Kommentaarid: 471 loe/lisa |
12 :: |
7 :: |
359 |
25.08.2015 09:40:48
Olid ajad, olid emotsioonid.
Kommentaarid: 143 loe/lisa |
128 |
mahno
25.08.2015 12:11:03
Win 95 oli pöördeline küll, tõi ta ju masskasutusse sellise töölaua, nagu me teda suuresti siiani kasutame. Peale natukest 95 kasutamist oli 3.11 ikka tõeline kiviaeg.
Muidugi suur osa tollal välja toodud tehnilistest featuuridest imesid algul vilinal - olgu siis USB (useless serial bus - ei olnud algses väljalaskes sees ) või PnP (plug and prey )tugi, mis oli paras nikastus ja lihtsam oli jumperitega seaded paika panna.
Kommentaarid: 23 loe/lisa |
21 |
Equinox
25.08.2015 18:12:19
Kui mälu ei peta siis vist isegi esimene Direct X tuli hiljem järgi mitte kohe Win95 launchiga.
_________________ Live long and prosper!
RIP, Spock. Leonard Nimoy 1931-2015 |
Kommentaarid: 27 loe/lisa |
26 |
25.08.2015 18:14:21
Equinox, nii on
https://en.wikipedia.org/wiki/DirectX#Development_history
tsitaat: |
The first version of DirectX was released in September 1995 as the Windows Games SDK. It was the Win32 replacement for the DCI[4] and WinG APIs for Windows 3.1. DirectX allowed all versions of Microsoft Windows, starting with Windows 95, to incorporate high-performance multimedia. Eisler wrote about the frenzy to build DirectX 1 through 5 in his blog.[5]
Initial adoption of DirectX by game developers was slow.[6] There were fears that DirectX could be replaced as WinG had been, there was a performance penalty in using Windows over DOS, and there were many die-hard DOS programmers.[6]
DirectX 2.0 became a component of Windows itself with the releases of Windows 95 OSR2 and Windows NT 4.0 in mid-1996. |
HV valuutakalkulaator |
12 :: |
7 :: |
359 |
voime
26.08.2015 09:23:24
Esimeses windowsis olid eesti kuude nimed ka valesti, kuna sisestajal oli vasak käsi vale koha peal.
olavsu1
külaline
26.08.2015 10:23:38
ja peale IE eemaldamist jäi järgi Win3.11
jnt
Kommentaarid: 111 loe/lisa |
103 |
olavsu1
külaline
26.08.2015 11:43:02
jnt kirjutas: |
olavsu1, esimesel win95'el polnudki vist ie'd kaasas... |
oli küll.. failibrauser avas ka veebilehti. millegagi tuli netscape alla tirida.
jnt
103 |
olavsu1
külaline
26.08.2015 12:34:24
Võimalik aga win98 nimelist asja pole mul kunagi olnud. Korra olen näinud, tundus fuihh olema. Mul olid win 95 (osr?) , winME, wind2k.sp4
siiski IE eemaldamisel nägi liides välja kui 3.11 ja veel ürgsemgi kui ma teda kooliajast mäletan.
jnt
103 |
Nipi1000
26.08.2015 13:09:09
jägaja kirjutas: |
Olid ajad, olid emotsioonid. |
ohjaa, mäletan suht hästi seda pettumust, kui peale installi otse windowsi laeti...esimeseks tegevuseks tuli kohe uninstall ja vana hea dos koos nortoniga oli jälle ees
Kommentaarid: 21 loe/lisa |
20 |
26.08.2015 13:11:12
Naljakas oli see arvuti väljalülitamine. Esimesed nädalad ei pannud Start menüüs tähelegi sellist asja nagu shut down valik... sai lihtsalt vanal moel niisama välja lülitatud nagu enne dos'i ajastul. 3.11 mul ei olnudki au kasutada.
Kommentaarid: 92 loe/lisa |
79 |
olavsu1
külaline
26.08.2015 14:28:06
jnt, ehh. kui ise poleks teinud siis ei usuks. Kuskilt netist leitud juhendi järgi sai tegutsetud.. tulemus oli suur tumesinine ekraan, kus vasakus alumises nurgas üks ainuke grupiikoon. kaks klõpsu sellel, tuli aken, mis polnud enam win95 aknadisainiga vaid win3.11 selles aknas olid omakorda grupiikoonid. mis aknahalduri ta mulle ette viskas?
samasuguse ikooniga rakendus on isegi win7 sees olemas. grpconv.exe
jnt
26.08.2015 14:32:01
olavsu1, progman.exe on ta vanades windowsites.
Aga kui sa ise windoozale just vana shelli peale ei ajanud, siis... ei, sa ajad midagi sassi. Win95'es pole win3.1 shelli kunagi olnud.
Kui win95 väga hapuks läks, oli võimalik, et taskbar jooksis kokku ja avatud programmid olid minimeeritult nagu start ribalgi, kuid üksteise otsas alt vasakult nurgast alates ilma taskbar'i endata. Win95 desktop ei ole võimeline näitama töötavate programmide ikoone nii, nagu seda win3.1 shell tegi.
Kõige vähem on kogu see teema seotud IE'ga.
Sa ajad miskit sassi. Vaata googlest erinevaid pilte ja tuleta meelde, mis reaalselt toimus. Ilmselt oli sul win95 + IE4 koos desktop update'iga, mis tegi ta win98 sarnaseks. Lastes IE maha, said endale "originaal" win95'e.
Seisab keldris vana 386-486-Pentium1? Räägime! Ehk saan vanakesele uue elu anda.
Vaata siia, äkki müün midagi põnevat -> https://www.osta.ee/index.php?fuseaction=listing.seller&q[seller]=jnt |
103 |
Nipi1000
26.08.2015 14:43:53
olen samuti kunagi ammu muutnud windows 95 desktopi välimuse samasuguseks nagu win 3.11 oli, et kindlasti on see võimalik...kuidas see täpselt käis, vot ei mäleta ja google kiirelt infot ka ei andnud...
20 |
jnt
103 |
sannu
26.08.2015 15:11:24
Kas tegemist ei võinud olla millegi taolisega:
Kommentaarid: 1 loe/lisa |
olavsu1
külaline
26.08.2015 15:17:47
jnt, kuule sa ajad ise midagi segi. IE oli väga sügavalt süsteemi ehitatud, failbrauser on ka IE. ja kui IE täielikult eemaldada, koos kõigega mille nimes "explorer", siis kaob failibrauser ka. mis järgi jääb?
tsitaat: |
mina ei paigaldanud midagi. C:\windows\system32 kaustas oli/on igasugu asju.
sannu kirjutas: |
sarnane, ainult selle vahega, et mul läksid akende elemedid (minimize, maximize, close) ka selliseks nagu win3.11 olid.
viimati muutis olavsu1 26.08.2015 15:31:16, muudetud 1 kord |
jnt
103 |
Nipi1000
26.08.2015 15:22:25
tsitaat: |
To use Program Manager as the shell in Windows, follow these steps:
Click the Start button, and then click Run.
Type system.ini in the Open box, and then click OK.
Locate the line that reads "shell=Explorer.exe," and then place a semicolon ( at the beginning of the line to disable the line.
Add the following line beneath the line you disabled in step 3:
shell=Progman.exe
Save and then close the System.ini file.
Shut down and then restart Windows 95/98. |
midagi leidsin, arvatavasti miskit sellist sai jah tehtud, ehk siis kasutatud lihtsalt progman'i shellina
ps. njah, sama mis see youtube video
20 |
26.08.2015 18:29:55
Ühesõnaga, siit me loeme, et inimene on oma harjumuste ori.
Tuleb uus programm siis tahetakse seda saada. Omades aga tahetakse minna tagasi keskkonda, nagu see vanasti oli.
Iga windowsi versiooniga on sama asi, tahan oma vana windowsi tagasi
128 |
olavsu1
külaline
27.08.2015 01:18:12
jägaja kirjutas: |
Iga windowsi versiooniga on sama asi, tahan oma vana windowsi tagasi  |
see päris nii ei olnud. see oli kunagine võitlus IE kui sellise vastu. milleks teda enam kui FF on alla laetud.
praegugi on IE vajalik vaid tulirebase allalaadimiseks. XP ja vanemate windowsite peal käisid uuendised ka IE kaudu.
degreal
27.08.2015 01:40:21
Nipi1000 kirjutas: |
jägaja kirjutas: |
ohjaa, mäletan suht hästi seda pettumust, kui peale installi otse windowsi laeti...esimeseks tegevuseks tuli kohe uninstall ja vana hea dos koos nortoniga oli jälle ees  |
Sama lugu siin, Win 95-st polnud vastast Norton Commanderile ja DOS-i käsureale . Alles Win 98 oli see, millest midagi kasu ka oli.
Kommentaarid: 26 loe/lisa |
24 |
