uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 Windows Update parandus märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3
helpless
helpless
sõnum 04.12.2016 14:26:04 vasta tsitaadiga
Ma installisin ka ühele masinale windows7 peale 2016 mai uuendustega. Ja keeks hakkas pihta. Ootasin 10 tundi ja siis viskas närvi roheliseks. Hullem kui mustaks variandi....
Katkestasin internetiühenduse, installisin KB3172605 peale ja kõik. Peale installimist taaskäivitus ja esialgsed 30 uuendust tuli.... ju siis klapib kõik?
sõnum 04.12.2016 14:54:44 vasta tsitaadiga
Üldist infot kah uuenduste installimiseks. Hiljuti just tegin läbi ja WU näitas esimesel korral ainult .NET ja muid ebaolulisi uuendusi. Mingit WU jokutamist õnneks polnud.
Paraku nii KB3125574 kui ka nüüd KB3197869 sisaldavad telemeetria jama, aga kuna Win7-le pole see vaikimisi sisseehitatud, siis saab üsna kerge vaevaga selle välja lülida.
## Convenience rollup update for Windows 7 SP1 ##
- KB3125574 is a comprehensive rollup update that contains almost all fixes released
after Windows 7 SP1's release, up through April 2016
- To apply this update, you must first install servicing stack update KB3020369.
This is the recommended installation order to get the best use of the rollup:
1. KB3020369 / Prerequisite
2. KB2670838 / Platform Update
3. KB3125574 / Convenience Rollup
4. KB3197869 / October 2016 Rollup
- If you intend to install any of the following feature packages, install them *first* (before KB3125574)
so the rollup can install their updated components afterwards:
IE11, RDP, WMF4, DCA2.0, AD LDS, RSAT, VirtualPC, WorkFolders, Server Essentials Connector
- This update aims to simplify the updating process for Windows 7, but it's completely optional,
and for due diligence purposes, be aware that it does contain some telemetry updates components (3068708, 3075249)
Be advised that starting October 18, 2016
the Monthly Quality Rollup will
include Unified Telemetry Client (Diagnostics Tracking Service DiagTrack)
which collects and uploads telemetry diagnostics data to Microsoft
and it will continue to exist in all future Rollups.
Therefore, if you do not want this component, you have two options to proceed:
1. Block and disable UTC functionality, keeping the rollup installed.
2. Skip the Monthly Quality Rollup from now on, and install Security Only Quality Updates.
1. Block Telemetry Client:
This allows you to utilize all non-security fixes in the Rollup.
- Start command prompt as administrator, and execute these commands respectively:
sc config DiagTrack start= disabled
sc stop DiagTrack
reg delete HKLM\SYSTEM\ControlSet001\Control\WMI\AutoLogger\AutoLogger-Diagtrack-Listener /f
reg delete HKLM\SYSTEM\ControlSet001\Control\WMI\AutoLogger\Diagtrack-Listener /f
reg delete HKLM\SYSTEM\ControlSet001\Control\WMI\AutoLogger\SQMLogger /f
reg delete HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Diagnostics\DiagTrack /f
reg delete HKLM\SOFTWARE\Policies\Microsoft\Windows\DataCollection /f
takeown /f %ProgramData%\Microsoft\Diagnosis /A /r /d y
icacls %ProgramData%\Microsoft\Diagnosis /grant:r *S-1-5-32-544:F /T /C
del /f /q %ProgramData%\Microsoft\Diagnosis\*.rbs
del /f /q /s %ProgramData%\Microsoft\Diagnosis\ETLLogs\*
- You might need to do that with each new Rollup installed.
You can also create a schedule task to run the commands in batch script on Logon.
2. Install Security Only Quality Updates:
This allows you to avoid any non-trustworthy components and only install security fixes.
however, be aware that Windows Update does not recognize these updates, and will continue to request the Monthly Quality Rollup
- Go to Microsoft Update Catalog, and search for
Security Quality
or copy and paste this URL into your browser:
http://www.catalog.update.microsoft.com/Search.aspx?q=Security+Quality
- Download and install each corresponding Month Security Only Quality Update
that matches your System version and architecture
i.e.
October, 2016 Security Only Quality Update for Windows 7 for x64-based Systems (KB3192391)
helpless
helpless
sõnum 04.12.2016 15:01:52 vasta tsitaadiga
Mul selliseid uuendusi polegi. Aga vaatan enda arvutis hetkel saadaval uuendusi: https://www.upload.ee/image/6414968/kuss.JPG
Mis "rollup" - normaalsed uuendused?
sõnum 04.12.2016 15:05:16 vasta tsitaadiga
helpless, Rollup = nad panevad uuendused nüüd "pakiks kokku", et ikka win7 inimesed ka spyware'i peale laseks :p
helpless
helpless
sõnum 04.12.2016 15:18:45 vasta tsitaadiga
On ahvid! Siis ignoneerin seda uuendust...
sõnum 04.12.2016 15:21:45 vasta tsitaadiga
KB3125574 ehk Aprilli Rollup on pmst pseudo SP2 Win7-le.
Samas plussid selle juures kaaluvad miinused ülesse.
Igakuised rollupid järgivad nüüd sama skeemi nagu Win10 puhul. Kõik turva ja patch tuesday uuendused mis varem tulid eraldi on nüüd ühte pakki pandid ja nt clean installi tegemisel pärast KB3125574 pealelaskmist saab viimase igakuise rollupi peale lasta ja oledki up to date enamjaolt. Iga rollup on kumulatiivne, ehk sisaldab ka eelmiste kuude fixe.
Õnneks kuna Win7-le on telemeetria lisa, siis selle kinnikeeramine või sellega seotud uuenduste mahalskmine midagi katki ei tohiks teha nagu Win10 peal võib juhtuda. W10-l on see juba nii tugevalt integreeritud, et enne pead pool maja maha lammutama, et prussakas ära tappa.
helpless
helpless
sõnum 06.12.2016 15:50:01 vasta tsitaadiga
Tomorrow kirjutas:
sisaldavad telemeetria jama - ehk siis emakeeles täpsemalt? Mida see endast kujutab? Natuke segaduses...
Tegin ühel läpakal kõik uuendused ära. Rollupid ja mis loomad veel. Reaalselt mõni uuendus jukerdab väga hullusti midagi ära?
Midagi sellist mida tõesti vaja pole ja on ainult koormaks? Eemaldaks sellised heameelega....
jaanus-
jaanus-
sõnum 06.12.2016 23:30:57 vasta tsitaadiga
tegin sama kompoti uuendustega vältides vaid ilmselgeid win 10 upgrade seosega uuendusi ja pole probleeme olnud
sõnum 06.12.2016 23:31:44 vasta tsitaadiga
mul wsus läks ühe masina kallale hetk tagasi.
Kontrollitud ja hooldatud sülerid: https://www.facebook.com/marketplace/profile/100087345405856 või https://www.yaga.ee/mox-fulder Umbes 25 arvutit kohe olemas.
helpless
helpless
sõnum 07.12.2016 15:50:32 vasta tsitaadiga
wsus ehk windowsi uuendused?
sõnum 07.12.2016 15:51:58 vasta tsitaadiga
https://en.wikipedia.org/wiki/Windows_Server_Update_Services
Märt.
Märt.
sõnum 07.12.2016 16:25:13 vasta tsitaadiga
Windows Server Update Services
sõnum 08.12.2016 00:06:33 vasta tsitaadiga
http://download.wsusoffline.net/
aeg ajalt lasen tal kettale valmis teha / uuendada mingi paki ja läheb siis kettalt "installer" käima.
netcat
netcat
sõnum 29.03.2017 16:42:23 vasta tsitaadiga
Kas keegi teab, W7 Starteril mis viimati edukalt 2016. aastal uuendused on saanud, on seesama standardkamm või on see mingi muu kamm? Varem ei ole samas masinas probleeme olnud ja nüüd otsib ja jääbki seda tegema.
sõnum 29.03.2017 18:11:52 vasta tsitaadiga
ultimate outsideri gwx control panel oskab WU cache kenasti puhtaks teha.
systxix
systxix
sõnum 31.10.2017 09:23:05 vasta tsitaadiga
Kas selle järjestuse osas on vahepeal midagi muutunud ka?
j22k0
sõnum 17.11.2017 22:27:00 vasta tsitaadiga
Upgrade-isin just ühe Windows 7 masina Windows 10 peale. Kuni aasta lõpuni veel jagatakse, siis enam ei saa tasuta. Praegu sain siit-> https://www.microsoft.com/en-us/accessibility/windows10upgrade
lutsukala
sõnum 20.07.2019 21:27:33 vasta tsitaadiga
mis teema see on, et peale KB2670838 installimist ja veitse aega mängimist tõmbas terve ekraani mingeid vertikaalseid jooni täis ja pilt ise näeb välja nagu mingi 256 colors?
sõnum 20.07.2019 21:35:35 vasta tsitaadiga
lutsukala kirjutas:
Kas vaatasid ka, mida see uuendus teeb?
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 Windows Update parandus mine lehele eelmine  1, 2, 3
