uus teema   vasta Tarkvara »  Arvutimängude foorum »  Medieval Engineers märgi kõik teemad loetuks
raitl
sõnum 14.01.2015 06:54:22 Medieval Engineers vasta tsitaadiga
Uus mäng Space Engineers loojatelt, mille kallal on juba mõnda aega nokitsetud.
Medieval Engineers
Link
About:
Medieval Engineers is a sandbox game about engineering, construction and the maintenance of architectural work and mechanical equipment using medieval technology. Players build cities, castles and fortifications; construct mechanical devices and engines; and perform landscaping and underground mining.
Medieval Engineers utilizes a realistic volumetric-based physics engine with a focus on structural integrity: all game objects can be assembled, disassembled, damaged or destroyed, and the object’s mass and structure influences its integrity. The game comes with creative mode and an early prototype of survival mode.
Features:
Game modes
- Creative - unlimited resources, instant building, invulnerability, levitation
- Survival - this mode is a work-in-progress and only death/respawn, slow construction and no-levitation are implemented.
To be added: resource management and inventory; material harvesting and processing; tools using
Single-player
Multi-player – will be added later
First-person & Third-person
Voxel hand – shape the terrain and its material (right now only creative mode voxel hand is implemented)
Block types
- Small: 0.25 meter (25 centimeters)
- Large: 2.5 meters
- Dynamic: can be used to construct carriages and machinery that is supposed to be moved around
- Static: immovable and connected to earth; if a heavy load breaks its structural integrity it cracks and unsupported parts become dynamic
Building blocks: stone walls (various shapes - from blocky to rounded), wooden walls and flooring, roofs (ceramic, thatched, hay), mechanical blocks (rotors, transmissions, transitions), power source blocks (wind and manual human labor), stored energy blocks (torsion spring), leverages, weights, swings, ropes, wooden beams of various length and shape, torches and other sources of artificial light, flags … More will be added in future!
Realistic physics – structural integrity, destructible objects (everything: from blocks to terrain), real proportions, volume, mass, storage capacity, integrity
Steam Workshop – share your creations with the Community
Modding - world files, 3D models, textures, shaders, API (scripting in-game objects in C#)
32-bit & 64-bit – 64-bit version expands the amount of objects and blocks (almost unlimited) and terrain
World management – generate new worlds, “save as” to multiple copies, auto-save every 5 minutes (can be turned on/off), edit world settings
Kommentaarid: 166 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 147
sõnum 14.01.2015 10:03:27 vasta tsitaadiga
Ilmselt läheb MP jaoks 1-2.a veel.
raitl
sõnum 14.01.2015 11:39:01 vasta tsitaadiga
Ei tea miskit.
Link
Alates 20:50 icon_wink.gif
Timberg
ööKARU
Timberg
sõnum 14.01.2015 15:38:47 vasta tsitaadiga
Kusjuures huvitav on see, et tüüpidel mitu rauda tules, mis on omamoodi arusaadav. Aga... nad on väike firma ja space engineers (kuigi väga hea mäng), ei ole veel kaugeltki valmis. Ka space engineers on endiselt early accessis (Release Date: 23 Oct, 2013). Ise kavatsen ka medieval engineersi hankida, aga tootjat see heas valguses ei näita, et eelmine mäng veel täiesti toores, kuid juba tegeletakse uue projektiga.
raitl
sõnum 14.01.2015 16:01:05 vasta tsitaadiga
Timberg, kuula/vaata teine video ära. Kaks eraldi tiimi on mängude kallal toimetamas ning samas mängud täiendavad üksteist. Konkreetse näitena toodi välja uus asteroidide lennult genereerimine. See sündis tegelikult just Medieval Engineers mängu meeskonna käe läbi ja toodi Space Engineersi üle.
Timberg
ööKARU
Timberg
sõnum 14.01.2015 16:04:27 vasta tsitaadiga
raitl kirjutas:
Kui kaks meeskonda ühendaks oma jõu ühe mängu valmistamiseks, saaks see kiiremini valmis. Üldiselt, space engineers on nii hea mäng, et ma usun tegelikult, et nad saavad hakkama säärase lahendusega. Samas see ei tähenda, et see minu meelest kõige parem lahendus oleks. Nende projektid, nende firma, neil õigus ka teha, mida tahavad.
flameas
flameas
sõnum 14.01.2015 16:17:43 vasta tsitaadiga
Sellisel mängul on kaks külge - ehitada on lõbus aga kas peale lossi valmimist ka midagi teha on? Loodame et on.
Kommentaarid: 91 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 81
Timberg
ööKARU
Timberg
sõnum 14.01.2015 16:21:41 vasta tsitaadiga
flameas kirjutas:
Kunagi kauges tulevikus pidavat multiplayer tulema. Pvp? Ja kas kusagil videos vist mainiti ka barbareid vms? Ma kiiruga vaatasin. Ehk kellelgi täpsemini meeles. Ma isiklikult loodan, et midagi rusti sarnast tuleks. Stiilis et maailm... ehitatad sinna kraami, korjad materjale, tapad vaenlaseid ja tapad teisi mängijaid. Aga noh... jah, see asi praegu nii alguses, et ega tea, kuidas projekt "Lõpus" välja hakkab nägema ja mis sinna tuleb.
kala1
kala1
sõnum 14.01.2015 16:27:07 vasta tsitaadiga
Näis põnev olevat
M: LG 29wk500-p
The German soldier has impressed the world, however the Italian Bersagliere soldier has impressed the German soldier.
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 48
raitl
sõnum 14.01.2015 16:57:59 vasta tsitaadiga
Timberg kirjutas:
flameas kirjutas:
Juba lossi ehitamine ise saab olema tõsine väljakutse. Alustad paljakäsi, leiad kivi ja kaika, teed puust kirve. Kui töövahendid ja materjalid olemas, ehitad juba viletsa rauast kirve ja labida, jne.
Ning kogu seda arenguprotsessi saadab pidev barbarite ja metsloomadega maadlemine. Vähemalt selline oli jutt tolles teises videos olnud intervjuus
chatro
chatro
sõnum 14.01.2015 17:01:26 vasta tsitaadiga
kala1 kirjutas:
Näis põnev olevat
+1
Ka mulle tundub huvitav, märgin ära.
Timberg
ööKARU
Timberg
sõnum 14.01.2015 17:02:37 vasta tsitaadiga
Kurat ma olen selle mngu nii sihtgrupp kui saab olla. NIi kui steami üles läheb, siis PÕMM icon_razz.gif Sandbox, pve, pvp, keskajas, hävitatav maailm. Puhas kuld.
sõnum 14.01.2015 17:43:05 vasta tsitaadiga
Timberg kirjutas:
mootor tundub võimekas.
raitl
sõnum 14.01.2015 17:53:53 vasta tsitaadiga
Endale avaldab eriti muljet structural integrity osa. Sild mis enda raskuse all kokku vajub? Hell yeah! icon_cool.gif
Timberg
ööKARU
Timberg
sõnum 14.01.2015 17:58:25 vasta tsitaadiga
raitl kirjutas:
... ja see värk on moditav. Jõhker.
-huviline-
sõnum 15.01.2015 14:11:59 vasta tsitaadiga
thumbs_up.gif loodame, et tuleb välja ja jõuab ka sellest viimase aja moest, early access, edasi. Idee selle mängu taga tundub täitsa hea. Mind on ausalt nende poolikute mängude mängimine natuke ära väsitanud.
Timberg
ööKARU
Timberg
sõnum 15.01.2015 15:57:01 vasta tsitaadiga
-huviline- kirjutas:
striker13
striker13
sõnum 15.01.2015 15:58:47 vasta tsitaadiga
Tundub huvitav, jään ootama
Sarcasm is just one of the many services I offer to people who ask stupid questions.
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 90
sõnum 15.01.2015 15:59:40 vasta tsitaadiga
Timberg kirjutas:
raitl
sõnum 01.02.2015 06:53:50 vasta tsitaadiga
Link
sõnum 01.02.2015 08:44:45 vasta tsitaadiga
Jack.igg
Jack.igg
sõnum 19.02.2015 16:20:35 vasta tsitaadiga
Mõne tunnipärast on siis saadaval mäng. Loodan ,et multiplayer lisatakse peatselt.
Redikate
Redikate
sõnum 19.02.2015 16:58:55 vasta tsitaadiga
Jack.igg kirjutas:
Ma üldse enne ei vaatagi kui MP olemas on. Üldsegi imelik, et ilma MP'ta tuli. Peaks ju sama mootori peal olema mis space engineers...
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
chatro
chatro
sõnum 20.02.2015 20:21:09 vasta tsitaadiga
Neil kel juba ostetud, kuidas muljed on?
sõnum 20.02.2015 20:22:25 vasta tsitaadiga
huvitaks ka, et kas tasub hetkel osta?
raitl
sõnum 06.05.2015 07:01:09 vasta tsitaadiga
Medieval Engineers - Multiplayer, First Look & Testing
Link
rainisk
sõnum 14.01.2020 20:13:46 vasta tsitaadiga
On siin sellel pelal mängijaid ka?
( -_・) ︻デ═一 ▸
Kommentaarid: 23 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 18
