mine lehele eelmine  1, 2, 3 ... 73, 74, 75 ... 319, 320, 321  järgmine
xpander
xpander
sõnum 28.08.2017 20:55:59 vasta tsitaadiga
anubis kirjutas:
http://techreport.com/news/32459/amd-ships-revised-ryzen-cpus-with-a-compile-bug-fix
A little while ago, the Linux-headed sleuths over at Phoronix came across an obscure bug in Ryzen CPUs that triggered segmentation faults ("segfaults," which cause application crashes) in a compiler-specific workload. The bug was confirmed by AMD's engineers, who described it as a "performance marginality problem" and indicated that owners of affected CPUs could reach out to AMD Customer Care. The engineers also noted that Ryzen Threadripper and Epyc processors are unaffected. Phoronix's Michael Larabel took AMD up on its replacement offer and recently received a revised CPU that's apparently clear of the bug.
Ryzen CPUs manufactured before week 25 (mid-June) of 2017 appear to be the ones affected by the problem. The bug is reasonably difficult to trigger, but users that want to rest easy can reach out to AMD Customer Care and get a replacement part.
Tea, kas peaks küsima, saaks vbolla märgatavalt parema kivi.
mul on launchi versioon ryzenist, ei viitsi jahutust ära võtta et vaadata mis nädala oma aga 7 märts sain kätte. jooksutasin 2x seda scripti(ryzen-kill.sh) mis selle bugi peaks välja tooma. Esimesel korral umbes tund aega, teisel korral veidi kauemgi, kuid ei suutnud minul seda segfaulti kätte saada.
Linux Gaming Videos: Xpander69
Thetommi
Thetommi
sõnum 01.09.2017 06:43:49 vasta tsitaadiga
Kui kellelgi ryzen 5 1600 ja MSI B350 pc mate siis, avastasin et chipset driver teeb asja palju paremaks, vähemalt mängides. Uus bios (eelmise kuu keskpaik) ka väljas tänu millele jooksevad mälud oma ette nähtud sagedusel thumbs_up.gif
Enne mõtle, siis ütle.
Kommentaarid: 40 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 38
anubis
anubis
sõnum 01.09.2017 10:15:27 vasta tsitaadiga
http://hexus.net/tech/news/cpu/109577-amd-officially-releases-ryzen-threadripper-1900x/
What made the call newsworthy was the announcement that AMD will be bringing in bootable NVMe RAID for the X399 chipset on September 25, to be made available via a BIOS update across all compatible motherboards.
xpander kirjutas:
anubis kirjutas:
Mul õnnestus ühe privaatsema asja kompileerimisel crash kätte saada. Võtsin igatahes AMDga ühendust, sain vastuse ka juba. Vaatab, mis tuleb sellest.
sõnum 01.09.2017 11:11:01 vasta tsitaadiga
1900X core conf: https://www.techpowerup.com/236680/amd-ryzen-threadripper-1900x-core-configuration-detailed
https://www.techpowerup.com/236659/latest-gigabyte-x370-k7-motherboard-bios-broken-dynamic-vcore-up-to-1-7v
Kahjuks ainult 3 aastat garantiid mitte 5 nagu TUF seerial tavaliselt thumbs_down.gif :
https://www.techpowerup.com/236652/asus-intros-tuf-b350m-plus-gaming-motherboard
anubis
anubis
sõnum 01.09.2017 11:42:20 vasta tsitaadiga
TR-1900x (8c/16t) = 64x PCIe ja 4ch
TR-1950x (16c/32t) = 64x PCIe ja 4ch
i7-7740x (4c/8t) = 16x PCIe ja 2ch
i9-7960x (16c/32t) = 44x PCIe ja 4ch
TR-1900x täidab niši kus hunnikut CPU-tuumi pole väga vaja kuid hunnik PCIe seadmeid vaja laia toru külge panna, või CPU'l vaja laia mäluriba. Emaplaati ei nudita.
7740x täidab olematut nišši ja nudib emaplaati.
sõnum 01.09.2017 12:49:35 vasta tsitaadiga
raimzu
raimzu
sõnum 01.09.2017 20:05:46 vasta tsitaadiga
white kirjutas:
See ei ole AM4 socket . Täpselt nii üritasingi panna aga see surve on meeletu kui peaksin latchi kinni suruma. St emaplaadi samgad liiga madalal.
http://assets.coolermaster.com/landing/am4-socket-ready/v2/download/RR-ACCY-AM4B-R1.pdf?_ga=2.87065176.1985926234.1504285088-1317225013.1504118674
tundub nagu sa oleksid see õnnetu kellel on see bracket AM4 jaoks puudu või lihtsalt polegi seda mõeldud sinna.
AM4 compatible tähendab tegelikult seda et seda on võimalik kasutada ka selle prosega...mul TT aio oli sama kirjas olid samamoodi aga bracketi polnud nö "Out-of-box Compatibility"
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 45
sõnum 02.09.2017 08:42:37 vasta tsitaadiga
http://wccftech.com/amd-cpu-sales-overtake-intel-first-time-decade-germanys-largest-e-tailer/
Mindfactory.de andmed siis. Inteli enimmüüdud on 7700K mis moodustab ligi poole müüdud Inteli prosedest. Ega peale selle ja vähemal määral ka G4560 polegi neilt midagi osta. G4560-st ülespoole teevad Ryzen 3 ja Ryzen 5 puhta töö ja kõik i7 mudelid peale 7700K on varjutatud Ryzen 7 poolt. Threadripper omakorda teeb i9-le ära.
Drake
sõnum 04.09.2017 16:27:16 vasta tsitaadiga
I7 6850k on kah praeguse hinna juures väga elujõuline valik.
Ei tee see 1800x talle midagi ära.
d.
On the other hand, I've turned rivers into blood... kings into cripples... cities into salt. So I don't think that I have to explain myself to you. -Gabriel-
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 85
sõnum 04.09.2017 17:44:46 vasta tsitaadiga
Drake, Ei saa su postist midagi aru. 6850K on 6c/12t. Ilmselt Ryzen 5 1600 see ületab olles kallim, aga järgmine kuu tulev 8700K muudab selle mõttetuks.
Diesel157
sõnum 05.09.2017 12:18:49 vasta tsitaadiga
Mõtlesin natuke oma Ryzen 5 1600 näppida. Lasin selle Masteri peale ja näppisin seal natuke asju. Pmst, kas asi ongi nii lihtsaks tehtud, et tõmbad ainult slaiderist mhz juurde, siis apply ja ongi kõik icon_eek.gif . Pmst, seni kuni ma volti ei näpi ei tohiks ta rohkem voolu tarbida ja kuumemaks minna, kui hetkel? Ei mäleta neid asju enam, viimane prose mida ma kellasin oli Phenom II 965 omajagu aastaid tagasi icon_biggrin.gif .
Kommentaarid: 162 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 146
siven
siven
sõnum 05.09.2017 13:27:22 vasta tsitaadiga
Diesel157 kirjutas:
kui cpu vcore auto peal siis ta ikka lajatab üldjuhul rohkem kui vaja....
amd puhul ei oska öelda aga intelil lajatab 1.300 selga kohe autoga... mis on üldjuhul palju ja pole mõistlik
Kommentaarid: 163 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 149
-antero-
-antero-
sõnum 05.09.2017 16:22:09 vasta tsitaadiga
Lajatab ka ryzenil. Ise mudisin enda oma Biosist. Kui mäletan õigesti, siis hetkel on stabiilne 1,2V ja 3800mhz peal. Ryzenil tasub ka chipset driver ära uuendada, minul tegi see asja stabiilsemaks.
sakinaga
sõnum 05.09.2017 17:02:09 vasta tsitaadiga
Tomorrow kirjutas:
i3 on ka mõtet osta, kui iGPU oluline. Odavama otsa ryzenitel seda pole.
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 155
sõnum 05.09.2017 17:39:06 vasta tsitaadiga
maatriks, G4560'l on kah iGPU olemas: https://ark.intel.com/products/97143/Intel-Pentium-Processor-G4560-3M-Cache-3_50-GHz
Jah i3'l on aste või kaks kiirem iGPU aga vaevalt keegi eriti ostab neid integreeritud graafika jõudluse pärast. See on rohkem selline pildi ette saamise teema, kuna see kes ostab jõudluse pärast võtab eraldi kaardi ja see kes ei osta jõudluse pärast ei tea HD610 vs HD620 vs HD630 vahet niikuinii.
Drake
sõnum 05.09.2017 20:02:24 vasta tsitaadiga
Tomorrow kirjutas:
Ei saa su vastusest midagi aru.
Benchides on see 6850k ka 1800x kiirem, miks seda üldse 1600-ga võrrelda ?
Hind amazonis on 342,99€ KÄIBEGA.
8700k ilmselt ei lenda väga palju kõrgema kaarega aga hind on muidugi sama.
Minu mõte oli selles, et hetkel on see väga hea alternatiiv kõikvõimalikele ryzenitele.
Minu suurem isiklik küsimus on aga, et kas TR16/1950X või I9 7950x?
Peamised kasutusalad on 2.5k/4k gaming ja video edit.
Soovitusi argumentidega ?
d.
sõnum 05.09.2017 21:06:34 vasta tsitaadiga
Drake, No muidugi on 6850K kiirem, kui 1800X, aga 1800X on ka võrdlemisi mõttetu mudel. Võrdlus 1600-ga kuna sama tuumade/lõimede arv aga odavam hind. Muidugi aeglasem kah aga hind paneb asjad paika. Enamus inimestele on 1600 mudelist küll ja veel.
8700K eelis on see, et uuem kiip ja pole ka kaugel enam. Lisaks emaplaadid odavamad ja uuemate featuuridega, kui X99 millel 6850K istub.
Mis puutub 1950X vs 7950X, siis palju sõltub tegelikult. Mina arvan, et 1950X kuna 2,5K ja 4K gaming + video edit ei sõltu niipalju IPC-st kus Intel tugev. Kõrgel resol mängides on 90% ulatuses GPU pudelikael ja video edimises loeb tuumade arv ja mingil määral ka kellad aga peamiselt tuumade arv.
Pealegi 7950X nõuab optimaalseks toimimiseks vesijahutust mis kergitab hinda veelgi. Samas Skylake-X mesh arhitektuur on hit and miss. Kord on see ülikiire mingis spetsiifilises workloadis. Kord isegi aeglasem, kui Broadwell-E. Muidugi 7950X benche me pole veel näinud.
Kui sul kohe vaja pole ja raha pole takistus, siis oota 7950X launch ära. Kindlasti pannakse see võrdlusesse 1950X-ga ja siis näed ära mis jõudlus on. X299 vs X399 on suht sama kallid seega seal vahet pole.
sõnum 05.09.2017 22:01:14 vasta tsitaadiga
7950x ei tohiks nagu olemas olla. 7940x (14c) või 7960x (16c).
- londiste
sõnum 06.09.2017 03:09:44 vasta tsitaadiga
Jep ilmselt käib jutt 7960X-st. Aga kes see Intelit ja nende nimetusi ka teab...
Drake
sõnum 06.09.2017 10:20:09 vasta tsitaadiga
Krt 5 ja 6 elavad liiga kõrvuti klaveril
7960x jah - 16c/32t.
Ilmselt tuleb jah reaalne bench ära oodata ja siis valida.
Hind pole probleem, kuid kui vahe on marginaalne, siis üle maksma kah ei taha hakata.
d.
anubis
anubis
sõnum 10.09.2017 00:40:07 vasta tsitaadiga
https://www.forbes.com/sites/antonyleather/2017/09/05/amd-ryzen-threadripper-the-fascinating-story-behind-the-processor-that-beat-intel
Link
SeedX
SeedX
sõnum 10.09.2017 18:54:59 vasta tsitaadiga
Ryzen 1700 sülearvuti testid, saksa keeles ainult!
https://www.notebookcheck.com/Live-Test-Asus-ROG-Strix-GL702ZC-Ryzen-7-1700-Radeon-RX-580-Laptop.247470.0.html
Kommentaarid: 92 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 85
flameas
flameas
sõnum 11.09.2017 12:28:30 vasta tsitaadiga
Link
Päris tore asi kui stock vendid välja jätta
Kommentaarid: 91 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 81
pots4t4j4
sõnum 11.09.2017 14:34:51 vasta tsitaadiga
Highest oc on a shitty aio peaks nimi olema.
Viilutaja
Viilutaja
sõnum 11.09.2017 15:01:38 vasta tsitaadiga
pots4t4j4 kirjutas:
Jep. Minumeelest päris mitmed on saanud 4.2Ghz tipp õhkjahutusega.
4,125ghz mingi AIO'ga .... dfug??
Parim kodukino projektor müügis: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11790090#11790090
Auron
Auron
sõnum 11.09.2017 15:47:05 vasta tsitaadiga
Viilutaja, aa miks sa üldse arvad, et AIO on võrreldes tippõhkjahutusega mingi müstiline asi mis peaks kõvasti paremaid tulemusi tegema? AIO point on pigem see, et prose ümbrus on vabam ja puhtam ja soe läheb otse kastist välja ja thats about it.
HDTanel
Overclocker
HDTanel
sõnum 11.09.2017 17:36:43 vasta tsitaadiga
Ma peaks lähiajal siin 1950X saama.. muren aga pead, et mis kuradima jahutuse sellele peale toppida.. icon_rolleyes.gif veeplokk suure pinnaga oleks vist kõige mõistlikum..
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
Mehikene
Mehikene
sõnum 11.09.2017 20:17:54 vasta tsitaadiga
HDTanel kirjutas:
Mina panin selle https://www.ekwb.com/shop/ek-supremacy-evo-threadripper-edition-full-nickel ning olen väga rahul.
Kommentaarid: 94 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 89
HDTanel
Overclocker
HDTanel
sõnum 11.09.2017 20:48:56 vasta tsitaadiga
Mehikene, see vast mõistlik jah.. samas ma ilmselt saan vaid laenuks selle nii, et päris poodi ostma plokki minna väga ei tahaks.. samas vist ikka peab.
Krüpto
DeTHiCa.
DeTHiCa.
sõnum 11.09.2017 22:10:34 vasta tsitaadiga
Mehikene kirjutas:
räägi, mis seadistusega sul mälud jooksevad? CL ja MHz huvitab.
Mehikene
Mehikene
sõnum 11.09.2017 22:47:31 vasta tsitaadiga
3466MHz 16-18-18-36
DeTHiCa.
DeTHiCa.
sõnum 11.09.2017 22:57:03 vasta tsitaadiga
Mehikene kirjutas:
3466MHz 16-18-18-36
ja sellel seadistusel kõik 32gb ka jookseb? 1t või 2t?
Mehikene
Mehikene
sõnum 11.09.2017 23:04:13 vasta tsitaadiga
Kõik 1T jah. Jookseb kenasti.
anubis
anubis
sõnum 14.09.2017 21:36:48 vasta tsitaadiga
https://www.techpowerup.com/237033/amd-raven-ridge-ryzen-5-2500u-with-vega-graphics-apu-geekbench-scores-surface
sõnum 14.09.2017 23:33:50 vasta tsitaadiga
Ei saa hästi aru, miks ei kõrvutata uudises tulemusi teiste tulemustega, et saada aru, kuhu tulemus positsioneerub. Ma (ja ilmselt ka paljud teised) ei viitsi neid igasugu testide numbreid eriti vaadata, samas tahaks teada, kuhu jõudlus positsioneerub. icon_smile.gif
sõnum 15.09.2017 09:25:18 vasta tsitaadiga
ryzen, 4c/8t, 2ghz.
perf tulemus on igav.
sinna kõrvale on voolutarvet vaja.
- londiste
HDTanel
Overclocker
HDTanel
sõnum 15.09.2017 12:32:42 vasta tsitaadiga
Keegi oskab öelda, mis nende kahe plaadi vahe reaalselt on? Lihtsalt pluss miinus mõned USB pesad, LED port jms?
Krüpto
sõnum 15.09.2017 12:45:20 vasta tsitaadiga
sa nagu esimest päeva tegeleksid rauaga
https://www.asus.com/Product-Compare/?products=crmB9fKGEQXtzLft,QwlTxpAeJ6tHHYFi&b=2
üks lisa m.2 pesa, wifi/bt, veidi erinev audio ja erinev portide konf (eelkõige jah, palju usbe) ning rohkem kaasas olevat nänni.
hero extreme poole kõik muidugi.
- londiste
sõnum 15.09.2017 13:24:21 vasta tsitaadiga
Extreme on nagu featuuridest ka näha võib rohkem all-in-one/OC plaat (ehitatud paljuski Hero põhjale). Strix on üsna tavaline X370 plate. Extreme eelis OC osas on rohkem sätteid OC jaoks. Eriti mäludele. Lisaks LN2 jaoks sobivad tweakid. Samas nii hea OC plate siiski pole kui Inteli poolel Apex ja OC Formula (need on ka nn pure OC plaadid kus on ohverdatud kaks mälukanalit, et saavutada maksimaalne mälu OC ja hakitud maha enamus featuure mis OC jaoks olulised pole).
HDTanel
Overclocker
HDTanel
sõnum 15.09.2017 13:26:29 vasta tsitaadiga
Krüpto
One
sõnum 15.09.2017 14:25:29 vasta tsitaadiga
HDTanel kirjutas:
HDTanel kirjutas:
Kuskil on mingi fckup toimunud või ajad ise segast?
1950X on TR ja X399 ju?
DeTHiCa.
DeTHiCa.
sõnum 15.09.2017 15:34:34 vasta tsitaadiga
noh, kui ta siin mõnikümmend lehte tagasi ei teinud isegi TR ja EPYC prosedel vahet, siis pole imestada et valed plated.
HDTanel
Overclocker
HDTanel
sõnum 15.09.2017 16:11:29 vasta tsitaadiga
Winterwind kirjutas:
HDTanel kirjutas:
HDTanel kirjutas:
Need tulevad hiljem
Krüpto
Denkeš
Denkeš
sõnum 15.09.2017 21:27:51 vasta tsitaadiga
rmc kirjutas:
AMD Ryzen 3 1200, 3100 MHz : 3622/9747
AMD Ryzen 5 2500@2000 MHz : 3561/9421
AMD Ryzen 5 1400, 3200 MHz : 3680/12259
a.k.a Ummikummi
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
sõnum 16.09.2017 11:45:36 vasta tsitaadiga
https://www.techpowerup.com/237061/amd-ryzen-threadripper-mcm-de-lidded-and-de-packaged
Paistab, et siiski reaalsed kiibid kasutusel mitte tühjad kivid. Tehliliselt on seega tulevikus võimalik teha ka 20, 24, 28 ja 32 tuumalised TR versioonid. 8 > 12 > 16 > 20 > 24 > 28 > 32
Denkeš
Denkeš
sõnum 16.09.2017 12:03:41 vasta tsitaadiga
Tomorrow kirjutas:
Puhtalt juba see, et kasutusel on tr4 socket avab teoreetilise võimaluse. Imestan, et keegi pole epicut x399 peal proovinud.
a.k.a Ummikummi
eix666
eix666
sõnum 16.09.2017 12:28:06 vasta tsitaadiga
Ma poleks küll kindel, et see asi nii lihtne on. Puhtalt sellepärast, et TR on 4 mälukanaliga plaatidel ja epyc 8 kanaliga. St minuteada töötab asi ju niimoodi, et igal ccx'il on oma mälukanal (mistõttu ryzen on 2kanaliga, TR 4 kanaliga ja epyc 8 kanaliga). Kui tahta 32 tuumast TR'i siis peab kas uued 8 kanaliga emaplaadid välja laskma selle tarbeks, või pooled mälukanalid kinni keerama, mis arvatavasti mõjub prose latentsusele pigem kehvasti, kuna iga ccx ei saa pöörduda otse tema küljes oleva mälukanali poole.
Igastahes on lihtsam ja loogilisem 32 tuuma vajaduse korral juba otse epyc võtta, ega 32 tumaga TR niikuinii odavam ei tuleks.
DeTHiCa.
DeTHiCa.
sõnum 16.09.2017 14:04:22 vasta tsitaadiga
Denkeš kirjutas:
Tomorrow kirjutas:
on ju kirjutatud:
The disabled dies can't be reenabled, at least not on an X399 chipset motherboard, as the Threadripper HEDT platform lacks DRAM, PCIe, and possibly even power wiring for the disabled dies.
razor
sõnum 16.09.2017 16:07:48 vasta tsitaadiga
Arvatavasti ei tööta TR ka EPYC plaatidel, artiklist
We could use the same socket as EPYC and just re-wire things. We’d already defined all the supply and ironed out the issues for EPYC, and this made it really easy to persuade our motherboard partners for example.
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 120
sama123
sõnum 18.09.2017 23:09:23 vasta tsitaadiga
Pole teemat kaua jälginud aga nüüd intel toob kodulehel ära sellised prosed mida veel ei toodeta! Seda pole enne olnud icon_biggrin.gif 18 tuumaline i9-7980XE kus seda kasutada kui on 18 suht aeglast tuuma? Kunagi oli mhz võistlus, siis mindi kuni 4000mhz ja standardseadetes oli lõpp, nüüd siis tuumade arvus. Kiireid 2-4-ja tuumalisi aga ei ole ega vist ei tule, single core perf kasvab aeglasemalt kui oli loodetud......
https://www.intel.com/content/www/us/en/products/processors/core/x-series.html
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 73, 74, 75 ... 319, 320, 321  järgmine
