Kuskil jäi silma, et paaril kasutajal oli mäludega mured. Ühel härral õnnestus DDR4 @ 3200Mhz tööle saada. Kui on abiks siis:
Lühidalt:
UPDATE - Finally I have DDR4-3200 running on Ryzen!
New Motherboard? - No
New BIOS? - No
New RAM? - YES
It only took a nice $210 G.Skill Trident Z DDR4-4000 memory kit to get it working... My G.Skill DDR4-3000 Ripjaws V didn't work. My Corsair Vengence LPX DDR4-3200 didn't work, but the TridentZ DDR4-4000 did.
Had to manually set the timings however, to 16-18-18-36 - the RAM wants to be at 2T, but the BIOS won't allow it, forcing it to 1T, but it appears to run.
"Your PC uses a processor that isn’t supported on this version of Windows" error when you scan or download Windows updates
This error occurs because new processor generations require the latest Windows version for support. For example, Windows 10 is the only Windows version that is supported on the following processor generations:
Because of how this support policy is implemented, Windows 8.1 and Windows 7 devices that have a seventh generation or a later generation processor may no longer be able to scan or download updates through Windows Update or Microsoft Update.
Sel tegelikult väga tugev (mõistlik) äriline põhjus olemas. Lihtsalt versioonid erinevad üksteise vahel nii palju, et MS jaoks on äärmiselt kulukas vanu arhitektuure kaua toetada. Arvestades, et nad liiguvad nagunii pigem SaaS mudeli poole, pole üldse imestada. _________________ Dima oli siin
Kahju, et sellel 1600'l pole 65W TDP'd. Tahaks sellist 6 tuumalist ja selle hinnaga!
Ask and you shall receive!
Eile oli Guru3D's vale info üleval, sellepärast kaduski see uudis sealt sama ootamatult kui tuli. TDP oli valeks märgitud.
Ainult 1600X'l on TDP 95W. Allapoole on kõik uued mudelid 65W
We have confirmation from AMD that there are no silly games going to be played with Ryzen 5. The six-core parts will be a strict 3+3 combination, while the four-core parts will use 2+2. This will be true across all CPUs, ensuring a consistent performance throughout.
Seega 4-tuumased on samuti 2 CCX-ga ära nuditud Zeppelin. Kuigi latentsus tuumade vahelisel suhtlemisel on suurem, siis vähemalt on neil tuumadel rohkem L3 vahemälu jagada.
Imelikul kombel samas artikli tabelis r5 1400 on 8MB L3 ja r5 1500X 16MB. Huvitav mis värk sellega siis nüüd on?
Kuidas need r5-d nii kehvasti klokkuvad siis? ümbruses peaks olema palju vaba ruumi ning per core peaks ka pinga olema ju? Või on katkised tuumad ära lõigatud küljest, et pindala kust sooja eraldada väheneb?
(ja hakkab jälle see mitme CCX teema pihta...)
Ühes ülevalpool postis oli juba ühe CCX katsetused tehtud, ainult et SMT oli välja lülitatud ning OC puudu.
Mälud paistsid juurde andvat korralikult FPS, jällegi oli puudu Inteli võrdlus. VB mängu spetsiifiline mälude kasutus ning sellest tulenev jõudluse kasv...
Täit selgust pole ikka.
See 1500X vs 1400 on väga huvitav värk. 1500X tundub jutu järgi olevat CCX 2+2 (8MB + 8MB L3 Cache) ja 1400 tundub nagu oleks CCX 4+0 (sellest tulenevalt siis ka 8MB + 0MB L3 Cache).
Siin hästi näidatud kuidas Zeppelin takt voldiga skaleerub..
Ilmselt 14LPP protsess on kõrgete taktide saavutamiseks pidurdav tegur. Serveritele ja mobiilsetele toodetele samas hea vooluefektiivsuse omadustega see sobib hästi. 3,3-3,5 baas ja 3,8-3,9 boost oleks nagu sweetspot.
kuda muidu B350 üleval on pidanud ennast? on kogemust? kõik kangesti tahavad neid yber-asuseid ja kraami, aga kas vaesemal mehel ka annab proovida? heaküll, ddr4-3000+ ja yberklokki on vast palju loota, aga midagi ikka saab. normi b350-mne saab julgelt alla soti kätte.
Ausalt öeldes ise ei näe küll suurt pointi x370 osta. Vb mõnel on vaja neid extra 2 pcie triipu või SLI-d aga muus osas on bling.
Kuna siin tuleb ju mitu prose revisionit või põlve vms.. sama emaplaadi peal, siis on paremate vidinatega emaplaat õigustatud. Hiljem odavamaks kindlasti ei lähe.
viimati muutis sooty 16.03.2017 16:42:16, muudetud 1 kord
Selles mõttes on X370'l point, kui need tõesti töötavad kiirema mäluga paremini, sest siiamaani on juba mingi +15fps vahe olnud, kui jooksutad 2133mhz mälu või 2667Mhz mälu. Mida kiirem mälu seda paremini Ryzen töötab. Ja FPS vahed on märgatavad.
Ning arvestades ka seda, et AM4 socket jääb kasutusse kauaks kauaks, ka tulevaste Ryzeni refreshide jaoks, siis X370 plaadiga pigem investeerid tulevikku. Eeldades seda veel, et X370'l on paremad elektroonilised komponendid küljes, mis peaks olema töökindlamad pikemas perspektiivis.
Prose revisjonid ju võivad tulla ja biossi uuendustega ka käima minna kuid see ei välista olukorda kus platede enda lisafeatuuride suhtes toimub areng ja siis praegune plate on 3-4 aastapärast naljakalt vana kuigi töötab kaasaegse prosega
See hõigati ju kuskil välja, et AM4 peale sobivad ka tulevased AMD prosed. Ning siimaani on AMD sama taktikat kasutanud, seega pole põhjust välja öeldus kahelda.
AM3+ on kui vana?
am3+ kui see socket, mis algas 2011 ja millele viimane prose (refresh sku-d, viimane reaalne arhitektuuriuuendus poolteist aastat varem) tuli 2.5+a tagasi 2014 lõpus?
halb näide.
edit:
kuna hakkas huvitama ja mälu vajas värskendamist, siis viimased amd socketid (alates athlon 64-st):
2003 - 754/940
2004 - 939
2006 - am2
2007 - am2+
2009 - am3
2011 - am3+
zen+ järgmise aasta algul peaks loogiliselt samale socketile istuma, sealt edasi ei tea keegi.
amd ei paista olema kuskil jaganud uuendatud platvormi roadmappi. _________________ - londiste
viimati muutis londiste 16.03.2017 17:47:24, muudetud 4 korda
Mis järgmise kolme-nelja aastaga nii väga muutuda tõotab?
Seda ei tea niimoodi keegi ette - midagi otseselt väga revolutsioonilist vast mitte kuid nipet näpet täitsa võimalik - ega aastal 2013 ka ei teand, et 3,5 aastapärast on meil 1TB platele käivad SSD'd mis loevad kribavad 3500 MB/sec.
eila õhtul mul veel mingid updated tulid aga noh, suht suva kui rohkem ei tule. Pole mingeid riigisaladusi arvutis _________________ LehesFoto - Täis suvaklõpse ja muud
salatoimik, Haavatav arvuti on oht nendele, kellel ON riigisaladused arvutis. (ja kõigile teistele küberrünnakute ohvritele) _________________ Dima oli siin
Kas mõni x370 mobo omab ka PCI siini? Ainult B350 emaplaate on silma hakanud PCI siiniga.
Kas x370 kiibiga emaplaatidel on arvestatav helikaart (võrreldav Creative Audigy või X-Fi omadega) ja B350 kiibiga emaplaatidel on lahjem?
viimati muutis KyBer 17.03.2017 11:09:33, muudetud 1 kord
Panustasin Crosshair 6 ostul sellele, aga väga rahule ei jäta. Kõrvaklappidega oli vanal AM3 gigabyte mobol parem surround. Helikvaliteet võib olla ja ilmselt praktikas ongi parem, aga dolby'st tunnen puudust.
