| Kommentaarid: 472 loe/lisa |
13 :: |
7 :: |
359 |
sooty
03.02.2016 22:54:12
Tasuta reklaam. Püramiidist huvitatuid mõjutab see uudis sama palju nagu MMS manustajaid perearsti hoiatus
| Kommentaarid: 12 loe/lisa |
12 |
Mõttetumees
04.02.2016 09:56:32
| HV s propageeris üks kasutaja antud skeemi kuid tagasi.
| Kommentaarid: 650 loe/lisa |
528 |
jnt
04.02.2016 10:30:13
Decompiled source code of Kairos Planets’ client software:
ghostbin.com/paste/vbzgm
Rentmodule.dll source code
ghostbin.com/paste/kzsq7
User “-” did some reverse engineering of Kairos klient app in Slovak forum about Kairos. His conclusions:
– App itself is harmless.
– It only pings Kairos server to count affiliate “online” time (for resources rental reward calculation)
– it checks installed/bought modules
– it gives access to affiliate’s backoffice and basic functions (like password change)
– it downloads RentModule.dll and pass control to this module (possible backdoor, depending on RentModule.dll content)
RentModule.dll does not seem to do anything really “smart”.
First of all, a source code for RentModule.dll is much smaller than for KairosPlanet.exe main file. So we cannot expect anything sophisticated and robust.
With some overhead, RentModule.dll does this:
It looks for the rented package (Silver, Platinum…). Based on the package type, it creates a hidden file “_disc” with an adequate allocated size in folder “_WinApp” on the first available hardrive with a sufficient storage space. That’s all.
The file “_disc” consumes a storage space of the user, but is not used by any other means. No sign of a distributed processing nor managing distributed storage space.
Good luck in “beta testing” of this software for affiliates!
If you open file _winApp/_disc (this supposed to be a container for Peer to Peer cloud data), you see it is absolutely empty (filled in with binary zeroes).
It’s in tune with analysis of Kairos client software, which initialize this file to size according to bought “investment package type”, but does not use it any other way.
It means one thing: promised distributed processing and cloud storage for Kairos’ corporate clients does not exist. It’s total fiction and fake. How it goes with Kairos mission statement? |
Seisab keldris vana 386-486-Pentium1? Räägime! Ehk saan vanakesele uue elu anda.
Vaata siia, äkki müün midagi põnevat -> https://www.osta.ee/index.php?fuseaction=listing.seller&q[seller]=jnt |
106 |
Pikkkõrv
04.02.2016 10:58:16
| Lollust näib olevat maailmas rohkem kui universumis tähti! Räägi inimestele kui palju tahes igasugustest kahtlastest skeemidest, selgitades sealjuures üksipulki lahti nende olemuse ja ohud kuid ikka joostakse neile nn. ülikasulikele pakkumistele karjakaupa tormi. Jutud suurest tulust oleks nagu mingi narkootikum, millest kuuldes kaob kohe viimanegi mõistus niipaljukest kui seda siis enne üldse oligi.
Chaza!
04.02.2016 11:27:02
| jnt kirjutas: |
Tänud hea info eest.
Uurisin ka hiljuti seda, kui tuttav tuli uue ja lihtsa raha teenimise võimalust pakkuma.
Tegin ka pisikese arvutuse asja tasumise/tulu kohta:
1000GB ketas = 108EURi (Võtsin kallima poolse enterprise ketta)
108/1000=0,108EURi/GB
15GB pakett = 130EURi (Ligikaudu, igasugu ülekandetasud on ka lisaks paketi hinnale)
130/15=8,667EURi/GB
8,667/0,108=80 Ehk siis Kairosele tuleb gigabaidi hind ligikaudu 80 korda kallim rentida inimese käest, kui osta see ketas ja panna tööle.
Nojah hind läheb nende jaoks kallimaks, kui serverifarmi üleval pidada vms. Aga noh ütleme, et on kallim 40x või 20x ikka on see ulme "hea" diil.
Jääb küsimus: MIKS peab keegi minu käest antud asja kallimalt ostma?
_________________ Linux - Future
viimati muutis Chaza! 04.02.2016 11:29:21, muudetud 1 kord |
| Kommentaarid: 59 loe/lisa |
53 |
hans
Nii ränk on olla.
04.02.2016 11:28:51
| Ära võta ketta hinda, võta mingi azure või amazoni storage mis on ka piisavalt odav..
80 |
UB
04.02.2016 11:29:29
| Igaühte peaks ettevaatlikuks tegema ärimudel kui küsitakse mingisuguseid summasid raha ette ning lubatakse garanteeritult jooksvat sissetulekut. Ükski normaalselt toimiv äri ei saa oma sissetulekuid garanteerida vaid need sõltuvad äri edukusest või olemasolevatest lepingutest. Stiil "korjame alguses suure raha kokku ning hakkame sulle vähehaaval tagasi maksma" ongi alati pettus.
| Kommentaarid: 45 loe/lisa |
39 |
Chaza!
04.02.2016 11:36:24
| hans kirjutas: |
| Ära võta ketta hinda, võta mingi azure või amazoni storage mis on ka piisavalt odav.. |
Amazon unlimited:
60 EURi
1000GB (Ütleme, et kasutada ~1TB ära)
60/1000=0,06EUR/GB vs 8EUR/GB Siin tuleb juba üle 100 kordne vahe. Seega võiks nagu ju otse diili teha pilveteenuse pakkujaga.
1984 was not supposed to be instruction manual |
53 |
jnt
106 |
ihvike
04.02.2016 12:32:13
| Püramiidskeemis on toode alati suitsukate. Mõnikord on need tooted ise ka midagi väärt, kuid raha teenivad skeemi tipus istujad ikka enamjaolt skeemi turustamisega. Ja see on sitt ja nõme töö, mis seisneb inimestele valetamises, sellega kaasneb sõprade-tuttavate jälestus ja sisuliselt elu ära rikkumine. Jõudu.
12 |
Lord Ami
04.02.2016 14:08:53
Nende skeemide lahtiseletamine ja igasugu linkide saatmine ei päästa mõne puhul... Ikkagi usutakse, et õhust tekib raha ja saadakse tõsiselt rikkaks... Lihtsalt niisama.
Mõne sõbra tuttavad on ka neid tahtnud konksu otsa sättida, aga õnneks on inimestel niipalju aimu, et näevad skeemi läbi. Mõnedel kahjuks mitte.
Tõsi, lühikeses plaanis võid selle raha isegi tagasi teenida ja võib-olla ka plussi jääda, aga jutt tuhandetest eurodest tulust on küll müüt.
Iga selline skeem, olgu siis Kairos või Onecoin on ühe suure puudusega: Kogu kasumit/tootlikkust ei saa korraga välja võtta. Mis sest, et arvutis ilutseb 2000 EUR, kontole sa seda kanda ei saa. Reeglina... võib ka erandeid olla. Kui seda aga teha ei saa, siis mina ei saa aru kuidas inimestel süsteemi usku on. Kui ma reaalselt selle raha olen teeninud, siis miks ma seda kõike enda kontole kanda ei saa?
Reeglina on hoopis nii, et saad mingi % kontole kanda ja siis "investeerid" ülejääva süsteemi uuesti sisse, et tootlikkus tõuseks. Aga olgem realistid, need on ainult pikslid su ekraanil.
| Kommentaarid: 57 loe/lisa |
52 |
olavsu1
külaline
04.02.2016 15:26:21
Pigem kaasneb sellega kadedus ja imetlus, kuidas küll see vend nii palju ja nii kasumlikke lolle leidis.
jnt
106 |
smurfar
04.02.2016 16:02:14
Eile just avastasin selle püramiidi, kui üks jagas FB-s postitust, kus kõigide jagajate vahel loositakse 50 euri
_________________ Parandan lõhutud küttepuid. Hind kokkuleppel |
106 |
Go Kane!
04.02.2016 16:47:45
| Lord Ami kirjutas: |
Ilmselgelt need kes toiduahela tipus on need teenivad ka. Mina jälgisin seda juba 6 kuud tagasi kui minu kunagine kooli kehalise õpetaja seda promoma hakkas. Nüüd tean väga paljusid tuttavaid kes seal sees on. Mulle on ka pähe määrida üritatud ent minu silmis tegemist ka mitte just "investeeringuna"
Väga kahtlane ettevõtmine ja olen üritanud tuttavaid ka hoiatada.
_________________ Vajad midagi Würthist , küsi julgelt 😉 https://eshop.wuerth.ee/et/EE/EUR/
taavi.jahu@wuerth.ee +37258309618 |
| Kommentaarid: 1842 loe/lisa |
1345 |
Renq
04.02.2016 19:09:01
Kas mitte delfi üks päev enne seda artiklit ei pasundanud, et pane oma kõvaketas raha teenima? keegi all kommenteeris, et püramiidiskeem ja see kommentaar laideti kohe järgmise poolt maha.
Go Kane!
04.02.2016 19:12:31
| Renq kirjutas: |
| Kas mitte delfi üks päev enne seda artiklit ei pasundanud, et pane oma kõvaketas raha teenima? keegi all kommenteeris, et püramiidiskeem ja see kommentaar laideti kohe järgmise poolt maha. |
See arktikkel võeti toopäev maha kuna mulje jöi nagu Delfi Äripäev soovitaks seda
1345 |
Forss
04.02.2016 19:38:26
| ihvike kirjutas: |
| Püramiidskeemis on toode alati suitsukate. Mõnikord on need tooted ise ka midagi väärt, kuid raha teenivad skeemi tipus istujad ikka enamjaolt skeemi turustamisega. Ja see on sitt ja nõme töö, mis seisneb inimestele valetamises, sellega kaasneb sõprade-tuttavate jälestus ja sisuliselt elu ära rikkumine. Jõudu. |
+1
Pooled siin teemas pole sellest veel aru saanud.
Muidu ei peetaks tulist arutelu kõvaketaste teemal
tonis12
04.02.2016 20:10:27
Arutatakse ühe teema üle aga samas võiks sõna võtta inimesed, kes konkreetselt on osalenud selles ettevõtmises ja räägiksid, kuidas nad sissepandud rahast ilma jäid ? Tahaks neid lugusid ka kuulda. Muidu on see lihtsalt ühekülgne arutelu 'see on kahtlane', 'see on püramiid', 'see ei saa tõsi olla' jms.
Go Kane!
04.02.2016 20:32:11
| tonis12 kirjutas: |
Arutatakse ühe teema üle aga samas võiks sõna võtta inimesed, kes konkreetselt on osalenud selles ettevõtmises ja räägiksid, kuidas nad sissepandud rahast ilma jäid ? Tahaks neid lugusid ka kuulda. Muidu on see lihtsalt ühekülgne arutelu 'see on kahtlane', 'see on püramiid', 'see ei saa tõsi olla' jms.  |
Praegu pole ilmselt veel keegi ilma jäänud. Ilmselt neid kes omadega isegi plussis.
1345 |
tonis12
04.02.2016 20:34:22
| tonis12 kirjutas: |
Muidu iseenesest üks kirjatükk siit kah : http://rahafoorum.ee/kairos-technologies-aitab-raha-teha/
riaak
04.02.2016 21:10:34
| tonis12 kirjutas: |
| Arutatakse ühe teema üle aga samas võiks sõna võtta inimesed, kes konkreetselt on osalenud selles ettevõtmises ja räägiksid, kuidas nad sissepandud rahast ilma jäid ? |
Tegu tüüpilise ponzi skeemiga, kus uute liitujate käest saadud raha kasutatakse vanadele maksmiseks.
Sellel teemal pole mõtet arutada, kes rahast ilma jäi. See aeg on ilmselt veel ees ning juhtub paugust.
Võidavad varased linnud ning omanikud, kaotavad enamus hiliseid liitujaid. Enamus siiski kaotavad, mingi ports jõuab nulli, vähesed võidavad.
Siit eelnevalt lingilt selline arvutus:
Lühidalt öeldes, et turunduskuludega ainuüksi nulli jõuda, tuleb selle 320 GB kettaruumi väljarentimise pealt teenida vähemalt $4943.06 – $5692.85 tulu. See teeb 1 GB kohta $15.45 – $17.79 aastas.
Kuna aga andmeid tuleb kopeerida samaaegselt kümnesse arvutisse, siis tegelikult kui Kairos rendib oma klientidele välja 1 GB kettaruumi, siis ta peab liikmetelt ostma vähemalt 10 GB kettaruumi ehk reaalne tulu 1 GB kohta peab olema vähemalt $154.5 – $177.9 aastas.
Võrdluseks, amazon küsib sarnase pilveteenuse eest näiteks $0.007 – $0.03 kuus 1 GB kohta esimese TB eest, suuremate mahtude puhul langeb see $0.007 – $0.0275 peale. Ühesõnaga, Amazon teenib kasumit umbes 5000+ korda madalama hinnataseme juures kui Kairose minimaalne hind, mille pealt nemad mitte midagi ei teeniks.
Kes on nõus sellist sadu või tuhandeid kordi kõrgemat hinda maksma? |
Ja alati tasub endalt küsida, et kui see tegevus nii kuradima kasulik on, siis miks nad sellega ise ei tegele ning teisi peavad moosima.
Minu tagasihoidlik pakkumine on, et lähima 6 kuu jooksul on asi uppis. Praegu tundub asi just massi koguvat. Kui nüüd tuleb massile hakata raha tagasi maksma, siis pole seda enam kusagilt võtta.
_________________ ¯\_(ツ)_/¯ |
105 |
Lord Ami
04.02.2016 22:03:16
Eelnevas lingis oli veel üks teema, millele ma enne ei mõelnudki: Kust ma seda Kairose kiidetud teenust ise osta saan (nt "oma firmale")?
Ma maksaks heameelega 320GB eest kuus 600+ dollarit, sest see on kõige mõttekam minu äri jaoks... naljatilgad ikka koos.
Hea küll, raha võid ju teenida, aga hakka mõtlema mida sa arvutisse installid, milliseid andmeid enda kohta jagad + kas reaalselt üldse mingit liiklust failide näol toimub?
Lisaks: Kui praegu toimuks klientide failide liigutamine, siis kuidas nad tagavad selle, et kliente on nii palju, et iga uus liituja saab kohe oma gigabaidid välja rentida? Ja seda täies mahus? Mitte kuidagi ei saa aru sellest. Ja kui seda ei toimu, siis mis valemiga inimesed sellega teenida saaksid? Reaalselt ju kliente pole... (tean vastust isegi - uute liitujate pealt).
Aga mõni elab selles unelmas ja mõtleb, et nii ongi õige.
52 |
Renq
04.02.2016 22:31:09
| Go Kane! kirjutas: |
| Renq kirjutas: |
See arktikkel võeti toopäev maha kuna mulje jöi nagu Delfi Äripäev soovitaks seda  |
Just seda ma mõtlesingi kui selle artikli kuskilt arhiivist kätte saaks
