Gap
12.03.2016 03:07:22
| VisaHinGG kirjutas: |
brace yourselves. pasalaine tulemas. Lugedes reviewsid, mis viimase tunni jooksul tehtud, siis enamik on negatiivsed.
| Bad Performance ... Just very bad Performance. Even hat all Graphic setups at LOW .. |
| Game crashed already.. i thought it was out of beta |
Very poor performance!
I have a GTX 770 and even with everything on minimum I get only around 30 fps. |
Unless patched, this game is unplayable. Crashed most of the time and if it did load, it had heavy graphical glitches.
Everything in this game is absolutely broken, the animations, the stealth mechanics and pc port, it is so unplayable for the moment and cant recommend anybody to buy the game unless it gets patched up
Also wtf? why is the texture quality setting locked to low if you have 2gb video ram? that is just absurd, let me have 100% control. if i want to play the game in 30 fps on ultra texture settign then let me do that.
Anyway, the content is enough for the 14 euro pricetag (for intro pack) and the gameplay feels slick, just disable all HUD and notifications and your golden good luck out there. agent 47 |
Cannot change textures...also setting in game locked to low. Ultra everything else. HOW COULD THEY #### this up?!? Scared of some VRAM managment...Sqaure Enix and IO... I expected more from you>>>
jne
well played |
Sain nüüd mängitud paar tunnikest ja ütleks et väga vägev mäng on! Jookseb paremini kui absolution ja graafika ka selline reaalsem võrreldes eelmise mänguga. Need kes räägivad et mäng ei jookse tema 3 aastat vana kaardiga millel on videomälu ainult 2GB siis peaksidki sellega arvestama et uued mängud on juba optimiseeritud DX12 jaoks ja nii vanade kaartidega ei saagi mängida kõik kellad ja viled põhjas ja nutta et miks mäng ei jookse. Vinguvad need isegi kellel on gtx970 taolised kaardid jne siis ma ei saa aru kuidas neil mäng ei jookse .... Mul ei olnud mitte mingisuguseid probleeme selle mänguga ja isegi imestasin et kuidas AMD-le optimiseeritud mäng nii hästi jookseb aga võib-olla on need probleemid siis DX12 all ? ei oska selle kohta midagi momendil öelda,eks kunagi kui saan win10 ka endale installitud eks siis peab proovima. neid steami revüüsid lugedes on tõesti täielik hämming.
| Kommentaarid: 21 loe/lisa |
17 |
Athunik
12.03.2016 03:33:58
Päris pikalt mängisin isegi. Hetkel viskas mängust välja, sest nende serverid läksid maha.
Muidu on väga kena mäng, sain isegi #7 kohale edetabelis ning suutsin unlockida omal igast pisividinaid.
Panen oma albumi ka senistest piltidest http://imgur.com/a/WLRmt
sooty
12.03.2016 16:20:00
| Athunik, always online DRM?
| Kommentaarid: 12 loe/lisa |
12 |
Athunik
12.03.2016 17:31:40
sooty, ei tea. See on mingi mõttetu hala inimeste poolt, sest seal on olemas ka offline mode ja saab ilusti mängida. Praegu inimesed nutavad iga pisikese asja peale, näiteks kui mäng puust arvutil välja ei jookse, siis kohe antakse negative review ja kui traileris oli näha W2000 snaiprit ning hetkel seda mängus pole, siis jälle nutt lahti ning negative review. Inimesed vinguvad ka iga pisikese asja peale, täiesti kohutav kommuun on Hitmanil, sest ma küll ei mäleta sellist nuttu kui Contracts või Blood Money välja tuli - kuigi mängud olid ikka üsna katki. Siin oli üks teema mingis foorumis, et üks venelane luges seda Hitmani lööklauset "Enter a World of Assassination" ning arvas, et see tähendab täieliku freeroami Pariisi peal. Inimesed ikka ei mõista seda episodic süsteemi ning ka sellepärast ajavad endal karvad turri.
Minu arvates igati tore mäng, sain just Pariisi missioonis omal mastery rank 20.
Unlockisin päris veidra välimusega relva http://i.imgur.com/irpWqbI.jpg
Scart
12.03.2016 17:52:58
| brace yourselves. pasalaine tulemas. Lugedes reviewsid, mis viimase tunni jooksul tehtud, siis enamik on negatiivsed. |
Äkki ei loeks Steami ülevaateid, mis koosnevad 99% ulatuses shitpostingust?
http://opencritic.com/game/1529/hitman
101 |
sannukas00
12.03.2016 18:18:26
| Athunik, mitte ainult Hitmani community vaid kogu PC community on kohutav. Reviewide tase läks alla igasuguse arvestuse peale seda kui valve refunde pakkuma hakkas. Varem olid negatiivsed reviewid ikka väga head ja asjalikud.
| Kommentaarid: 16 loe/lisa |
14 |
Gap
12.03.2016 18:46:30
Athunik, päris omapärane relv ennast huvitab kuidas seda meest võtta sniperiga maha nagu seal challenges seda võimalust näitab.Ise ei ole veel seda Pariisi missiooni jõudnud tegema hakata,aga täna on see plaanis.Minumeelest on väga hea mäng ja meeldib see et võimalusi on antud poole rohkem kui Absolutionis!
Scart, ma ei saa ka sellest aru.... eile huvi pärast lugesin neid steami revüüsi ja täiesti hämming oli.endal jookseb mäng väga hästi ja mingeid probleeme pole,seda muidugi DX11 all....selline jutt et mäng on cräp ja performance sitt,siis äkki on neil kes mängivad seda DX12 all ?
17 |
Athunik
12.03.2016 19:01:37
Gap, ei miskit muud kui hoia silmad lahti Vaata, kus saad natukene kõrgemale ronida ja siis avanebki hea viis vastase maha võtmiseks. Kui soovi on, siis lisa Steami - http://steamcommunity.com/id/athunik/ - võin aidata sind mõne challange juhendamisega. Ma mõndasi asju ikka päris tükk aega otsinud ning kuna mäng on alles nii uus, siis pole õpetusi ka netis.
sannukas00, nujah.. nii ta paraku on. Nendest naljakatest reviewidest ma saan veel aru, võib nagu silma kinni pigistada. Aga selline tühja lahmimine on küll paras idiootsus nagu praegu toimub.
sooty
12.03.2016 19:04:38
| Athunik kirjutas: |
| sooty, ei tea. |
Ütlesid ju, et viskas välja, sest mingid serverid tagant ära kukkusid?
12 |
VisaHinGG
12.03.2016 19:16:22
Kui osta see Hitman full expierence, siis kohe alguses kui mitu h seda gameplay-d umbes on? Mõtlen praegu, et kas võtta ligi aga nagu kuskilt loen siis prolgue + Paris episode ainilt saadaval hetkel ?
Vb saan millestki valesti aru.
| Kommentaarid: 15 loe/lisa |
15 |
Gap
12.03.2016 19:20:40
VisaHinGG, jah prologue + Paris on ainult hetkel jah,mingi aega ehk selle aasta jooksul tuleb contenti juurde. Seda saad ka eraldi osta mingi 12 euri.aga jupi kaupa ostes võib kallim tulla
Athunik, kui sobib ja tüli ei tee siis lisan kindlasti pärast
17 |
Athunik
12.03.2016 19:29:22
sooty, seal on ainult see, et kui sa tahad onlines väga mängida ja contract modei näiteks minna, siis sul on kohustatud olema internet. Kui tahad asju unlockida, siis samuti peab olema internet. Aga kui otse offline mode'i lähed, siis ei viska sind keegi välja. Niiet otseselt midagi hullu pole sellest, serverid kukuvad samuti üsna harva tagant ära. Suurema numbri teevad sellest need, kes kirjutavad neid Steami reviewsi.
Gap, aight!
VisaHinGG, see oleneb puhtalt missugune mängija sa oled. Kuna Hitman on rohkem selline mäng, kus on replay value, siis sa võid seda mängida ikka lõpmatult. Aga kui lihtsalt korra missiooni läbi teed ja mängu nurka viskad, siis teeb ehk tunniga läbi kõik prologued ja Pariisi taseme.
sooty
12.03.2016 20:07:57
| Athunik kirjutas: |
| sooty, seal on ainult see, et kui sa tahad onlines väga mängida ja contract modei näiteks minna, siis sul on kohustatud olema internet. Kui tahad asju unlockida, siis samuti peab olema internet. Aga kui otse offline mode'i lähed, siis ei viska sind keegi välja. Niiet otseselt midagi hullu pole sellest, serverid kukuvad samuti üsna harva tagant ära. Suurema numbri teevad sellest need, kes kirjutavad neid Steami reviewsi. |
Ehk siis sniper rifle'i parema scope vms (mida üldse unlockida saab?) unlockimiseks pean pidevalt online's istuma? Mitte nagu vanades mängudes, et lihtsalt 'silent assassin' või missioonide lõpetamise eest antakse võimalus osta? Või pead silmas achievemente?
12 |
Athunik
12.03.2016 20:34:10
sooty, seal pole kahjuks sellist süsteemi nagu Blood Moneys või Codename 47's. Seal on see süsteem nii üles ehitatud, et sa alustad praktiliselt tühjade kätega. Sul on ainult ICA-19 püstol, paar ülikonda, peotäis münte, fiberwire ja proximity explosive. Relvi ise customizeda ei saa, kahjuks. Selle asemel on seal mastery süsteem. Kõige suurem level mis sa saad saavutada on 20, iga leveliga sa unlockid omal uusi alustuskohti või uusi relvi. Näiteks Silverballer on unlockitav, siis Jaeger 7 snaiper on unlockitav ja igast sedative vialid jm. Ehk siis igas tasemes on omad unlockitavad asjad. Omamoodi vaheldus, aga siiski igatsen seda customizingut.
Absolutionis ma mäletan oli ka customization, aga ainult contracts mode's. Siin ma pole seda ka tähele pannud, võib-olla jäi lihtsalt kahe silma vahele.
// Aa jah, unustasin mainida kuidas mastery't saab. Mängus on igasugused challanged, näiteks kukutad millegi vastasele peale ja see annab sulle kuigi palju experience'i. Nende challange'ite tegemiseks on vaja online'i. Aga seal on ka igasuguseid teistsuguseid challangeid, mis on üpris humoorikad.
sooty
12.03.2016 20:44:10
Tänud selgituse eest. Mitte ei meeldi selline värk Kui serverid 2-3 aasta pärast maha võetakse, siis ei saagi uusi relvi unlockida?
Ehk 2017 või millal ta valmis pidigi saama, lasevad reeglid lõdvemaks.
12 |
Athunik
12.03.2016 21:16:26
sooty, see oht on igal pool. Kui Steam ära kaoks, siis sa ei näe seda mängu ennast ka.
Aga muidu suht nõme süsteem selle poolest tõesti. Samas ei teaks, et Square Enix oleks varem ühelgi mängul võtnud servereid maha. Kas neil üldse on selliseid mänge olnud, millel serverid taga?
softis
12.03.2016 21:17:48
Mäng on hästi õnnestunud. Klassikaline Hitman.
Selles mõttes võib see see esimene pakett natuke lahja tunduda, et 2 sissejuhatavat taset on üsna sellised... lambised ja võrdlemisi lihtsad võrreldes Pariisiga. Tegevust jagub aga Pariisis päris palju ja päris mitu aega kulus juba levelis niisama ringi kondamisele
Challenge'id ja võimalus-ülesanded lisavad ka sügavust korralikult sellele mängule. Contracts on veel täitsa proovimata.
Kas kuskil on mingi manual ka üleval, kust näiteks nende relvade pisiikoonide tähendust saab vaadata? Pole nagu leidnud veel kuskilt seda kohta.
Tehniliselt jookseb hästi medium-high seadetega minu kastiga. Varjudega on mingi teema, et värelevad kohati, muus osas kõik ok.
Üks asi siiski häirib - need menüü tabid laevad pilte kuidagi maru aeglaselt, kas asi on online'iga seotud nii rängalt?
21 |
Athunik
12.03.2016 23:09:01
softis
- Suppressor / Quiet, reduced range
- Extended magazine / Extra ammunition in the magazine, based on weapon type
- Steady aim / Gently squeeze the trigger to improve aim
- Scout / Can be aimed quickly, increased rate of fire
- Subsonic / Very quiet, reduced damage
- Rate of fire / Increased rate of fire
margus27
13.03.2016 00:07:54
Keegi featured contracti "Do Me I Dare You" Tren Po on saanud märkamata maha võtta? Tüüp ei liigu mingi nipiga oma nurgast välja
91 |
Athunik
13.03.2016 18:17:59
margus27, seal kus ta oma naisega seisab. Seal ees on üks tühi ruum, jäta ukse ette oma püstol ning kui ukse avad, siis tema naine läheb sellest guardile teatama. See uks, kus guard seisab, see pane samuti ennem kinni, sest see paneb mingil põhjusel ta naise läbi ukse rääkima. Löö süstlaga Tren Po'le selga ja tee minekut. Kui probleemiks on teisel pool seisev guard, siis tekita mingi lõhkeseadeldisega väike distraction. Arvatavasti üks kõige lihtsamaid contracte, aga kasuks tuli mul muidugi selline alustuskoht nagu Undercover at IAGO Auction.
Anyway, sain lõpuks kõik challanged tehtud. Nüüd prologue kui ka Paris 100% tehtud, alles on jäänud ainult need elusive targets'i ja escalation mode'i challanged. Neid samuti vaja, et ma saaks kõik achievementid kätte mängus.
margus27
13.03.2016 18:32:54
Athunik, selliselt jääb ikkagi laip näha
Lahendusena leidsin, et tühja ruumi saab naise ja Tren Po meelitada müntidega, kus saab nad siis märkamatult kõrvaldada.
91 |
Athunik
13.03.2016 18:59:04
margus27, mul sellest laibast jällegi täitsa savi Ma sain unnoticed killi kirja igatahes.
Seal enamus contracte sellised, kus sa ei saa laipa kuskile ära peita. See keda jahid on lihtsalt terve aeg rahvamassi sees.
Muidu panin tähele, et siin saab isegi Escalation'i eest väikest tasu.
Challanges - Paris - Feats
Jama ainult selles, et hetkel seda relva ei saa unlockida. Sest hetkel pole veel Pariisi jaoks Escalationi tehtud.. kahjuks.
Aga sellest võib oletada, et küllap nad plaanivad Elusive Targets'i tasuks ka anda relvi ja muid vidinaid.
// Uudis: Hitman's first Elusive Target will appear within the next 10 days
// Source: http://www.videogamer.com/ps4/hitman/news/hitmans_first_elusive_target_will_appear_within_the_next_10_days_2.html
// Nii, et õppige omale Pariisi tase selgeks. Teil on ainult üks võimalus seda elusive target'it teha.
Jewman
14.03.2016 12:14:48
Vaatan, et mängu müüakse kolmes erinevas hinnaklassis - intro pack, upgrade pack ja full experience.
Saan aru, et full experience ees makstes saad tulevikus ka kõik uued episoodid ning nende eest ei pea maksma, erinevalt Intro ja upgrade packist.
Kas peale selle on neil packidel ka mingeid sisulisi erinevusi (ala Full Experience packiga on mingid lisarelvad või muud perkid)?
sooty
14.03.2016 12:32:39
Jah, maksad teadmata sisu eest täisraha ette ära. Eraldi ostes vaevalt kallim jääb. Arvata võib, et mingi DLC vms tuleb ettemaksjatelt suurema raha meelitamiseks. Pigem võta väikese hinnaga esimene ots ära ja vaata, kas üldse uus versioon meeldib.
Mina ei ole siiani väga positiivset näinud. Always-online ja põhimõtteliselt kogu progress on nende serveris, e. singleplayer mängus kogu mängule juurdepääsu saamiseks traineri või cheatide kasutamise eest annavad äkki veel bänni või võtavad üldse juurdepääsu ära.
Ja palun mitte tuua vabanduseks ladderite jms juttu. Nende "hardcore" hitmanide pärast on kõigi casualite jaoks mäng ära piiratud. Ilma online's mängimata ei saa uut sisu avada ega juba avatud sisule juurde pääseda.
12 |
-Kaivo-
14.03.2016 14:46:33
| Mis asi see intro pack on siis ? Saad ühe missi teha ja ülejäänud kräpi saad ajajooksul ? kui võtad fulli ?
15 |
