Märt.
13.05.2016 15:15:22
Veider meil aadressilt service@teamviewer.com |
Selline:
Hello,
Asynchronice would like to add you as a contact in his/her TeamViewer contacts list.
To accept Asynchronice as a contact please click the following link.
_ttps://login.teamviewer.com/accountnotification.aspx?lng=&token=7cc85eac-a3a4-4adb-8131-ea439be9ce20
Regards,
Your TeamViewer Team
www.teamviewer.com
TeamViewer GmbH * Jahnstr. 30 * 73037 Göppingen * Germany
Tel. 07161 60692 50 * Fax +49 (0) 7161 60692 79
Registration AG Ulm HRB 534075 * CEO: Andreas König, CFO: Stephan Kniewasser
If you do not wish to receive this type of email from TeamViewer, please click on following link to unsubscribe:
_ttps://login.teamviewer.com/accountnotification.aspx?lng=&token=3084b72e-0558-422c-966f-443ca15af6c2
Päised:
Delivered-To: mar.xxxxxi@gmail.com
Delivered-To:xxxx@hot.ee
Received: by 10.112.198.164 with SMTP id jd4csp668066lbc; Thu, 12 May 2016 03:11:33 -0700 (PDT)
Received: by 10.25.135.8 with POP3 id j8mf27944746lfd.1; Thu, 12 May 2016 03:11:32 -0700 (PDT)
Received: from mh-front01.mgmt.hot.ee ([62.65.42.212]) by mh-repl23.mgmt.hot.ee (Dovecot) with LMTP id C7yKJ8ziGlcJCQAAyl8oFA for <udusiil@hot.ee>; Thu, 12 May 2016 12:40:54 +0300
Received: from vm-hot-relay1.estpak.ee ([62.65.42.28]) by mh-front01.mgmt.hot.ee (Dovecot) with LMTP id 6o7cNvQDK1dYBwAA4QoZ+g ; Thu, 12 May 2016 12:40:54 +0300
Received: from localhost (localhost [127.0.0.1]) by vm-hot-relay1.estpak.ee (Postfix) with ESMTP id 9A4E113C3 for <udusiil@hot.ee>; Thu, 12 May 2016 12:40:54 +0300 (EEST)
Received: from smtp-out.hot.ee ([127.0.0.1]) by localhost (vm-hot-relay1.estpak.ee [127.0.0.1]) (amavisd-new, port 10024) with ESMTP id UMvbdrcJeNaD for <udusiil@hot.ee>; Thu, 12 May 2016 12:40:54 +0300 (EEST)
Received: from mail.hot.ee (hot-mx-relayhost3.estpak.ee [213.180.2.88]) by vm-hot-relay1.estpak.ee (Postfix) with ESMTP id 40A7C1407 for <udusiil@hot.ee>; Thu, 12 May 2016 12:40:54 +0300 (EEST)
Received: from tvweb01.teamviewer.com (tvweb01.teamviewer.com [46.163.100.194]) by HOT-MX-Relayhost3.estpak.ee (Postfix) with ESMTP id E292040013 for <udusiil@hot.ee>; Thu, 12 May 2016 12:40:53 +0300 (EEST)
Received: from tvweb-clnfe03 ([46.163.100.198]) by tvweb01.teamviewer.com with Microsoft SMTPSVC(7.5.7601.17514); Thu, 12 May 2016 11:39:26 +0200
X-Received: by 10.25.196.20 with SMTP id u20mr3911487lff.164.1463047892618; Thu, 12 May 2016 03:11:32 -0700 (PDT)
Authentication-Results: mx.google.com; spf=softfail (google.com: domain of transitioning service@teamviewer.com does not designate 62.65.42.212 as permitted sender) smtp.mailfrom=service@teamviewer.com; dkim=pass (test mode) header.i=@teamviewer.com
Authentication-Results: vm-hot-relay1.estpak.ee (amavisd-new); dkim=pass (1024-bit key) header.d=teamviewer.com; domainkeys=pass (1024-bit key) header.from=service@teamviewer.com header.d=teamviewer.com
Received-SPF: softfail (google.com: domain of transitioning service@teamviewer.com does not designate 62.65.42.212 as permitted sender) client-ip=62.65.42.212;
Received-SPF: Pass (sender SPF authorized) identity=mailfrom; client-ip=46.163.100.194; helo=tvweb01.teamviewer.com; envelope-from=service@teamviewer.com; receiver=xxxx@hot.ee
X-Gmail-Fetch-Info: xxxxxx@hot.ee 1 mail.hot.ee 110 xxxxxx
Return-Path: <service@teamviewer.com>
X-Virus-Scanned: Debian amavisd-new at vm-hot-relay1.estpak.ee
X-Spam-Flag: NO
X-Spam-Score: 3.255
X-Spam-Level: ***
X-Spam-Status: No, score=3.255 tagged_above=1 required=4.96 tests=[ALL_TRUSTED=-1, AWL=0.246, DCC_CHECK=4, DKIM_SIGNED=0.1, DKIM_VALID=-0.1, DKIM_VALID_AU=-0.1, HTML_MESSAGE=0.001, MIME_HTML_ONLY=1.105, RP_MATCHES_RCVD=-0.996, SPF_PASS=-0.001] autolearn=disabled
X-SMTP-Auth-NETI-Businessmail: no
DKIM-Signature: v=1; a=rsa-sha1; c=relaxed/relaxed; s=s1024;d=teamviewer.com; h=mime-version:from:to:date:subject:content-type:message-id; bh=wbX/UaYh4kSVSTuGKL30lTEQz04=; b=UoWcDlAV9gGM4Hdq2tAUqh7q/s1JIE0tC5oCSWjMBS6TT44tiYW0iGBL6Uu35W71qOP2kRbX 1r+dNAkQo3urNjQ4Rc81Ty0qzHh8j7QgzYksRZWsvzz134lJUAUNNtQddnGZpn8KgmVbAiAj oVc59B+Zp2E69MVH8zNzT0q+iLc=
DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024;d=teamviewer.com; h=mime-version:from:to:date:subject:content-type:message-id; b=UwIKXhy5yxlf69i3sf1fBQ7E1So3Oy7hpazQiDGgI4r02PWDJbAxLB3eSYjlBMc5kF6qJ3SU 741y1qKawfosy4+UF/3EjFzLESv6LWGHAQZqKWgkD2MrAl8E48xXsLdfhldLbf5T2BmkhBVF Brf+VlDrrzg4AJiQ44qCUn9TVQ8=
To: xxxx@hot.ee
Date: 12 May 2016 11:39:27 +0200
Subject: New contact request
Message-ID: <TVWEB017ObrtBsVezJk000395c7@tvweb01.teamviewer.com>
X-OriginalArrivalTime: 12 May 2016 09:39:26.0687 (UTC) FILETIME=[2C96AEF0:01D1AC32]
MIME-Version: 1.0
Content-Type: text/html; charset=utf-8
Content-Transfer-Encoding: 8bit
Justkui õige, samas pole kunagi sealt kirju tulnud ja saatsin päringu neile kah. Seni pole vastatud.
Mis teie arvate?
_________________ Albert Einstein: "Vaid kaks asja on lõpmatud, universum ja inimlik rumalus, ja selles esimeses pole ma nii kindel."
viimati muutis Märt. 13.05.2016 17:17:16, muudetud 2 korda |
| Kommentaarid: 29 loe/lisa |
23 |
19Mart94
13.05.2016 15:27:42
"Asynchronice would like to add you as a contact in his/her TeamViewer contacts list." Ütleb juba kõike.
Mul on samuti enda TeamVieweri konto alla lisatud teised kasutajad, kelle arvutitele tarvis tavapärasest sagedamini ligi saada, kiirem, kui hakata ID-d ja parooli taga ajama iga kord. Keegi on lihtsalt sinu e-maili oma kontaktide hulka lisada tahtud. "Asynchronice" siis kontakti nimi.
| Kommentaarid: 36 loe/lisa |
34 |
Märt.
13.05.2016 16:44:50
Mul on selles listis ca paarkümmend kasutajat, ise lisatud oma konto alla. Ent eales pole saabunud sellist meili. Veider on ikkagi.
23 |
13.05.2016 16:47:57
| ignoreeri. mis seal veidrat
| Kommentaarid: 95 loe/lisa |
19Mart94
13.05.2016 16:56:09
| Märt. kirjutas: |
| Mul on selles listis ca paarkümmend kasutajat, ise lisatud oma konto alla. Ent eales pole saabunud sellist meili. Veider on ikkagi. |
Kas sina lisasid või vastupidi? See meil tuleb minuteada ainult lisatavale, mitte lisajale.
34 |
A.S.
13.05.2016 16:57:03
| Ju siis keegi tahab Märdi arvutile ligi pääseda.
| Kommentaarid: 34 loe/lisa |
34 |
Märt.
13.05.2016 17:34:28
| A.S. kirjutas: |
| Ju siis keegi tahab Märdi arvutile ligi pääseda. |
Vot selline tunne on jah.
| 19Mart94 kirjutas: |
| Märt. kirjutas: |
Kas sina lisasid või vastupidi? See meil tuleb minuteada ainult lisatavale, mitte lisajale. |
Mina ise lisan oma hallatavad masinad ja pole eales palunud end kellegi TV kontaktidesse lisada.
| Super AMOLED kirjutas: |
| ignoreeri. mis seal veidrat |
Ise ignoreeringi, aga kui see on mingi uus kurivara levitamise vorm?
Igaks juhuks annan teada ja kui ongi false positive, siis on ju tore.
23 |
Märt.
23 |
Mizz
| Kommentaarid: 135 loe/lisa |
119 |
Aista
03.06.2016 00:14:01
| Mizz kirjutas: |
| palju HVst TV kasutavad? |
Kasutan.
Endal oli eelmise aasta juuli lõpus selline intsident, et keegi oli mu arvutisse TeamVieweri abil sisse saanud (ei ole õrna aimugi kuidas, aga logide järgi hiljem nägin, et mingi võõras ID on sisse tulnud) Siis mu arvutist oli pere arvutisse TeamVieweri kaudu liigutud (parool oli TV-s salvestunud viimasest külastusest ja oma arvuti 24/7 enam-vähem sees). Igatahes paps oli pere arvutis too hetk ja kuna ma teada ei andnud, et ma tulen, siis mõne aja pärast lükkas arvuti igaks juhuks välja.
Logid jätsin alles sellest, aga väga edasi uurima ei hakanud, panin ID paroolid kõige raskema peale ainult. Proovisin võõra ID-ga arvutisse ühenduda, siis tuli TeamVieweri kastike infoga, et ma pean selle ID-ga ühendamiseks litsentsi ostma (et ei ole personaalne kasutus enam).
viimati muutis Aista 03.06.2016 00:15:27, muudetud 1 kord |
| Kommentaarid: 452 loe/lisa |
389 |
LKits
| Kommentaarid: 13 loe/lisa |
tiirP
107 |
7 :: |
364 |
Märt.
03.06.2016 10:33:28
Tegin endal siis kahetasandilise autentimise ära, kaes kuidas edasi.
23 |
LKits
tiirP
107 |
Märt.
03.06.2016 12:18:49
Läks vist lihtsalt. Vaid kahes masinas ongi autologin ja needki enamasti väljas.
Seni on rahulik.
23 |
NATAS999
03.06.2016 12:30:50
| Märt., muidugi vajuta linki. suure tõenäosusega oled võitnud 4375163usd ja kätte saamiseks tuleb linki vajutada.
| Kommentaarid: 41 loe/lisa |
39 |
Märt.
03.06.2016 14:02:40
Ei kliki lollustel. Aga kui kontosid on häkitud, tasub kahelda kõiges.
23 |
ufo56
03.06.2016 17:57:49
| Märt. kirjutas: |
| Tegin endal siis kahetasandilise autentimise ära, kaes kuidas edasi. |
Kasutajad kes on teinud 2way authi on saanud ka häkitud
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
19.07.2018 12:20:57
Tõstan vana teemat, aga endiselt on parem kasutada TeamViewerit installimata: https://0day.city/cve-2018-14333.html
| Kommentaarid: 759 loe/lisa |
569 |
LKits
Märt.
21.07.2018 09:17:18
Teine aste on ju muutuv.
23 |
ccplazza
21.07.2018 12:48:17
| Ise kasutan blacklisti võimalust. Luban arvutisse sisse logida ainult seadmetest, kus olen sisse loginud ja seadmete listi lisanud. Kui vaja keegi 3mas isik sisse lasta, siis võtan korraks maha.
| Kommentaarid: 63 loe/lisa |
59 |
napoleon
Unknown virus
21.07.2018 19:01:28
| ccplazza kirjutas: |
| Ise kasutan blacklisti võimalust. Luban arvutisse sisse logida ainult seadmetest, kus olen sisse loginud ja seadmete listi lisanud. Kui vaja keegi 3mas isik sisse lasta, siis võtan korraks maha. |
Oleme korrektsed, siis on sul whitelist
60 |
ufo56
22.07.2018 19:33:20
| LKits kirjutas: |
Ärge logige suvalistest seadmetest enda turvalistesse seadmetesse...
Või kasutage sealsest seadmest logimisel ajutist parooli, mis muutub iga disconnect korral.
See, et ajutiselt salvestatud parooli vahemälust kätte saab, ei ole kindlasti ainult TeamViewer mure, neid programme on kõvasti rohkem. |
Viimasel TW versioonil ei taha enam ajutine parool isegi muutuda.
67 |
LKits
ufo56
67 |
569 |
