"Uus disain" väietavalt. Samuti muudetakse vist saadavust paremaks.
edit:
The OnePlus 3 concept images come from Chinese technology blog Mobile-Dad and show a sleek device with an elegant, chamfered metal frame. The front camera seems to be located on the top right side, while a speaker grille comes in the middle, slightly higher than the camera module. At the bottom, the OnePlus 3 apparently features a physical home button, which should house a fingerprint sensor.
On the rear, the OnePlus 3's main camera seems to have a dual-tone LED flash. The familiar "1+" logo rests below the camera.
The OnePlus 3 further has a USB Type-C port, an alert slider and a dedicated camera button.
When it comes to hardware specifications, the OnePlus 3 is expected to sport a 5.5-inch full HD display (1,920 x 1,080 pixels), pack the latest Qualcomm Snapdragon 820 powerhouse under the hood, boast 4 GB of RAM and run Android 6 Marshmallow out of the box. The handset should also come with a 20-megapixel rear camera.
The OnePlus 3 will make its official debut in June, as OnePlus co-founder Carl Pei recently confirmed. The smartphone could cost roughly $350 unlocked.
As always, take all leaks, rumors and speculation with a grain of salt until the official announcement. In the meantime, we're still waiting for some higher-quality images to surface and offer a better look at the OnePlus 3 design.
Juba jälle uus telefonimudel. _________________ " Maailm on täis kõikvõimalike külatarkade kogukondi, kelle ühine joon on teadus- ja tõenduspõhisele elukäsitusele vastandumine."
Mis selles nii erilist on? Tänapäeval saab paljudel telefonidel erinevaid nuppe või kombinatsioone seadistada nõnda, et kaamera avaneks ja/või teeks pilti.
Küsimus ei olegi selles, et nupule saab erinevaid funktsionaalsusi määrata, vaid et lisaks kolmele-neljale nupule on olemas veel eraldi füüsiline nupp, millel on omaette põhifunktsionaalsus, ehk siis üks koht, mis teeb ainult ühte asja igal ajal. Lisaks nupu paiknemine loogilises kohas, kui pildistaja hoiab telefoni käes nagu fotoaparaati ja mis ka käitub füüsilise juhtimise poolt sellena.
Oluline neile, kes pildistavadki rohkem, kui räägivad nutiseadmega.
See eraldi füüsiline kaameranupp oli vahepeal surev nähtus, nüüd siis pannakse mõnele mudelile jälle tagasi. _________________ " Maailm on täis kõikvõimalike külatarkade kogukondi, kelle ühine joon on teadus- ja tõenduspõhisele elukäsitusele vastandumine."
SKG, mida sa mees tehnikafoorumis teed?
Ajaga tuleb kaasas käia ja silmad häbenevalt maha lüüa ülemöödunud aastase tehnika kasutamisest rääkimisel.
Kaameranupp tundub palju loogilisemal kohal olevat, nagu seda näitena mu vanal Xperia S telefonil oli. Toitenupp on lihtsalt kasutusmugavuselt vale koha peal. Aga maitse asi. _________________ " Maailm on täis kõikvõimalike külatarkade kogukondi, kelle ühine joon on teadus- ja tõenduspõhisele elukäsitusele vastandumine."
On igasuguseid lekkeid Oneplus 3 välimusest, pole kusagil confirmed, et välimus just selline on. Paljud lekked näitavad, et füüsilist home nuppu justkui poleks... Varsti tuleb, eks siis näe
Üritasin ka mingi pool tundi aga tundub, et päris otsas. Need kes said viimati on ka hädas tellimuste vormistamisega.
Edit: Tegin refresh peale seda sain carti pandud ja maksmisel oli juba otsas. Minge <b>piixu</b> tõesti
Nad tegid vea - lasid rohkem kui ühe tellida (iseasi kas läbi läheb) ning ei olnud mingit paid account piirangut (ehk kui selle kasutajaga on keegi varem neilt ostnud) - pole ime kui varsti näed mingit hiinlast ebays müümas "1000 in stock".
