.
See ei kehti võib-olla kõikide autode korral, küll aga kehtib nende autode korral, kus:
- pärast akuvahetust tuleb "autotarkus" üle programmeerida.
- ja siis, kontroll-Terminaliga, omakorda üle kontrollida kas on kõik õigesti või mitte.
Ja probleem on siis selles, et seda Programmeerimist ning kontrolli ei tehta.
Vana aku maha, uus peale ning siis "andku omanik tuld".
Ei kirjuta asjata.
Olen praegu huvi pärast, ühiskondlikus korras ühe Auto ja tema Starteri tehniliseks Advokaadiks ja päästan autoomanikku mõttetust, Autofirma poolt meeleheitlikust uue starteri müügist sellele autole.
Vana starter on laitmatus korras, kõik "kamm" käib ümber akuvahetuse.
Lühidalt - autofirmas vahetati aku, kuid "unustati teha programmeerimine".
Ja nüüd on siis auto käitumises nii mõnedki "kummalised probleemid" ning mis mitte kuidagi ei saanud tulla sellest uuest akust.
- Hetkeseis on siis selline, et vajalik programmeerimine on tehtud (mitte autofirmas) ja need salapärased nähtused on hetkel kadunud.
-"maha murtud-häkitud" midagi pole , sai automargi tootja käest küsitud mis teha
- ja nad siis lahkelt andisid juhise kuidas Omanik ise tibake programmeerida saab seda osa mis käib kaasas akuvahetuse korras.
Ning mille autoelektrik tegemata on jätnud.
Nii, et moodsa aja Akumaailm on ikka neetult põnevaks aetud - ja muudkui tuleb mängida kõiksugu "luuremänge" , et taga otsida mis on õige ja mis vale.
Väikseks teemaarenduseks:
Üks link välismaalt ning see siis näitab selgelt seda viimase aja "aku-jama" kus autoomanikud ei suuda enam täis laadida uhiuusi autoakusid ning mõne kuu pärast on need akud kutud.
Eriti siis olukorras kus:
- tehakse lühikesi "linnasõite"
- või kui auto seisab pikemat aega ja akule ei tehta igakuist Kohustuslikku Täislaadimist. (Exide enda laadimis-juhend).
ConsumerComplaints.in › Exide Industries
Exide Battery — Battery problem
Party has refused to replace batteries which are under Guarantee period.
https://www.consumercomplaints.in/complaints/exide-battery-c37854.html
PS: Suure tõenäosusega osad neist kutudest akudest on tõenäoliselt "ellu-äratatavad" kuid selleks tuleb kasutada juba spetsiifilist Repair-laadimist.
Taas üks Edit ja see võib teha nukraks juba nii mõnegi, varasemalt rõõmsa Autoomaniku.
1. on täitunud minu suvine Ennustus - müüki on siis jõudunud juba sellised Smart-laadijad kus siis on veel ainult:
A. kas GEL ja AGM laadimine
B. või siis GEL ja AGM ning Kaltsiumakude laadimine.
Ning igasugune WET-akude laadimine, nii "avatud-täidetavate püttidega" kui ka "suletud püttidega" on siis välja visatud.
Ehk siis: on ainult üks kindla suurusega, GEL-ile ning AGM-ile sobiv laadimispinge ja laadimisvool, mitte ei ole enam neid mitu erinevat.
Seega, see "laadimis-teadus" on siis nüüdseks veel keerukamaks keritud.
Endal on majapidamises hetkel kaks täiesti erineva käitumisega Smart-laadijat ning mõlema juures on kenasti näha kuidas mingeid ühesuguseid Laadimisteooriaid olemas pole.
Kuigi näha on, et vist peaks veel ühe kolmanda, veel erineva käitumisega, samuti juurde ostma.
- üks oskab ise automaatselt aru saada millise akuga on tegu
- teisega pean ma ise Smart-laadijale ütlema kas on tavaline WET-aku või on siis GEL / AGM.
Samuti on siis suvisest - talvisest laadimisest tehtud üsna keerukas "laadimis-maailm".
- variant a. aku ja laadija peavad olema üle 20 kraadises ruumis, temperatuurikontroll puudub,
- variant b. käsitisi tuleb valida kas suvine laadimine või talvine laadimine.
PS: Ja juba üsna mitu korda olen näinud õnnetuid autoomanikke kelledel on tava-WET aku läbi ning akupoodi minnes - on neile asemele müüdud GEL-aku.
Ja mida siis autogeneraator ei suuda täis laadida kuna GEL-i laadimispinge on hoopis kõrgem kui see on tavalise WET-aku korral. Kuid seda pinget autogeneraator välja ei anna. Või on jäetud reguleerimata.
- tõsi - lõpuks saab ehk ka aku täis kuid selleks tuleb sõita jutti palju rohkem kilomeetreid, ei piisa enam "kuulsast" 20-30km läbisõidust.
Taas üks Edit - internetist silma jäänud, paar aastat, vana tabel - ning see näitab selgelt miks "oleks kasulik taga jahtida", et aku oleks korralikult täis laetud, mitte et omanik sõidab "rõõmsalt" pooltühja akuga.
- Sama jama pärast on siis ma maailmas kõvasti kisa, et akusid tuleb vahetada juba iga 3-4 kuu tagant ning tavaautod näevad välja nagu "elektriautod, istudes pidevalt vooluvõrgus, et akusid korralikult täis laadida..."
Theoretical Example
Battery #1 59 Ah
Voltage, Charge, Remaining Capacity
12.6V 100% - 59 Ah
12.5V 50% - 29.5 Ah
12.4V 30% - 17.7Ah
12.3V 20% - 11.8 Ah
12.2V 15% - 8.9 Ah
12.1V 10% - 5.9 Ah
Battery #2 70 Ah
12.6V 100% - 70Ah
12.5V 80% - 56 Ah
12.4V 60% - 42 Ah
12.3V 40% - 28 Ah
12.2V 25% - 17.5 Ah
12.1V 10% - 7 Ah
PS: näiteks pinge 12,4V "ei ole mingi ime uue aku korral" - avastasin selle oma tuttava autost - kus siis samamoodi toimus aku vahetus ja mingi meetodiga ei suuda auto laadida akusse pinget kuni 12,6V. Pinge on ja jääb vahemikku 12,42-12,43V, tegime huvi pärast ridamisi mõõtmisi.
Nüüd üks soovitus siis - ehk on kasuks neile kes on siis samamoodi sama probleemi ees, kus:
A. on vaja uut akut autole, mis:
- sõidab vähe ja ainult "lühikesi otsi"
- ja mida pole võimalik iga kuu 1-4x "silmini täis laadida"
- ja millele lisaks pole ostetud Smart-laadijat - mis kogu aeg aku küljes on ning siis pidevalt akut laeb:
B. Siis sel juhul tasuks pöörata pilgus järgmise Keemia-lisanditega akude poole:
- Plii-hõbe-aku (silver), näitena: Hankooki Silver-lisandiga akud
- plii-süsink-aku (carbon): näitena: Exide Carbon-lisandiga akud
Nende kahe akutüübi kohta õnnestus siis leida lõpuks info, et need on siis ainsad:
- mis säilitavad pikalt oma mahtuvuse ka madalamatel temperatuuridel.
- ja kannatavad ka juhuslikke, lühiajalisi sõite ning lühiajalisi laadimisi.
- ning lisandid tagavad väga väikse sulfadeerumise.
PS: Hetkel käib siis lõplik valik, et kumma akutüübi kasuks otsustada.
Oli ka Varta Silver aku "silmapiiril" - aga Varta ei suutnud kirja panna kogu vajalikku infot oma hõbe-akude kohta.
Smart-laadijatest niipalju, et kui keegi seda osta plaanib, siis peamine, mida julgen vaadata:
- et oleks olemas Automaatne Termokompenseerimine laadimisel.
Ehk siis - Smart-laadija mõõdab temperatuuri ning vastavalt sellele reguleerib automaatselt laadimisprotsessi.
Ja siis hoiatuseks - kui kasutada Smart-laadijat millel ei ole termokompenseerimist, siis sel juhul tuleb tagada aku temperatuur üle 15 kraadi.
PS: katsetasin reaalselt kahe erineva Smart-laadijaga ning oligi nii - temperatuurikompenseerimise puudumisel pidin autoakut "lisa-soojendama", et aku temperatuur oleks üle 15 kraadi. Alla selle jäi Smart-laadija hätta.
Ning nüüd on võimalik juurde lisada veel üks suur, õigemini väga suur probleem - ning on väga halb "Jõulukingitus" nii neile kes ostavad-kasutavad - kui ka neile kes neid "maale" toovad ning müüvad - ultramoodsa ajastu akusid.
Ehk siis neid akusid mis on toodetud Euroopa Komisjoni kõige viimaste nõuete kohaselt -ehk siis akud mille sees ei tohi enam kasutada "vedelal kujul hapet" vaid see hape peab olema immutatud kujul.
Ning mille tulemusena tekkis "aku-versioon" mis on saanud omale hüüdnimeks: "DryWET battery".
- ehk siis aku mis ei ole enam WET-aku kuid mis ei ole ka GEL vms. "imeaku".
Selliste akude peamised kaks puudust on siis sellised:
A. kõik aku sees olevad pliiplaadid või pliitorud on Formeerimata.
B. kõik pliiplaadid või pliitorud on Stabiliseerimata.
Sellise aku ühendamised autoga toimub siis selline nähtus, et auto akulaadmiskontroller laeb täis ainult a 1-2 pliiplaati või pliitoru, ülejäänud jäävad "mängust välja".
- Seda probleemi ei suuda lahendada ka mitte ükski Smart-laadija kuna ka nemad mõõdavad sel juhul ainult nende kahe "pulga" pinget.
Ning selleks, et sellist "moekat akut" kasutada tegelikult saaks, tuleb - enne autoga ühendamist:
A. aku pliiplaadid ära Formeerida.
B. seejärel tuleb läbi teha pliiplaatide Stabiliseerimine.
- see kõik võib tunduda imelihtne kuid kui ma Smart-laadijaid "läbi kammisin", siis:
- oskas neid kahte tegevust ainult üks ja väga kallis Smart-laadija.
- kuid Smart-laadijaga oli kaasas hoiatus: Formeerimine ja Stabiliseerimine kestavad kokku kuni 70 tundi!
Lõpetuseks Üks Must Huumor kah - tegelikult Reaalne Keiss:
- autoomanik ostis samuti siis "sellise ime-aku" - ja nagu pidigi olema - auto seda laadida ning hooldada ei suutnud.
- siis käis suurem "maade ja puude jagamine" nii akumüüjaga kui ka aku maaletoojaga: et müüsite "Praak-aku".
- Ning finaal oli selles: et see "püha sõda" oleks äärepealt jõudnud Kohtusse, süüdistusega selle aku Maaletooja vastu, et miks ta toob maale "Praak-akusid"....
PS: Ja ma tean ise ka juba neidsamu "Ime-akusid" mis samuti "Praagiks tembeldati" ning välja vahetati. Aga keegi samas ei tulnud selle peale, et tegemist ei ole "praak-akuga". Vaid, et tegemist on akudega mis tuleb Formeerida ja Stabiliseerida enne auto peale panekut.
- hetkel on mul majapidamises kaks sellist "ime-akut", üks on siis tänaseks päevaks Formeeritud ja Stabiliseeritud, teine ootab oma järge.
- On võimalik, et Laadimis-teema uuringute tarbeks ostan kolmanda samasuguse veel. Neid on hea ära tunda - neil kõigil on peal üks kindel Logo mis seda uut tehnoloogiat tähistab.
- Hetkel vaatan - kas Autofirmad julgevad nüüd selle kõik ka ise avalikustada. Kaks Autofirmat on selle Probleemi kirjelduse igatahes saanud kuna nemad müüvad ja paigaldavad autodele neid "iime-akusid".
Täna laekus veel üks info - kui nii läheb, siis saavad Autoomanikud väga rõõmsad olema ning samas teeb see kindlasti Kõva Peavalu nii autoakude maaletoojatele kui ka autoakude müüjatele kuna sel juhul saavad nad maha müüa palju vähem akusid.
See on hetkel siis Exide näide - kuid võib oletada, et aasta-kahega teevad kõis siis sama.
1. Exide muutis sel aastal kõvasti oma 3DX Carbon Boost tehnoloogiat.
2. Ja vot nüüd annab Exide seda uut tehnoloogiat sisaldavale akule 4 aastase garantii. Ehk siis 2 korda pikema kui on teistel Exide mudelitel.
3. On üsna kindel, et ka kõikide Exide Tütarfirmade poolt toodetud 3DX Carbon Boost akud saavad samuti endale 4 aastase garantii.
- üks selline "Tütar" on siis näiteks Centra.
4. Küsisin täna juba ka ühelt Hulgimüüjalt, et miks tema juba ei paku samuti Exide 3DX Carbon Boost akudele 4 aastast garantiid.
- Oldi kõhkleval seisukohal, et on mõttetu kuna need akud niikaua vastu ei pea.
PS: Selles lauses on näha samuti siis see vastuolu kus Maaletoojad-müüjad ei viitsi ära õppida mis on vana tehnoloogia ning uue tehnoloogia erinevus.
Exide on seda ise üritanud selliselt selgitada:
- kui vana tehnoloogia korral on aku vastupidavus: 50 000 käivitust
- siis uue 3DX Carbon Boost tehnoloogia korral on aku vastupidavus: 500 000 käivitust.
PS: Selline suur käivituste arv võib olla täiesti reaalne kuna:
- siis kui ma formeerisin ning stabiliseerisin 3DX akut, tegin ma ka ridamisi 100 ampriseid koormusteste.
- koormustestide arv oli kümnetes ning aku läbis 100% kõik need koormustestid.
ThedEviL
05.12.2017 17:39:32
AGM edasiarendus on EFB aku.
Või siis täpsemalt öelda:
EFB on tavalise aku edasiarendus, et leida kuldne kesktee tavalise käivitusaku ja AGMi vahel.
AGM'i põhi häda on kuumakartvus. Nt mootoriruumi kohe mootori kõrvale pole AGM just parim variant.
Kui aku asukoht on salong või pagasnik, siis AGM on väga hea ja ilmselt on siis auto kohe AGM'i jaoks ka disainitud.
EFB sobib neile, kellel on pidevalt lühikesi otsi kuna laadimisvool suurem.
EFB ei sobi süvatühjenemis akuks. Ehk kui pidevalt parklas tümmi lasta kuni aku tühi, siis tuleb kindlasti AGM või juba Solar soetada.
Ja ei tohi unustada:
Kui auto on ette nähtud AGM'ile, peab kasutama AGM'i
Kui auto on ette nähtud EFB või tavalisele käivitusakule, ei tohi kasutada AGM'i ilma pingeregulaatorit vahetamata. Või pingeregulaatori ümber programmeerimata. Volvo'l näiteks sai aku moodulile öelda, mis akut kasutatakse.
Tavalist kävitusakut võib probleemideta EFB vastu vahetada.
Minul on kõik tavalised EFB vastu vahetatud ning enam ei ole vajadust olnud akut laadida. Laadimisvool on piisavalt suur, et laeb ka talvel täis.
See on vist üks haruldlasi hetki, kus tahanteada jutul on tõepõhi taga.
Väga paljudele uutele autodele on vaja ajule öelda, et uus aku on peal. Siis õpib auto uue aku ära.
Volvo nt õpib ära uue aku ka siis kui toide maha lasta, ehk vana aku eemaldada ja autolt toide maha võtta.
Kahjuks tahavad akuvahetajad "head" teha ning aku vahetatakse pinge all, ehk lisa toiteallikat kasutades.
Tulemus on puhas loterii.
22.01.2018 15:04:28
Eesti Esimesel, õigesti formeeritud ning stabiliseeritud, Exide Centra Plus 3DX akul on nüüd siis edastada väike, kuid positiivne Jõulusõnum ülejäänud nukratele 3DX-tehnoloogial akudele.
PS: Muide, mul on olemas tähelepanek - tegelikult juba juulikuust - et selliseid, "kuivi-happevabu" (Dry-WET) akusid tuleb laadida - formeerida hoopis Liitiumaku laadijaga.
Liitumakude laadijad on kenasti, mõnes kohas ka müügis - aga maksavad ikka kõvasti rohkem.
- aga seda Liitiumlaadija teooriat pole ma veel katsetanud, kuigi - tunda on, et see võib olla Poimt mis laadimisteema kõige lihtsamalt lahendaks nii akuküüjate juures kui ka Autofirmades.
- Igatahes Exide on seda 3DX-i juba ka nimetanud "vaese mehe AGM akuks" või siis AGM akude asendajaks kohtades kus ei tohi kasutada AGM akut.
Ja paistab sedamoodi, et ka Kaltsium-lisandiga akud on siis sellised järgmised mida samuti tuleb esmakordselt täis laadida enne autos kasutamist.
Vähemalt õnnestus nüüd ära näha kuidas tuttava auto ei suuda laadida Kaltsiumakut.
PS: Hetkel mind ennast hämmastab kõige rohkem see kui vähe pööravad tähelepanu nii autoomanikud kui autofirmad kui akude maaletoojad, et mida akutootjad toodavad ning mida nad lähiajal ümber organiseerivad - tänu Euroopa Komisjoni väga karmidele tingimustele ning mis nõuavad veelgi happe ning plii kasutamise vähendamist.
Ei tohiks ju olla eriti keerukas nõuda töötajatelt pidevalt uute ning uute kursuste läbimist ning kus siis kõike uut õpitakse ja seejärel kasutusele võetakse.
Veel üks tore lugemismaterjal - ning mille peaks - "kaanest kaaneni" läbi lugema kõik kes kavatsevad enda autole peale osta Exide ülimoeka 3DX tehnoloogial aku.
Lühidalt: autole uue õige aku leidmine on nüüd siis enam-vähem sama keeruline tegevus kui sülearvutile või tahvelarvutile uue aku otsimine. Eriti veel olukorras kus autol on peal "vanamoodsam generaator".
Tsitaat ning pilt sellest kataloogist - ja kellele ei meeldi, siis Pretensioonid tuleb esitada Euroopa Komisjonile.
Getting ready for the future
The European car parc is changing at unprecedented speed. Legislators passed strict targets requiring carmakers to reduce CO2
emissions to 130g/km by 2015 and 95g/km by 2021, representing a 40% reduction from the 2007 fleet average. These ambitious targets
forced manufacturers to design much more fuel-efficient cars with modern engines and advanced powertrain features such as Start-
Stop, battery management systems and intelligent generators, which no longer recharge batteries in continuous mode. These new
technologies rely on advanced OE-compliant AGM and EFB batteries. Micro-hybrid vehicle production levels are already soaring in
Europe. While cars with conventional powertrains still account for a majority of the car parc, the percentage of Start-Stop vehicles is
accelerating rapidly every year.
PS: Muide - veel üks huvitav tähelepanek:
- iga päevaga suureneneb Liitium-Start-Up abide mudelite arv ning hoogsalt on suurenenud ka nende läbimüük.
Pean silmas siis neid "Liitium-Akupankasid" millega saab laadida telefoni või arvutit ning siis vajadusel teha ka autole Käivituse Stardiabi 200/400A.
- Endalgi juba paar tuttavat kes ostsid uue aku ning sinna kõrvale ostsid koheselt ka "Stardi-abi" seadme.
Edit:
Nüüd siis kaks "Kurba Sõnumit" nii autoomanikele kui ka 3DX akude müüjatele ning ka neile kes usinasti müüvad ja ostavad Smart-laadijaid - ilma, et pööraks tähelepanu sellele mis pingeni need Smart-laadijad pinget laevad.
A. Uusima tehnoloogiaga 3DX akud ei ole enam 12,6-12,8V pingega autoakud.
B. vaid on hoopis juba 13,2-13,4V pingega autoakud.
See tuleb siis sellest, et 3DX akude sees poleva "plaadid" pole enam pingega 2,1V (6x2,1=12,6) vaid on juba pingega 2,2V (6x2,2=13,2).
Reaalne kinnitus siis Exide Centra Plus 3DX aku näitel:
Pinge enne 3DX akuplaatide formeerimist ning stabiliseerimist
0 12.90 DCV V 09:21:06:449
1 12.90 DCV V 09:21:06:980
2 12.90 DCV V 09:21:07:510
Pinge pärast 3DX akuplaatide formeerimist ning stabiliseerimist
0 13.21 DCV V 20:56:19:242
1 13.21 DCV V 20:56:19:773
2 13.20 DCV V 20:56:20:303
See tähendab siis seda kahte karmi värki:
A. Smart-laadija peab olema kindlasti pingeni kuni 15,2V
B. Ning ka auto enda generaator peab samuti välja andma pinge kuni 15,2V.
- ehk siis ultramoodsa aja, targad-reguleeritava pingega autogeneraatorid.
C. aku laadimisel vanamoodsa Smart-laadijaga, mis on pingega kuni 14,5V
või laadimisel auto enda generaatoriga mis on samuti 14,5V,
- ei saa sellist 13,2V akut mitte kuidagi täis laadida kuna laadimisprotsess lõpetatakse liialt vara ära.
- testisin - 14,5V sain aku laetud nii 50% mahus.
D. Sellest kui palju on aku laetud, sõltub see kui hästi ning kui palju "Järjestik-käivitamist" aku välja kannatab.
Tegin huvi pärast täislaetud 13,2V 3DX (Centra Plus) 20 korda 100 amprise Käivitustesti.
Tulemus: testi läbimine 100%:
Enne koormus(käivitustesti imitatsioon)testi algust:
- kasutatud koormus, vooluga: 100A
13.14 DCV V 10:04:01:348
Koormustest, 100A vooluga, algas,
20x, 15 sek. vahedega:
Tulemus: Testi läbimine 100%
Välja valtud siis kõige madalama pingega tulemused:
12.06 DCV V 10:04:35:294
12.00 DCV V 10:05:06:057
12.04 DCV V 10:05:20:378
12.03 DCV V 10:06:04:401
12.05 DCV V 10:06:20:313
Üks karm Edit veel.
Märkus - mul on kaks erinevat 3DX akut - kuid see järgmine Probleem on esinenud mõlema 3DX akuga - ning selles olukorras kus aku on alles ostetud ja on selliselt, ilma ette täislaadimata ning formeerimata ja stabiliseerimata olukorras.
1, Kui aku tühjeneb, siis tekib väga tugev, suure pingeamplituudiga (2V-13V), "piikiv" voolukõikumine,
2. Ja see voolukõikumine, vähemalt selle konkreetse auto korral, ajab autoelektroonika "lolliks".
3. Ning elektroonika normaalseks uuesti töötamiseks tuleb aku küljest lahti ühendada ning siis tagasi ühendada.
Ning veel üks tähelepanek:
- "talverežiim" algab selliste 3DX akude korral juba temperatuuril 10 kraadi, mitte aga temperatuuril 5 kraadi või 0 kraadi.
- meil on garaažis temperatuur 5 kraadi ning on ilusti näha kuidas "pool-laetud / pool-tühja" Exide Premium 3DX mahtuvus lausa "silmnähtavalt" väheneb.
A. kui garaaži temperatuur oli üle 10 kraadi, siis test-koormusel püsis Eixe aku pinge 12,3V juures.
B. Kuid nüüd, 5 kraadi juures on see pinge - täpselt samal mõõtekoormsuel - juba alla 12V-i, viimati mõõdetuna 11,6V.
Paar asja lühidalt lisaks:
1. õnnestus lõpuks ka ära Formeerida ning Stabiliseerida Exide Premium Carbon Boost 3DX aku.
- see aku on siis 13,2V aku, mitte ei ole 12,4 või 12,6V aku. Selline kõrge pinge, 13,2V, tuleb siis aku suurest sisetakitusest.
- kuna ma tegin seda toas ja pisivooludega, siis kulus selleks tegevuseks samuti a 2 nädalat.
- ilma Formeerimata ja Stabiliseerimata kujul - nii nagu sellest Exide akut müüakse - oli aku mahtuvus kusagil 20-30%.
2. Maailmas ja Euroopas annab Exide oma 3DX Premium Carbon Boost akudele 4 aastase garantii. Esialgu Eestis mitte ükski Müüja seda kuulda ei tahtnud, arvates, et käib 2 aastat garantiid küll.
3. Andsin teema ka kusagile Kõrgemale edasi - eks näis kas suudetakse värk viia niikaugele, et iga aku saaks endale lõpuks peale kirja selle kohta mis on selle aku reaalne pinge, pärast Formeerimist ning Stabiliseerimist.
Et kas on siis:
12,4V aku
12,6V aku
või 13,2-13.4V aku.
Seda selleks, et autoomaik saab järgi vaadata mis on tema auto generaatori pinge ja siis vastavalt sellele lõpuks ka osta õige aku.
Umbes siis nii:
14,2-14,5V = 12,4V aku
14,8V-15,2V = 12,6V aku
15,6V-16V = 13,2-13.4V aku
Muudel juhtudel lihtsalt autogeneraator ei suuda akut täis laadida. Või kui, siis ainult olukorras kus kõik tarbijad, kaasa arvatult lambid, on välja lülitatud.
PS; Laua peal katsetades, 13,4V Centra akuga, oli ilusti näha, et imiteerides akugeneraatori pingega to 14,5V, õnnestus aku kuidagimoodi täis saada kuni 50%. Lhtsalt laadmine lõppeb ene ära kui aku suudab ennast täis laadida.
Edit:
Niipalju lisaks, et lõpuks õnnestus siis endale leida selline Smart-laadija mis siis tõepoolest õigesti oskab laadida ka kõikvõimalikke uuema aja 13,2V-13,4V pingega, autoakusid.
Ning järgmine mõõtmine näitab selgelt, et igasugu kõrge pingega, näiteks kaltsiumakud või siis ka AGM+ (AGM kaltsiumakud) laetakse pingega kuni 15,9V.
Ehk siis pingega mis võib olla ohtlik ka paljude autode elektroonikale. Ning seetõttu kontrollivad Smart-laadijad kas aku on autoga ühendatud või mitte. Kui on ühendatud autoga, siis akulaadimist ei toimu.
Smart-laadija,
laadimisvalik: Kaltsiumaku / AGM+ (AGM kaltsiumaku)
15.89 DCV V 16:01:58:224
15.89 DCV V 16:01:58:755
15.89 DCV V 16:01:59:285
Nii, saab juurde lisada veel ühe Probleemi - õigemini täiesti huviga ootan, et:
Millal ärkavad kõiksugu Autofirmad ning Ülevaatusfirmad, et nende poolt kasutatavad kõiksugu Aku-testrid ja Aku-mõõtmisstendid:
A. eksivad kuna need on ette nähtud ainult "vanatüübiliste WET-akude" kontrollimiseks.
- ehk siis "kuulutavad korralikeks-täislaetuks" tegelikult ikka üsna kõvasti tühjad (a la 20-30% täituvusega) akud.
B. ja need Stendid ei ole ette nähtud uuema, moodsa ajastu "kuivade-poolkuivade (DRY-WET) akude kontrollimiseks.
Õigemini - Autofirmades ning Ülevaatusfirmades on praegu vaja sisuliselt kahte erinevat Kontroll-stendi ning töötajad peavad omama kahte erinevat Mõõtmis-testimis-koolitust kuna need kaks erinevust on tegelikult erinevad nagu "öö ja päev".
- kuigi, see võib endaga kaasa tuua massilise töötajate lahkumise sest kes ikka on nõus kõike uut õppima ning lisaks tegema teste mis võtavad kokku aega a 12-24 tundi, halvemal juhul a la 48-100 tundi.
Plaanin lähiajal ühte "Road-Show-d" ühe Autofirma juhi juurde, et talle natuke pilte joonistada. Eks siis näis mis ta kostab selle peale kui teada saab, et tema firmas kasutatav tehnika eksib ning, et ta peab kulutama kõvasti raha uuema kontroll-tehnika ostmiseks.
- targemaks saan, eks siis lisan teemasse juurde.
PS. Ei ole nali, olen juba näinud reaalselt seika kus Kontroll-stend trükkiski, tühja aku kontrollimisel välja tulemuseks:
Battery OK.
Tegin huvi pärast siis:
- formeeritud-stabiliseeritud Exide Premium 3DX Carbon Boost akuga 36 tunnise pingekatse.
Kenasti on näha kuidas pinge püsib väärtusel 13,2V.
Ning sellest on ka kenasti näha miks autofirmade ja akufirmade kõikvõimalikud Laadimis-kontrollstendid vale test-tulemuse välja annavad.
- need Kontroll-stendid on programmeeritud mõõtma-analüüsima 12,4-12.8V pingega WET-akusid, mitte aga pingega 13.2-13,4 "DryWET" akusid.
Testitulemus:
Exide Premium 3DX Carbon Boost aku.
N-ö Õige pingega Smartlaadija, laadimispinge: 16V.
12 tundi pärast laadimist:
13.24 DCV V
13.24 DCV V
24 tundi pärast laadimist:
13.24 DCV V
13.24 DCV V
36 tundi pärast laadimist:
13.20 DCV V
13.20 DCV V
Edit:
1. Eespool, mitu korda olen vihjanud siis sellele, millest Akufirmad ja Autofirmad paaniliselt "igaks juhuks ei räägi".
A. Kõikvõimalikud Kontroll-standid on arvestatud-projekteeritud kontrollima-testima 12V WET-akusid.
B. Ja eksivad kõvasti kui sellise Kontroll-stendiga kontrollida (poolkuivi, Euroopa turule toodetud) DryWET 13V akusid.
2. Nüüd siis realne Pildinäide kus 12V WET-aku "pähe":
- kontrolliti hoopis 13V DryWET 3DX akut.
- ning "kuulutati" formeerimata, stabiliseerimata, laadimata 13V aku "täiesti korras ning laetuks" olevat.
PS: Selle aku kohta siis Auto teataski paar päeva hiljem, et:
- aku on tegelikult tühi ning seda akut ei osata täis laadida.
Pilt ise siis ja nagu vanasti öeldi: "pilt räägib rohkem kui 1000 sõna".
rex
23.01.2018 12:18:53
| tahanteada kirjutas: |
- targemaks saan, eks siis lisan teemasse juurde. |
Mis ta ikka kostab - Männikul kalad näljas. Vaevalt, et pärast saadud "koolitust" tarkust enam foorumisse lisada õnnestub.
Kui tõsisemalt rääkida, siis kahtlemata väärt uurimus- ja selgitustöö.
27.01.2018 11:43:38
Edit:
Oli natuke aega ja ma tegin selle "vale tulemusega kviitungi" kõrvale natuke paremini selgitava pildi.
Ja näitab seda, et sel ajal kui 12V WET akude testseade näitab laetust / kvaliteeti a 100%, siis laetuse tegelikkus on kusagil 20-30%.
Ja nii see on - kõik 3DX akud, mis "riiulilt" võetakse:
- on formeerimata / stabiliseerimata pingega plaatidega.
- ja seetõttu ongi see mahtuvuse-kavaliteedi tegelik protsent selline "madal".
Edasi, kuna tegemist on 13,2V DryWET akudega, siis nende formeerimiseks-stabiliseerimiseks on vaja oluliselt kõrgemat laadimispinget kui autogeneraator ise välja annab.
- osadel laadimisjuhtudel isegi 22-24V, mõningate impulss-laadimiste korral isegi nii 30-40V ülikiired Peak-id.
Ning siit Oht: Liialt kõrge laadimispinge põletaks maha autoelektroonika.
Seetõttu Smartlaadijad kontrollivadki kas aku on ühendatud autoga. Kui on ühendatud, siis kõrge pingega laadimist ei toimu, toimub ainult Hoolduslaadimine.
Nüüd siis see täiustatud pilt - olen neid mõõtmisi teinud kümnel erineval mole ning erinevate seadmetega - lahendustega.
Kõik tulemused on täpselt samasugused: 20-30%.
Ja selles pole mõtet mind süüdistada - selles süüdistage Eestimaa suurt sõpra: Euroopa Komisjoni ning tema poolt tehtud "huvitavaid otsuseid"...
Nonii - viimaks ometi - õigemini Kahtlustasin seda järgnevat infot juba eelmise aasta suvel - aga kus sa sellega, ega Exide akude müüjad ju ei taha midagi rääkida sellest, et mis laadija on siis:
Ideaalselt Õige Laadija Exide akude korral.
Nüüd on mul siis vastus üheselt käes - ja see ei tee rõõmu tegelikult mitte ühelegi autoomanikule kes kasutavad Smart-laadijaid, eriti selliseid odavaid kelledel pole ka üleüldse teada, et mis pingega või laadimisgraafikuga see värk toimub.
Vastused siis:
1. Exide moodsa aja akude laadimispinge on 15.5V.
2. Ja sellist laadimispinget annavad välja ainult Exide enda poolt toodetud uuema aja akulaadijad.
3. Ning kolmandana ka veel see, et Laadimistemperatuuriks soovitatakse 25 kraadi.
- ning see on kõrgem kui paljudes muudes allikates soovitatud: "üle 15 kraadi".
PS: Seega on siis mul ka selge, miks 15,2V laadijad kohe mitte ei taha ideaali-lähedast laadimist teha.
Ja ma pean kasutama 16V pingega Smart-laadijat.
Edit:
Nüüd on siis Smart-laadijate "kollektsioonis" olemas ka Exide enda Smart-laaija.
Saab hakata elama siis "moodsat elu" kus iga autoakuga on kasutusel täpselt sama tootja Smart-laadija.
Esimesed tähelepanekud:
A. Temperatuuriandur on paigaldatud "Miinus-krokodilli" sisse.
- seega, mõõdetakse peamiselt aku katoodi temperatuuri.
Mitte ei mõõdeta ruumi temperatuuri nagu see konkurentidel tavaliselt on.
B. Näha on, et Akulaadimise algoritm on hoopis teistsugune kui on konkurentidel.
- kuna 3DX on patenteeritud tehnoloogia, siis võib olla üsna kindel, et ka see algoritm on 1:1-le sobilik selle "3DX leiutisega".
C. Miinuse poolelt siis see, et Manuaal on üsna lahjake ning isegi seda pole kirja pandud - kaua, ligikaudselt, kogu laadimistsükkel aega võib võtta.
- testriga saadud mõõtetulemuste järgi võttes - kestab täistsükkel kusagil a 20-30-40 tundi.
Ja nii võib see ka olla - üks sarnane konkurent annab Max. laadimiskestuseks 70 tundi.
Lisa 1, see Exide enda Smartlaadija:
- esimene Proovitest: selle kestus oli nii a 15 tundi.
- praegu jookseb teine Proovitest, siis hakkan analüüsima kas ning kui reaalne see laadimine selle kestusega oli.
Ehk siis - kas ja kui hästi siis Exide aku "ära tunti" ning laadida osata.
PS: Välismaalt laekus ka veel sellist infot, et Exide kasutab samuti enda akudes kaltsiumilisandit.
Seega - selline "imekõrge" laadimispinge vajadus võibki tulla sellest, et ka sellised akutüübid võivad sisaldada samuti mingis koguses kaltsiumit.
- kaltsiumakude / AGM+ akude laadimispinge max. on 16V.
mikk55
27.01.2018 11:53:17
AGM akude puhul on nende pinge külmaga suurem, see seletab ka seda, miks on neid vaja soojas laadida.
_________________ Tegelen autovõtmete lisamisega (peamiselt BMW ja Mercedes) ja osade autode puhul ka plokkide kodeerimisega jne. |
12.02.2018 11:44:06
Nii, paar päeva on siis võrreldud Exide Smartlaadija käitumist ning laadmist / säilitamist vesrsus siis mõned teised Smartlaadijad.
Peamine erinevus tundub olevat see, et:
A. kui "tavapärasel" Smartlaadijal on:
- üks laadimispinge
- üks säilituspinge
B, siis Exide Smartlaadija teeb korraga:
- kaks erineva pingega laadimistsüklit
- ja alles seejärel, kolmandana, on siis säilitustsükkel.
C. Ning Exide Smartlaadija laadimisväärtused on 100% täpselt sellised nagu Exide ise ka igasugu enda Laadimisjuhendites soovitab kasutada.
- aga nagu öeldud, selline, soovituslik Laadimisprotsess on väga pikk.
Umbes nii, et kui ma ostan täna Exide formeerimata-stabiliseerimata aku, siis auto peale saan ma selle panna alles nii 12-24 tunni möödudes.
PS: Ning netist jäi veel üks huvitav asi silma - õigemini, kunagi ka sellele vihjasin:
- sõda siis akutootjate ning Euroopa Komisjoni vahel jätkub - tunda on, et tõusvas joones.
- ning nüüd nõutakse juba üsna häälekalt, et Euroopa Komisjon tühistaks oma otsused ning lubaks Euroopa turule tagasi, "silmini ehtsat hapet", sisaldavad WET-akud.
Eks näis kuidas edasi läheb - karta on, et EK "vilistab selle nõudmise peale".
Võrdlesin siis veel "konkurent-Smart-laadija (väga hea ning tark, paljude võimalustega) selle uue Exide enda Smartlaadijaga.
Ka ajalised toimingud on ikka neetult kõvasti erinevad:
Exide 3DX premium Carbon Boost aku:
A. konkurendi Smartlaadija:
- laadimispinge: tõus kuni 14,7V (AGM režiimi laadimispinge),
- seejärel, üsna koheselt langetati pinge "säilitus-hoolduspingele" 13,6V.
B, Exide Smartlaadija käitumine:
1. laadimispinge tõus kuni 14,7V
- nüüd, säilitati seda pinget 2 tundi.
2. Nüüd langetati laadimispinge väärtusele 14,5V.
- nüüd, sellel pingel kestis laadimine: 9 tundi.
3. Ja nüüd, lõpuks, pärast 11 tunnist laadimist:
- langetati pinge "säilitus-hoolduspingele" 13,8V.
Kui kellelgi on küsimus, miks laadimisaeg on nii neetult pikk,
- siis see tuleb väga väikse väärtusega laadimisvoolu kasutamisest laadmisel.
mA-d või siis kümned mA-d.
Tibake siis natuke "akuhuumorit" kah:
- kunagi esitasin - lihtsalt info saamiseks ühele Riigifirmale aku-teemalise küsimuse.
Nüüd siis laekus umbes sellises sõnastuses vastus:
Et Eesti akuturul toimuv olla salastatud 70 aastaks.
- selle peale vastasin, et see, mis nad üritavad salastada, on tegelikult kenasti kirjas Euroopa Komisjoni ametlikes, avalikes, direktíivides.
Ning teise huumori-teemana - viisin siis selle valesti testimise probleemi reaalselt Autofirmani.
- ning neile tundus kummaline, et miks 12,4V-12,8V pinge mõõtestend "äkki eksib kui mõõdab 13,2V pingega akut".
Lubasin lahkelt, et kui kunagi viitsin, siis lähen kohapeale ning "maalin natuke pilte ja graafikuid", et tehnikud aru saaksid miks nad ei saa õigesti mõõta 13,2V akusid, ilma et oleksid ostnud täiesti uue ning palju kallima Test-stendi.
Paar "mittemeeldivat" leidu veel:
A. See uus Exide "odav-Smartlaadija".
- kui Exide 3DX aku on "väga tühi": Süvatühjenenud aku, siis:
- tuleb teha kaks järjestikust laadimist kuna enne kui tühi aku täis laetakse.
Ning mõlemal korral laetakse erineva Algoritmiga ning kokku on laadmisaeg kusagil 25-30 tundi.
B. Jäi silma üht-teist ka Varta autoakumaailmast - tundub, et samuti allutakse siis Euroopa Komisjoni "survele" - lõpetada vedelal kujul happe kasutamine ning vähendada oluliselt plii koguseid:
- igatahes on osades Varta akudes samuti kasutusel "plii-võrk" - samamoodi nagu on see ka Exide 3DX akudes.
- hetkel ei leia uuesti üles, kuid Varta hoitatus oli selline:
1. kui Varta aku on sügavtühjenenud, siis selle akuga autot käivitada ei tohi.
2. Ja kui käivitatakse, siis Varta süvatühjenenud akuga saab sõita ainult - oli vist - 900 meetrit.
- kui leian selle Varta lingi üles - siis panen selle siia üles. Seal on nii juttu kui pilte sellest süvatühjenemis-probleemist.
Edit: uurisin paari Autofirma seisukohti ning tegin läbi Rollimängud.
- nii Autofirma juhi oma
- kui Autofirma tehniku / elekttriku oma
Ning näha on paar üsna kindlat "murdumatut" seisukohta - nagu oleks "aeg pöördunud tagasi nii 20-30 aastat".
1. Meil "savi" sellest Euroopa Komisjoni Direktiivist - meie oleme eestlased ja meil on ikka kõik samamoodi nagu 20-30 aastat tagasi.
2. Ja meil on ükskõik autoomanikest - nad nagunii ei julge kusagile kaebama minna kui on kas vale aku või selle vale laadimine või vale diagnostika.
- aga eks nii ka see üsna kindlasti on - kuna olen näinud ainult ühte Autoomanikku kes pärast akuvahetust nägi, et Värk vale ning siis otseselt Kohtuga ähvardades Maaletoojani välja jõudis.
- ning kelle autos siis kibekähku vale aku asendati Kaltsiumakuga.
PS: On mu oma tuttav, praegu, külmade ilmadega sõidab siis nii, et laeb praegu iga öösel akut minu poolt laenatud Smartlaadijaga, pingega 15,2V.
- põhjus - autogeneraator, mis on mõeldud WET-aku laadimiseks, pingega 14,3V, ei suuda korralikult laadida Kaltsiumakut mis tahab saada laadimiseks 16V. Seega, see 15,2V on siis selline "küla keskmine"...
Edit:
Tegin siis vahepeal, toas, Exide Premium 3DX akuga veel natuke "labori-katseid" ja "põletasin katsetuste käigus spetsiaalselt maha" natuke elektroonikavidinaid, et näha kuidas elektroonikale meeldib siis nii "tühjenenud aku" kui ka "süvatühjenenud moodsa aja aku".
PS: tegemist on "mõne euroste vidinatega", nii, et materiaalne kahju kõvasti väiksem kui samalaadsete vidinate põlemine auto peal.
Ning tulemuseks avastasin selle, mida ka ammu olen kahtlustanud - neile, Euroopa Komisjoni nõuetele vastavatele, akudele - kui need on siis formeerimata-stabiliseerimata ja õige pineni laadimata - ei meeldi ka see, kui autos korraga lülitatakse tööle Suurkoormus (lambid, küte). Ühesõnaga - kõik see siis mis lülitatakse tööle pärast signalisatsiooni mahavõtmist.
Edasi: uurisin ka ühe auto elektriskeemi, meie autoga, arnane ning ka skeemist on tegelikult näha kaks asja:
A. kõik koormused lülituvad tööle korraga.
B. ja pole kasutusel mitte ühtegi filtrit ega muud lahendust mis piiraks sellist järsku vooluPiiki mille need tarbijad korraga tekitavad.
Nii, et kellel jamad majas - ning kes tunneb jootekolbi ning oskab elektriskeemi lugeda, siis tasub ehitada ja paigaldada LC-filtrid, et selliste vooliPiikide mõjusid vähendada.
Ja veel - kes otsib näidet mujalt kõrvale - siis näiteks kasvõi hõõglampidega prožektorid mis korraga süttides voolukaitse suudavad välja lüüa, järjestikku süttides aga mitte.
Wordmc9
12.02.2018 11:53:35
| EFB aku siis vanale 72 aasta masinale ok ja see M aku 2002 Audile ?
22.02.2018 15:14:01
Edit:
Tegin ka konkreetse pildi sellest mida siis ei kannata välja tänapäevased, moodsad, Euroopa Komisjoni nõuetele, vastavad "Poolkuivad (DryWET) Exide 3DX tehnoloogial baasnevad akud.
- erinevus ongi siis vanatüübilistest WET-akudest see, et kui WET-akud olid "silmini" täis topitud pliid ning hapet, siis EK-tingimustele vastavates Dry-WET akudes on plii asemel "pliivõrk" ning suurest happekogusest on järgi ainult "pisike piisake".
Ja sellest tulebki, et kui vanatüübiline WET-aku ka tühjana kannatab edukalt välja järsku Peak-koormust (lambid, küte) (pildil punane), siis DryWET aku aga mitte.
Ning siis LC-filter suudabki sellist Peaki "siluda". Üsna tavaline Põhikooli füüsika, iseasi miks autotootjate insenerid pole füüsikatundides käinud.
Pilt siis kah:
PS: Mis aga puutub Starterisse, mille kaela tavaliselt "see probleem määritakse", siis Starter on Mootor, seega on tema käivitus "kolmnurk-Peak".
Edit: Kuna eile oli "juba ilus suvepäev" , siis külastasin, kahe kuu möödudes, garaažis olevat autot. Temperatuur: 5 kraadi.
Kontrollisin oma ideed kas saab koormuste paralleelselt, korraga toimuvat, Kooslülitamist jagada mitmeks, järjestikku toimuvaks lülitamiseks.
Täiesti oli üks, kuid kergelt tüütu variant, olemas.
Signalisatsioon maha.
1. kõigepealt "kaasreisija ukse" avamine.
2. seejärel alles juhiukse avamine.
Ning auto signalisatsiooni alla panekul täpselt vastupidi:
1. kõigepealt juhiuks kinni.
2. siis kaasreisija uks kinni.
Ning alles nüüd signalisatsioon peale.
Igattahes oli selline versioon akule ikka väga meeltmööda.
Sellele Exide 3DX akule läks siis peale Exide enda Smartlaadija ning näha oli, et käivitus veel hoopis teistsugnue laadimis-algoritm, mida ma veel varem näinud pole, kuid käitumise järgi võttes:
- suudab Exide akut laadida ka siis kui see aku on ühendatud autoga.
- mitte ei käitu nii nagu Konkurentide omad kus Smartlaadija - sellises olukorras: aku autoga ühendatud - teeb ainult hoolduslaadimist.
Edit: nüüd on mul siis olemas majapidamises ka aku, mida Exide ise otse soovitas vanema auto korral kasutada:
EFB 3DX Start-Stop aku.
- tehase säilituspinge on tal 12,55V.
- ehk siis pinge mille kohta Exide ise kirjutab:
kõigepealt lae aku täis, siis alles mine sõitma. Vastasel juhul "söövad" autos olevad tarbijad ära selle juurdelaetava pinge.
PS: üks tähelepanek veel, ei tea kas see kunagi ka Eestisse jõuab:
osades Euroopa Liidu riikides on selliste EFB akude garantii 4 aastat, mitte enam 2 aastat.
See aku saab siis homme peale Exide enda Smartlaadija, eks siis ole näha millist laadimisalgoritmi kasutatakse ning mis pingeni täis laetakse. Tõenäoliselt on pinge samuti 13V ning üle selle.
- see 13V on järjest rohkem leviv info ka välismaal.
Grid-aku (pliivõrk): pinge üle 13V: aku on täis, ei vaja juurdelaadimist.
Grid-aku: pinge alla 13V: aku on tühi, vajab juurde laadimist.
Edit: Nii, paar infot siis lisaks:
1. Exide Smartlaadija oli garaazis, autoga ühendatud aku küljes:
- temperatuur garaažis: +5 kraadi.
- Exide Smartlaadija laadimis-säilituspinge sellel temperatuuril: 15,2V.
Tegemist siis Automaatselt töötava temperatuurikompensatsiooniga ning sellele vastava pinge valikuga.
+15,2V temperatuuril +5 kraadi näitab siis seda, et "talvine laadimispinge" algab juba alla 10 kraadi.
Mitte enam alla 0 kraadi - nagu varasemalt levinud oli.
2. Edasi - oli see Smartlaadija toas, temperatuuril 22 kraadi, asuva Exide 3DX EFB aku küljes ning tegi sellele akule Kohustusliku Esimese Laadimise. Exide enda Laadimisjjuhend: kõigepealt esimene laadimine, siis alles aku auto külge.
Laadimiskestus: 9 tundi.
Nii, et uued Exide 3DX Grid-akud nõuavad väga mehist kannatust, enne kui aku tegelikult laetud saab ning siis alles saab autoga sõitma minna.
Edit:
Lisaks siis: Laadimine on lõppenud +12 tundi Kohustuslikku säilitussega:
Akupinge pärast seda "pikka ooteaega:
13.06 DCV V
Välismaal liigub ringi üks uus tabel / klassifikatsioon - ei tea paljudele akutüüpidele see kõlbab, kuid Plii-võrku (Grid) kasutavatele akudele on tehtud "eraldi rida":
A. pinge üle 13V: aku ei vaja juurdelaadimist
B. pinge alla 13V: aku vajab lisalaadimist
Pisike Edit:
Suhtlesin täna tuttavaga - kellel siis samuti vanakesel autol uue aja moodne aku ning kes selleks, et auto käima läheks selle külmaga:
- kuna tal pole aega aku laadimiseks a 10-12 tundi, siis on tal lahenduseks:
A. mootori- ning akusoojendi millega soojendatakse mootor ja aku temperatuurile 20 kraadi.
- ütles, et selleks kulub 2 tundi.
B. ning kotis kannab lisaks kaasas 3-e, USB-kujulist, Liitiumakul töötavat StardiAbi.
Ühtlasi kommenteeris, et see "kola kokku" maksis ikka neetult suure raha.
Sellele EFB akule tegin nüüd läbi siis ka Pliiplaatide Stabiliseerimise ja Formeerimise. Eks siis 24-48 tunni pärast ole näha mis pingele akupinge stabiliseerub.
See ongi siis nende uute akude kõige tüütum-pikem protsess, osade akutüüpide korral võib see ulatuda isegi 72 tunnini.
Paar Pisilisa siis:
1. Kui hösti läheb, siis tehakse Exide akude kõikvõimalikud Tutvustus-müügireklaamid ringi, vähemalt Soome suunast tulevatel Exide akudel.
Ning lisandub siis see juurde, et:
- Akut ostes tuleb aku kõigepealt täis laadida, siis alles sõitma minna.
- Ning, et ainus, ideaalselt Õige Smartlaadija on siis Exide enda laadija.
Kui keegi tahab teada mis ta niikaua - 9 tundi teeb , kui aku laeb - siis, eks vahepeal suusatab või jalutab männimetsas.
2. Ning teise teemana - see võib tunduda samasugune Ulme kui oli omal ajal Lutheri "Kirikupööre" - kuid kui teha täpselt ühesuguseid koormamis-laadimisteste kümnete kaupa Exide uute 3DX akudega ja Exide enda Smartlaadijaga,..
..siis kipub jääma mulje, et nendesse uutesse Exide akudesse on sisse topitud "Exide ID-Chip" ning siis Exide enda Smartlaadija saab selle "ID-Chipi" käest info, et tegemist on Exide enda akuga.
Automeestele -autoelektrikutele on selline teema-idee kindlasti "kauge ja utoopiline Kosmos" kuid elektroonikuna poleks selles mitte midagi uut. Kõiksugu vahelduvpingelist infot-signaale on võimalik täiesti edastata paralleelselt alalisvooluga. Ning seda osatakse teha oma 50 aastat või ka rohkemgi.
Igatahes, kui on olemas ning kasutusel "Exide ID-Chip", siis see seletaks loogiliselt lahti paljud kummalised "laadimismustrid" nii laadimisel "laua peal" kui laadimisel autos, Exide enda Smartlaadijaga.
Küll võib sellega kaasneda peagi see, et sama lahendus võetakse kasutusele ka Konkurentide akudes ning siis võib tõepoolest ees oodata see, mida olen ennustanud - et igat autoakut saabki laadida ainult mingi kindla Smartlaadijaga.
Nii nagu on näiteks kasvõi laptoppide juures kus kontrollitakse, et kas kasutad õiget laadijat või mitte.
pinkman
22.02.2018 15:29:50
| Väga huvitav jutt akude kohta.Omal 2017 renault grand scenic 1.5 diisliga millel lasin peale panna webasto.Millist laadijat oleks siis sellise asjal vaja.
27.02.2018 23:43:54
Hetkel on ikka see hämmastav mismoodi lp. Eesti Autojuhid käivad ringi kinniste silmadega ja on kusagil "pilvedes" ja kohe mitte ei suuda Akupoes või Autofirmas märgata, et vananenud tehnoloogiaga WET-akud on Helesinine mälestus ning millele Euroopa Komisjon, järgmisel aastal, lõplikult "vee peale tõmbab".
Hakake harjuma - pole enam olemas paksust pliist ämbreid mis on silmini hapet täis valatud.
Exide akudest veel natuke.
Kuna lubatakse "super-külma" , siis tegin kahele Exide akule, üks Premium Carbon Boost ning teine EFB, katse kumb paremini koormust kannatab ning kiiremini laadimisega keemilise reaktsiooni tekitab.
Võitja oli igatahes EFB-aku, keemiline reaktsioon on kiirelt koheselt algav, samas kui Carbon Boostil võttis see toiming rohkem aega.
Tõsi, EFB kaalub oluliselt ka rohkem, see tähendab siis oluliselt rohkem pliikogust ning happekogust selle aku sees.
Seega, karmimates oludes, karmimate masinate, kasvõi põllutöö- ja metsatöömasinate korral võib tekkida olukord kus EFB-aku on ning jääbki ainult ainsaks akuvalikuks millega "vanamoodsat WET-akut" asendada.
Edit: Eespool kirjutasin, et vähemalt Exide uute 3DX (Pliivõk) akude korral - kui aku pole silmini täis laetud ning stabiliseeritud pliivõrk-plaatidega,:
- siis on kasulik kõikvõimalikud koormused hajutada laiali, mitte lubada nende rakendumist korraga.
Nüüd. lubatud suurte külmade tulekul sai huvi pärast paari vanema autoga katsetatud sellist "hajutamist" ning jäi silma vähemalt üks variant - on tüütu -kuid töötas kõigi nende autode korral.
Ehk on kellelgi abiks kui on suur külm, aku külma tõttu "silmini tühi".
1. signalisatsioon maha
2. seejärel. kõigepealt kas kõrvalukse või pagasniku avamine.
3. nüüd alles juhiukse avamine.
4. Ja nüüd siis käivitamine - avatud ustega.
5. Kui auto on käivitunud, siis alles autouksed kinni - ja sõitma.
Selle versiooniga tekitatakse olukord kus kõikvõimalike ustemagnetite ning valgustuste jms, suurtarbijate voolupeak ei oleks täpselt ühel ja samal ajal.
See on muidugi kummaline, et kõikvõimalikud "kuulsate autofirmade" Autoinsenerid - projekteerijad pole tulnud nii lihtsa asja peale:
alati hajuta koormused laiali, mitte ära luba ühe, hiilgesuure-võimsa voolutõuke (voolu Peak) tekkimist.
Edit:
Kammisin netti a la aasta 2018:
Ning silma jääb nüüd juba kenasti nii see, et:
1. - uusimate, täislaetud, modernsete akude pinged on üle 13V.
- ning paistab, et ka nii mõnedki "on hakanud ärkama" ning nüüd siis taipavad kurta, et Autode Generaatorid (altenuaatorid) ei anna välja sellist hädavajalikku pinget mis on tarvis moodsate autode akude täislaadimiseks, ehk siis selleks, et saada akusse pinge 13V ja üle selle.
2. Ning teisena siis Exide moodsa aja akude kohta kirjutatakse siis juba ausalt kahte asja:
A. Exide akut on soovitav laadida ainult Exide enda Smartlaadijaga kuna ainult sellega on tagatud maksimaalselt õige laadimine.
B. Ning pärast aku laadimist - tuleb oodata 12-24 tundi, enne kui aku ühendatakse autoga ning minnakse sõitma.
Ei ole veel uurinud kuid tõenäoliselt "keevitatakse see: õige laadija ning ooteaeg vähemalt 12 tundi" peatselt ka kõikide teiste firmade Grid-ehitusega akude laadimisjuenditesse. Nii nagu on ka Exide-l, üks tehnoloogiline lahendus (Grid) ning täpselt ühesugune Laadimisjuhend kõikidele uutele Exide akudele.
Edit:
Kui keegi näeb oma auto juures Jamasid uuema ajastu 13V Exide Grid-tehnoloogiaga 3DX akuga, siis soovitus:
- ei tasu kodus, nurgas, patja nutta. Kuigi eestlased seda väga armastavad, paaniliselt Akumüüjaid ning Autofirmasid kartes.
- vaid tuleb nõuda Akumüüjalt, et võtku ning laadiga see Exide aku täis õigesti, ehk siis ainult Exide enda Smartlaadijaga.
Seda lihtsal põhjusel, et Akumüüja on rikkunud Exide enda poolt kehtestatud Laadimisreziimi ja mis ütleb üheselt, selgelt:
A. laadimine peab toimuma enne autoga ühendamist.
B. õige laadimine on ainult Exide enda Smartlaadijaga.
PS: Kui keegi siin Mustamäel on silmitsi suures hädas, siis mõne üksiku Exide uuema aja 3DX Logoga aku saan ka mina õigesti täis laadida.
Ainult hoiatuseks - laadmisprotsess kestab nii 24 tundi ning aku ei saa sel ajal olla auto peal.
elukaz
28.02.2018 00:23:02
Vauu, mis hülgemöla
rex
28.02.2018 08:05:21
B. õige laadimine on ainult Exide enda Smartlaadijaga. |
1. Akumüüjat selline sõnastus otseselt ei kohusta, kuna sama hästi võiks eeldada, et täis laadimine jääb tarbija (antud juhul siis ostja, mitte autos oleva elektritarbija) teha.
2. Üks kord õigel pingel formeerimist ja täis laadimist ei kaota probleemi, kui auto genekas sellise aku pidevalt laetuna hoidmiseks liialt madalat pinget väljastab. Pidev välise laadijaga lisalaadimine ei ole suure osa kortermajades elajate jaoks mingi lahendus. Pingeregulaatorit ka päris lambist vahetada ei saa, kuna paljud kurdavad juba 14,4V juures liialt kiiret hõõglampide läbipõlemist jms. Siis peaks autol korralik power management olema, mis tarbijatele ikkagi standardset pinget annaks.
28.02.2018 08:11:23
Täna lähevad välja igatahes kolm Ratsionaliseerimisettepanekut - põhjusel, et on üheselt selge, et Euroopa Komisjoni Direktiivide mõjul toimub lähiajal Maailma suurim Akutööstuse pööre.
Ning üks esimesi on kindlasti juba praegu Exide, kus firmajuhid üheselt aru saavad, et tuleb akud ringi ehitada, et saaks Euroopa turul akusid toota ja müüa.
Ratsid on siis sellised:
1. Kõikide autode, kuhu on paigaldatud, Exide 3DX akud, kohustuslik tagasikutsumine.
Ning siis korrektse Esmalaadimise tegemine.
2. Kõikidesse nendesse autodesse Exide Smartlaadijate paigaldus kuna on üheselt selge, et õige Laadimisalgoritm on ainult Exide Smartlaadijatel.
3. Ning kolmandana siis see, et:
- kuna uued Exide 3DX akud on 13V akud, siis:
- blokeerida auto käivitamine alla 12,8V pingega.
Kõige lihtsama variandina starteri relee käivitamise blokeerimine kuni selle ajani kus inimene on akupinge laadinud pingeni üle 12,8V.
PS: Käisin eile mitmes Kaubanduskeskuses - see on ikka hämmastav, et inimesed ei oska näha kui "pimedad" on nende autode lambid - tänu sellele, et akud on silmini tühjad. (parklates)
. Kui Politsei väga tahaks - ja viitsiks mõõta lampide heledust, siis saaks liiklusest maha võtta autosid ikka päris palju,
rex
28.02.2018 10:22:49
Kui praeguse külmaga politsei inimesi autode tulede mitte piisava heleduse eest nussima hakkaks, viiks see ilmselt ülestõusu ja riigipöördeni. Inimestel on siiski elu elada, mitte pingsalt jälgida, et üks akunässakas alla 12,8V ei langeks ja pisut kahju saada ei võiks.
Küsin veel kord (võtan häbematuse monoloog katkestada): kuidas aitab 220V lisalaadija kortermaja elanikku?
The_Boss
28.02.2018 10:36:53
. Kui Politsei väga tahaks - ja viitsiks mõõta lampide heledust, siis saaks liiklusest maha võtta autosid ikka päris palju,  |
Ütle nüüd, et ühelgi sellisel autol polnud genekas ühendatud.
H_K
28.02.2018 10:46:02
| Kuskilt meelde jäänud, et lähituled nn päevatulede režiimis saavadki vähem pinget peale, see aitavat pikendada lambi eluiga ja päevasel ajal ei ole nende lampide eesmärk teed valgustada, vaid autot nähtavaks teha. Pimedas järelikult laksatakse samale lambile pinget enam ja pilt säravam.
mikk55
28.02.2018 11:11:01
Full led merss puhul näitavad esituled päeval vähem valgust .
elukaz
28.02.2018 11:55:41
Ououtasin hommikul, aku pinge käis 8 voldi juurde. Peab vist minema nööri ja seepi shoppama.
28.02.2018 11:59:15
Üks kena Koodportree siis kah
Ja nagu öeldud, siis ainult selline Koostöö omab ainsana Exide firma Ametlikku heakskiitu.
PS: See kõik on siis läbi katsetatud Exide kolme erineva 3DX (Pliivõrguga) akudega.
Kõikidega on täpselt ühtmoodi:
- tavalistest Konkurent-Smartlaadijatest saab kõige lähema laadimistulemuse ainult Kaltsiumakule mõeldud Smartlaadija, laadimispingega 16V.
- kuid 100% max õige tulemuse saab Exide enda Smartlaadijaga.
See on tegelikult tavaline "Turuvõitlus" kus siis iga Akutootja tahab, et kasutatakse ainult tema poolt toodetud või heakskiidetud akulaadijat.
Sama nagu kasvõi sülearvutite korral. Dellil on Delli laadija, Lenovol Lenovo laadija, näitena.
Nüüd siis pilt ise neist kahest, omavahel kokkusobivast koostööpartnerist;
Lõppu lühidalt niipalju, et juba sel aastal saab Eestis olema tuhandeid autosid - milledel Exide akud peal, õigesti laadimata ning mis seetõttu kõik, Ülevaatustel, saavad endale "kaela" ridamisi Valediagnoose - tänu Exide akudele ning sellele, et Diagnostikud ei suuda neil akudel vahet teha ning ka WET-akudele programmeeritud Kontroll-stendid eksivad kuidas suudavad.
rex
28.02.2018 13:53:24
| Keegi võiks selle blogi lukku panna, kuna foorum see teema siin küll ei ole...
28.02.2018 14:29:08
Ühe Pisiasja lisan juurde - ja nagu ka mujalt näen - huvittaval kombel ei tule keegi ka veel selle järgmise peale.
See Euroopa Komisjoni uus direktiiv ei pane "löögi alla" tegelikult ainult autojuhte ning nende autosid.
Vaid ta paneb "löögi alla" kõik elualad kus on kasutusel 12V akud.
Näiteid:
põllumajandusmasinad, metsandusmasinad, igasugu muud elektriseadmed-tõstukid,
kiirabi, päästetehnika, politsei
siis kasvõi kõikvõimalikud salvestusseadmed, säilitusseadmed kus on kasutusel ka Aku-reservtoited.
jne, jne,
Ja kui ka need Exide 3DX Grid-akud on samamoodi õigesti laadimata-stabiliseerimata, ka siis on täpselt sama Krahh - akud on iga natukese aja tagant tühjad ning muudkui tee uuesti laadimist ning siis taas avastamine, et akud on taas tühjad.
wiinanina
28.02.2018 22:46:03
Kui inimene tahab teada, siis on see ju positiivne.
Kui ta saadud "teadmised" ilma analüüsita teistele esitab on juba teine teema.
Aga antud juhul ei maksa pahandada ja tulebki eeldada, et kui nimi ei vasta tekstile, siis tuleb üles näidata teatud ettevaatlikkust.
Näiteks minu puhul tuleb eeldada, et poolte teadete kirjutamise eel olen tarbinud Viru Valget ja ülejäänutest poolte puhul mingeid eksootilisemaid marke.
01.03.2018 07:59:24
Kunagi juba märkisin - nüüd saab siis uuesti mainida - et Eesti Autorahva "sõber- ja vaenlane" Pliivõrk-tehnoloogia (Grid) ajab - nagu vähk - oma "juuri laiali".
Eelmine kord nimetasin Varta akusid, seekord on siis väike leid kus on Boschi Grid-akuga tegemist.
Ning veel sama jutt - nägin välismaa paaril lingil taas siis täpsetl sedasama kus on koheselt, korraga, kasutusele võetud nii Exide aku ja Exide akulaadija.
Üks suurím selliselt kasutaja oli igatahes üks välismaine Päästeamet kus kõidele autodele on peale pandud Exide aku ning koheselt on sisse ehitatud ka 7 või 15 amprise laadimisvooluga Exide Smartlaadijad.
Otsid ainult koha kus saad 220V elektri ja muudkui saad juurde laadida.
Nii, et turuvõitlus ning Grid-tehnoloogia arendamine käib usinalt, kõik tahavad Euroopa Liidus "ellu jääda", mitte ei taha, et Euroopa Komisjon nende töö Euroopa Liidus lõpetab.
elukaz
01.03.2018 10:27:29
Et siis exide toodab akusid mis ei sobi tavalisele autokasutajale vaid neile kellel meeldib juhtmeid auto juurde vedada? Või veel parem hobi et aku ööseks tuppa
11.03.2018 00:22:12
Selle Exide 3DX akude Esmalaadimisega saab omanikke tabama veel üks "kurbus ning nukrus.
Kordi ning kordi, uuesti ja uuesti Exide 3DX akut laadides Exide enda Smartlaadijaga on kenasti näha ka veel see:
- et selle esimese laadimise temperatuur peab olema ikka üsnagi täpne.
- ning peab olema vahemikus 22-25 kraadi.
Meenutab juba nagu ENSV aegset fotolaboratooriumit kus lahustel pidi alati olema väga täpne temperatuur, et kõik oleks OK.
PS: Tundub, et ma nägin kusagil isegi veel müügis Exide "vanamoodsaid akusid" - ehk siis akud kus sees on hape vedelal kujul, mitte immutatuna materjali sisse.
Ehk siis Exide akud milliseid võib siis otse auto peale tõsta ning sõitma minna ning mida auto siis mingi tunni-paariga lõplikult täis laeb.
- needsamad akud siis millele Euroopa Komisjon, järgmisel aastal, sisuliselt "lõplikult vee peale tõmbab ja seejärel Aku-arhiivi saadab".
Edit; praeguseks on siis vesteldud - kurssi viidud neist Euroopa Komisjoni Direktiivi probleemidest kaks Aku- ja Autofirmat.
Mõlema juhtide seis on esilagu see, et Tehnikuid kolmes vahetuses tööle vist ei panda, et teha Exide 3DX (Pliivõrk) akudele kohustuslikku Esmalaadimist.
Ise pean peamiseks jätkuvaks probleemiks mitte niiväga seda, et tuleb käia kolmes vahetuses vaid seda - ja mida Autoomanikud kuidagi endale ette ei taha kujutada:
Ehk siis:
- vale diagnostika
- ning valed otsused-diagnoosid.
Lihtsamal juhul tähendab sees Autoomanikule "tühiseid kümneid eurosid" lisakulusid.
Halvemal juhul võib see tähendada "mitte enam tühiseid" sadu või tuhandeid eurosid lisakulusid.
- ja siis selgumine, et diagnostika-diagnoos oli vale, tegelikult polnud see selle kalli sõlme-ploki probleem.
Lihtne näide ja mis võib täiesti reaalne olla kui tegemist on tühja - stabiliseerimata - laadimata akuga:
1. Kallis auto, juht-elektroonika plokk, hinnaga a 2000 euri.
2. Nüüd siis vale käitumine mille põhjustab tühi aku kuid mis "kuulutatakse terveks-laetud" akuks.
3. Nüüd valediagnoos - elektroonikaplokk on läbi, vajab väljavahetust.
4. tellitakse uus plokk, omanik plekib 2000 euri - ning siis ... ilmneb täpselt sama vale käitumine...
PS; Ise olen reaalselt näinud väheke "odavamat valediagnoosi" - tühja aku korral öeldi, et starter on läbi ning vajab vahetust.
Õnneks sai ära tõestatud - ja mis võttis kõvasti aega - et tegemist on hoopis tühja akuga ning et tühja akuga ei peagi starter normaalselt töötama.
Edit:
Paistab, et peagi lisanduvad ka EV Seadusandluses olevad mõned Karmid Punktid.
Ja kui need lisanduvad, siis on tegelikult "kahvlis" nii Autofirmad / Ülevaatusfirmad kui ka Autojuhid.
- minu suunas pole mõtet rusikat vibutada kuna mina pole Euroopa Komisjon.
Tegelikult huvitav, et keegi pole sellele veel viitsinud mõelda:
"Kahvel" on siis selles, et:
1. Ülevaatus on kohustuslik, ilma selleta EV Seadusandlus sõita ei luba.
2. Kuid ei Autofirma ega Ülevaatusfirma ei saa enne testida Exide 3DX (Grid) akut, kui see aku on õigesti täis laetud.
3. Ehk siis alles pärast seda saab teha aku testimist kui kas Autofirma või Ülevaatusfirma on selle aku:
- maha võtnud auto pealt
- ning siis, vastavalt, Exide laadimisjuhendile läbi teinud Kohustusliku Esimese laadimise.
Seesama laadimisalgoritm siis, mida õigesti suudab teha ainult Exide enda Smartlaadija + lisaks "seisuaeg" 12 tundi.
Ja kui Autofirma või Ülevaatusfirma seda kõike läbi ei tee, siis ei saa see Firma omanikule autot tagasi anda - kuna Akutest on tegemata / läbimata.
Või kui ainnab tagasi, siis omanik sellega sõitma minna ei saa kuna auto pole Ülevaatust läbinud.
Edit:
Eespool kirjutasin, et kõik "märgid" viitavad sellele, et kui Exide aku on autoga ühendatud - ka siis suudab Exide enda Smartlaadija ära tunda, et tegu on Exide akuga ning teha sellele laadimisrežiim, mitte üksnes säilitus-hoidmisrežiim.
1. Kaks nädalat tagasi koormasin auto peal oleva Exide aku tühjaks.
2. siis laadisin selle aku täis - Exide Smartlaadijaga.
3. Ning nüüd garaažis käies mõõtsin akupinge üle / temperatuur garaažis: +5 kraadi.
Pinge on üle 13V, seega on aku veel siiamaani täiesti täislaetuna.
- signalisatsioon on siis ainus tarbija.
13.15 DCV V
13.15 DCV V
Edit: Suhtlesin veel mõningate Aku- ja Autofirmade-ringkondadega ning võis vabalt järeldada kolme, täpselt ühtmoodi olukorda.
1. Ei teata mis asi on pinge, seega ei teata ka seda, et uut tüüpi 3DX (Pliivõrk) akud toovad endaga kaasa:
- kõrgema pinge 12,4V-12,6V asemel pinge üle 13V.
- ning, et see kõrgem pinge toob omakorda kaasa kõrgema pingeamplituudiga Pinge-Peakid.
2. Ei tajuta seda / või ei osata selle peale tulla, et kui ise minnakse Akupoodi ning samalaadne ultramoodne aku ostetakse, siis "tabab täpselt sama saatus". Iseasi, kas rohkem või vähem nähtav - aga samalaadsed Probleemid tekivad kindlasti.
3. Töötades Autofirmas ei tajuta seda, et "Moodsa akumaailma probleemidele vilistades" tehakse Praaki ning kannatajateks on siis kümned või sajad autod, kus autoomanikud - endale teadmata - on samuti Lisaprobleemi Kaela saanud.
- ning mille likvideerimine võib Autoomanikule maksma minna, halvemal juhul, ka tuhandeid Eurosid.
Reaalne näide: vanema auto, marki ei mäleta, autoelektroonika tegi laadimata-stabiliseerimata moodsa akuga "trikke".
(Vale) Diagnostika: elektroonikaplokk vajab vahetust - hind 500Euri.
PS: hetkel sõidetakse (asendusakuga) Kaltsiumakuga - sellega elektroonikaprobleeme pole rohkem olnud. Vähemalt autoomanik pole mulle hetkel rohkem kurtnud.
Tõsi, eks see on natuke Tuleviku-stsenaarium, hetkel ehk nii sadu autosid puudutades kuid mõne aastaga on probleemsete autode arv kümnetes tuhandetes.
Seda enam, et pole siiamaani kuulda olnud, et Euroopa Komisjon oleks minemas seda teed, et ei rakenda oma "kuulsat" Direktiivi aastast 2019 ja mis lõpetab sisuliselt vedelal kujul happega autoakude (WET-akud) tootmise ning müügi Euroopa Turul.
Edit:
Laupäeval õnnestus siis kenasti ära näha kuidas "poest ostetud Eel-laadmis-pingega" akuga auto veel kuidagimoodi ennast käima vedas.
Õnneks juhtus see meie garaaži juures ja kuna oli mu tuttav, siis ta auto aku sai Kiire Pääste-laadimise.
Koos korraldusega, et otsib mingi asendusaku ning toob oma auto aku korralikku, õigesse täislaadimissse.
Käivituspinged:
1. käivituspinge enne Pääste-laadimist:
9.76 DCV V
2. käivituspinge pärast Pääste-laadmist:
10.26 DCV V
3. Aga jamada tuleks veel kõvasti kuna tegelik pinge - käivitamisel - peaks olema midagi sellist:
11.76 DCV V
11.90 DCV V
11.81 DCV V
PS: need on täiesti reaalsed numbrid, muide. Õigesti täislaetud EFB-akuga saaduna.
Niipalju veel suureks üllatuseks - olen ka seda varem märganud, et ei autoomanikud ega ka Tehnikud mingil salapärasel põhjusel ei suuda - kõrvaga kuulates - kui automootor teeb "valet häält" kui autot käivitatakse tühja, laadimata akuga. See mootori hääl on ikka "üsna kohutav" , nagu ka laupäeval kuulda oli.
Pärast pääste-laadimist oli auto mootori hääl tunduvalt "reipam".
PS: Ma ei tea küll mida tänapäeval Autokoolides õpetatakse kuid ENSV ajastul, elektroonika-õppes, kohustuslikku Autoelektri kursusel oli üks oluline punkt igatahes: kuulamisega automootori probleemide avastamine samamoodi nagu arst avastab kopsupõletikku või bronhiiti.
NightStriker
11.03.2018 02:34:13
_________________ Allverelaev sukeldub määramata ajaks...
viimati muutis NightStriker 07.04.2024 18:53:49, muudetud 1 kord |
11.03.2018 11:44:32
Edit:
"paar rida ülevalpool" mainisin, et laupäeval tuli läbi viia oma tuttava auto autoaku "Pääste-laadmis-operatsioon".
- kuna aku oli nii tühi, et autogeneraator seda enam laadida ei suutnud.
Korjasin arvutist kokku veel laupäeval salvestatud infot - panin selle väikseks tabeliks ning see tabel näitab siis kenasti moodsa ajastu Geel-immutatud materjalidel akudel (ka kaltsiumakud) probleemi:
Autogeneraatorid ei suuda laadida Süvatühjenenud autoakusid ning need akud vajavad hädasti lisaaadimisi:
Tabel siis:
Esimene käivitus, tühi aku:
generaator ei suuda tühja akut laadida
9.74 DCV V
10.36 DCV V
14.04 DCV V
14.04 DCV V
teine käivitus
aku on veelgi rohkem tühjenenud
9.76 DCV V
10.23 DCV V
10.18 DCV V
10.85 DCV V
13.99 DCV V
14.00 DCV V
14.03 DCV V
14.04 DCV V
käivitus pärast juurdelaadimist
generaator suudab akut laadida
10.26 DCV V
12.28 DCV V
14.23 DCV V
14.23 DCV V
PS: Kui kedagi huvitab, milleks "mässasin" ja ei saatnud omanikku Akupoodi - siis asi lihtne, kui raha ikka ei ole piisavalt, siis ei saa Akupoest kätte mitte ühtegi autoakut.
- lisaks sellele, tänapäevased akud vajavad ka kõik Esimest Esmalaadimist ja mis võib kesta kümneid tunde.
elukaz
11.03.2018 12:15:04
Milline kristallkuul sulle ütles et genekas ei suuda laadida? Pingete järgi ütleks et laeb, täiesti tühja aku kohta isegi hästi.
radist87, kõige lahjem nutilaadija, või veel odavam kui on suvaline toitekuubik mis 13.2-13.5V välja annab. Kui on 24/7 järel siis piisab mõnesajast milliamprist.
26.03.2018 09:14:47
Nii - Exide EFB-aku, täislaetuna Exide Smartlaadijaga ning seejärel spetsiaalselt hoitud enne kasutamist 2 nädalat.
on siis vanema auto peal, asendamaks "ärakulunud WET-akut".
Esimese testina siis viimasel ajal moekas (tihti ka kohustuslik) CCC-järjestiktest (järjestik-käivutused).
PS: EFB-aku kannatab tootja andmetel kuni 300 000 käivitust.
Antud CCC-test on siis:
testimisaeg: 10 ninutit
käivituste arv: 8
- osadel kordadel on lisakoormuseks: sisselülitatud salongisoojendus.
Tabel:
11.32 DCV V 14:51:06:031 soojendus väljas
11.07 DCV V 14:52:05:537 / lisakoormuseks salongisoojendus
12.01 DCV V 14:53:47:904 soojendus väljas
11.11 DCV V 14:55:02:481 / lisakoormuseks salongisoojendus
11.76 DCV V 14:56:42:285 soojendus väljas
11.90 DCV V 14:58:18:763 soojendus väljas
11.81 DCV V 14:59:55:853 soojendus väljas
12.15 DCV V 15:01:19:493 soojendus väljas
Edit:
Juhtusin täna lugema paari suuremat vaidlust autoakude ning nende laadmise kohta.
Ja minu suureks üllatuseks ei suutnud lp. vaidlejad vahet teha:
A. Avatud "püttidega" WET-akude ning "suletud" püttidega" WET-akude vahel.
Kuigi ühed neist on täidetavad ning sisaldavad ohtralt akuhapet ning teised on Green & Öko ning nendes on happekogus oluliselt väiksem.
Ning sellest tingituna: laetakse esimesi pingega 14,3V ja teisi pingega 15,2V.
B. Ei suudeta vahet teha WET-akude ning Geel / ning immutatud materjalil ehitatud akude vahel.
Elati nagu ajas 10-20 aastat tagasi.
PS: Mul endal käis vaidlus Autofirmaga ikka mitu kuud kui kuidagi hakati aru saama, et WET-aku pole Geel-aku ning Geel-aku pole WET-aku.
Ning nüüd alles kõige lõpuks on siis näha, et EFB-hübriidaku on veel sisuliselt ainus mis omab mingitki sarnasust WET-akuga.
- kuigi ka EFB akuga tuleks natuke muuta Autoelektri-skeemi muidu jääb skeemi võimalus üheks vägagi ohtlikuks Pinge-voolu-Peaki tekkimiseks. Ja mille käigus nii mõndagi võib maha põleda.
Edit:
Avastasin veel ühe suure ning vist küll "lõpmatult lõpmatu" vaidluse - et kas akuhape peab ikka "mulisema (keema) või ei pea."
Siit nüüd üheselt võiks edaspidi kinnisilmi teada, et vähemalt Exide 3DX akud "mulisevad (keevad) nii, et vähe pole.
Ning kõige kõvemini - Smartlaadijatega võrreldes - "mulistab (keedab) Exide 3DX akusid justnimelt Exide enda Smartlaadija.
- täna huvi pärast vaatasin - kõige kiiremini - kõrvaga kuulates - hakkas "mulistama (keema) EFB (hübriidaku).
Edit:
Avastasin sellise "huvitava" asja, et Eesti kõiksugu Ametkonnad ei oska Euroopa Direktiive lugeda. Õigemini ei osata lugeda ega analüüsida n-ö "kaasnevaid Direktiive ja dokumente".
A. Näha on, et kõik teavad seda, et Euroopa Direktiivid käsitlevad vanade autoakude ning autode utiliseerimist, kõrvaldamist ringlusest.
B. Kuid keegi ei oska välja lugeda, et on olemas ka "teine pool" mis käsitleb auoakude ning uute autode tootmist.
Kui Euroopa Komisjon nõuab järjest rohkem Start-Stop autosid, siis peaks ju une pealt selge olema, et seetõttu nõutakse, et ka akud peavad olema sobilikud Start-Stop akud.
Ehk siis EFB Start-Stop ning AGM Start-Stop akud, mitte enam WET-akud.
Paistab, et vist on veel üks kena tunnus olemas et kas "vaatesilmaga aku" või siis "vaatesilmata" aku.
Need Dry-WET akud, mis minu käest on läbi käinud, Exide 3DX akud, neil pole ühelgi enam mingit "silma peas" olemas.
Ikkagi ainult tester on see mis näitab mis on parajasti akupinge.
- ja autosse läheb juurde samuti voltmeeter, et näha pidevalt akupinge väärtust.
Edit:
1. väike uudis siis ka "sõjarindelt" kus ühel pool "rindejoont" on siis Euroopa Komisjon ning teisel pool "rindejoont" on siis Akutootjad ning Autotootjad.
A. Näha on, et Euroopa Autotootjad ning Akutootjad on siis "alla andmas" ning nõustumas sellega, et nii "tava-WET-aku" kui ka Conventional-autod on minevik ning, et vähemalt 80% autodest peavad olema siis Start-Stop autod ning ka sellised mis oma töös kasutavad ainult siis kas AGM Start-Stop akut või siis EFB Start-Stop akut.
Ning ainult 20% autodest võivad siis olla "vanamoodsad" tooted kus on siis kasutusel "vanamoodsamad" akud.
2. Ning teine teema siis "moodsa aja" Exide akude maailmast.
Avastasin sellise "toreda nähtuse", et:
A. Exide Premium aku lõplikuks stabiliseerimiseks kulus 2 kuud.
B. Exide EFB Star-Stop aku lõplikuks stabiliseerimiseks kulus 2 nädalat.
Seega, ühel juhul saab ikka päris mitu paksu romaani läbi lugeda -enne autoga sõitma minekut, teisel juhul mõned õhemad novellid.
C. Küll oli näha see positiivne tulemus, et kui muidu oli mahtuvuse laeks nii a 60-70%, siis paari kuu või paari nädala järel tundub tulemus olema nii 80-90%.
Sellel tegelikult,, miks see nii on ja miks see nii peabki olema, on olemas üsna kindel põhjus - üks välismaine, Austraalias asuv, Akufirma "lobises" selle välja.
Uurin, kas on nii ja kui on - siis millalgi pajatan. Kuigi üsna "kehv värk" kuna sel juhul ei saagi selline sõplik stabiliseerimine kuidagi olla lühemaajaline. Või kui, siis peavad akud saama hoopis mingi teise sisemise ülesehituse.
Edit:
Nonii, taas siis järjekordselt Valediagnoos.
Täpselt samamoodi:
- tühi, moodsa aja aku
- ning taas siis Valediagnoos - sama nagu ka ise olen üle elanud:
"Starter on läbi, vajab väljavahetust":
ja lõppes siis samamoodi - akule usinasti "särtsu sisse juurde" - ja kõik "valed nähtused, auto käivitamisel", kadusid.
- loodetavasti varsti läheb soojemaks siis selline aku peab tiba paremini ise vastu, kui külmas kliimas peab.
Eks muidugi on nüüd "Automehed õelad" , et nii läks ning neil jäi "väike, mitmesaja eurone, kopikas" teenimata.
Aga nad oleks sellest nagunii ilma jäänud kuna autoomanikul poleks kohe nagunii seda raha võtta olnud.
PS: Märkasin ka paari Riigifirma korral sama keissi, et mitte kohe ei osata lugeda Euroopa Komisjoni Direktiive.
Õigemini - osatakse lugeda seda mis käib akude ning autode utiliseerimise kohta, kuid ei osata lugeda seda mis käib Start-Stop akude ning Start-Stop autode tootmise ning müügi kohta.
Edit:
Lihtsalt väikseks lisaks:
1. Läänemaailmas - käib väike paanika ning ennustatase, et see "Akusõda Euroopa Komisjoni ning Akufirmade & Autofirmade vahel" võib kaasa tuua autoakude hinnatõusu ning põhjjusel:
Tekib akudefitsiit kuna WET-akusid enam toota ning müüa ei tohi, kuid samas ei ole Akufirmadel nii suurt vaba raha (sadades miljonites eurodes), et kiiresti oma akutootmin üle viia AGM ning EFB akude tootmisele.
2. Ning mida rohkem ma edasi olen uurinud Exide 3DX akusid - seda enam on siis näha "Exide Sala-trikid" , sundimaks Exide 3DX akuomanikke juurde ostma ka Exide enda Smartlaadijaid.
Ning Exide siht paistab selge olema - ei mingeid konkrentide Smartlaadijaid, vähemalt esmalaadimise korral.
3. Üritan praegu seda - Exide 3DX akude ning nende akude "kohustusliku 24-tunnise laadimise Trikki" viia kusagile "kõrgemale tasandile", et sellega:
tekiks kusagil keegi kes need Exide 3DX akud, juba enne müükisaatmist, ette ära teeks selle 24 tunnise kohustusliku laadimistsükli.
Ja siis Exide 3DX Akuostja:
A. saab seda kohe õigesti kasutama hakata
B. ning saab seda laadida siis ka paljude teiste Smartlaadijatega.
Eks annan teada kuidas läheb - karta on, keegi kohe mitte ei taha tegelda 24-tunniste akulaadimistega ning käia tööl 3-s vahetuses, 7-l päeval nädalas.
Edit:
Paistab sedamoodi - õigemini paistab järjest rohkem välja see, et Euroopa Liidu Autofirmad ning Akufirmad on alistunud Euroopa Komisjoni "kurjade direktiivide ees" - ning on pannud akendest välja "allaandimise valged lipud".
- sisuliselt kõik autotootjad räägivad nüüd ainult Start-Stop autode tootmisest ning müügist. Ning akumüüjate kataloogd näitavad selgelt kuidas järjest kaovad ajalukku lahtikeeratavate korkidega, täidetavad, WET-happeakud ning nende asemele on asunud siis suletud, Geel-täidisega autoakud.
Näide: Järgmises kataloogis on siis Exide akud veoautodele, trkatoritele jne, ning on kenasti näha, et veel ainult paar mudelit on sellised mida omanik siis ise täita saab. Ehk siis WET-happeakud.
Ülejäänud on kõik juba samuti kinnised Geel-happeakud.
Commercial Vehicle Battery Solutions
https://www.evofenedexbedrijvengids.nl/site/exide-technologies/$FILE/CV-Leaflet-Exide.pdf
PS: Olen juba ise seda meelt - ja olen seda mõtet ka levitanud, et Eesti võiks olla / peaks olema Esimene riik Euroopas kus WET-happeakud, päevapealt, lõplikult ning jäädavalt ära keelustatakse.
Sain sellele veel ka sellega kinnitust, et üks mu enda Exide 3DX (Geel)akudest on praeguseks läbinud juba 3-kuulise Stabiilsustesti ning seda 5 kraadises temperatuuris. Ehk siis protsess mida ei suuda mitte ükski WET-happeaku.
elukaz
26.03.2018 12:25:26
Kui aku nõuab mingit formeerimist kuskil mujal kui sõitva auto peal siis kvalifitseerub see sitaks akuks ja ei ole sobilik massiliseks adaptsiooniks.
26.03.2018 16:02:18
Igatahes, ääretult uhke tunne on olla Eestis Esimene kes aru saab, et:
1. WET-happeaku ei ole Geel-happeaku ning vastupidi, oma kvaliteedis ning stabiilsuses.
2. Ning, et head Pensionile minekut, vana hea WET-happeaku ning tänades, et abistasid lp. Autoomanikke 150 aastat.
Tegelikult, ma isegi leidsin pärast pikka otsimist autoomaniku kes sai aru WET ning Geel-akude erinevusest.
Aga ka tema vargsi lootis, et ehk tulevad toredad vanad ajad tagasi ning, et ta saab taas ise jälle akut, akuvedelikuga, täitma hakata.
Aga sellest olen siis endiselt nüüd üsna kindel - tuleb minna seda teed, et:
näiteks alates 01.05.1018 lõpetatakse terves Eestis WET-happeakude müük ja kasutaminel.
Ning minnakse ühe liigutusega lõplikult üle Geel-happeakude kasutamisele.
Selline üleminek tuleb mõne aasta pärast nii ehk naa - ainult siis läheb see kümneid kordi rohkem maksma kui see läheks praegu.
Ajaloost on täisti näide ka võtta: Läptoppide üleviimine nikkel-kaadiumakudelt liitiumakudele.
Üleminek oli samuti üsna järsk kuid tänapäeval pole enam kedagi kes liitiumakut tagasi vahetada tahaks nikkel-kaaiumaku vastu.
Wiltz
26.03.2018 16:31:17
"näiteks alates 01.05.1018 lõpetatakse terves Eestis WET-happeakude müük ja kasutaminel"
ja mina olen endiselt üsna kindel, et tahanteada jääb igaveseks lõuapoolikuks oma tõsiste naljadega kahjuks mitte vist eesti esimene ja kindlasti mitte ka viimane
pakun omalt poolt ka veel ühe hea idee välja, et seoses nende happeakuga kasutamise lõptamisega päeva pealt terves eestis võiks esimesel mail terve eesti näiteks lõpetada igaveseks ajaks ka cocacola joomise
12.04.2018 19:24:16
Paar toredat pildikest ja mis on siis tegelikkus ning on võimalik ainult Geel-akudega.
Need, mis on pildil, on siis kaks erinevat Exide 3DX akut:
1. Exide Centra Plus, pinge pärast 3-kuulist seismist. Temperatuur kogu aeg on olnud: 5-6 kraadi.
- selline pikk stabiilne pinge näitab selgelt, et tegemist on Geel-akuga kuna WET-aku ei oma sellist pinget.
2. Exide EFB Start-Stop 3DX aku.
Seda laeb Exide enda Smartlaadija, temperatuur selle pildistamise ajal 5-6 kraadi.
-Exide enda Smartlaadija on siis ainus mis omab õiget Laadimisalgoritmi.
Pinge 15,03V: kõik on õige: Exide 3DX Smartlaadija omab temperatuurikorrektsiooni ning mõõdab aku Katoodi temperatuuri.
Seetõttu ongi laadimispinge madalal temperatuuril üle 15V.
PS: Igatahes Riigiasutused kerivad seda avalikuks tulnud Geel-akude probleemi "kui kuuma kartulit".
Ja tunda on, et ma pean ist minema ühe järgmise Härraga, näost-näkku kohtuma,
Edit:
See märkamine, et tegemist on "Kuuma kartuliga" - see teema, kehtib ikka täiesti.
Õigem oleks see ringi nimetada "Väga kuuma kartuli veeretamine".
See on ikka kohutav kui väga tahetakse aastal 2018 omada sellist Autoakut mille mahtuvust tuleb Aeromeetriga mõõta 2-4x aastas ning siis vastavalt vajadusele happevedeliku kogust reguleerida.
Selle asemel, et käia moekalt kaasas ajaga - ning kus akumahtuvust reguleeritakse hoopis pinge ning vooluga.
PS: Tegin eile lisaks spetsiaaltesti (100A koormus, testide arv kokku: 80) - tõestamaks, et Moodsa aja aku peab vastu ka olukorras kus jutti tehakse korraga kümneid käivitusi ning aku ei tee veel samas sugugi "teist nägu".
Näidiseks siis "üks plokk" ning see pinge 11,5V psüsis tegelikult kõik 80 testi.
Esmane Käivitus-test-imitatsioon:
Koormus 100A, test: 4x minutis.
(paanikas autojuht kes muudkui uuesti ja uuesti käivitab)
11.55 DCV V 10:06:30:844
11.54 DCV V 10:06:46:406
11.60 DCV V 10:07:01:758
11.62 DCV V 10:07:13:706
11.64 DCV V 10:07:29:408
11.63 DCV V 10:07:45:331
11.65 DCV V 10:08:01:294
11.63 DCV V 10:08:15:945
11.64 DCV V 10:08:30:636
11.63 DCV V 10:08:47:120
11.65 DCV V 10:09:01:431
11.65 DCV V 10:09:15:090
11.65 DCV V 10:09:29:110
11.64 DCV V 10:09:47:266
11.66 DCV V 10:10:01:617
11.65 DCV V 10:10:15:667
Edit:
Paarist Kõrgemast Ametist on siis vihjatud või loodetakse - et härrad-prouad ise on nii nutikad ja osavad ,et hakkvad hoopis ise juurde õppima ning ennast täiendama ja et suudavad seepeale ise kõike mõõta-analüüsida. Jne.
Seepeale sai vihjatud, et seesama jama võib tabada ka nende Soovitajate-asutuste edi autoparke ning nende endi töötajate isiklikke autosid.
Eks näis, kas selle peale tuleb mingi vastus või ei. Tõenäoliselt ei tule kuna on näha, et Riigiametite töötajad on nõus elama aastas 2008 või siis 1998, peaasi, et ei tule elada aastas 2018.
Endal on tõenäoliselt järgmine kohtumine ees neljapäeval või reedel. Plaanin teha maketi, et siis maketiga näidata miks Euroopa Komisjon käsib kasutada Dry-WET Geel-happeakusid, mitte aga WET-happeakusid.
Meenutab kergelt 1-2 klassi kus kogu aeg mingeid makette kokku liimisime ja siis pidime nende kaasabil midagi lahti selgitama.
Edit:
Niipalju siis lisaks:, et eelmisel aastal ikkagi toimus Autofirmade ning Akufirmade "väga suur Koosolek".
- huvitaval kombel, kas Eestis keegi ei tea sellest midagi - või vaikitakse meelega. Ise usun seda "vaikimist".
Ning sellel "koosolekul" pandi paika siis pmst. järgmine:
A. tuleb oluliselt kiirendada Advanced (Start-Stop) autode tootmist.
B. ning vastavalt sellele tuleb siis ka oluliselt kiirendada- suurendada Advanced akude (Start-Stop) akude tootmist.
C. Ning kuna järjest olulisemaks on muutunud ka järjest kiirem akude laadimine, siis seda enam rõhuti Carbon-lisanditega akude tootmise suurendamist.
Ehk siis kõik seesama mida ma räägin nii Pool aastat ja mida kõik Eesti Autofirmad ning Akufirmad kohe väga "liiva alla peita tahavad".
peaasi, et ei peaks midagi juurde õppima.
Nii, et kui kellelgi on vaja - näiteks mõnel Autofirmal / Akufirmal neid dokumente, siis all on mu mailiaadress olemas.
Kirjutage sinna, siis saadan need PDF-id. Ainult nende lugeja peab oskama väga head tehnilist inglise keelt.
Edit:
Viimased paar päeva õnnestus - võrdluseks lugeda ka konkurendi Varta dokumente, nii uhiuusi, välismaiseid kui ka neid mis eesti keeles on kättesaadavad.
Ning näha on siis täpselt sama keiss - eesti keelsed dokumendd ei kajasta veel silpigi seda mis tegelikult juba praegu välismaal, eriti Euroopa Liidus, toimub.
Ning näha on kenasti, et tulemas on akud - mis on nagu ka Exide akua:
A. täislaetuna pingega üle 13V.
B. kui akupinge on alla 12,7V, siis on see aku nii tühi, et Varta sellega enam sõita ei luba. Lubab ainult aku laadimist.
C. Ning on tekkimas olukord, et vähemalt esialgu muutud Exide Smartlaadija ka ainsaks selliseks laadijaks mis ka siis ainsana õiget, 20-24 tundi kestvat Eel-laadmist teha oskab.
Igatahes need Smartlaadijad, mida Varta soovitab kasutada oma akude korral, seda akude Eel-laadmist teha ei oska.
Edit Varta teemale lühidalt lisaks:
1. täna siis peaks Varta aku nimeline Õnn õuele maanduma.
2. Esimesed tähelepanekud kättesaadava info põhjal on siis sellised:
A. on oma olemuselt-ehituselt väga sarnane ühe Exide 3DX akuga.
- näidates siis seda mida ka olen varem täheldanud, et Exide ning Varta on ühendanud jõud, võitlemaks Euroopa Komisjoniga.
B. kuid samas näitab see keiss seda endiselt, et informatsioon uute Grid-akude kohta on Eestis ikka täiesti olematu.
- Eestis oli ainult see info, et tegemist on Grid (Pliivõrk) akuga.
- kuid kusagil polnud silpigi sellest, et see akutüüp on kaltsium-hõbetäidisega Ca-Ag aku.
Ning see info tuli siis taas välismaalt "välja kaevata".
Edit:
See Varta aku (kaltsium-hõbeaku) on siis kohal ning esmane info siis selline:
1. Akus seesolev n-ö "säilituspinge" oli 12,7V.
- seda pinget pidas Maaletooja OK-pingeks, unustades, et tegemist on Pliivõrk-akuga. Seega ei saa reaalne pinge nii madal olla.
- See tuleb sellest, et Pliivõrk-aku sisetekistus on kõrgem kui tava-WET happeakul ning seetõttu peabki akupinge kõrgem olema. Ning pinge 12,7V näitab tegelikult üsna tühja akut.
2. Nüüd on siis peal Kaltsium-akusid õigesti laadida oskav Smartlaadija ning see Smartlaadija:
- tunnistas selle aku üsna tühjaks akuks.
- praeguseks on seda Varta akut laetud 4,5 tundi ning veel siiamaani laadimist lõpetatud pole.
elukaz
12.04.2018 22:43:09
Mõtteharjutus.
Kuidas mõjutab sisetakistus käivitusvoolu ja kuidas tühijooksu pinget?
Kuidas mõjutab paralleeli ühendatud akupakk stardivoolu, tühijooksu pinget ja sisetakistust?
Fail.
14.04.2018 20:35:14
Edit:
Selle Varta (PowerGrid) kohta natuke lisaks.
PS: Ostmisel tegin täiesti kindla valiku, on "numbrite" poolest sama mis konkurent Exide Carbon Boost 3DX aku.
Et siis tekiks võrdlus nii pinge, laadmise kui moodsa värgi "Suutlikkus tööd teha".
1. Akupinge ostmisel: 12,7V
2. Aku laadinine Kaltsiumile sobiva Smartlaadijaga: 5 tundi, siis jätsin pooleli.
3. "Seisuaeg" pärast laadimist: 10 tundi.
4. Ning pinge pärast 10 tunni möödumist: 12,9V.
Ja see pinge näitab selgetl seda, et:
A. Pliivõrk-akud, mida Eestis müüakse, on Eel-laadimata.
B. Ning see Eel-laadimise 20-24 tunnine "Püha Üritus" on siis jäetud akuomanike kanda.
Täna millalgi hakkab seda akut laadima Exide Smartlaadija. Et näha kas Exide laadimis-logaritm sobib ka konkurendi Varta akule.
Kõik märgid näitavad, et peaks sobima ülimalt hästi.
Edit: niipalju on siis värk täpsemalt selgeks saanud siis Varta Silver PowerGrid aku kohapealt:
1. On kindlasti nii - millest Eestis nende maaletoojad ning müüjad ei tea - kuid välismaal teatakse:
A. et on kindlasti Kaltsium-Hõbeaku.
B. ja et selle, kõige esimese, täiesti õige Eel-laadimise saab teha ainult Kaltsiumakude õige laadijaga.
2. Ning näha on ka suur probleem sellise aku ostjale - autoomanikule.
A. Ning see probleem seisneb selles, et see Esmane Eel-laadimise aeg on nii kusagil 40-60 tundi.
B. Ning lisaks veel see, et kasulikum on kulutada aega rohkem ning teha seda pikka Eel-laadimist "plokkidena".
- umbes nii, et 10-12 tundi laadimine.
- siis stabiliseerimisaeg nii 12 tundi.
- ja siis uuesti laadimine 10-12 tundi.
- ning see selle ajani kuni Kaltsiumakude Smartlaadija ise laadimise ära lõpetab.
Hetkel on siis seis selline võrrelduna täpselt samade parameetritega Exide Carbon Boost akuga, on tulemuseks:
Varta aku Töövõimekus / Suutlikkus teha tööd on hetkel oluliselt väiksem kui on Exide aku töövõimekus / Suutlikkus teha tööd.
- lähipäevil panen paar pilti, siis saab igaüks ise näha kuidas Exide aku on palju suurema töövõimekusega. Ning see näitab selgelt, et Varta aku on veel siiamaani ikka kõvasti tühi.
Märkus: Grid-akude korral ei mõõdistata enam mitte aku pinget vaid seda kui hästi "aku suudab tööturul oma aku-tööd teha".
Ja kui ei suuda "enam aku-tööd teha", siis viiakse aku utiili.
raxz
14.04.2018 23:33:47
| WTF?
21.04.2018 18:30:01
Edit:
Varta Kaltsium-hõbeaku kohta siis lisaks:
Täna siis teatas kaltsiumakude Smartlaadija pidulikult: Et sai selle Varta kaltsium-hõbeaku lõpuks laetud.
Kokku kulus selleks siis a 40 tundi. Rõõm on õuel kuna olen äninud hoiatusi, et kaltsiumakude Esmane eel-laadmine võib aega võtta ka kuni 70-100 tundi.
Üks väike asi, mis on veel silma hakanud - iseasi kas see millalgi ka Eestisse jõuab või ei.
Igatahes osades Euroopa riikides on lahti läinud ka "garantiipikkuse sõda" ning kus on näha selliseid "võitlusvahendeid" nagu:
A. Exide 3DX akud: garantii kuni 4 aastat.
B. Varta PowerGrid akud: garantii kuni 5 aastat.
- aga nagu öeldud, on see pikkus riigiti erinev - kuigi Üle-Euroopa Liidu võiks see olla ikkagi ühtne pikkus. A la 4-5 aastat.
Edit: sai taas vaieldud ikka mitmete Ametkondadega ning ka mitmete Bossisedega kellede seljataga on firmad kus otseselt autode, ülevaatuste, akudega, generaatoritega kokku puututakse.
Ja kõik on ikka endiselt Eht-eestlaslik - kõik peab olema "nagu keskajal" - ainult unustades, et keskajal sõideti hobuse ja vankriga, mitte autoga.
Teisiti väljendudes - kõrgelt haritud, elukestvat õppimist tegevad eestlased ei kipu kuidagi aru saama, et Euroopa Komisjoni Auto-Akusõja tõttu peavad ka kõik autoomanikud, autofirmad, ülevaatusfirmad täpselt samamoodi ümber õppima. Vajadusel kasvõi nurgas vesistades ning nuttes: "ma kohe mitte ei taha välja tulla "mugavustsoonist", et siis taas ning taas kõike uuesti ümber õppida.
Ja nüüd omades juba mitme erineva firma moekaid Geel-akusid, on kenasti näha kuidas akufirmad "tõmbavad kõige rohkem mütsi pähe" neile autoomanikele kes odavaid akusid ostavad ja nendega sõidavad.
- kõige kehvemaks on siiani osutunud Varta odav kaltsium-hõbeaku.
Ning võib lõppeda ka sellega, et see Varta rändab, teatud probleemi tõttu hoopiski Utiili.
- ning kõige paremaks on osutunud, Varta akust, mitmeid kordi kallim Exide EFB-aku.
Ja ei kirjuta niisama - vahed on ikka mäekõrgused. Niisama ei saa aru kuid kui need on kõrvuti ja läbivat täpselt ühesuguseid katseid, siis on vahe selgelt näha.
Aga ega siin midagi imestada pole:
- Euroopa Komisjoni nõudel toimuv EFB- ning AGM-akude tootmisele üleminek nõuab akutootjalt investeeringuid mis on suuruses "kümned miljonid eurod".
- ning selle tõttu tahetaksegi, et autoomanikud ostaks kalleid EFB ning AGM akusid kuna nii saab investeerigukulu tagasi teenida.
Edit:
Külastasin garaaži, kus on siis auto ning selle auto peal, ilma lisalaadimata Exide Smartlaadijaga, seisab Exide EFB-aku.
Temperatuur: 7 kraadi garaažis oleku ajal, öösiti tõenäoliselt nii 5 kraadi.
Aku on seisnud tänakseks nii 1 kuu.
Tegin täiendkontrolli sellele Karmile informatsioonile, et:
A. Exide akude "talvelaadimine algab temperatuurist: alla 10 kraadi", mitte enam pole selleks piiriks 0-kraadi.
B. Ning tegin 5 käivitust, et näha kas tuleks juba lisaks juurde laadida või veel mitte, Exide Smartlaadijaga siis.
Tulemus:
- kaks tulemit - alla 11V, näitavad selgelt, et 7 kraadi juures tuleb EFB-akut pidevalt lisalaadida Exide Smartlaadijaga.
11.22 DCV V 14:47:58:660
10.69 DCV V 14:48:31:848
11.65 DCV V 14:49:19:266
10.98 DCV V 14:50:08:256
11.26 DCV V 14:50:56:746
elukaz
21.04.2018 19:27:28
Sa ikka viitsid
Enne õlivahetust ikka mõned fritüüritsüklid teed õlile? Muidu ei formeeru veel ära.
raxz
21.04.2018 19:50:37
| Kas ma pean muretsema? 7 aastat vana AGM aku. Laen ainult auto generaatoriga.
25.04.2018 20:46:39
Igatahes on Autoomanikel viimane aeg hakta harjuma selle Karmi Värgiga, et vanamoodsaid - 150 aastat vanal "happepüti-tehnoloogial" pliiakusid sisuliselt enam pole. Need on nii Akufirmade kui Autofirmade poolt "kirstu pandud ning maha maetud".
Ning Aku- ja Autoturul ruulivad nüüd hoopis, Geeli "uputatud happega", EFB- ning AGM-akud.
Ning seetõttu ongi nii:
A. Pinge käivitamisel üle 11V: Lisalaadimist vaja pole.
B. Pinge käivitamisel: 10-11V: Võib sõita kuid peab kindlasti juurde laadima.
C. Pinge käivitamisel alla 10V:
- ei tohi sõita, aku tuleb lahti ühendada ning siis täis laadida. Laadimisaeg siis nii 20-24 tundi. (Exide akudega ning Exide Smartlaadijaga).
Ning veel - uued Exide 3DX akud on 13V-13,2V akud, ei mingeid 12,4V-12,6V akusid enam.
Sellise madala pingega akud on tühjad ning vajavad enne autoga ühendamist 20-24 tunnist Esmalaadimist.
See on tegelikult täiesti õige lähenemine - ja mida mina olen oodanud aastakümneid - kuna:
- kasutatav käivitusrelee on 12V relee
- kasutatav Starter on oma ehituselt ikkagi 12V pingega Mootor.
Seega, pinge alla 10V on ohtlik nii releele kui ka Starterile kuna nii relee kui Mootori korral ei tohi pinge olla liialt madal.
Selline lihtne Põhikooli füüsika, mingi 7-8 klass.
Ning siis ka eelpool juba nimetatud Käivitustesti pilt / graafik, temperatuur garaažis 7 kraadi.
Ja ka see graafik näitab vajadust Exide Smartlaadijaga lisalaadimise järgi:
Edit:
Jalutasin veel siis tibake, ükspäev, garaaži vahet.
Ning tegin läbi siis selle "moeka versiooni", kus autoaku on pideva laadimise all.
Laadimine "maha", ning seejärel "autoga sõitma".
Panin pildid kõrvuti - kenasti näha kuidas Exide Smartlaadija kasutuse korral on Exide aku palju reipam ning "väge täis tegmaks korralikult karmi Auto-käivitustööd".
Märkus: Sellist samasugust tulemust pole ma saanud mitte ühegi teise firma Smartlaadijaga kuna nende Laadimis-algoritmid on hoopis teistsugused kui on Exide Smartlaadija laadimis-Algoritm ning seetõttu need teised ei sobi Exide akude laadimiseks madalatel temperatuuridel.
Edit:
Natuke "musta huumorit" ka tibake.
Sai natuke vesteldud, et sellised aku-jamad on olemas ning tasuks ära õppida kuidas tuleb elu korraldada nende Uute akude maailmas.
Siis kõlas nukker vastus:
"Ja vaata tore värk küll - aga see kõik nõuab õppimist. Ja vot seda ma küll ei viitsi, hakka veel õppima mis asi on tester ja kuidas seda kasutatakse.
PS: Olen samalaadseid "loosungeid" ka varem kuulnud - et äkki ikka tuleb mingi ime ja et kõik jääb vanamoodi edasi.
Nojah - niipalju siis sellest "kuulsast Elukestvast Õppimisest".
sukelduja
26.04.2018 08:02:40
On ikka palju vaba aega mõnel.
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
