abc9
29.04.2004 12:08:00
4GB Capture limiti problem |
Tekkis selline problem: tõmbasin Pinnacle 8-ga analoog videot arvutisse. Kui lindistatav video fail jõuab suuruseni 3,99GB lõpetab programm lindistuse. Kuskilt peab seda ju seda piiri suuremaks panna saama. Help me!
Kommentaarid: 194 loe/lisa |
168 |
Doha
29.04.2004 12:14:23
kes siis filme ühe korraga arvutisse ajab ? ikka juppiden siis pärast viimistlust ajad progega jälle kokku....
_________________ ···(_.·´¯)··¦DOHA¦··(¯`·._)···
________+UsE MiNd+________
www.pillipood.ee |
Kommentaarid: 1 loe/lisa |
dyyp
29.04.2004 12:19:17
AVI 4GB Limit Explained
Be careful when dealing with large files! The Windows 95/8 file system cannot handle AVI files larger than 4 gigabytes! There has been much confusion regarding this issue. In short, the old Windows File Allocation Tables (FAT16) cannot store more than 2 gigabytes per file. Windows 98's FAT32 allows a 4 gigabyte storage capacity per single file. So where does the 1 and 2 gig storage limit come in? Most AVI parsers use something called signed arithmetic. This forces a storage limit of 2 gigabytes for .avi files on Windows 98. But the multimedia system in Windows 95 cannot cope with RIFF files (such as .avi files) bigger than 1 gigabyte! And this is why people will say there is either a 1, 2 or 4 gigabyte limit on single file storage. This is why DeCSS, DOD Power Ripper, Vob Merge, Peck Power Join and all other programs like this are incapable of storing more than 4 gigabytes on most peoples computer systems! I think this is the chief reason for so many unexplained error messages when using these programs too!
There is a partial way around this that is used extensively by Virtual Dub that is similar to OpenDML. These settings can be used to create very large .avi files by grouping smaller files together so they are forced to play in sequence. This solution means that the finished files can only be played with Windows Media Player or other programs that support OpenDML type files. For more details on this consult the VirtualDub help files.
Kommentaarid: 21 loe/lisa |
20 |
abc9
29.04.2004 13:31:29
Nagu aru saan, polegi testmoodi võimalik. Praegalt kakun DV kaameralt üle tunnist videot sisse ja iga 17 mindi tagant pean siis jälle uuesti capturima panema - väga tüütu. Analoog video capturimisel on see ju veel juram, kui pead iga kord jälle lõigu lõpu tagasi kerima ja kogu aeg juures passima ja siis jälle hiljem kokku ajama. Jama värk.
168 |
Dijital
Kommentaarid: 40 loe/lisa |
31 |
abc9
29.04.2004 14:20:43
Kasutan XP Pro SP1. Win98 - I don't think so
_________________ ▀▄▀▄▀▄▀▄▀▄█▓▒░ |
168 |
Dijital
31 |
abc9
29.04.2004 15:46:42
Äkki on asi selles, et NTFS lubab üle 4GB faili ja FAT32 mitte.
168 |
Arvo Cobrietti
29.04.2004 16:06:32
abc9 kirjutas: |
Äkki on asi selles, et NTFS lubab üle 4GB faili ja FAT32 mitte. |
no kolmandas postis toodud jutust peaks ju välja lugema, et Fat32 üle 4GB ei võimalda ühe faili suuruseks
Kommentaarid: 39 loe/lisa |
37 |
s.p.o.c.k
29.04.2004 16:12:03
Kui DVga tööd teha (või pruukida mõnda teist väheste kadudega kompressorit), on FAT32 küll täielik mõttetus - sunnib sind kasutama progesid, mis suudavad avi suurusepiirangust straipimisega mööda hiilida (mitte et need halvad oleksid, aga... ). Ma ei näe põhjust, miks ei võiks tarvitada NTFSi. Kui sul on juhtumisi süsteem samale partitsioonile juhtunud ja uus format kõne alla ei tule, siis pruugi utiliiti convert, näiteks:
convert c: /fs:ntfs
Mõistagi võib olemas olla ka selliseid progesid, mis niikuinii üle neljagigaseid avisid ei toeta, olgu see failisüsteem mis iganes, aga see on mul lihtsalt pessimistlik oletus, pole oma silmaga selliseid poolpeeretajaid näinud ega tarvitanud.
_________________ Welcome to Dogville, USA. |
Kommentaarid: 2 loe/lisa |
lisa lemmikuks |
