maty
19.11.2015 20:20:30
Samba |
Mure selles, et enda arvutiga pääsen samba serverile ligi (st näen kaustu jms, all näitab ka online), aga teise arvutiga ei pääse ligi. Teisel arvutil värskelt reinstallitud sama OS. Kunagi ammu ühes praktikakohas sain edukalt ligi - oli Windows 7, aga ei mäleta täpselt (Home/Professional jt).
OS on Windows 7 Professional N (64 bit). Windowsis veateateks lööb 0x80070035. Seda ütleb siis kui Start - Run - \\(linux server ip) või \\(linux server ip)\martin
Proovisin ka seda, et My Computer - Map network drive - Täidan seal andmed ära + linnuke sellele, et other credentials, siis jääb küsima credentialsi (isegi kui sisestan õiged andmed)
Olen loonud sõbrale konto ja ta ei saanud samuti samba serverile ligi, tal oli Windows 7 Home (hiljem läks Windows 10-le, endiselt sama).
Samba logi ei ütle midagi (st midagi uut pole seal kirjas v.a et samba server on käivitatud)
Linux CentOS 6.7
[root@*** home]# uname -a
Linux *** 3.10.23-xxxx-std-ipv6-64 #1 SMP Tue Mar 18 14:48:24 CET 2014 x86_64 x86_64 x86_64 GNU/Linux |
Samba version 3.6.23-20.el6
smb.conf
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# For a step to step guide on installing, configuring and using samba,
# read the Samba-HOWTO-Collection. This may be obtained from:
# http://www.samba.org/samba/docs/Samba-HOWTO-Collection.pdf
# Many working examples of smb.conf files can be found in the
# Samba-Guide which is generated daily and can be downloaded from:
# http://www.samba.org/samba/docs/Samba-Guide.pdf
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not made any basic syntactic errors.
# SELINUX NOTES:
# If you want to use the useradd/groupadd family of binaries please run:
# setsebool -P samba_domain_controller on
# If you want to share home directories via samba please run:
# setsebool -P samba_enable_home_dirs on
# If you create a new directory you want to share you should mark it as
# "samba_share_t" so that selinux will let you write into it.
# Make sure not to do that on system directories as they may already have
# been marked with othe SELinux labels.
# Use ls -ldZ /path to see which context a directory has
# Set labels only on directories you created!
# To set a label use the following: chcon -t samba_share_t /path
# If you need to share a system created directory you can use one of the
# following (read-only/read-write):
# setsebool -P samba_export_all_ro on
# or
# setsebool -P samba_export_all_rw on
# If you want to run scripts (preexec/root prexec/print command/...) please
# put them into the /var/lib/samba/scripts directory so that smbd will be
# allowed to run them.
# Make sure you COPY them and not MOVE them so that the right SELinux context
# is applied, to check all is ok use restorecon -R -v /var/lib/samba/scripts
#======================= Global Settings =====================================
[global]
log file = /var/log/samba/log.%m
load printers = yes
cups options = raw
server string = Samba Server Version %v
printing = bsd
os level = 20
server signing = auto
printcap name = /dev/null
security = user
passdb backend = tdbsam
max log size = 50
# ----------------------- Network Related Options -------------------------
# workgroup = NT-Domain-Name or Workgroup-Name, eg: MIDEARTH
# server string is the equivalent of the NT Description field
# netbios name can be used to specify a server name not tied to the hostname
# Interfaces lets you configure Samba to use multiple interfaces
# If you have multiple network interfaces then you can list the ones
# you want to listen on (never omit localhost)
# Hosts Allow/Hosts Deny lets you restrict who can connect, and you can
# specifiy it as a per share option as well
; netbios name = MYSERVER
; interfaces = lo eth0 192.168.12.2/24 192.168.13.2/24
; hosts allow = 127. 192.168.12. 192.168.13.
# --------------------------- Logging Options -----------------------------
# Log File let you specify where to put logs and how to split them up.
# Max Log Size let you specify the max size log files should reach
# logs split per machine
# max 50KB per log file, then rotate
# ----------------------- Standalone Server Options ------------------------
# Scurity can be set to user, share(deprecated) or server(deprecated)
# Backend to store user information in. New installations should
# use either tdbsam or ldapsam. smbpasswd is available for backwards
# compatibility. tdbsam requires no further configuration.
security = user
# ----------------------- Domain Members Options ------------------------
# Security must be set to domain or ads
# Use the realm option only with security = ads
# Specifies the Active Directory realm the host is part of
# Use password server option only with security = server or if you can't
# use the DNS to locate Domain Controllers
# The argument list may include:
# password server = My_PDC_Name [My_BDC_Name] [My_Next_BDC_Name]
# or to auto-locate the domain controller/s
# password server = *
; security = domain
; passdb backend = tdbsam
; realm = MY_REALM
; password server = <NT-Server-Name>
# ----------------------- Domain Controller Options ------------------------
# Security must be set to user for domain controllers
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
# Domain Logons let Samba be a domain logon server for Windows workstations.
# Logon Scrpit let yuou specify a script to be run at login time on the client
# You need to provide it in a share called NETLOGON
# Logon Path let you specify where user profiles are stored (UNC path)
# Various scripts can be used on a domain controller or stand-alone
# machine to add or delete corresponding unix accounts
; security = user
; domain master = yes
; domain logons = yes
# the login script name depends on the machine name
; logon script = %m.bat
# the login script name depends on the unix user used
; logon script = %u.bat
; logon path = \\%L\Profiles\%u
# disables profiles support by specifing an empty path
; logon path =
; add user script = /usr/sbin/useradd "%u" -n -g users
; add group script = /usr/sbin/groupadd "%g"
; add machine script = /usr/sbin/useradd -n -c "Workstation (%u)" -M -d /nohome -s /bin/false "%u"
; delete user script = /usr/sbin/userdel "%u"
; delete user from group script = /usr/sbin/userdel "%u" "%g"
; delete group script = /usr/sbin/groupdel "%g"
# ----------------------- Browser Control Options ----------------------------
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
; local master = no
; os level = 33
; preferred master = yes
#----------------------------- Name Resolution -------------------------------
# Windows Internet Name Serving Support Section:
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
# - WINS Support: Tells the NMBD component of Samba to enable it's WINS Server
# - WINS Server: Tells the NMBD components of Samba to be a WINS Client
# - WINS Proxy: Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least one WINS Server on the network. The default is NO.
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups.
; wins support = yes
; wins server = w.x.y.z
; wins proxy = yes
; dns proxy = yes
# --------------------------- Printing Options -----------------------------
# Load Printers let you load automatically the list of printers rather
# than setting them up individually
# Cups Options let you pass the cups libs custom options, setting it to raw
# for example will let you use drivers on your Windows clients
# Printcap Name let you specify an alternative printcap file
# You can choose a non default printing system using the Printing option
; printcap name = /etc/printcap
#obtain list of printers automatically on SystemV
; printcap name = lpstat
; printing = cups
# --------------------------- Filesystem Options ---------------------------
# The following options can be uncommented if the filesystem supports
# Extended Attributes and they are enabled (usually by the mount option
# user_xattr). Thess options will let the admin store the DOS attributes
# in an EA and make samba not mess with the permission bits.
# Note: these options can also be set just per share, setting them in global
# makes them the default for all shares
; map archive = no
; map hidden = no
; map read only = no
; map system = no
; store dos attributes = yes
#============================ Share Definitions ==============================
[homes]
comment = Home Directories
browseable = no
writable = yes
valid users = %S
; valid users = MYDOMAIN\%S
[printers]
comment = All Printers
path = /var/spool/samba
browseable = no
guest ok = no
writable = no
printable = yes
[publik]
comment = Publik
path = /home/samba/public
guest ok = yes
writable = no
browseable = yes
public = yes
read only = yes
[martin]
comment = Martin vorguketas
path = /home/martin
writable = yes
browseable = yes
valid users = martin
[kristo]
comment = Kristo vorguketas
path = /home/kristo
writable = yes
browseable = yes
valid users = kristo
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
; comment = Network Logon Service
; path = /var/lib/samba/netlogon
; guest ok = yes
; writable = no
; share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
; [Profiles]
; path = /var/lib/samba/profiles
; browseable = no
; guest ok = yes
# A publicly accessible directory, but read only, except for people in
# the "staff" group
; [public]
; comment = Public Stuff
; path = /home/samba
; public = yes
; writable = yes
; printable = no
; write list = +staff
viimati muutis maty 19.11.2015 20:50:37, muudetud 1 kord |
| Kommentaarid: 81 loe/lisa |
69 |
DJope
19.11.2015 20:29:15
olete kõik ikka samas workgroupis?
windowsi default on WORKGROUP.
selle peaks siis smb.confi ka kirja panema:
[global]
workgroup = WORKGROUP
141 |
maty
19.11.2015 20:32:45
| DJope kirjutas: |
[global]
workgroup = WORKGROUP |
Lisasin selle viimase rea ära ja taaskäivitasin samba teenuse, proovisin uuesti - endiselt sama olukord. Neil on sama workgroup jah (vaikimisi WORKGROUP).
69 |
DJope
19.11.2015 20:41:39
| proovisid ka map network drive alt ja other credentials?
141 |
maty
19.11.2015 20:50:25
| DJope kirjutas: |
| proovisid ka map network drive alt ja other credentials? |
| maty kirjutas: |
| Proovisin ka seda, et My Computer - Map network drive - Täidan seal andmed ära + linnuke sellele, et other credentials, siis jääb küsima credentialsi (isegi kui sisestan õiged andmed) |
Proovisin uuesti... endiselt sama.
69 |
DJope
19.11.2015 22:01:38
| Mis konto sa sinna sõbrale tegid, linuxi oma ja samba oma ka?
141 |
maty
19.11.2015 22:03:26
| DJope kirjutas: |
| Mis konto sa sinna sõbrale tegid, linuxi oma ja samba oma ka? |
Linuxi ja samba oma jah.
69 |
20.11.2015 03:20:56
Samba 3 puhul tuli Windows 7 registris väike parandus teha. Samba 4 puhul, mis suudab toimida AD DC-na, pole seda enam vaja.
https://wiki.samba.org/index.php/Required_settings_for_NT4-style_domains
Ma pole kindel, kas see oli vajalik ka workgroup-i puhul, aga proovida võiks.
Lisaks võib vaadata, et NTLM ei küsiks 128-bitist krüptot:
Go to: Control Panel -> Administrative Tools -> Local Security Policy
Select: Local Policies -> Security Options
"Network security: LAN Manager authentication level" -> Send LM&NTLM use NTLMv2 session sec. if negociated
"Minimum session security for NTLM SSP" -> uncheck: Require 128-bit encryption |
Samba konfi võiks vist lisada:
client lanman auth = yes
client ntlmv2 auth = yes
lanman auth = yes
ntlm auth = yes
maty
20.11.2015 03:36:27
| Dogbert kirjutas: |
lanman auth = yes
ntlm auth = yes |
Lisasin need 4 read samba konfi ja taaskäivitasin samba teenuse, endiselt sama olukord.
Kusjuures olen selle asja ära teinud (Local Policies - Security Settings) juba ammu, see jäi tõesti esimeses postituses mainimata.
Ei tea, kas peaks laskma selle praeguse versiooniga samba maha ja paigaldama samba4 asemele? Repositoorium ütleb, et samba-le pole uusi versioone, aga uurisin yum search abiga, seal oli samba4 kirjas, mis peaks olema siis uuema versiooni oma.
Selle lingi juures..
The following error occourred attempting to join the domain „.....“:
The specified domain either does not exist or could not be contacted. |
Mul ei löö sellist veateadet, pigem seda - "file and print sharing resource (linux serveri ip) is online but isn't responding to connection attempts." (0x80070035).
"The remote computer isn't responding to connections on port 445, possibly due to firewall or security policy settings..."
Sai ka proovitud kui tulemüür oli maas, oli endiselt sama olukord.
69 |
20.11.2015 20:56:13
CMD aknast net use käsuga ühendust saada oled proovinud, kui serveri nime asemel kasutad IP-aadressi? Mis vastuseks on?
maty
20.11.2015 23:32:31
| Dogbert kirjutas: |
| CMD aknast net use käsuga ühendust saada oled proovinud, kui serveri nime asemel kasutad IP-aadressi? Mis vastuseks on? |
System error 53 has occured.
The network path cannot be found.
69 |
DJope
20.11.2015 23:47:50
| Kas linuxi kasutjal on ikka kõik õigused kaustale ligi pääsemiseks?
141 |
maty
21.11.2015 05:53:52
| DJope kirjutas: |
| Kas linuxi kasutjal on ikka kõik õigused kaustale ligi pääsemiseks? |
Ikka jah, lausa 777 chmod. Ma pääsen enda arvutiga sellele teenusele ligi, aga teis(t)e arvuti(te)ga ei pääse. Kahtlane case.
69 |
Adebisi
21.11.2015 14:33:01
| Loll küsimus aga server ping'ile ikka vastab?
| Kommentaarid: 58 loe/lisa |
55 |
maty
21.11.2015 18:13:10
| Adebisi kirjutas: |
| Loll küsimus aga server ping'ile ikka vastab? |
Vastab
69 |
Omega
21.11.2015 18:30:46
| maty kirjutas: |
| Adebisi kirjutas: |
Vastab |
Kas ka sellest masinast, mis sinna ligi ei saa?
Mis juhtub siis, kui selle mitte ligi saava masina võrguprofiiliks panna Home network ja tulemüür välja lülitada?
| Kommentaarid: 21 loe/lisa |
20 |
maty
21.11.2015 18:34:20
| Omega kirjutas: |
| maty kirjutas: |
| Adebisi kirjutas: |
Vastab |
Mis juhtub siis, kui selle mitte ligi saava masina võrguprofiiliks panna Home network ja tulemüür välja lülitada? |
Ikka, pääseb isegi veebiserverile.
Mõlematel on 'Home' võrguprofiil. Nagu ma enne mainisin, olen proovinud ka siis kui tulemüür maas oli.
69 |
22.11.2015 00:32:39
Enda arvutiga pääsed ligi ja kõik toimib? Ja teistega ei pääse?
Need teised on default seadistusega, teenuseid pole optimeeritud, võrguliidese seadetes client for ms networks pole välja lülitatud?
Proovida võid veel Windowsis võrguliidese seadetes IPv4 properties advanced seadetes WINS lehel NetBIOS lubada. Ja testimise ajal kas tulemüür maas kogu aeg või siis vaata tulemüüri inbound rules alt, et oleks lubatud "file and printer sharing" reeglid nb datagram in (UDP 138), nb name in (UDP 137), nb session in (TCP 139) ja smb in (TCP 445).
Omega
22.11.2015 01:00:32
Oled proovinud, kas see masin, mis samba sharele ligi ei saa, saab ligi windowsi masina sharele?
Võiks ka proovida turvalisuse madalamaks keeramist nagu enne soovitati:
Control Panel - Administrative Tools - Local Security Policy
Local Policies - Security Options
Send LM & NTLM responses
Disable Require 128-bit encryption
Egsa seal masinas mõni vpn-i tarkvara ei tööta?
Kas võrgukaardi seadetes on Client for Microsoft Networks ja File and Printer Sharing for Microsoft Networks olemas ja aktiivsed?
Kas võrgukaardi TCP/IP sätetes on WINS i all NetBIOS üle TCP/IP lubatud?
Kas see windowsi masin on sambaga samas võrgusegmendis? Vähemalt xp-s oli sharedele ligipääs vaikimisi piiratud ip piirkonnaga, milles see masin ise asus.
Kas see masin on võimeline nägema samba porte TCP 139,445, UDP 137,138.
Edit: ehh aeglane kirjutaja... Dogbert jõudis paari soovitusega ette
20 |
22.11.2015 13:54:40
Õigus, kindlasti proovida probleemsete Windowsi masinatega teises Windowsis jagatud kaustadele ligi pääseda. Siis on aimu, kus pool otsas viga võib olla.
Ülejäänud soovitused on teemas juba varemalt läbi käidud.
