HDTanel
Overclocker
23.03.2004 05:57:26
Jeah jõudsin 16. osasse and what a surprise... pean õhku laskma tuuma jaama irww ja üks inimene lõi kampa minuga
http://www.zone.ee/platoonsgtelias/1/FarCry_31.JPG?2
edit: Panin Shadow Fullile... nojah äge küll et relval vari peal ja puha... muidu suht sama mis lowga... aga fps 30 :-/
Kuda radeon9800proga asi on? kui vaadata suht sama kohta nagu siin... kõik full 1024
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Cyberlord
23.03.2004 07:40:07
Hmh kasutades farcry configuration tooli ja vajutades "auto detect" nuppu seal kus saab masina võimekust valida, paneb auto ainult medium mulle
Nu krt huvitav mis tema meelest high on siis
| Kommentaarid: 546 loe/lisa |
449 |
One
23.03.2004 07:46:51
3ghzi amd prosega masin 8)
2.7 peal paneb veel mediumi
edit:
väljavõte readme'st
High System Requirements
- Computer: A 3 GHz AMD processor or better is recommended.
- Memory: We recommend 1024 MB of RAM
- Drives: 4 Gb of free space on hard disc are required to install and play the game. 16x DVD or 32x CDROM is recommended to install the game.
- Video: A 3D accelerator video card with support for DirectX® 9.0b and at least 128 MB of video memory is recommended
- Multiplayer Connectivity: We recommend the use of cable or ADSL connection with 512 Kb/s in downstream and 128 kb/s in upstream.
viimati muutis Winterwind 23.03.2004 07:48:28, muudetud 1 kord |
728 |
HDTanel
Overclocker
23.03.2004 07:47:00
AMD FX53
1024Mb Pc4500
ATI9800XT 256mb
edit: Readmest LOL
Minimum System Requirements Single Player Only
- Computer: AMD Athlon 1 GHz or Pentium III 1 GHz (AMD Athlon XP 2000 / Pentium 4 2 GHz recommended)
- Operating System: FarCry is supported on the following operating systems: Windows 98SE, Windows ME, Windows 2000, and Windows XP.
- Memory: The game requires 256 MB of RAM.
- Controls: A keyboard and mouse are required
- Drives: 4 Gb of free space on hard disc are required to install and play the game. 4x DVD or 16x CDROM is required to install the game.
- Video: A 3D accelerator video card with support for DirectX® 9.0b and at least 64 MB of video memory is required.
- Sound: A DirectX®-compatible 16-bit PCI sound card is recommended.
For Multiplayer play only the following configurations are supported
Recommended System Requirements
- Computer: A 2GHz AMD processor or better is recommended.
- Memory: We recommend 512 MB of RAM
- Drives: 4 Gb of free space on hard disc are required to install and play the game. 8x DVD or 32x CDROM is recommended to install the game.
- Multiplayer Connectivity: Access to UBI.com online gaming service, requires a low-latency, active Internet connection, rated at 64 Kbps upstream or faster. Multiplayer games played over a LAN require an active connection to a TCP/IP network. We recommend the use of cable or ADSL connection with 512 Kb/s in downstream and 128 kb/s in upstream. ESRB notice: Game Experience May Change During Online Play!
- Computer: A 3GHz AMD processor or better is recommended.
Multiplayer Server Requirements
Dedicated Server
- Computer: A 2.4 GHz AMD processor or better is recommended.
Non Dedicated Server:
Computer: A 2.8 GHz AMD processor is recommended
Memory: We recommend 1 Gb of RAM, however we do not recommend connecting many players to a non-dedicated server.
496 |
mutabor
23.03.2004 09:33:20
| PlatoonSgtElias kirjutas: |
kas sul visuaalselt muud varjud ei tekkigi igale poole, et ainult relval? puudest ja inimestest varjud, siseruumides samuti?
_________________ /allkiri |
| Kommentaarid: 24 loe/lisa |
22 |
One
23.03.2004 09:45:46
sain siis kah peale väikest pusimist sinna doom 3 taolistesse levelitesse, päris raskeks kisub, kuna mehi ja elukaid tuleb korraga päris palju
ma ei suuda ikkagi aru saada, kuidas üks mootor suudab teha nii väljas kui sees sellist pilti, et karbi lahti võtab, müts maga cryteki tiimi ees, need ajad, kus osad mootorid välisavarustes, teised seestasemetel paremad olid on vist möödas
728 |
Scart
23.03.2004 09:59:01
| heh, mind paneb hoopis imestama, kuidas deus 2 mootor võrreldes sellega sihuke häbiplekk on... far cry oskab kõiki asju, mida deus 2 ja teeb seda nii 10 korda paremini ja kiiremini 8)
101 |
Le Inc
23.03.2004 10:01:34
Rääkige kust mängu saite? Mõni eesti pood ka müüb asja?
Lisa: 26. märts tuleb välja ja juba meestel mängud käes!? Kiired vennad ...
viimati muutis Le Inc 23.03.2004 10:51:46, muudetud 1 kord |
| Kommentaarid: 56 loe/lisa |
54 |
Mawrec
23.03.2004 10:19:44
"The game is scheduled to release in the UK on March 26th."
| Kommentaarid: 42 loe/lisa |
37 |
System
23.03.2004 10:24:06
Deus exis mulle meeldis too "bloom" efekt. See tegi asja ikka päris kobedaks .
_________________ Tuli vaikselt, tuli tasa. Varjud jättis seintele ja maha. |
| Kommentaarid: 14 loe/lisa |
23.03.2004 12:54:32
nonii... sai läbi... liialt lühike
eks tuleb hakata kõige raskema tasemega pelama, sest kui mõned jaburalt rasked kohad välja jätta oli mäng lihtne...
samas häiris see, et osad asjad kipuvad pärast save'i samasse kohta tagasi minnes kaduma
200 |
Denke
23.03.2004 14:52:31
| Krt, mitu korda ma pean seal BOAT osas peale laeva õhkulaskmist kopterile raketiga pihta saama? Tavaliselt piisab ju 1 korrast aga siin lased 5 korda pihta ja ei tee teist nägugi.
23.03.2004 14:59:55
| Denke kirjutas: |
| Krt, mitu korda ma pean seal BOAT osas peale laeva õhkulaskmist kopterile raketiga pihta saama? Tavaliselt piisab ju 1 korrast aga siin lased 5 korda pihta ja ei tee teist nägugi. |
nii see kahjuk on... ma raiskasin 14 raketti ära + veel kuulid
200 |
Scart
23.03.2004 15:04:34
pullimotji peal olev vend on taseme boss
101 |
ppg
23.03.2004 15:30:17
| Scart kirjutas: |
pullimotji peal olev vend on taseme boss  |
Scart ma tõlgin vähe...kes ei tea mis on pullimjot eesti tähtedega kirjutatud vene sõna...see siis kuulipilduja
138 |
Riivo
23.03.2004 15:42:13
mis levelit sa täpselt mõtled?
221 |
xav
23.03.2004 19:03:07
| Minu masina kohta (vaata profiili) kinnitas autodetect et tegemist on High, ent mitte veel Very High. Käsitsi kõik asjad maksimumi pannes jooksis asi ikkagi nagu miilenki.
Denke
23.03.2004 21:34:00
| xav kirjutas: |
| Minu masina kohta (vaata profiili) kinnitas autodetect et tegemist on High, ent mitte veel Very High. Käsitsi kõik asjad maksimumi pannes jooksis asi ikkagi nagu miilenki. |
Tundub ,et programm paneb need tasemed(low/med/high) RAM hulga järgi, kuigi sul on kõva videokaart ja/või prose.
Cyberlord
23.03.2004 22:00:54
| Denke kirjutas: |
| xav kirjutas: |
Tundub ,et programm paneb need tasemed(low/med/high) RAM hulga järgi, kuigi sul on kõva videokaart ja/või prose. |
Nu mul kah 1Gb mälu aga annab tulemuseks medium
449 |
margusser
23.03.2004 22:33:37
ja mul on pool giga ja annab kah medium
167 |
System
Cyberlord
23.03.2004 23:38:57
Oeh lõhnab väljamineku järgi Järgmine nädal tuleb lattu piiratud kogus SK8V plaate kah
449 |
biker
23.03.2004 23:44:15
| Kas see bossi tapmine seal laeva juures on mängu lõpp või on veel leveleid?
xav
24.03.2004 00:05:23
| 20 levelit on mängus, ning see ei ole boss ning sa ei tapa teda veel ära. Crowe (see kes seal helikopteris passib ning peale suuremat kogust rakette ka sellega minema lendab) tuleb tappa natuke hiljem.
arm2004
24.03.2004 00:58:55
ma avastasin ühe toreda asja.
siis kui teises levelis pead selle laeva tekile minema, aga seal on see helikopter jne.
kui lähed tagasi oma august alla ja üldse pool teed tagasi, siis saab selle kopteri lõdvalt alla lasta.
seejärel hüppad vette ning ujud enamvähem selle kummipaadi alla, mis üleval ripub.
tulistad kaks paela paadil puruks ja see kukub alla, ning sõida minema 8)
ongi tase läbi
P.S. see on neile, kes muidu sealt edasi ei saa (nagu mina )
_________________ nooope! |
97 |
