| Kas Eesti peaks lähema 5-10 aasta jooksul alustama tuumajaama ehitamisega? |
| Jah |
78% |
[ 101 ] |
| Ei |
21% |
[ 28 ] |
| hääli kokku : 129 |
17.12.2013 16:50:26
ee ei saagi ju oma ettevõtmisi avalikult ja üksikasjalikult jooksvalt kajastada, see ei ole mitte kuidagi mõeldav. kui mõni neist projektidest lõpule saab, siis ilmselt tuleb ka rohkem infot.
"plekime meie kinni" on ka natukene samasse auku. iirc on ee nii öelnud kui ka aruannetes näidanud, milline osa klientidest/käibest on erakliendid ja kui suur osa kasumist sealt saadakse.
_________________ - londiste
216 |
vipu
17.12.2013 16:53:14
| Ma räägin varematest asjadest. See vimm on tekkinud väga pika ajaga. Mis puutub nendesse projektidesse, siis Ekspressi artiklite järgi pole kõik nii roosiline midagi. Suhteliselt palju on mindud ehku peale.
gemini
13.02.2014 10:12:56
link :: Funny Looking Tower Generates 600% More Electrical Energy Than Traditional Wind Turbines
This funny looking wind tower acts like a funnel, directing the wind from any angle, down through a tube to a ground based turbine generator. The funneling of the wind through a narrow passage effectively creates a “jet effect” increasing the velocity of the wind, while lowering the pressure. This is called the Venturi Effect. This speeds up the wind turbine mounted inside the narrowest portion and generates electricity.
| Kommentaarid: 75 loe/lisa |
61 |
gemini
14.02.2014 08:54:06
link :: The World's Largest Solar Plant Started Creating Electricity Today
The Ivanpah Solar Electric Generating System is now operational and delivering solar electricity to California customers. At full capacity, the facility's trio of 450-foot high towers produces a gross total of 392 megawatts (MW) of solar power, enough electricity to provide 140,000 California homes with clean energy and avoid 400,000 metric tons of carbon dioxide per year, equal to removing 72,000 vehicles off the road.
61 |
hervor
14.02.2014 09:16:21
| Kas suudad asja rajamise kulud kah välja tuua?
gemini
14.02.2014 10:31:09
| The total cost of the project is about $2.18 billion
61 |
313 |
01.05.2014 14:38:45
Jälle üks punt igiliikuri ehitajaid, kelle mootorist ja generaatorist kaadervärk suutis seekord mõne minuti töötada ja natuke valgust anda (nende oma jutu järgi), enne kui algne laeng otsa sai - nagu ka igasuguse muu "igiliikuri" puhul ikka. Paraku ei räägi keegi, kui palju see töölehakkamiseks energiat võttis.
Energia jäävuse seadus, termodünaamika - nagu hane selga vesi...
01.05.2014 15:09:57
laeng otsa sai? masin oli kogu aeg vooluvõrgus.
väide on aga jätkuvalt, et genereerib rohkem voolu kui töötamiseks sisse võtab.
tehnilistest detailidest on isegi maksnud huvilistel puudu kui otsida ja lugeda sel teemal.
tehnilisi andmeid, video juurde kasvõi mõõdetud numbreid otse loomulikult ka ei jagata - mis on automaatne red flag, et tegemist on täieliku jamaga.
216 |
01.05.2014 18:42:28
Ah nüüd on siis kohe sedamoodi liikur, et juhet ei peagi seinast ära tõmbama? On siis teiste petiste vigadest õpitud nähtavasti. Eriti hea siis ju seda demonstreerida. Tuleb vaid mõõtetulemuste koha pealt mokk maas hoida või siis mõõteseadmeid natuke tviikida ja leiad lolle kui murdu, kes seda kohe on valmis ostma. Ma ei viitsinud seda tervet lora läbi lugeda TL/DR
viimati muutis Dogbert 06.12.2015 16:33:27, muudetud 1 kord |
fallout3
01.05.2014 19:31:30
| Dogbert kirjutas: |
Energia jäävuse seadus, termodünaamika - nagu hane selga vesi...  |
Mulle meenub nagu kuskilt keskkooli füüsikatunnist see, et juba 18. sajandil loobus Prantsusmaa patendiamet või selle tollane vaste sellele vastu võtmast igiliikurite patendiavaldusi, kuna energia jäävuse seadus oli juba selleks ajaks piisavalt selge.
| Kommentaarid: 27 loe/lisa |
26 |
Kristoferr
31.10.2015 12:22:01
Väidetavalt saavad inimkonna energiavajaduse probleemid kohe kohe lahendatud. Nimelt on Keshe Foundation lõpuks välja tulnud oma pikalt arendatud plasma energiatootmise seadmega.
Sellel nädalal peeti üle interneti otseülekannetes iga päev üks õpetav loeng, seadme ehitamise ja toimimise kohta. Eile avaldati ka ametlik joonis ja õpetus.
Tehnikahuvilisele on selle seadme valmis ehitamine üsna lihtne ülesanne. Tõestus, kas see lihtne imeseade üleüldse mingil määral ka toimib on lähipäevade küsimus.
Link Keshe Foundationile, kust leiate kõik vajamineva informatsiooni.
http://www.keshefoundation.org/
PS. Loenguid jälgis igapäevaselt 7-8 tuhat inimest üle maailma.
_________________ Liitu Z.ai soodsa coding plaaniga
Liitu Wise'ga! |
216 |
7 :: |
360 |
Kristoferr
31.10.2015 12:40:28
Terve mõistuse juures, kahe jalaga maa peal olev inimene on härra Keshe ulmeliste lubaduste peale jah 99.999% skeptiline. Samas, kui vaba aega on, siis tasub tal silma peal hoida, sest on ennegi neid hulle teadlasi nähtud, kellest ideedest nende eluajal midagi head ei arvata, aga hiljem osutavad geniaalseteks.
Liitu Wise'ga! |
216 |
raxz
03.11.2015 09:09:27
| Kristoferr kirjutas: |
| PS. Loenguid jälgis igapäevaselt 7-8 tuhat inimest üle maailma. |
People are stupid...
| Kommentaarid: 46 loe/lisa |
45 |
03.11.2015 12:34:57
See mees pole teadlane vaid kõige pesuehtsam petis ja petistelt peale pettuse ei ole paraku midagi oodata.
Fukiku
03.11.2015 13:31:53
See Keshe nimi on maru tuttav. Ma peast ütleks, et see suur lahendus energiakriisile pidi välja tulema juba mitu aastat tagasi. Sai tollal ka ühe true believer'ga FB-s vaieldud selle üle. Kuna aga FB-s konkreetset postitust ja kommentaare leida on pea võimatu, siis ma ei suuda ei aega ega jutulõime vist enam hetkel leida.
_________________ Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist. |
Smati
04.12.2015 14:11:56
Noh, kas aparaat töötab?
| Kommentaarid: 8 loe/lisa |
nexus4
04.12.2015 14:20:09
| Ma ei saa sealt lehelt mitte midagi aru, keegi kes neid udujutte loeb võiks paari sõnaga selle energiavajaduse probleemi lahenduse siia kirjutada
| Kommentaarid: 29 loe/lisa |
26 |
Scart
10.12.2015 17:41:39
http://www.ipp.mpg.de/3984226/12_15
On 10th December 2015 the first helium plasma was produced in the Wendelstein 7-X fusion device at the Max Planck Institute for Plasma Physics (IPP) in Greifswald. After more than a year of technical preparations and tests, experimental operation has now commenced according to plan. Wendelstein 7-X, the world’s largest stellarator-type fusion device, will investigate the suitability of this type of device for a power station.
101 |
7 :: |
360 |
sooty
| Kommentaarid: 12 loe/lisa |
12 |
10.12.2015 19:01:22
Ma lugesin umbes kuu aega (või kaks?) tagasi sellest, see pidi siis juba käivitatama plaani kohaselt, aga mingeid uudiseid käivitamise kohta leida ei õnnestunud ega ka midagi käivitamise edasilükkamise kohta. Ilmselt siis ikkagi lükati edasi. Vägagi muljetavaldav aparaat igatahes, ma ei imestaks kui see enne ITER-it rakendust leiab ja ITER-ist ei pruugi lõpuks üldse asja saada.
Scart
101 |
Scart
101 |
