Kuidagi vâhe _________________ Every version of the garment appears to be sold out online, with prospective shoppers given the opportunity to join a waitlist.
Lavazza Qualita Oro ja Caf.fe Espresso vahe? Teab keegi.
edit:
Ok keegi juba välja uurinud.
Which is better, the Lavazza Gold or Black can variety? Well, I'll tell you.
ByJ. Randolphon June 30, 2008
The major difference between the Lavazza Qualita Oro Espresso (the gold can) and the Lavazza Italian Coffee, Caffe Espresso (the black can) coffees is that the Gold can Lavazza uses 100% Arabica beans from two different countries and the Black can Lavazza uses 100% Arabica coffee beans from only one country.
The Lavazza Gold AND Black canned coffees BOTH are:
1. Lavazza coffee
2. Made using 100% Arabica coffee beans
3. Blended from 100% Arabica beans.
4. Blended to make espresso
5. Roasted and Packaged in Italy.
Differences:
The Lavazza Gold can coffee uses 100% Arabica beans from two countries:
1. Central America and,
2. Africa.
Note: Lavazza states that the Central American beans in this blend contributes a floral aroma.
The Lavazza Black can coffee uses 100% Arabica beans from only one country:
1. South America.
Note: Lavazza states that the South American beans in this blend are sweet and aromatic.
Opinion: Both coffees are excellent. They have different characteristics and while everyone pretty much agrees that both are excellent coffees, some will favor the Black Can variety over the Gold Can - and vice-versa. NEITHER are bad coffees, they just appeal to different tastes and one might perform better in your coffee making procedure/equipment than the other. That still doesn't make either one "bad", it just makes one variety better suited to a particular brewing procedure and to personal taste.
I prefer one variety to the other MOST of the time - primarily because of the excellent result/taste I get from one using my primary coffee making procedure. When I use a completely different system AND procedure for making coffee, I prefer the other variety. BOTH are excellent coffees but one is more likely to perform better in your coffee making method and system and give you better results than the other. Properly made, I sincerely believe that BOTH coffees are EXCELLENT! Now, please excuse me while I go make myself a fresh mug of Joe (quadruple espresso, nothing added). MMMmmmmmmmmmm....
Järgmine kord, kui salatit närite, siis mõelge selle peale Vali liha!
The researchers at the University of Missouri (MU) found that plants can identify sounds nearby, such as the sound of eating, and then react to the threats in their environment.
Kuulge, Kalevipojad ja muud finnofiilid - kas Eestis tehakse samuti selliseid lihatooteid nagu "lenkkimakkara"?
https://fi.wikipedia.org/wiki/Lenkkimakkara
Ma pole meie lihatootjate valikust suutnud sama maitsega toodet leida
Mingi sardell või?
Teemasse ka, ostsin Tallegi seatiibu kirsimarinaadis ja ikka maru head on
mu poole pisem teeb samasuguseid
Eriti odavam küll polnud
Aga noh, amazonis hea valik, aga siia enamus ei saadeta või siis hind taevas _________________ This message was sent from space using stargate
eraldi post boxi ostmine siia on suht kirves..... ei näinud mõtet
#letsgetfat
#indeed _________________ This message was sent from space using stargate
Mingi sardell või?
Selle loo suurem moraal on pigem see, et kui mullivesi kõrvale jätta, siis näiteks ühte Eesti parimat joogivett, Kärdla vett pakume klientidele täiesti tasuta.
Sellega seoses tuli mulle kohe meelde, et käisin reedel Virma pubis söömas ja seal ilutses menüüs "kann kraanivett 2€" _________________ This message was sent from space using stargate
see umbes nagu 2 sõpra tellivad pubis õltsi,
1 lisab et mulle paluks puhtas klaasis,
ettekandja tuleb hiljem 2 õllega - kumb teist puhtas klaasis tahtis...
Täna plaanis suitsuliha valmistamine.
Tänu öösel püütud lestadele läheb nagunii suuremaks tossutamiseks siis proovin ka liha teha.... first time in my life.
vanal heal ajal keetis vanaema soolvees ära need tükid, mis vanaisa hommikul suitsuahju pani. suitsuahi suitses hommikust õhtuni.. toore lihatükiga majandama hakkad siis varu aega.. suits peab ka soe olema. kala käib kiirelt. viina võib võtma hakata alles lõpufaasis. vanaema lõikas liha sellisteks ca kilosteks tükkideks. eelistati sellist läbikasvanud liha.
Eelmine oli naise ostetud mingi 600W mänguasi, mille mootori lasin jääkuubikutega smuutit tehes kärssama.
Mis mudeliga tegu ? Peaks omale ka vaatama ühe, aga mingite nn mänguasjadega ei viitsigi aega raisata, viimane läks külmunud maasikaid hakkides samuti kärssama ja siis lendas prügikasti
Jep, alla 1200W pole mõtet ostagi minu arvates.
Alguses oli see plaanis: https://www.amazon.co.uk/dp/B0085120T0
Mis iseenesest hea hinna/võimusese suhtega, aga leidsin 100 eur eest veel võimsama ja võtsin hoopis selle: Ambiano Professional Nutrient Power Blender
Kann on 1.8L
Ostsin siin kohalikust poest, mitte online.
See 2kW mootor teeb muidugi omajagu "heli", nii et kui hommikusmuutit teen, siis pole naisel äratuskella vaja panna lol.
Laualt lendas lina ka minema haha, teen homme video, parajalt naljakas vaatepilt.
Ahjaa.. garantii 3 aastat.
kui ma aastaid tagasi prantsusmaal olin, oli nende jaoks piim 0% fett & everlasting ning seisis kaubanduskeskuse kõige soojemas nurgas kuhu päike peale paistis.. kolmandal nädalal suutsin seda sinist ila isegi hommikul saia kõrvale juua.. _________________ Kontrollitud ja arvega sülerid: https://www.yaga.ee/mox-fulder ja https://www.facebook.com/marketplace/profile/61591165192783/?ref=permalink küsi ka akut, klaviatuuri.. kiireim viis on helistada 5213582
tegin sellel aastal kolmandat korda moosi. 1 kord: mustikamoos. pärit kesk-eesti metsadest. tuli ca 8 väikest purki. 2. kord: hiline vaarikas koos õunaga. vaarikad vorbuselt, õunad tartu linnast.. tuli 6 purki. 3: õunamoos. õunad sealt samast aiast kust eelmise moosi jaoks toodud õunad. tegemine: klassikaline puhastatud + suhkruga keedetud. kolmandat aastat olen nüüd teinud ja käärima pole ühtegi seni läinud. purkideks kasutan salvesti keeratava kaanega purke. peale täitmist keeran tagurpidi ja jahtuvad ka sedasi. _________________ Kontrollitud ja arvega sülerid: https://www.yaga.ee/mox-fulder ja https://www.facebook.com/marketplace/profile/61591165192783/?ref=permalink küsi ka akut, klaviatuuri.. kiireim viis on helistada 5213582
laurx, respekt.... et viitsid sellise mudruga mässata.
~2 nädalaga olen 4 korda suitsuahjus liha teinud. Peak kõik toodangu olen sõpradele laiali jaganud ja ohtralt kiidusõnu kuulnud.
Viimase korraga hakkasin juba ka ise vaikselt tulemusega rahule jääma.
noh.. mis seal mässata tegelikult. õunte koorimine oli.. mul oli 7,5l pott, selle puhastasin alla poole tunniga täis. südamed välja ja koorisin ära. mustikad sain puhastatud peast, hilised vaarikad on ussivabad.. purgid tasub siis ära pesta kui sisu välja võtad, on hiljem vaid vaja loputada. mulle see " ää, paneme tooreid marju sügavkülmaää " beibevärk ei istu.. need asjad kõlbavad ainult koogi sisse. teine asi, et igasugu sellised oskused on ainult boonuseks.
mul on veel 2012 aastast alles 1 purk oma marineeritud seeni. kaas kummis pole, eeldatavasti on pädev. 2013 sai maasikamoosi tehtud. see sai vedel aga maitseb hea. 2014 tegin maasikamoosi rabarberiga. nagu marjakeedis ning rabarberitükid on sees. salvestil on ka maasika - rabarberimoos aga see on selline kus 70% on rabarberit ja 30 % on maitseks maasikat. mul on vastupidi. tasakaalustab suhkru mõnusalt hapuks. ma teen päris tihti hommikuks putru, sinna peale käib või siis õhtul kaks kolm moosisaia külma piimaga.
kuidas sa nüüd oma liha teed? mingid temperatuurid ja põlemised enam-vähem käppa hakanud saama? sooja suitsuliha sibula/hapukurgi ja leivaga ning vana haljast vahele.. _________________ Kontrollitud ja arvega sülerid: https://www.yaga.ee/mox-fulder ja https://www.facebook.com/marketplace/profile/61591165192783/?ref=permalink küsi ka akut, klaviatuuri.. kiireim viis on helistada 5213582
viimati muutis laurx 05.10.2016 22:15:30, muudetud 1 kord
