uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Just5 freedom X1 märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
tont23
tont23
sõnum 31.05.2016 01:21:20 Just5 freedom X1 vasta tsitaadiga
Sai siis selline tore 5 tolline ''lätlaste'' telefon soetatud icon_smile.gif
Kõigepealt põhilised andmed:
GPRS: Yes
EDGE: Yes
WCDMA: Yes
LTE: Yes
Max download speed: HSPA 42.2Mbps, LTE CAT4 150Mbps
Max upload speed: HSPA 11.5Mbps, LTE CAT4 50Mbps
WLAN: Wi-Fi 802.11 b/g/n, Wi-Fi Direct, hotspot
Bluetooth: v4.0, A2DP, EDR, LE
USB: MicroUSB v2.0
Chipset: MTK6753, Cortex A53, 64-bit
CPU: Octa-core 1.3GHz
GPU: ARM Mali-T720 MP3 450MHz
Sensors: Light, Proximity, Accelerometer
Messaging: SMS, MMS, E-pasts
Browser: HTML5
Radio: Yes
GPS: Yes, with A-GPS
Java: Yes, via Java MIDP emulator
Video supported: 3GPP,MPEG-4,H.264.WMV9,VP9
OTG: Yes
Internal: 32 GB, 3 GB RAM
Card slot: microSD, up to 128GB
2G Network: GSM 850/900/1800 MHz
3G Networks: HSDPA 900/2100 MHz
4G Network: LTE 1800/2600/800/2100 MHz
SIM: 2 Micro-SIM, Dual Standby
põhikaamera: Samsung 3L2 16 MP, 4608*3456 pixels, autofocus, LED flash
Features: Simultaneous HD video and image recording, geo-tagging, touch focus, face/smile detection, HDR
Video: 1080p@30fps
esikaamera: 8 MP 1080p@30fps
LG IPS capacitive touchscreen, 16M colors
Resolution: HD 720x1280 pixels
Multitouch: Yes, up to 5 point
Features: On-cell, 2.5D Glass
aku: Li-poly 2800mAh, non removable, Quick charge
Stand-by: 2G up to 350h, 3G/4G up to 320h
Talk time: 2G up to 21h, 3G up to 13h
hetkel kasutanud seda ~12h ja midagi saab juba välja tuua
thumbs_up.gif 2sim kaardi pesa+mälukaardipesa
thumbs_up.gif suur aku mahutavus
thumbs_up.gif üpris hea kaamera
thumbs_up.gif hind(arvestades mälumahtu jms) -199euri
thumbs_up.gif tundub et on isegi tootetugi,lühikese kasutusaja jooksul oli 2 update-t ja peaks tulema ka 6.0.1 millalgi
thumbs_down.gif hetkel tundub et karbil lubatud kiirlaadimine pole just kiire(mingeid aegasid kuskilt välja hetkel ei loe) võrreldes oppo find 7a-ga pole see küll kiirlaadimine icon_lol.gif
thumbs_down.gif suhteliselt odav/robustne välimus
thumbs_down.gif võib vist panna pigem miinuseks et mõned kiired mängud tehes läks telefon ka üpris tuliseks,samas mäng töötas sujuvalt jne.
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 110
arny
sõnum 31.05.2016 08:14:12 vasta tsitaadiga
ise mingi aeg valisin kah selle x1 ja gigabyte guru gx vahel aga valisin siiski guru gx kuna ekraan pidavat ülevaadete põhjal parem tunduvat. Võrdlusena on guru gx käes eriti mõnus ja üli kerge tõesti, kvaliteetne tudnub samuti. Algul tundus veider, et telefoni ei olegi võimalik lahti võtta aga samas ei näe ka põhjust. Asi on mõnusalt kiire ja laadimine jääb sinna 1,5h kanti on see kiire või mitte sõltub kasutajast. Kuumaks lähevad vist kõik nutikad nii et see pole vist x1 puhul suur miinus.
sõnum 31.05.2016 08:46:07 vasta tsitaadiga
tont23, palun jälgi, et ülevaate algus oleks HV avalehel ka kenasti, praegu oli pilt selline
Tingimused:
a) Pealkiri algab "Ülevaade:"
b) Pilt (vabalt kättesaadav) peab kohe alguses olema, selle järel lühike tutvustav tekst.
Muutsin nüüd teema alguse ära.
HV valuutakalkulaator
Kommentaarid: 468 loe/lisa Kasutajad arvavad:  :: 12 :: 7 :: 359
vortex
vortex
sõnum 31.05.2016 08:58:57 vasta tsitaadiga
Kus on ülevaade?
Hetkel nääen ainult andmete listi.
Toote ülevaade/arvustus peaks olema ikka vähemalt 500-1000 sõna kogemusepõhist teksti.
Tanel, kas siin ei oleks õige koht mõelda reeglite täpsustamisele?
sõnum 31.05.2016 09:02:10 vasta tsitaadiga
vortex, võiks/peaks jah. Keegi võiks aidata kirja panna thumbs_up.gif
tont23
tont23
sõnum 31.05.2016 11:39:40 vasta tsitaadiga
vabandust....pole varem korralikku ülevaadet teinud icon_smile.gif pigem oligi see lihtsalt lühitutvustus
ptbl
ptbl
sõnum 01.06.2016 18:09:17 vasta tsitaadiga
Ostsin ka omale selle telefoni siis kui eestisse kohe müüki tuli. Kõik näitab seda, et iphone ja muu jamps on lihtsalt puhas bränd mis maksab. Kindlasti ma ei väida, et see telefon on täielikult samal tasemel aga pikemas perspektiivis kui tuleb tarkvara bugfixe siis on see telefon rohkem kui palutud.
Hetkel olen 101% rahul 199.- eurose ostuga. Isegi kui mu telefon peaks katki minema või kaduma siis mu süda ei jätaks lööke vahele mida võib juhtuda 600.- eurose telefoniga.
Ainukese miinusena tooks välja, et nad oleks võinud tarkvara natukene paremini kohandada ja ka mingeid uudiseid Android 6 kohta anda.
Aga siinkohal mõtlen, et mida ma vingun? 199.- euro eest on telefoni küll ja küll. Kui nad vaid suudaks oma võimsuse ja tarkvara sünkrooni viia siis oleks see super telefon selles hinnaklassis. Välimuse üle ka ei nurise ning ma ei peagi telefoni mingisuguseks näituste tegemiseks vaid ikkagi oma funktsionaalsuse ära kasutamiseks.
Mina isiklikult annaks siuke tugeva 8.5/10'st sellele telefonile! thumbs_up.gif
PS. ainult minu arvamus ja nägemus asjast!
viimati muutis ptbl 01.06.2016 18:18:36, muudetud 1 kord
tont23
tont23
sõnum 04.06.2016 23:49:58 vasta tsitaadiga
nõus... android 6 peaks tulema,keegi euronicsi tootejuht väitis seda thumbs_up.gif
väikeseks miinuseks võiks pidada vist seda et esiküljel puudub märguande LED...vastamata kõnede jms jaoks
aku vastupidavust on siiski kõvasti üle keskmise,2päeva suht aktiivselt kasutanud ja hetkel alles 39%
hea telefon oli suhteliselt...OLI ,st 2-3päeva sain kasutada ja pärast seda ta töölepingu lõpetaski icon_cry.gif nüüd garantiis ja eks näis mis saab...
keset laadimist/näppimist viskas ekraani mustaks ja oligi kõik,mingi nupukomboga sain küll pildi ette- fastboot-recovery-normal aga sealt edasi ei juhtunud midagi peale musta ekraani thumbs_down.gif
mmadiss
sõnum 05.08.2016 09:11:56 vasta tsitaadiga
tont23 kirjutas:
Kuu aega pärast telefoni ostmist ilmnes täpselt sama probleem. Saatsin garantiisse ja kuu aega hiljem kui telefoni kätte sain, sain telefoni kasutada ainult 1 päev ja sama probleem jätkus. Kurb
tont23
tont23
sõnum 07.08.2016 22:37:31 vasta tsitaadiga
sain enda telefoni u kuu pärast garr remonti tagasi -tehti mainboard replacing.ok,see selleks ,kuna endal oli selle aja peale juba uus telefon soetatud siis andsin naisele kasutada.umbes nädal aega(isegi varem) pärast garantiist tulekut selgus et ekraan ei pööra end...sai ka mingi äpiga proovitud ja andurit ei tuvastatud icon_neutral.gif igaljuhul telefon on paras saast ja see MTTC vms teeb kah parajat praaki jms
ei tea kas ongi enam viitsimist see jama uuesti garantiisse viia...seda enam et võtmetega vms sarnasega on ekraanile miskid kriimud tekkinud-tehakse niikunii mingi jama ära et ''a la ei kuulu garantii alla kuna kriimud ekraanil'' icon_lol.gif icon_rolleyes.gif
ImArlet
sõnum 07.11.2016 19:40:28 Android 6.0 Just5 Freedom X1 vasta tsitaadiga
http://www.needrom.com/download/just5-freedom-x1/
Siin lingil on loodetavasti Android 6.0 uuendus mis on Just5 Freedom X1 oma
Selle peab arvuti kaudu "sideloadima"
karl260
sõnum 15.11.2016 22:21:44 vasta tsitaadiga
Kui kellelgi on enda telefonist siiber: http://soov-ee.postimees.ee/596330-just-5-freedom-x1-display/details.html
Istusin enda ekraani pooleks, aga enne seda töötas suuremate viperusteta pool aastat.
tont23
tont23
sõnum 16.11.2016 00:51:05 vasta tsitaadiga
pmst on üle töökorras telefon..miskil müstilisel põhjusel ekraan ei pööra kuva
karl260
sõnum 17.11.2016 00:46:01 vasta tsitaadiga
Tahaks natuke s***mas seisukorras telefoni. muidu arvestatav pakkumine.
ImArlet
sõnum 21.11.2016 16:25:45 vasta tsitaadiga
Tervist
Kas keegi siit on võimeline tegema täieliku Tarkvara Backup-i
Tarkvarast mis tuleb seadmega kaasa ehk siis 5.1.1?
SSD
SSD
sõnum 24.11.2016 01:35:09 vasta tsitaadiga
Ostsin lapsele jõulukingiks selle telefoni. Loodan et päris kohe katki ei lähe.
Mingi kesta peaks ka juurde ostma. Oskate midagi soovitada?
Kommentaarid: 312 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 266
ptbl
ptbl
sõnum 24.11.2016 12:25:04 vasta tsitaadiga
SSD kirjutas:
Kodukalt neil on mingi kest. www.just5.com
somnambuul
sõnum 24.11.2016 16:38:40 vasta tsitaadiga
Vernee Thori kestasi võib vaadata, peaks täpselt sobima.
SSD
SSD
sõnum 24.11.2016 19:16:25 vasta tsitaadiga
ptbl kirjutas:
SSD kirjutas:
tont23
tont23
sõnum 24.11.2016 22:22:54 vasta tsitaadiga
JOKKER666
JOKKER666
sõnum 25.11.2016 12:54:51 vasta tsitaadiga
somnambuul kirjutas:
thoril on sõrmejäljelugeja - ülearune auk kestas.
Kommentaarid: 47 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
kaitsevaim
sõnum 06.12.2016 13:18:42 vasta tsitaadiga
https://pood.elisa.ee/webshop/private/device/JUST5FREEDOM
kas soovitate sellise 11 aastasele poisile kasutamiseks anda?
Kommentaarid: 28 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 22
tont23
tont23
sõnum 06.12.2016 18:31:27 vasta tsitaadiga
selle raha eest pole vast väga hullu,samas kogu see lätlaste just5 seeria suht piix kvaliteediga thumbs_down.gif vähemalt see freedom X1 küll oli
DeTHiCa.
DeTHiCa.
sõnum 20.06.2017 18:47:13 vasta tsitaadiga
kas keegi teab kedagi, kes teab kedagi, kes on kokku puutunud selle just5 hiinaime touchi vahetusega?
viimati muutis DeTHiCa. 23.08.2017 19:04:51, muudetud 1 kord
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
Märt.
Märt.
sõnum 02.08.2017 18:49:27 vasta tsitaadiga
Sõber kurtis oma fööniga (ei ole teemakohane mudel) ka sama. Lõpuks jutu käigus selgus, et ta sim ei toetagi 4G, max 3,5G.
Vaheta sim ära.
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Just5 freedom X1 mine lehele 1, 2  järgmine
