08.04.2015 09:43:03
ADSL/VDSL?
"Correctable" viitab justkui parandatavale asjale (mitte, et ma teaks millega täpselt on tegu antud kontekstis). Kui on mingi *DSL siis on seal liini peal kogu aeg vigu - suurem osa parandatakse nii ära, et klient ei saa arugi. Pealegi on vigu erinevaid - osad on parandamatud ja põhjustavad näiteks TV pildi ruudutamist, paketikadu jne. Suurem osa aga sellised mis käivadki sadade või tuhandete meetrite vasega kaasas.
Kommentaarid: 181 loe/lisa |
145 |
08.04.2015 12:14:56
Mark0, optika ikka.
Google "brcmnand_ctrl_verify_ecc" viitab "Broadcom NAND flash controller interface"-le ja sellega seotud koodile.
Kommentaarid: 168 loe/lisa |
157 |
08.04.2015 12:29:24
Ahha, hea teada.
Saada logi Elioni, las annavad enda hinnangu.
145 |
12.04.2015 01:14:10
Mingi vähe tehnilisem e-mail ka Elionil on kui ainult see info@elion.ee?
Vigu neid tiksub vaikselt aina juurde:
Apr 07 22:37:09 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:0765b600
Apr 07 22:37:09 brcmnand_refresh_blk: Performing block refresh for correctable ECC error at 765b1cc
Apr 07 22:37:09 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:0765e600
Apr 07 22:37:09 brcmnand_refresh_blk: block refresh success
Apr 07 22:37:51 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:0765e600
Apr 07 22:37:51 brcmnand_refresh_blk: Performing block refresh for correctable ECC error at 765e1e4
Apr 07 22:37:51 brcmnand_refresh_blk: block refresh success
Apr 08 23:53:51 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:0715be00
Apr 08 23:53:51 brcmnand_refresh_blk: Performing block refresh for correctable ECC error at 715b6dc
Apr 08 23:53:51 brcmnand_refresh_blk: block refresh success
Apr 09 05:41:39 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:06932800
Apr 09 05:41:39 brcmnand_refresh_blk: Performing block refresh for correctable ECC error at 6932a5c
Apr 09 05:41:39 brcmnand_refresh_blk: block refresh success
Apr 09 22:52:45 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:06d3a000
Apr 09 22:52:45 brcmnand_refresh_blk: Performing block refresh for correctable ECC error at 6d3a17c
Apr 10 13:28:09 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:074dd200
Apr 10 13:28:09 brcmnand_refresh_blk: Performing block refresh for correctable ECC error at 74dce08
Apr 10 13:28:09 brcmnand_refresh_blk: block refresh success
Apr 10 15:57:01 [0;33;41mFCACHEfc_query_fdb ERROR: net_fdb_p<0x8a9ea880> key<0x1005> fdb_p<0x (null)>[0m
Apr 10 16:18:33 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:0715be00
Apr 10 16:18:33 brcmnand_refresh_blk: Performing block refresh for correctable ECC error at 715b6d0
Apr 10 16:18:33 brcmnand_refresh_blk: block refresh success
Apr 11 08:34:33 brcmnand_ctrl_verify_ecc: Correctable ECC error at 00000000:077fe600
Apr 11 08:34:33 brcmnand_refresh_blk: Performing block refresh for correctable ECC error at 77fdfb4
Apr 11 08:34:33 brcmnand_refresh_blk: block refresh success
Kellelgi teisel kel ka Intenol viimane FW peal, pole sarnaseid teateid logis?
157 |
304nt
12.04.2015 09:53:36
Mul on tekkinud sellised read:
Apr 12 09:17:01 Inteno crond[8759]: crond: USER root pid 22181 cmd /root/slabcheck.sh
Apr 12 09:18:01 Inteno crond[8759]: crond: USER root pid 22302 cmd /root/slabcheck.sh
Apr 12 09:19:01 Inteno crond[8759]: crond: USER root pid 22374 cmd /root/slabcheck.sh
Apr 12 09:20:01 Inteno crond[8759]: crond: USER root pid 22435 cmd /root/slabcheck.sh
Apr 12 09:21:01 Inteno crond[8759]: crond: USER root pid 22522 cmd /root/slabcheck.sh
Apr 12 09:22:01 Inteno crond[8759]: crond: USER root pid 22597 cmd /root/slabcheck.sh
Apr 12 09:23:01 Inteno crond[8759]: crond: USER root pid 22658 cmd /root/slabcheck.sh
Apr 12 09:24:01 Inteno crond[8759]: crond: USER root pid 22723 cmd /root/slabcheck.sh
Apr 12 09:25:01 Inteno crond[8759]: crond: USER root pid 22820 cmd /root/slabcheck.sh
Apr 12 09:26:01 Inteno crond[8759]: crond: USER root pid 22947 cmd /root/slabcheck.sh
Apr 12 09:27:01 Inteno crond[8759]: crond: USER root pid 23051 cmd /root/slabcheck.sh
Apr 12 09:28:01 Inteno crond[8759]: crond: USER root pid 23180 cmd /root/slabcheck.sh
Apr 12 09:29:01 Inteno crond[8759]: crond: USER root pid 23266 cmd /root/slabcheck.sh
Apr 12 09:30:01 Inteno crond[8759]: crond: USER root pid 23349 cmd /usr/sbin/fcctl flush
Apr 12 09:30:01 Inteno crond[8759]: crond: USER root pid 23350 cmd /root/slabcheck.sh
Apr 12 09:31:01 Inteno crond[8759]: crond: USER root pid 23466 cmd /root/slabcheck.sh
FW on ikka veel DG301-W7P2U_ELION2.3.11RC1-140422_1519, kasutusel VDSL
145 |
noxton
12.04.2015 19:50:39
kas keegi on 4g pulka kasutanud? Väidetavalt pidavat saama, dhcp tugi olemas
Kommentaarid: 186 loe/lisa |
169 |
UrmasP
13.04.2015 07:27:11
tsitaat: |
Kellelgi teisel kel ka Intenol viimane FW peal, pole sarnaseid teateid logis? |
Vaatasin, et sarnased teated jooksevad minul ka sealt läbi. Nii need, mis saatis bladerunner, kui ka sellised, mis postitas kasutaja 304nt. Kas sellest mingit probleemi tekib, ei oska öelda. Olen nüüd päris mitmeid asju proovinud ja testinud ja hetkel on ruuter pikemat aega püsti püsinud. Ei oskagi öelda, millest see tuleb. Öeldakse, et kui töötab, siis ära näpi ja nii ma olengi hetkel käitunud.
Kommentaarid: 1 loe/lisa |
13.04.2015 07:49:12
noxton kirjutas: |
kas keegi on 4g pulka kasutanud? Väidetavalt pidavat saama, dhcp tugi olemas |
Viimati kui proovisin, eelmise softiga täiesti töötas. Kui tahad lihtsalt 4G ruuterina tööle panna, saab. Kui aga tahad mingit backup lahendusena kasutada siis saab ka aga see ei toimi automaatselt vaid peab käsitsi tööle panema.
Kõik need funktsioonid on testimiseks, kas need võimalused ka kunagi seal ametlikult supporti saavad, pole kindel.
Kommentaarid: 260 loe/lisa |
226 |
noxton
13.04.2015 21:49:21
Multi WAN sisse lülitada, siis peaks töötama backup lahendusena. Lihtsalt küsimus oligi just kiirustes
169 |
systxix
17.04.2015 13:23:25
Võibolla teemana siit läbi käinud kuid kas conf failidele ligipääs olemas? Või elion omaltpoolt kõik kinni keeranud ? Oleks vaja dhcp confi paar rida juurde lisada, GUI-st seda võimalust ei näinud.
Kommentaarid: 90 loe/lisa |
84 |
17.04.2015 13:53:30
Ainult GUI on tavakasutajale ligipääsetav.
145 |
systxix
20.04.2015 14:42:18
Sel juhul vist siis ei ole võimalik ruuterit konfida selliselt, et klientmasinad saaksid bootida TFTP serveri pealt, Inteno pakuks ainult dhcp teenust...
Paar rida mis oleks vaja lisada /etc/config/dhcp faili:
config 'boot'
option 'filename' 'Boot/x86/wdsnbp.com'
option 'servername' 'xxx'
option 'serveraddress' '192.168.1.x'
84 |
20.04.2015 18:06:50
Jahh. Ei tööta ikka see ruuter. Peab ikka välja vahetama.
Kommentaarid: 142 loe/lisa |
127 |
friik1
20.04.2015 19:14:07
revotechnik,
ot: |
WDS boot fail tuleb anda backslashiga, mis tuleb omakorda escape'da. Ehk siis 'Boot\\x86\\wdsnbp.com'. Vähemalt mingi 2010-2011 tuli veel nii teha, sest Windowsi TFTP / ei söönud ning \ tuli dhcpd jaoks ära escape'da. |
Kommentaarid: 188 loe/lisa |
166 |
target
22.04.2015 19:11:56
Sel nädalal juba teine alg seadete taastamine elioni poolt.
Lootust on, et saab ehk varsti garantii korras uue
_________________ PSN: powwa25 |
Kommentaarid: 75 loe/lisa |
Six
26.04.2015 07:33:01
Tuleb välja, et ikka ei ole kõik tarkvara versioonid restardivabad.
Enne uuendamist ELION2.4.12RC7 peale, oli firmwareks eelmise kevade ELION2.3.11RC1.
Ühtegi iseeneseslikku restarti kogu kasutamise aja jooksul ei olnud.
24.03.2015 läks RC7 peale.
Ja hakkasid restardid pihta:
Apr 8 19:35:16
Apr 25 00:05:27
Võrgustruktuur on täpselt sama, uusi seadmeid võrku pole lisatud.
On kellelgi kogemust, kui ilusti küsida, siis kas Elioni kasutajatugi saab pushida ruuterile vanema firmware tagasi peale?
On see tehniliselt võimalik või lubatakse ainult uuemat firmware peale lasta?
indrekp kirjutas: |
bladerunner kirjutas: |
Kas see DG301-W7P2U_ELION2.4.12RC7-150302_1654 peaks restardivaba olema või mitte?
Igatahes logi järgi on ta täna kell 06:30 restardi saanud. Püsti püsis siis ligikaudu laupäeval kella 17 alates. |
Restardivabad on kõik tarkvaraversioonid, miski või keski põhjustab seda restarti mingites kohtades. Mitmed on siin juba oma seadmete uptime näidanud, mõnel püsib, mõnel mitte.
Uus tarkvara sai eelkõige märgatava paranduse wifi probleemidele. |
Kommentaarid: 40 loe/lisa |
39 |
SilQ
26.04.2015 09:31:26
Six, Ei ole muidugi. Uue versiooni peanin peale ja 4tunni pärast oli esimene restart. Sai ka elioni helistatud. Pidid asja uurima nagu alati.
Hetkel on upTime 3päeva, mis on parem tulemus kui varem.
_________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Kommentaarid: 241 loe/lisa |
208 |
Six
26.04.2015 09:54:50
No mul asi nii hull pole - umbes kaks nädalat venitab uptime ikka välja.
Helistasin ka klienditoele.
Lubati uurida ja tagasi helistada.
EDIT: Helistatigi tagasi ja öeldi, et vanast firmwarest võid ainult unistada.
Ja loo moraal on jällegi tuntud tõde - ei tasu näppida töötavat asja!
SilQ kirjutas: |
Hetkel on upTime 3päeva, mis on parem tulemus kui varem. |
39 |
seeru
26.04.2015 10:58:20
Uus tarkvara versioon oleks su ruuterisse nagunii peale lastud. Nagu Elion sulle endale laseb.
Six
26.04.2015 11:09:01
Vägisi vist ikka ei uuendata.
Bugine on see RC7.
seeru kirjutas: |
Uus tarkvara versioon oleks su ruuterisse nagunii peale lastud. Nagu Elion sulle endale laseb. |
39 |
26.04.2015 12:08:17
Mille poolest see RC7 bugine on? Nagu ma aru olen saanud, on restardid siin erinevatel kasutajatel sõltumata tarkvaraversioonist? Kas kuu jooksul kaks korda restart on probleem ja kuidas ning mille peale see seade siis otsustab ikkagi restarti teha? Logidest tuleks täpsemalt lahata, mis seda põhjustab. On ju ka ruutereid mis on kuude kaupa üleval, sealt ei saa ju lahata, miks nad töötavad.
226 |
Six
26.04.2015 12:58:15
Olen siin eespool kirjutanud Guest Wirelessi bugist.
Ja nüüd hakkasid RC7-ga restardid pihta, mis enne mul absoluutselt puudusid.
Ja ainuke asi, mis muutunud on, on firmware. Thats all.
Ja sa leiad, et kõik on tipp-topp ja nii peabki olema?
Et paar korda kuus restart käib asja juurde?
Palusingi toest, et uurige logisi ja tehke selgeks, mis restarte põhjustab.
Seepeale otsustati uus ruuter panna. Et küllap vana ruuter on vigane. Johhaidii.
Okei, mul pole midagi vastu uuele ruuterile. Vaatame, kas midagi ka muutub.
Peaasi, et ei saa nüüd ruuterit, mis iga paari päeva järel restarte teeb.
indrekp kirjutas: |
Mille poolest see RC7 bugine on? Nagu ma aru olen saanud, on restardid siin erinevatel kasutajatel sõltumata tarkvaraversioonist? Kas kuu jooksul kaks korda restart on probleem ja kuidas ning mille peale see seade siis otsustab ikkagi restarti teha? Logidest tuleks täpsemalt lahata, mis seda põhjustab. On ju ka ruutereid mis on kuude kaupa üleval, sealt ei saa ju lahata, miks nad töötavad. |
viimati muutis Six 26.04.2015 13:11:39, muudetud 2 korda |
39 |
26.04.2015 12:58:51
jeesus188 kirjutas: |
jee, tuli meelde parool
Uptime 156d 17h 31m 35s  |
10 päeva veel juures.
2 telekat, 2 aparaati wifi otsas, no problemos  |
8 päeva tagasi tegi keegi restardi
pm napilt jäi poolest aastast puudu  |
pm pole yhtegi probleemi. loodan uue rekordi teha
viimati muutis jeesus188 26.04.2015 13:16:56, muudetud 1 kord |
Kommentaarid: 71 loe/lisa |
Six
26.04.2015 13:02:01
Mis firmware sul on?
39 |
