08.04.2015 22:08:47
jutud olnud sellest, et nvidia tehnoloogiad kasutuses, mantle kohta ei ole väga saanud infi.
edit: amd kodukal on gtav olemas, a infi, mis toetatud jne. pole: http://www.amd.com/en-us/markets/game/featured/all-games/grand-theft-auto-v#
väidetavalt töötavad AMD inimesed väga intensiivselt vulkan'i kallal, mis kasutab suurel määral mantle't...
http://www.overclock3d.net/articles/gpu_displays/gta_v_will_support_the_vulcan_api/1
"When asked if GTA V will support AMD's Mantle API, Roy Taylor, Corporate Vice President at AMD, said that "it will via Vulkan", which blatantly says that the game will support the Vulcan API in the future. The tweet confirming this can be seen below."
"*Edit*
AMD's Roy Taylor has since retracted this statement on GTA V, saying that his statement regarding Vulkan was not related to GTA V but the future of Mantle. Sadly this means that Rockstar may not be bringing the game over to the Vulcan API after release. "
Kommentaarid: 196 loe/lisa |
182 |
tere112
08.04.2015 22:34:44
Scammy kirjutas: |
SLI ei tööta nii
Kasutusse jääb ikka 4GB |
Sli 980's 4GB per card. 8GB cards do not exist yet for the 980 line...
*edit*
I realize that two 4GB do not give you 8GB memory They must have made a mistake.
Not really, in GTA4, if you had 2 cards, the meter there would show double the memory too.
So maybe that's still the same code as they used in GTA4 and thus showing 8 instead of 4GB?
_________________ BMW |
Kommentaarid: 61 loe/lisa |
55 |
immot
08.04.2015 23:10:09
Can't wait, pole kordagi konsoolidel mängu mänginud ega näinud kedagi mängimas (ainult mõningaid videoklippe youtube's stuntidest jne), lisaks mitte ühtegi spoiler tagi avanud. Haibi rong laseb täispööretel igatahes!
Kommentaarid: 3 loe/lisa |
trip
09.04.2015 00:53:54
tere112 kirjutas: |
Scammy kirjutas: |
SLI ei tööta nii
*edit*
just, nagu maxpayne3-l, mul 2x gtx670 2gb sees ja graphics all 4096mb näitab
gta4 puhul ati/cf setup kalas ja näitas mõlema kaardi mälu kokku, käsitsi oli vaja kofiguratsiooni faili 1 kaardi mälu suurust lisada, nv/sli toimib ikka korrektselt.
Kommentaarid: 406 loe/lisa |
303 |
pohmakas,
käed värisevad
09.04.2015 02:30:47
painkillah kirjutas: |
google translate abil teed konto, logid sisse. paned browserile HOLA, lülitad sisse Braziilia reziimis, lähed nuuvemi lehele, ja ostad ära. |
Mõtlesin küll, et pre-orderit ise ei tee, aga nuuvemis oli päris hea hinnaga.
Lisainfoks sealt ostjaile - Hola't kasutades Brasiilia regioon ei pruugi toimida, minul näiteks ei toiminud. Küll aga toimis Argentiina regiooniga ostes
Kommentaarid: 164 loe/lisa |
136 |
Draco
09.04.2015 09:11:46
trip kirjutas: |
tere112 kirjutas: |
Scammy kirjutas: |
SLI ei tööta nii
*edit*
Masinas, kus oli HD4870x2, näitas mäng mäluks 1GB mitte 2GB (ehk siis õigesti)
_________________ Purgatory Judgement |
Kommentaarid: 12 loe/lisa |
12 |
libe
kvaliteetne mees
09.04.2015 10:08:14
kellelgi veel juhtub preloadimisel, et gta v launcher has stopped woking
vahetult enne seda viskab ühenduse tagant ja üritab reconnectida
_________________ ☠ |
Kommentaarid: 82 loe/lisa |
NATAS999
09.04.2015 10:16:05
libe kirjutas: |
vahetult enne seda viskab ühenduse tagant ja üritab reconnectida |
ei olnud sellist asja. aeg tundus ka selline, et vahepeal mingeid probleeme vahepeal ei olnud.
Kommentaarid: 41 loe/lisa |
39 |
Arx07
09.04.2015 10:38:28
Selle Nuuvemi teemaga saab rohkem online cash boonust kui plaadiversiooniga? Mul endal Euronicsist plaat eeltellitud, aga mõtlen äkki mõistlik raha tagasi küsida ja asi nuuvemist ära võtta(kuigi see pedereerimine HOLA'de ja teemadega pole kunagi meeldinud )
R3ality
09.04.2015 11:03:45
Paistab, et Steamis läks asi just 5€ kallimaks? Niiet kes pre-orderit seni ei teinud peavad otse Steamist ostes välja käima 59,99€ (eelneva 54,99€ asemel)
Kommentaarid: 60 loe/lisa |
54 |
SilQ
09.04.2015 11:18:23
R3ality, Koguaeg olnud 59.99€. Vahepeal oli mingi soodukas kust võeti -5€ aga see oli mõned päevad.
_________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein |
Kommentaarid: 244 loe/lisa |
210 |
Evil14
09.04.2015 12:01:18
NATAS999 kirjutas: |
bitCON kirjutas: |
Evil14, inflatsioon juba nii kõrge, et mõne kuu pärast on 60€ kommiraha? |
Mõne kuu pärast saab juba 30ga kindlasti |
kindlasti mitte, kui just ei satu mingi madnessi või sale "ohvriks" |
Kui praegu juba saad siit http://www.kinguin.net/category/15836/grand-theft-auto-v-rockstar-digital-download-key/ 45 eest, siis paari kuuga võib vabalt saada 20-30 euroga mängu. Kes tahaks sul osta paari kuu pärast 50-60 eest GTA-d.
Hetkel ostavad kallilt ainult tõsised friigid ja need kellel on raha väga palju.
Kommentaarid: 223 loe/lisa |
194 |
Arx07
09.04.2015 12:34:59
Dj-E kirjutas: |
Mis selle rahaga peale hakata? Eelnevate mängude pöhjal polnud küll selle rahaga miskit tarka teha.  |
Single playeris savi jah, onlines raha ongi kõige alus(autod, korterid, lennukid-kopterid, relvad jne)
xonix
Kommentaarid: 72 loe/lisa |
66 |
09.04.2015 13:45:19
Nagu näha, siis RS järgi vähemalt oleks saanud oma vana GPU'ga ka FullHD peal ära mängida, ent suht rahul, et 290 peale liikusin, 4gb tuleb vast kasuks ja tahaks kõik põhjas @ 60fps mängida
182 |
KrikU
09.04.2015 14:17:53
rmc kirjutas: |
Nagu näha, siis RS järgi vähemalt oleks saanud oma vana GPU'ga ka FullHD peal ära mängida, ent suht rahul, et 290 peale liikusin, 4gb tuleb vast kasuks ja tahaks kõik põhjas @ 60fps mängida  |
Kõik GTA osad alates 3-ndast on eelkõige kiirest CPU-st benefiti saavad, graafikakaart niipalju rolli ei mängi. Tõenäoliselt sama ka seekord.
Kommentaarid: 129 loe/lisa |
119 |
trip
09.04.2015 14:42:44
pole paha, hd7870 see on pmst ps4 gpu, tundub et hästi optimeseeritud mäng.
303 |
09.04.2015 15:03:09
trip kirjutas: |
pole paha, hd7870 see on pmst ps4 gpu, tundub et hästi optimeseeritud mäng. |
Väidetavalt on delay'de põhjuseks RockStar'i tahe GTA V võimalikult paljudel käima saada = nõudeid alla tõmmata jne.
Win-win situatsioon, võidavad tarbijad ja ka tootja, sest müüb rohkem
182 |
09.04.2015 15:05:34
Pakun, et see tuleb üks paremini optimeeritud mänge üldse
Kommentaarid: 71 loe/lisa |
Pihv
09.04.2015 15:18:30
Tegelikult ei usu, et ma 60fps oma 7870 välja vean nagu nad lubavad. Kui veab no siis müts maha
Kusjuures GTA 4 jookseb 1920x1200 palju paremini kui sama spec ja 1680x1050, nii kummaline kui see ka pole.
Kommentaarid: 101 loe/lisa |
94 |
mufferino
09.04.2015 15:47:48
Pihv kirjutas: |
Kusjuures GTA 4 jookseb 1920x1200 palju paremini kui sama spec ja 1680x1050, nii kummaline kui see ka pole. |
Pole eriline saladus, et GTA IV oli optimiseerituse kohapealt kõige otsesemas mõttes täielik p****sk
Kommentaarid: 33 loe/lisa |
09.04.2015 15:48:38
Optimeerimine ei tähenda, 60 fps. Aga antakse piisaalt suur vahemik kus mäng töötab normaalselt. Siin foorumis neid silky smooth kasutajaid küllaga, kes naudivad 15fps
c4v6
09.04.2015 15:57:36
Natukene OT aga 30 kaaadriga annab mängida küll - Lihtsalt ajad olid teised. Mäletan kui LFS S2 tuli ja võrgus sai mängitud. Pidevalt oli 25-30 kaadrit.
Kui sain uuema arvuti ja avastasin, et ka 100 kaadriga saab edukalt sõita koos teistega, siis oli nagu teine dimensioon üldse
Kommentaarid: 62 loe/lisa |
58 |
mufferino
09.04.2015 17:06:03
jeesus188 kirjutas: |
Optimeerimine ei tähenda, 60 fps. Aga antakse piisaalt suur vahemik kus mäng töötab normaalselt. Siin foorumis neid silky smooth kasutajaid küllaga, kes naudivad 15fps |
Tean ka paari härrat, kes pildiraamatuid naudivad, aga see pole imo üldse lõbus .. csgo nolades 50-55 fps ligi tikub siis võtab ikka kulmu kortsu ja käe rusikasse,
09.04.2015 19:31:10
preload tuli steamist täpselt nii kiiresti kui toru lubas...
aga üldpildis võiks asi paremaks minna, preload juba natukene aega lahti, siis raugeb see esimene suurem tung ära ja lähevad kiirused ka normaalseks.
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
