uus teema   vasta Hinnavaatlus »  Andmeside ja kõnelevi »  wifi märgi kõik teemad loetuks
tavikas
sõnum 02.04.2015 17:45:22 wifi vasta tsitaadiga
värske probleem, kus üks kahest sülearvutist ei leia ruuterist tulevat wifit. Veel täna hommikul wifi selles arvutis toimis probleemideta. Postitus tehtud asjaosalise arvuti ning ruuteriga DSL ühendusega/Cat5 kaabliga.
Probleemsel arvutil on windows 7 home premium
Wireless manager
Wifi: ON
füüsiliselt wifi tuluke põleb.
proovitud on wifi sisse-väljalülitamist arvutis, arvuti restarti, ruuteri restarti - senini tulemusteta
Veel täna hommikul kõik toimis ning ka hetkel teise arvutiga wifi toimib...
Probleemses arvutis:
> ping 192.168.0.1
pinging 192.168.0.1 with 32 bit of data
PING: Transmit failure. General Failure
> ipconfig /release
Windows IP configuration
No operation can be performed on Wifi connection 2 while it has its media disconnected.
No operation can be performed on Bluetooth connection while it has its media disconnected.
No operation can be performed on Wifi connection while it has its media disconnected.
No operation can be performed on Local connection while it has its media disconnected.
> ipconfig
Windows IP Configuration
Wireless LAN adapter Wifi connection 2
Media state . . . . . . . . . . . : Media disconnected
Connection-specific DNS suffix . :
Ethernet adapter Bluetooth connection
Ethernet adapter Local connection
Tunnel adapter Local connection* 9
Tunnel adapter isatap.<92C...>
Tunnel adapter isatap.<39F...>
Ühendatud cat-5 kaabel:
Connection-specific DNS suffix . : lan
Link-local IPv6 Address . . . . . : fe80:..
IPv4 Address . . . . . . . . . . . : 192.168.1.67
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
IPv6 Address . . . . . . . . . . . : 2001:..
Default Gateway . . . . . . . . . : ::
Tunnel adapter isatap.lan
help center: Windows can not resolve Wireless Connection problem
Windowsi riistvara seadetest: (device manager)
Wireless LAN 802.11 Network adapter -> this device is working properly
Milles probleem võib olla?
tänan vastuste eest
ja olemegi tagasi..
Kommentaarid: 17 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 15
Helseth
sõnum 03.04.2015 12:18:06 vasta tsitaadiga
Draiaverit ei ole proovinud uuendada?
p2ep
sõnum 04.04.2015 17:59:57 vasta tsitaadiga
Proovi:
Device manager, otsi sealt wireless adapter ja uninstall (ära lase drivereid kustutada)
Seejärel "Scan for hardware changes"
Dijital
Dijital
sõnum 05.04.2015 15:09:15 vasta tsitaadiga
Pingid aadressi 192.168.0.1 aga ise oled 192.168.1.67 ?
p2ep
sõnum 05.04.2015 15:56:18 vasta tsitaadiga
No tal wifi ei saanudki aadressi ju, pingi mida tahad.
Märkus muidugi õige, vale puu all haukus.
tavikas
sõnum 05.04.2015 21:38:07 vasta tsitaadiga
oops.. pingimisel panin veidi pange küll jah, aga tegelikult oli sama tulemus ka suvalise nimeserveri pingimisel..
Aga tundub, et probleem on lahendatud ruuteri vahetamise läbi.
(üleeile tekkisid kordamööda probleemid mõlemal seadmel ning kui üks arvuti oli ühendatud, siis teist wifiga järgi ei võtnud. hetkel uue ruuteriga töötavad jälle mõlemad).
Hetkel lõpetan ise teema jälgimise. tänan vastuste eest
ja olemegi tagasi..
