uus teema   vasta Vaidlused »  Võitlustanner »  Konsoolid vs PC märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 16, 17, 18 ... 215, 216, 217  järgmine
Millega mängid?
Ainult konsooliga
12%
 12%  [ 51 ]
Rohkem konsooli kui PC-ga
8%
 8%  [ 35 ]
50/50
5%
 5%  [ 24 ]
Rohkem PC kui konsooliga
15%
 15%  [ 65 ]
Ainult PC-ga
57%
 57%  [ 239 ]
hääli kokku : 414
tofay
sõnum 15.06.2016 17:43:54 vasta tsitaadiga
Kui see scorpio just xbox4 pole, siis tundub, et konsool kui selline, on oma mõtte kaotamas. Neo puhul peavad arendajad mängu tegemisel ka vanema PS4-ga arvestama, võimalik, et uuel xboxil sama teema. Enne mängima asumist valid vastavad sätted, et ikka jookseks..
Kommentaarid: 12 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 10
bitCON
sõnum 15.06.2016 21:04:51 vasta tsitaadiga
"[Xbox One] Scorpio is designed as a 4K console, and if you don't have a 4K TV, the benefit we've designed for, you're not going to see."
http://www.gamespot.com/articles/xbox-one-scorpio-needs-4k-tv-to-meet-full-potentia/1100-6440918/
trip
trip
sõnum 20.06.2016 14:07:31 vasta tsitaadiga
https://www.facebook.com/GamersGrottoOfficial/videos/1326611454034272/
Gap
Gap
sõnum 28.06.2016 18:51:24 vasta tsitaadiga
trip kirjutas:
Aeron
Aeron
sõnum 05.07.2016 17:41:12 vasta tsitaadiga
http://vrworld.com/2016/07/05/nvidia-gp100-titan-faster-geforce-1080/
The target is at least 50% higher performance than GeForce GTX 1080 Founders Edition, and our sources are saying they’re now bound by the CPU. Even Core i7-6950X isn’t enough to feed all the cards and in a lot of scenarios you could see an Intel Core i7-6700K, with its supreme clock (4.0 vs. 3.0 GHz) easily feed the GP100 more efficiently than Broadwell-E based Core i7 Extreme Edition. The running joke inside Nvidia is “don’t buy the 6950X – buy 6700K and a Titan” but we’re not sure that Nvidia will use this for an official tagline. Truth to be told, they might be right – we need Intel to return to the 4-core next-gen mainstream/enthusiast and then X-core big-daddy part using the same architecture, rather than the current cadence which makes sense only if you’re working for Intel. AMD’s 8-core ZEN cannot come soon enough.
Võib öelda,et ma olen liigselt enesekeskne,aga mind see ei häiri
sõnum 05.07.2016 17:49:07 vasta tsitaadiga
blablabla. see on suht tühi jutt.
loomulikult on 6700k mängudes kiirem sest mängud raiped ju ei skaleeru hunnikule tuumadele. lõimedele veel vähem. 4 tuuma ja 8 lõime on täna oluliselt mõistlikum kui 10 tuuma ja 20 lõime, eriti kui esimene neist jookseb sisuliselt 25% kiiremal taktil. vanem arhitektuur on suhteliselt non-issue siin.
- londiste
Aeron
Aeron
sõnum 05.07.2016 18:02:18 vasta tsitaadiga
Olgu kuidas on, CPU bound paistame ikka olema. Päris huvitav...
sõnum 05.07.2016 18:04:53 vasta tsitaadiga
piisava gpu jõu juures on alati ühel hetkel cpu-limited oldud.
sli/cf on seda piisavat jõudu alati lähemale toonud.
teisest küljest on 120/144hz monitorid. fps skaleerumine numbrite suurenedes läheb üldjuhul halvemaks.
optimeerimine aitab aga mitte alati. praegusest konsoolipõlvkonnast on ju näha, kus jaguar piirama hakkab ja näiteid leiab päris palju.
- londiste
sukelduja
sukelduja
sõnum 12.07.2016 07:55:15 vasta tsitaadiga
Hapukurgihooaja ergastamiseks.
http://motherboard.vice.com/read/pc-gaming-is-still-way-too-hard
NATAS999
sõnum 12.07.2016 09:35:56 vasta tsitaadiga
sukelduja kirjutas:
icon_lol.gif noo ei ole ikka nii saamatuid inimesi olemas, see raudselt mingi troll post vms. lasteaedades/sõimedes enam ammu vist järelikult pole neid püramiid/kera/kuubik värgendusi, et ei osata enam leida kahte kokku sobituvat tükki icon_lol.gif
sukelduja
sukelduja
sõnum 12.07.2016 09:47:38 vasta tsitaadiga
NATAS999 kirjutas:
sukelduja kirjutas:
Noorema generatsiooni hulgas on mehhaaniku/elektrooniku oskused räigelt allakäinud. Paljud pole kruvikeerajat elusees käes hoidnud. icon_sad.gif Selles suhtes läheneme ka meie kiiresti Lääne-Euroopale ja USAle.
sõnum 12.07.2016 13:02:04 vasta tsitaadiga
hehe, sinna need premium jupid lähevad. 200+ raha plate for no good reason. ma korralikku partslisti ei märganud aga ilmselt on neid seal veel.
manuaalide lugemise võimetus on õpitud abitus. kui ma otsisin nüüd üles ja vaatasin oma emaplaadi ja korpuse manuaali, siis neil on väga step-by-step kirjeldused kuidas ehitada.
mõlemad ta viidatud butiigid pakuvad umbestäpselt sama speciga masinat sama raha eest.
coolermaster müüb 100 raha eest korpust, millel on käsi lõigata suutvad ääred?
on jah ehitamine omajagu keeruline aga kõik ta kurtmised on kuskil wtf nurkadest.
- londiste
erick
erick
sõnum 13.07.2016 16:07:16 vasta tsitaadiga
Link
Vulkan API annab Doomis osadele AMD kaartidele ligi +50% perf boosti...
sõnum 13.07.2016 18:04:17 vasta tsitaadiga
vale teema pole? aga oleks palju rohkem muljetavaldav kui opengl all 970 fury x-iga samal tasemel ei oleks...
ainukene impressive tulemus selle video järgi on 1080p resol ka, ülejäänutes on meh.
- londiste
erick
erick
sõnum 14.07.2016 09:43:47 vasta tsitaadiga
Ei ole vist otseselt vale teema, vähemalt teoorias võiks loota sarnast perf improvementi ju ka kumbki konsool?
sõnum 15.07.2016 13:37:19 vasta tsitaadiga
miks? konsoolidel on sellised võimalused algusest peale olemas olnud ja eeldatavasti ka ära kasutatud.
doom ei ole väga nõudlik mäng, jookseb tegelikult väga hästi ka tagasihoidlikul raual.
edit:
ps4 neo info on välja ujunud.
nagu arvata oli, gpu osas uue põlve midrange kaart, ehk siis (underclockitud) rx480. cpu on kahjuks ikka see aneemiline jaguar.
NEO Hardware Spec
CPU: Uses same "Jaguar" cores as the original PlayStation®4, at higher frequency
- Original PS4: 8 cores at 1.6 GHz-
- NEO: 8 cores at 2.1 GHz (1.3x faster)
GPU: Uses improved version of AMD GCN CUs, more CUs / at higher frequency
- Original PS4: 18 CUs at 800 MHz
- NEO: 36 CUs at 911 MHz (2.3x FLOPs)
Memory: Uses same 8 GB GDDR5 as the original PlayStation4, at higher bandwidth
- Original PS4: 176 GB / s
- NEO: 218 GB / s (1.24x)
HDD: Same as original PlayStation 4
- londiste
sõnum 23.07.2016 22:37:57 vasta tsitaadiga
https://youtu.be/J8uyonbs1v0?t=2m33s
erick
erick
sõnum 25.07.2016 00:14:04 vasta tsitaadiga
mikk36, "if you really hate consoles, it's probably because you want to own a console"? See ongi siis see, mida delusional konsooliomanikud loodavad - et keegi ka salaja kadestaks nende jubedat kasutajakogemust pakkuvaid jullasid icon_biggrin.gif Unistage edasi, not gonna happen.
Mulle on isiklikult alati tundunud, et konsooliomanikud on oma karpe kuidagi tajunud staatusesümbolitena. Võibolla selle juured on 90ndates, kus konsoolid olid liiga kallid, et igaüks saaks neid endale lubada, samas kui rahhi oli siis nende kasutamine oli piisavalt lihtne, et iga ajukääbik saaks hakkama (PC'd juba nõudsid ajusid, eriti 90ndatel). Selline uusrikkurlik attitude. Aga praegu on meil aasta 2016 ja iga normaalne mänguarvuti ületab kumbagi konsooli nii võimsuses kui lifetime omamise odavuses ning tihtipeale ka kasutusmugavuses. Et sorry, faux uusrikkurid, teie PS4 impressib võibolla kellegi lapsi, aga mitte mõtlevaid täiskasvanuid.
sõnum 25.07.2016 00:50:55 vasta tsitaadiga
erick, ära muretse, video autor ei ole konsooliinimene ja konsooliversiooni Kerbalist striimis vaid seetõttu, et Squad oli selle valmis teinud. Küll aga on tore lugeda, kuidas sa kohe leili lähed ja leiad vajadust portsuga põhjuseid leida, miks ikka konsoolid kuhugi ei kõlba.
Vondur
Vondur
sõnum 25.07.2016 04:04:59 vasta tsitaadiga
mikk36 kirjutas:
Põhjusi pole vaja otsida, nad lihtsalt on... ja muide, Erick ei läinud leili, vastupidi, ta kirjutas emotsioonivabalt lahti konsoolide eksistentsi mõtte. Leili läksid hoopis sina ja reageerisid üpris valulikult ja agressiivselt! icon_smile.gif Miks? Kas sind ajab tigedaks see, et sinu teleka kõrval vedelevat staatusesümbolit ehk siis ajumahu mõõtmise aparaati ei käsitletud "staatusekohaselt"?
NATAS999
sõnum 25.07.2016 06:05:14 vasta tsitaadiga
erick, config ja autoexec failidesse paari rea ette rem kirjutada või eest ära kustutada pole ka väga suur ajugümnastika võrreldes näiteks windows10'ga, kus pead kurat teab kust, kurat teab mida taga ajama, et sellised lollused nagu lock screen ja peale winkey+nooleklahvi vajitamist mingi imeliku pläusti ära kaotada.
sõnum 25.07.2016 09:36:13 vasta tsitaadiga
Konsooli andsin vennale ära peale ~3-4 aastat niisama seismist riiulis.
Vondur
Vondur
sõnum 25.07.2016 09:38:35 vasta tsitaadiga
mikk36 kirjutas:
Miks ma inimesi lugema peaksin? Lahmin samuti nagu sina Ericku postituse puhul tegid... kas maitseb sinu enda retsept? icon_lol.gif
sõnum 25.07.2016 09:44:22 vasta tsitaadiga
Vondur, no kuule. Ma postitasin lihtsalt kergelt švipsis muidu 100% arvutite peal tööd tegeva ja mängiva isiku humoorika märkuse, ei tasu seda kohe tõsiselt võtta.
Miks sa inimesi lugema peaksid? Seda sa ju teed siin määrates mind konsooliusku inimeseks näiteks. Kiidan sind su suurepärase oskuse puhul.
Vondur
Vondur
sõnum 25.07.2016 09:50:08 vasta tsitaadiga
mikk36 kirjutas:
Tundub, et sa oledki ju konsooliusku... alateadvuses, konsoolide kapisõdur nii-öelda. icon_smile.gif Muidu sa ju Erickule sellist vastust poleks kirjutanud... näed, loengi inimesi! Ise tahtsid seda... icon_cool.gif
uus teema   vasta Vaidlused »  Võitlustanner »  Konsoolid vs PC mine lehele eelmine  1, 2, 3 ... 16, 17, 18 ... 215, 216, 217  järgmine
