praegune kellaaeg 21.11.2026 00:58:17
janeklass
08.04.2016 08:58:43
python chekkbutton |
| python:
from tkinter import * def arvuta(): T=float(mPaksus.get()) R=float(tera_R.get()) A=float(P_nurk.get()) PR=float(prisma_laius.get()) PP=float(P_pikkus.get()) K = 0.420 Pi = 3.14159 if T == 8 and R == 16 and PR == 80: #bend_allowance_valem_8_16_80() 1. null_punkt = 45 ba = Pi * (A / 180) * (R + K * T) tulemus = null_punkt - ba if A <= 55: tulemus = tulemus - 1 elif A > 55: tulemus = tulemus - 1 while PP > 700: tulemus = tulemus - 0.2 PP = PP - 500 tulemus_K=Label(myGUI,text="ALA on umbes: %.2f" % tulemus).grid(row=7,column=2) return tulemus_K def arvuta_HR(): T=float(mPaksus.get()) R=float(tera_R.get()) A=float(P_nurk.get()) PR=float(prisma_laius.get()) PP=float(P_pikkus.get()) K = 0.420 Pi = 3.14159 if T == 8 and R == 16 and PR == 80: #bend_allowance_valem_8_16_80() 1. null_punkt = 45 ba = Pi * (A / 180) * (R + K * T) tulemus = null_punkt - ba if A <= 55: tulemus = tulemus - 20 elif A > 55: tulemus = tulemus - 120 while PP > 700: tulemus = tulemus - 0.2 PP = PP - 500 tulemus_K=Label(myGUI,text="ALA on umbes: %.2f" % tulemus).grid(row=7,column=2) return tulemus_K myGUI=Tk() myGUI.geometry('400x200+100+200') myGUI.title('PainCalc') rida1=Label(myGUI,text='Materjali paksus').grid(row=0, column=0) rida2=Label(myGUI,text='Tera(R)').grid(row=1, column=0) rida3=Label(myGUI,text='Painde nurk').grid(row=2, column=0) rida4=Label(myGUI,text='Prisma').grid(row=3, column=0) rida5=Label(myGUI,text='Painde pikkus').grid(row=4, column=0) mPaksus=StringVar() tera_R=StringVar() P_nurk=StringVar() prisma_laius=StringVar() P_pikkus=StringVar() Paksus=Entry(myGUI,textvariable=mPaksus).grid(row=0,column=2) tera=Entry(myGUI,textvariable=tera_R).grid(row=1,column=2) nurk=Entry(myGUI,textvariable=P_nurk).grid(row=2,column=2) prisma=Entry(myGUI,textvariable=prisma_laius).grid(row=3,column=2) pikkus=Entry(myGUI,textvariable=P_pikkus).grid(row=4,column=2) hardox = IntVar() Checkbutton(myGUI, text="Hardox", variable=hardox).grid(row=0,column=5) rihvel = IntVar() Checkbutton(myGUI, text="Rihvel", variable=rihvel).grid(row=0, column=6) nupp1=Button(myGUI,text='Arvuta',command=arvuta).grid(row=5,column=0) myGUI.mainloop()
Tervist, nimelt olen siis värske progemise õpilane(mingi poolteist kuud õppinud). Graafilise liideseni pole tegelikult õpingutega jõudnud,aga kuna huvi on olen youtube ja google abiga midagi üritanud. Küsimus siis järgmine:
Nimelt kuidas saab teha nii,et kui chekbutton(nt koodis olev "hardox) on aktiivne siis tehakse arvutus teise funktsiooni järgi. Mul siin näites 2 funktsioni praegu arvutab nupp "arvuta" funktsiooni "arvuta" järgi ,aga oleks vaja nii,et kui on chekkbutton "hardox" aktiivne siis arvutaks nupp "arvuta" funktsiooni "arvita_HR " järgi.
Rauno266
08.04.2016 09:29:08
Isiklikult tundub kõige mõistlikum olevat hardox objekti väärtust küsida. Kui on checkitud, siis peaks olema väärtus 1 ja kui ei ole, siis väärtus 0.
if hardox.get() == 0:
nupp1 = Button(myGUI,text='Arvuta',command=arvuta).grid(row=5,column=0)
else:
nupp1 = Button(myGUI,text='Arvuta',command=arvuta_HR).grid(row=5,column=0) |
| Kommentaarid: 46 loe/lisa |
42 |
janeklass
08.04.2016 09:50:08
| Rauno266 kirjutas: |
else:
Kuidas ja kuhu see koodi tuleks mul pista? Proovisin,aga muutusi ei toimu,tulemus on sama kui on chekitud ja kui pole. Vb teen midagi valesti. Praegu sättisin selle siis nii:
hardox = IntVar()
rihvel = IntVar()
else:
myGUI.mainloop() |
08.04.2016 10:01:59
| Pead ühe lisafunktsiooni tegema, mis kutsuks siis kas arvuta või arvuta_hr välja (hetkel kutsud sa arvuta otse välja nupule vajutades). Seal kontrollid ka selle checkbuttoni väärtust.
| Kommentaarid: 85 loe/lisa |
janeklass
08.04.2016 10:53:12
| mikk36 kirjutas: |
| Pead ühe lisafunktsiooni tegema, mis kutsuks siis kas arvuta või arvuta_hr välja (hetkel kutsud sa arvuta otse välja nupule vajutades). Seal kontrollid ka selle checkbuttoni väärtust. |
Kuidas see kontrollimine käib? Ma tegin kül funktsiooni ,aga seis on sama....tulemus ei muutu. Kas ma pean selle väärtuse chekbuttonile kõigepealt andma?
08.04.2016 12:03:07
| Mis su praegune kood välja näeb?
janeklass
08.04.2016 12:19:00
| mikk36 kirjutas: |
| Mis su praegune kood välja näeb? |
Praegune kood siis selline:
def arvuta():
K = 0.420
Pi = 3.14159
null_punkt = 45
if A <= 55:
elif A > 55:
while PP > 700:
PP = PP - 500
return tulemus_K
def arvuta_HR():
K = 0.420
Pi = 3.14159
null_punkt = 45
if A <= 55:
elif A > 55:
while PP > 700:
PP = PP - 500
return tulemus_K
def cb():
else:
myGUI=Tk()
mPaksus=StringVar()
tera_R=StringVar()
P_nurk=StringVar()
hardox = IntVar()
Checkbutton(myGUI, text="Hardox", variable=hardox,).grid(row=0,column=5)
rihvel = IntVar()
nupp1 = Button(myGUI,text='Arvuta',command=cb).grid(row=5,column=0)
myGUI.mainloop() |
riaak
08.04.2016 12:23:14
Funktsioonis cb kutsu kohe õige funktsioon välja, mitte ära hakka nuppu üle kirjutama.
_________________ ¯\_(ツ)_/¯ |
105 |
janeklass
08.04.2016 12:31:25
| riaak kirjutas: |
| Funktsioonis cb kutsu kohe õige funktsioon välja, mitte ära hakka nuppu üle kirjutama. |
Tnx saingi tööle.
