uus teema   vasta Raud »  TSI (TeeSeeIse) »  Kuidas flashida BENQ monitor märgi kõik teemad loetuks
XeStAiSy
Aeg Maha 2a
sõnum 12.11.2016 20:56:51 Kuidas flashida BENQ monitor vasta tsitaadiga
Monitori Fläshimisieks vaja bootiv linux ja natuke copy paste
Boodi linux usb pulgalt ilma UEFIta
Testimiseks kasutati BENQ XL2411Z MONITOR
Allikas http://forums.blurbusters.com/viewtopic.php?f=13&t=779
Firnwared
https://1drv.ms/f/s!AkQqWXPLNfg-gVFgbSqQ9RqLAZ2A
Kui need kaovad andke teada
Copy Paste
Here's what you'll need to build the tool, using the Ubuntu 14.04 LTS iso (which also behaves as a live CD):
boot in "Try ubuntu" mode (the default), open a terminal (Ctrl + Alt + T);
type "sudo gedit /etc/apt/sources.list";
an editor opens, add "universe multiverse" at the end of the second line, to it reads "deb http://archive.ubuntu.com/ubuntu/ trusty main restricted universe multiverse" Save, then exit the editor;
type "sudo apt-get update", to update the package list;
type "sudo apt-get install i2c-tools subversion libpci-dev" to install required packages.
You can then follow the procedure, building flashrom with the patch, and detecting your I2C buses.
# build
svn co svn://flashrom.org/flashrom/trunk@1846 flashrom
cd flashrom
wget -O- http://boeglin.org/static/benq/0001-Add-programmer-for-the-MSTAR-I2C-ISP-protocol.patch | patch -p1
make -j
# load i2c-dev driver
sudo modprobe i2c-dev
# list all i2c buses
sudo i2cdetect -l
# list i2c devices on bus 1
sudo i2cdetect 1
# get EDID (0x50) from bus 1
sudo i2cdump -r 0-127 1 0x50
# identify flash chip, on bus 1 (/dev/i2c-1) at address 0x49
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49
# dump current firmware
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605A/MX25L1606E" -r backup.bin
# extend firmware to 2MB, to match the flash chip size
tr '\000' '\377' < /dev/zero | dd of=firmware.bin bs=1k count=2k
dd if=XL2411Z_V2_20131209_8B72.BIN of=firmware.bin conv=notrunc
# write firmware
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605A/MX25L1606E" -w firmware.bin
Video ka
Link
Edukat pusimist.
viimati muutis XeStAiSy 13.11.2016 13:35:24, muudetud 2 korda
Anna tooli
sõnum 12.11.2016 21:00:25 vasta tsitaadiga
Mida see flashimine annab?
XeStAiSy
Aeg Maha 2a
sõnum 12.11.2016 21:26:01 vasta tsitaadiga
Kui kasutad v2 - v1 firmwaret siis see on silmailu kuna uued firmwared on edasiarendus ja parandavad vigu. Kahjuks BENQ ei avalikusta mida uuemas firmwares parandati. V4 on ilusam võrreldes v2 suhtes pilt teravam.
von Wu
von Wu
sõnum 12.11.2016 21:27:03 vasta tsitaadiga
Leidsin sellise asja: http://www.blurbusters.com/benq/strobe-utility/
Osta auto ära
Müüa naastrehvid
XeStAiSy
Aeg Maha 2a
sõnum 12.11.2016 21:42:11 vasta tsitaadiga
von Wu kirjutas:
See vidin on üsna vajalik korrigeerida monitori Blurri eemaldamine 60Hz peal juba siis toimib läbi HDMI ka ja nautida ilma blurrita puhast pilti.
Kasutan seda ise ka, see kord seaded paika ja unustad.
sõnum 13.11.2016 12:14:00 vasta tsitaadiga
Oleks võinud ju allika lingi ka siia juurde lisada: http://forums.blurbusters.com/viewtopic.php?f=13&t=779
XeStAiSy
Aeg Maha 2a
sõnum 13.11.2016 13:36:39 vasta tsitaadiga
Mudisin veits esimest posti.
