| Kas omad relvaluba või plaanid seda teha? |
| Oman relvaluba. |
14% |
[ 24 ] |
| Ei oma relvaluba. |
27% |
[ 46 ] |
| Plaanin kunagi loa teha. |
42% |
[ 71 ] |
| Tulirelvad on kurjast! |
15% |
[ 26 ] |
| hääli kokku : 167 |
Smati
19.11.2015 23:19:19
| Kasutatakse ikka - hädakaitse piiride ületamine, jahiõnnetused jne. ÜLdiselt poodi ei röövita küll seadusliku relvaga.
| Kommentaarid: 8 loe/lisa |
Fisher
19.11.2015 23:24:14
Kopeerin siia postituse soomlaste IPSC foorumist - http://www.toiminta-ampujat.fi/phpBB/viewtopic.php?f=90&t=27537&start=1740
VERY BAD NEWS!
The proposed draft was put on the table again from the French, whom -- strong of over 130 victims -- basically pointed a gun at the European Union and said: "This has to be done, now".
From what we learned, ALL the representatives of the other EU countries voted YES -- Finland included. So whatever they are telling you now is probably a big load of bullshit.
The proposed changes could become law in LESS THAN 5 MONTHS -- even faster if there are other incidents. And if they pass, Member States will have no choice but to conform to the directive.
so the directive was already voted in favour of adoption?
The draft was proposed to the representatives of the member States -- it's a first step.
But all representatives voted YES.
Finland included.
It still has to go through a long road.
But may not be so long at all.
did this happen just now?
It happened between yesterday and today.
Our source on ALL member States representatives endorsing the proposed changes is Mr. Mauro Silvis, director of ANPAM and secretary-general of IEACS.
You MUST publish this information on Finnish forums. Alert Finnish enthusiasts. We must ACT. NOW.
Ja sama heidän sivuiltaan:
Our reporter has managed to get first-hand information from Brussels.
The proposal was made by the French Government, which has placed under moral blackmail the representatives of Europe, and was accepted unanimously. Which means that all the representatives of all the European governments have given their consent. Any politician who deny it, is lying.
The proposal to reform the EU directive could be brought in front of the European Parliament, and so become law, in less than five months. If there were any other attacks, regardless of the type of weapons used, could speed up the process. And if this happens, the member states would not have no choice but to comply.
In particular for Italy it would take us from 18 months to two years, normally, because of the feasibility studies and of those relating to the economic aspect. Unfortunately, we are sure that the current structure of government, that wants to give of himself an image and efficiency which has already expressed on the anti-gun positions, may want to press on the gas.
What is even more serious, even if the European laws and constitutions provide for the compensation for every requisition, the European Union (what is without precedent!) That the b7 -- Officials and deactivated -- Legitimately held by European citizens are confiscated immediately without compensation.
The petition that we are relaunching is just the first step. To days the Comitato Direttiva 477 Firearms United-Italia, and other bodies will give more instructions on how to support the fight!
Ehk siis selle jutu järgi korjatakse relvad kokku ilma kompensatsiooni maksmata. Kas mitte kord pole juba Eestist relvi kokku korjatud ja kuidas see lõppes? Seekord tehakse asi ära Euroopa tasandil.
65 |
rex
20.11.2015 20:00:02
| Smati kirjutas: |
| LOL. Glock 18 on täisautomaatne versioon poolautomaatsest GLock püstolist. Keelame kõik püstolid? Lauskeelamine ei ole lahendus mitte millegi puhul. |
Glock 18 on selline ükssarviku moodi elukas, mida keegi kunagi näinud ei olevat. Enamik videoid, kus Glock püstolkuulipildujana esineb, on tehtud modifitseeritud 17-ga. Kel natukenegi insenertehnilist mõtlemist, suudab igast poolautomaadist automaadi teha. Enamjaolt jääb see aga (lisaks ebaseaduslikkusele) motivatsiooni taha, sest mis sest moonast ikka raisata.
Eks nad ole hellaks tehtud ja loodavad, et saavad edaspidi igale automaadi moodi asja vilksatuse vihjele erirühma peale saata. Palju õnne, M4/M16/AR-15 imiteerivate airsoftide omanikud...
| Kommentaarid: 248 loe/lisa |
227 |
ranel
20.11.2015 21:47:06
Kaua reaalselt kulu aega relvaloa tegemiseks ? Ei pea silmas õppimist, vaid koolituste läbimist ja bürokraatiat.
165 |
rex
20.11.2015 22:39:34
| ranel kirjutas: |
| Ei pea silmas õppimist, vaid koolituste läbimist |
Mis seal koolitusel siis teha plaanid, kui mitte õppida?
Aga koolitus pole kohustuslik, võid otse eksamile minna ja kui pole enne Makaarovit käes hoidnud ega osanud arvata, et esmaabi kohta ka midagi teadma peaks, siis põruda.
Üldiselt sõltub sellest, kui kiirelt saad kätte arstitõendi, mille saamine omakorda sõltub sellest, kui kaua võtab psühhiaatri vastuvõtule saamine. Perearstil ei ole küll otsest kohustust psühhiaatrit kaasata, aga oma pe*se kaitsmiseks nad seda üldjuhul siiski teevad. Normaalkorras võib järjekord kuu kandis olla, tasulisena saab vast paari päevaga. Edasi paned end eksamile kirja. Jälle ~kuu. Väljaspool Tallinna kiirem. Võimalik veel, et ootad enne eksami aja saamist paar nädalat kohaliku pol. konstaabli kodukülastust. Vaatab, kes, kus ja mis ja teeb märkmeid. Isegi kui soov vaid ühe relva järele, mille jaoks pole raudkapp otseselt nõutav.
Fakt on, et hetkest, kui sa arvad, et sul relva relva vaja võiks minna kuni hetkeni, kui sa ta lõpuks seaduslikult kätte saad, läheb maru kaua aega. Kelle jaoks pluss, kelle jaoks miinus... Ole ettenägelik või ole ilma.
viimati muutis rex 20.11.2015 22:40:55, muudetud 1 kord |
227 |
Ragnar7474
20.11.2015 22:39:47
2a tagasi tehes kulus perearstile kirjapanekust loa kättesaamiseni kuskil 3 kuud, kiiremini ei saanud kuidagi Talliinas.
_________________ O: Kaevurikraami - Toiteplokid, riserid, emaplaadid, FAN controllerid jms
O/M: NVIDIA 10xx 20xx 30xx videokaarte. |
| Kommentaarid: 93 loe/lisa |
89 |
attrs
| Kommentaarid: 417 loe/lisa |
367 |
antikondor
20.11.2015 23:20:40
See kuradi loogika seal on ikka faking vapustav. Pandi toime rünnak, kus kasutati illegaalselt sisse smuugeldatud täisautomaatseid relvi, alustame tsiviilturul liikuvate poolautomaatide keelustamist.
Kuigi relvade deaktiveerimise standardiseerimine on isegi mõistlik osa sealt, markeeringute standardiseerimine ka.
_________________ Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer |
| Kommentaarid: 48 loe/lisa |
45 |
ranel
20.11.2015 23:26:45
| rex kirjutas: |
| ranel kirjutas: |
Fakt on, et hetkest, kui sa arvad, et sul relva relva vaja võiks minna kuni hetkeni, kui sa ta lõpuks seaduslikult kätte saad, läheb maru kaua aega. Kelle jaoks pluss, kelle jaoks miinus... Ole ettenägelik või ole ilma. |
Ei eeldagi, et õppima ei peaks. Lihtsalt üldjuhul siiamaani need avalikkusele suunatud koolitused on nii labaselt lihtsad, et ülikooli eksamitega ei saa võrreldagi, seepärast ma neid väga ei põegi.
165 |
attrs
21.11.2015 00:02:22
| antikondor kirjutas: |
Kuigi relvade deaktiveerimise standardiseerimine on isegi mõistlik osa sealt, markeeringute standardiseerimine ka. |
Rahvale vaja näidata, et näete, teeme ju midagi ja tänu sellele tulevik kõigile helgem. Enamik relvandusega kokkupuudet mitteomavatest inimestest tänab veel taevani ka.
IPSC saab lihtsalt tulevikus semi autod koos metricuga samale riiulile tõsta.
367 |
antikondor
21.11.2015 00:06:19
Näitlikuse tootmine tegeliku tegevuse asemel on üks suuremaid põhjuseid, miks reaalsed probleemid plahvatuslikult esile tulevad, lastakse lihtsalt uue tapeedi all edasi kopitada.
000 WHILE hangover
001 drink beer |
45 |
attrs
21.11.2015 00:15:58
| Aga kui läbi ja lõhki vigane toode edukalt müüb siis milleks parandada.... Poliitikule loeb vaid häältesaak ning kui 20% peale sülitamisega võidab 70% heakskiidu ei hakka keegi neist midagi päris kasulikku tegema.
367 |
Fisher
21.11.2015 00:23:25
Eesti IPSC juhatus saatis täna laiali kirja, et nad tegelevad asjaga ja informeerivad meie EU saadikuid asjast. Noh, palju usku mul sellesse pole. Õnneks on soomlased väga tagajalgadele aetud ning suur vastane on ka poola. Eesti inforuumis selle kohast infot kas pole, või kui on, siis inimesed väga ei reageeri, militaar.net foorumis on enamus arutelust.
Mul puudub kontakt jahimeeste kogukonnaga, aga loodetavasti seal suunas toimub ka midagi.
65 |
antikondor
21.11.2015 02:18:56
Sommide valitsus lasi selle asja kenasti alla, deaktiveeritud relvade nõuete standardiseerimine sai heakskiidu, muu mitte just eriti. Võimalik, et loen miskit valesti, soome keel üsna roostes https://www.eduskunta.fi/FI/vaski/Lausunto/Sivut/HaVL_15+2015.aspx
000 WHILE hangover
001 drink beer |
45 |
Fisher
21.11.2015 22:22:23
| Soomlased jah ajavad asja, aga nad on valmis ka selleks, et saavad oma reservväelaste tõttu erandi. Seljuhul on meil endiselt asi puus.
65 |
attrs
22.11.2015 00:40:02
| Jahimeestele ma väga ei panustaks, semi-auto asju selles ringkonnas vähe (põhjus lihtne, semi-auto jahirelv tohib maksimaalselt mahutada kolme padrunit. Kuni 2 salve ja 1 rauda). Isegi kui liigub mõni siis pole tegemist AR/AK vms derivaadiga. Teisisõnu, kuna neid ei puuduta, siis aktiivse kampaania peale väga ei looda. See mulje jäänud suhtlusest mõne viljandimaa omaga. Kuristiku tn seisukohta pole uurinud. IPSC foorumis asi leige. Sirvides kiirelt läbi meie esindajad EU-parlamendis ei jäänud küll silma kedagi, kes ilmselt relvade poolt võitlema hakkaks. Reformarid ja IRL tegelased pole senini millegagi silma paistnud (kõik mis sealt poolt öeldakse on täitmiseks ja mitte vastu vaidlemiseks). Sotsid varemgi relvade vastast võitlust pidanud. Tarand selline so-so kuid enamasti kuuleb temast aktiivsemalt midagi vaid enne valimisi ning Toom esindab veidi teistsugust ideoloogiat. Õnneks jah soomlased, poolakad ja sakslased pead tõstnud selle asja vastu.
367 |
Fisher
22.11.2015 10:33:52
Vepri peaks ikka jahimeeste hulgas leiduma. IPSC foorum on üldse leige koht, kus peale mõningase asjade müügi eriti midagi toimu. Küll saatis IPSC juhatus laiali vastava meili, aga sellist aktiivset tegutsemist nagu näiteks soomlastel meil ei ole.
EU esindajate kohapealt puudub mul samamoodi usk millessegi. Eks peab lootma teistele, Tšehhi ka lubab mässu, kui keegi neilt relvi korjama kavatseb hakata
65 |
antikondor
22.11.2015 11:03:21
Belglased on ka asja üsna selgesõnaliselt pikalt saatnud.
000 WHILE hangover
001 drink beer |
45 |
Fisher
25.11.2015 17:34:02
Soome ja Tšehhi on hakanud ajama seda liini, et nad saaks seadusest erandi.
Käisin täna ühest Tallinna relvapoest läbi ja tegin ka teemat müüjaga jutuks. Müüja ei osanud eriti midagi arvata, ühmas, et "jahimehi ju see ei puuduta" ning kui ütlesin, et järgmisena korjatakse neilt ära poltlukud ei tundnud ta endiselt muret, "riideid müüme ikka poes edasi".
Noojah.
Palju huvitavaid kommentaare - https://www.facebook.com/EuropeanCommission/videos/957149650999182/
65 |
sooty
25.11.2015 17:53:33
viimati muutis sooty 24.09.2018 21:47:27, muudetud 1 kord |
| Kommentaarid: 12 loe/lisa |
12 |
antikondor
25.11.2015 23:17:20
Täiesti haige hülgemöla.
000 WHILE hangover
001 drink beer |
45 |
lightbluefox
01.12.2015 14:40:37
| Keegi teab kus Tallinna lähedal odavalt püssi lasta saab, instruktori juuresolekul?
| Kommentaarid: 45 loe/lisa |
44 |
attrs
01.12.2015 14:41:53
| Odavus selline suhteline asi aga hoobilt meenub tactical shooting ja siis see tondi oma.
367 |
lightbluefox
01.12.2015 14:50:25
Surm.ee tegi veel odavamalt, 30.- 4 relva ja 25 padrunit, aga kui on veel kellelgi mingi salakoht, kuulaks huviga
44 |
Fisher
01.12.2015 15:35:09
Hea äri, võtsin suvalise TLK paketi ette, 80 eurose paketi laskemoona hind on suts alla 20 eurtsi
65 |
