Timberg
ööKARU
01.03.2016 18:41:41
Nii, ostsin mängu ära. Nüüd... kas keegi mängib juba kusagil serveris või plaanib kusagile minna? Kui jah siis, kuhu ja miks?
272 |
pro
01.03.2016 23:12:39
ma ostan ka homme ära siis vähemalt võiks sama serveri võtta
_________________ In game name:lusikas |
Timberg
ööKARU
01.03.2016 23:38:05
Ma pole ise veel otsustanud, millisesse serverisse lähen, kuid hetkel olen mõelnud, et ehk...
Jordine EU. Seal peaks lisaks kõigele teistele toredatele inimestele olema ka toimiv roleplay kogukond (võib olla hää vaheldus tavalisele grindile - saab metas miskete jorssidega ringi joosta ning teeselda, et oled kaktus vms).[media]
There's a post on the official forums, international/general/pvp section.
In there it gives the current updated list of guilds registered on the servers (with over 20 members in the guilds).
Alustine was decided (by the bigger community) to be Pve/casual pvp.
Jordine was decided to be hardcore pvp/competitive pvp
Croxus is a spillover of both at the moment, as it was announced only recently.
Jordine has the bigger pvp community and will be the most competitive BUT it will be a packed server.
Alustine should be more relaxed and Croxus even more so.
Takes your pic, either way there'll be competitive pvp on all and regardless, a lot (not all!) of the current big competitive guilds on Jordine are closed communities so it won't matter if they stay or go later, the game really is good enough to recoup and gain as many as what might leave even after a couple of years, it really is that good of a MMO.
Jordine has also most of PvP English speaking International guilds.
http://forum.blackdesertonline.com/index.php?/topic/20924-server-selection-and-discussion-thread/
http://bdo.guildex.org/guilds/eu/jordine
Arvan, et Jordine (palju rahvast, palju gilde)
272 |
Diesel
02.03.2016 11:02:24
| peaks vist kah ühinema - seltsis segasem.
| Kommentaarid: 37 loe/lisa |
37 |
Timberg
ööKARU
02.03.2016 11:18:21
| Diesel kirjutas: |
| peaks vist kah ühinema - seltsis segasem. |
Mängu saab praegu täitsa edukalt allalaadida ja ära installida (ise tegin eile ära), kliendi suurus ~31.9 gb.
272 |
pro
02.03.2016 11:23:26
teeme siis Jordine serverisse siis saaks midagi koos vahel teha
lazynator
02.03.2016 16:43:12
Peale avamist on need lvldamis alad vist paksult rahvast täis.
Peab parve craftima ja kalale minema kuhugile üksikule saarele 😀 senikauaks, kuni see esimene tormijooks üle on läinud.
Kellega mängima asute? Endal plaanis sorcerer ligi võtta.
_________________ el Bambito |
Diesel
02.03.2016 16:46:02
| Koread proovisin bladeriga - ilmselt võtan uuesti ligi.
37 |
Rasvane
02.03.2016 17:05:44
| Diesel kirjutas: |
| Koread proovisin bladeriga - ilmselt võtan uuesti ligi. |
Eus on minuteada ainult 6 klassi. Ninjasi Tamereid ja asju pole. Might be wrong thou. Aga ise proovisin KR's ninjat, homme eus asun vist Valkyrie kallale.
| Kommentaarid: 13 loe/lisa |
Diesel
02.03.2016 17:20:11
| Rasvane kirjutas: |
| Diesel kirjutas: |
Eus on minuteada ainult 6 klassi. Ninjasi Tamereid ja asju pole. Might be wrong thou. Aga ise proovisin KR's ninjat, homme eus asun vist Valkyrie kallale. |
Eeeh okei, Berseker siis ehk?
Loodan, et lisavad ikka tamerid ja bladerid jms ka. Meeldis just see ninja stuff...
Pole eu susteemi vaga süvenenud
37 |
Timberg
ööKARU
02.03.2016 17:22:06
| Rasvane kirjutas: |
| Diesel kirjutas: |
Launchi ajal on warrior, sorc, ranger, berserker, valykrie, wizard, teised tulevad "soonTM"
272 |
supersize
02.03.2016 18:09:59
| Timberg kirjutas: |
| Rasvane kirjutas: |
| Diesel kirjutas: |
Launchi ajal on warrior, sorc, ranger, berserker, valykrie, wizard, teised tulevad "soonTM" |
Minu meelest oli tamer ka valikute hulgas
Timberg
ööKARU
272 |
l3mpz
02.03.2016 18:49:44
Küll need klassid tulevad ajajooksul
Enamikes Korea mängudes olnud mingi vahemik kuni asi tuleb EUs
Kuidas keegi siis hetkel mängule ligi saab?
VPN koguaeg tööl?
Laggi ei ole??
| Kommentaarid: 55 loe/lisa |
49 |
pro
02.03.2016 22:03:34
Mul mäng ja vpn ostetud ööseks panen tõmbama
xarguid
OnuUno89
03.03.2016 11:18:53
Märgin teema ära. VPN teenust kasutan nagunii, aga mängu pole veel soetanud.
Kas keegi juba mängib? Kuidas on?
| Kommentaarid: 10 loe/lisa |
10 |
Dominus
03.03.2016 11:19:41
Plä, te ajate oma jutuga mind kihevile Tekib ka tahtmine uuesti proovida aga tasulise VPN-iga seekord.
Meil oli JP servus ka paar asjalikumat venda ja rääkisid miski serveri rendist EU serverite lähedal ja läbi selle seda VPNi või mingit asja teha. Ei mäleta täpselt, kuidas selle termini nimi oli aga pidavat palju parem olema.
76 |
pro
03.03.2016 12:28:12
mingi mumble või ts võiks kuskil olla kus koguneda saaks
Timberg
ööKARU
272 |
supersize
03.03.2016 16:39:19
19:30 (CET 17:30 +2)
Rasvane
03.03.2016 18:23:48
| Launcher ja Twitter räägivad 1700UTC'st. So 19:00 meie aeg. Dno kumb õige.
-Kaivo-
03.03.2016 18:30:02
Miks nad piirangu peale on pannud ? ei suuda ära hallata või suka plät ja kurwa rahva pärast ?
| Kommentaarid: 16 loe/lisa |
15 |
l3mpz
03.03.2016 19:00:14
| Regiooni piirang on sellel põhjusel, et nad müüsid õigused teatud aladele Venemaale ja nüüd ei saa neid tagasi
49 |
Rasvane
03.03.2016 19:06:20
| Igatahes nüüd on servud üleval ja lets go boys!
Diesel
03.03.2016 19:16:13
Jagage hiljem siis esimesi muljeid kah.
Ise ei saa hetkel veel ühineda.
37 |
Timberg
ööKARU
03.03.2016 22:24:58
Natuke olen saanud mängida. Töötab hästi, mängides vpniga lag silma ei hakanud, väga erinev wowist - maailm avatum jms nagu juba teame. Mäng on ka väga keeruline võrreldes wowiga Möllasin kusagil 30 minutit mängus, võitlus oli äge, aga kui aus olla, siis mängust endast veel eriti aru ei saa. Põõsastest ja puudest korjasin mingit kola, siis mingi energia sai mul otsa... ei tea, kuidas energiat juurde saada AGa kuramus, väga väga... mitmekülgne mäng. Saab lahe olema, kui lõpuks aru saan, kuidas asjad töötavad. Praegune avastamise faas on ka muhe. Mingeid õpetusi jms ei vaata hetkel.
272 |
pro
04.03.2016 00:24:54
mul ka mingit lagi pole
Levelxer
04.03.2016 12:27:14
| Metacriticus kasutajate arvamused üsna negatiivsed. A la' "usual MMORPG with better graphics". Kas on nii?
114 |
pro
04.03.2016 12:38:17
| Levelxer kirjutas: |
| Metacriticus kasutajate arvamused üsna negatiivsed. A la' "usual MMORPG with better graphics". Kas on nii? |
kui tahad proovida tasuta tõmba vene oma ja proovi
Timberg
ööKARU
04.03.2016 14:00:07
Graafika on hea, kuid tavaline... no lääneturu mõistes kindlasti mitte. Mäng erineb tõsiselt wowist, warist, aocist, starwarsi mmost jne.
272 |
ottn
04.03.2016 15:16:16
| Tellisin ka mängu ära nii et ühinene varsti Jordine serveriga. 29 eurot ei ole palju maksta terve mängu eest millel ei ole kuumaksu.
Diesel
04.03.2016 15:18:54
| ottn kirjutas: |
| Tellisin ka mängu ära nii et ühinene varsti Jordine serveriga. 29 eurot ei ole palju maksta terve mängu eest millel ei ole kuumaksu. |
Võib lisanduda kuumaks korraliku VPN näol
37 |
OnuUno89
04.03.2016 17:26:30
Muljetage siis nüüd täpsemalt.
VPN olemas, mäng olemas, aga kurat aega pole veel leidnud.
10 |
Timberg
ööKARU
04.03.2016 19:56:27
| OnuUno89 kirjutas: |
VPN olemas, mäng olemas, aga kurat aega pole veel leidnud. |
No mina isiklikult kolan praegu mängus üksinda ringi ja naudin seda tohutult, et maailm on avatud. Paistab, et xp saab igasuguse jama tegemise eest - kaevamine, kalastamine, inimestega rääkimine jne. Ütleksin, et hetkeseisuga on tegemist kõige rohkem "päris maailma" meenutava MMO'ga. On jube keeruline, aga mõnus on. Kolan siiani esimeses külas ja selle lähiümbruses, kuulan mida npc'd räägivad, ronin majade katustele ja mägedes jne.
Mäng töötab hästi, ui'l saab asju ümber tõsta... no ilmselgelt on mängus pood, kust saab ka päris raha eest asju osta. Mulle see ei meeldi otseselt, aga väga ei sega ka - kui otsest kuumaksu seetõttu maksma ei pea, siis olen õnnelik. VPN'i eest igakuisel miske 4-5€ välja köhida pole probleem (sellest mujal ka kasu).
Mis veel... tegelase loomise juures on tohutult võimalusi. Üks funktsionaalsemaid ja keerukamaid tegelase loomise süsteeme on ehitatud. Lahe iseenesest, aga esimese tegelase loomise puhul oli tüütu see, et nii palju oli võimalik tegelast muuta, aga oleks tahtnud kohe mängima hakata
PS. Ebays ostetakse guest passe. Kui tahate mängu hinda veidi alla saada, siis ebay
272 |
Scart
04.03.2016 20:35:27
| Kas VPN peab olema kogu aeg sees või ainult sisse logistades?
101 |
Rasvane
04.03.2016 21:17:32
| Scart kirjutas: |
| Kas VPN peab olema kogu aeg sees või ainult sisse logistades? |
Koguaeg.
Timberg
ööKARU
04.03.2016 21:37:24
| Scart kirjutas: |
Lülitasin vpni sisse, logisin mängu, lülitasin vpni välja, logisin tegelasega sisse.
Mäng töötas, aga sisselogides kuvati akent, kus teavitati, et mängid regioonist, kust sa ei peaks mängima (akna sai sulgeda). Ei oska öelda, kui kaua vpn väljas mängus olla saab ja kas sellele banaan ei järgne.
272 |
l3mpz
05.03.2016 08:21:09
Palju hetkel mängu hind on?
Ei raatsi hetkel hinna vaatamiseks VPNi seadistama asuda
49 |
lazynator
05.03.2016 09:55:56
| l3mpz kirjutas: |
Ei raatsi hetkel hinna vaatamiseks VPNi seadistama asuda |
30eur
Rasvane
06.03.2016 00:16:25
Keegi võiks selle guildi ka mingihetk ära teha, saaks grindikaaslasi lihtsamini sebida.
Endal siis lvl 28 Valk + 25 Sorc. Sorcerer meeldib rohkem ja ilmselt jäängi selle juurde.
Visake PM'i oma nimesid, võin listi lisada - kuigi ilge kala on sellega. Ütleb, et "not found" jne.
Timberg
ööKARU
06.03.2016 00:43:27
| Rasvane kirjutas: |
Visake PM'i oma nimesid, võin listi lisada - kuigi ilge kala on sellega. Ütleb, et "not found" jne. |
Ma paar päeva tagasi ühe eestlase lisasin, mingit kala polnud. Lisad ikka õige nime järgi?
Ütlen ausalt, mulle väga meeldib mõte Eesti gildist. Olen erinevates mängudes gildidega tõsiselt tegelenud ning neid luua aidanud. Samas küsiks nüüd inimestelt, kes on BDO'ga paremini kursis... mida antud mängus gild teeb? Mis on gildi võimalused? Mida on gildi tegemise jaoks vaja? Kas gildi puhul ei saaks mingil hetkel takistuseks see, et sellel on vähe liikmeid?
Ehk on siinkohal mõistlikum liituda mingi suurema gildiga?
272 |
Rasvane
06.03.2016 00:53:42
| Timberg kirjutas: |
| Rasvane kirjutas: |
Ehk on siinkohal mõistlikum liituda mingi suurema gildiga? |
Jep, proovisin nii family name kui ka char namega. Samamoodi prooviti mind lisada. Ei õnnestunud, peksab lihtsalt "char does not exist" optionit. Aitas see kui ma sõbraga partysse läksin ja läbi party sai lisada.
Guildi kohapeal, 100k vist oli tegemine. Mingid guildi vahelised battled on endgame poole. Rohkemaga väga kursis pole. 100k algkapitali oli vist vaja tegemiseks, peale seda oli 75k guildi raha vms.
Mõtlesin just et guild teha kuna saaks lihtsamin kõik omavahel suheldud jne. Aga võib ka mõne suuremaga liituda ofc. Samas dno mis see char limiit neil on, sest osad kes chatis recruitivad lisavad sinna taha ka juba et "x spots remaining"
Timberg
ööKARU
06.03.2016 00:55:46
Pmst... vb oleks lihtsam lihtsalt eestlastel koguneda kusagil ühes teamspeakis vms? Ja kusagile üles mingi nimekiri nendest, kes tahavad oma tegelaste nimed avaldada. Nagu öeldud, ma ei tea antud mängu gildidest midagi - las targemad otsustavad Ma hea meelega liitun mingil hetkel kaasmaalastega voicechatis ja kusagil elukaid tappes - hetkel veel kolan üksidna nuubrina ringi.
272 |
dstar
06.03.2016 16:43:31
"Some countries are excluded from the EU/NA servers due to the territory license agreement from the Russian service. Here are the countries whose IP will also be blocked:
RUSSIAN FEDERATION, ARMENIA, AZERBAIJAN, GEORGIA, KAZAKHSTAN, KYRGYZSTAN, MOLDOVA, TAJIKISTAN, TURKMENISTAN, UKRAINE AND UZBEKISTAN, LATVIA, LITHUANIA, ESTONIA, TERRITORIES WITH LIMITED STATUS ABKHAZIA AND SOUTH OSSETIA"
Venelased keerasid Balti riikidele ikka korraliku pasa kokku - julm IP blokk peale ja kõik.
Kuidas te seda üldse mängite ja ostate, kui isegi koduleheküljel vaatab vastu selline tekst: "Your country is restricted from accessing our service."
https://www.blackdesertonline.com/shop/GamePass.html
VPN on ka tasuline?
Timberg
ööKARU
06.03.2016 16:51:10
Mitmed (ka. MINA) Eesti BDO mängijad kasutavad mängimsieks Airvpni. ~4€ kuus. Ehk leiad ka mingeid tasuta lahendusi.
Kui ostad kupongiga "bvfu_10" saad hinnast natuke alla.
liituda saad siin https://airvpn.org või minu refferal lingi kaudu https://airvpn.org/?referred_by=226131
Venelased ei keeranud käru. Vene ettevõte ostis Balti regiooni õigused. Käru keerasid need, kes antud õigused müüsid.
272 |
ottn
06.03.2016 17:40:09
| Rääkige kuidas te raha teete või millele keskendute? Ja palju üldse inimestel hetkel seda mänguraha juba käes on? Ise olen enamuse rahast vist kalastades saanud ja kalade müügist. Hetkel kotis mingi 179k hõbedat. Jube palju aega läheb nende craftimise questide peale kuid samas on tore, õpetab mängu
Timberg
ööKARU
06.03.2016 18:01:56
Öö... ma tahaks teada, kuidas ma asju craftida saan Ise kolan veel selles esimeses küõlas ja püüan leida kõiki "11 tähtsad NPC'd". Kuidas ma näiteks rebase nahast või taimedest midagi teen?
272 |
lenny666
06.03.2016 19:10:24
Ma ei ole kunagi läbi VPN-i mänge mänginud. Rääkige kas see AirVPN mida siin enne mainiti on piisavalt hea kiirusega (sest nagu ma aru sain hoiate te VPN-i lahti mängides)?
Teine asi mida ma küsida tahtsin oli see, et nagu ma aru sain ostsite te €30 maksva EU versiooni ja mängite läbi VPN-i. Kas te seda ei karda, et teie konto võib ban-i mingil hetkel saada?
Küsin sellepärast, et ma leidsin ühe foorumi kus üks vend oli avanud blackdesertonline.com-is ticketi ja neilt endilt küsinud, et kas on ok VPN-iga mängida... et ei ole oht ban-i saada. Talle vastati umbes nii, et neil on litsents ainult teatud territooriumi jaoks ja nad on sunnitud ülejäänud riigid blokeerima. Et nad võivad olla tulevikus sunnitud võtma lisameetmeid kasutusele mis võib ka VPN-i kaudu ühendamise võimatuks muuta... ja sel juhul ei maksa nende poolt mingisugust supporti oodata (ega ka mängu eest raha tagasi saamist), sest VPN-i kasutamise näol on tegemist TOS punkti 3 rikkumisega (ja et nad ei taha enda ja Abyssal Games-i vahelist lepingut rikkuda... TOS 8.1).
Ehk siis teisisõnu vihjati, et hetkel nad VPN-i kasutajatega midagi ette ei võta, kuid see võib muutuda (küsimus käis küll Argentiinast NA serverisse ühendamise kohta aga arvestades, et NA ja EU mõlema publisheriks on Daum Games, siis ma pakun, et meie oleme samas seisus).
Tegelt ma võin selle GM-i vastuse ka lihtsalt siia copy-pasteda.
Since
we have no license for countries outside of the territory we cover, we
had to IP Block such countries. Players using a VPN should understand
that we may be required to implement further mechanisms in the future
that may prevent them from accessing the game even with a VPN. In such
cases, they should not expect any support from us, including the
reimbursement of the game, pursuant to the provisions of article 3 of
the Terms of Use.
Please note that a VPN is a means
to circumvent a license restriction. We do not, under any circumstances,
encourage the violation of our licensing agreement with Pearl Abyss
(the developers of the game) and of article 8.2 of our Terms of Service.
As such we do not provide any information on the use of VPN.
We
understand the disappointment of players who are unable to play and
hope we may be able to provide them Black Desert Online in the future
Rhotaaz
English Games Master
ottn
06.03.2016 19:10:31
| Timberg kirjutas: |
Öö... ma tahaks teada, kuidas ma asju craftida saan Ise kolan veel selles esimeses küõlas ja püüan leida kõiki "11 tähtsad NPC'd". Kuidas ma näiteks rebase nahast või taimedest midagi teen? |
Selles esimeses Velia linnas hakkavad ükshaaval need craftingu questid ja gathering pihta. Õnneks need questid õpetavad päris hästi.
