uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Samsung Galaxy Note 4 märgi kõik teemad loetuks
mine lehele 1, 2, 3, 4, 5, 6, 7, 8, 9  järgmine
gemini
sõnum 04.09.2014 09:38:09 Samsung Galaxy Note 4 vasta tsitaadiga
link :: GSMArena
GENERAL
2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 850 / 900 / 1900 / 2100
4G Network LTE 800 / 850 / 900 / 1800 / 2100 / 2600
SIM
Micro-SIM
BODY
Dimensions 153.5 x 78.6 x 8.5 mm (6.04 x 3.09 x 0.33 in)
Weight 176 g (6.21 oz)
- S Pen stylus
- Fingerprint sensor
DISPLAY
Super AMOLED capacitive touchscreen, 16M colors
Size 1440 x 2560 pixels, 5.7 inches (~515 ppi pixel density)
Multitouch
Corning Gorilla Glass 3
MEMORY
Card slot microSD, up to 64 GB
Internal 32 GB, 3 GB RAM
DATA
GPRS
EDGE
Speed HSDPA, 42 Mbps; HSUPA; LTE, Cat4 (N910C), Cat6 (N910S), 50 Mbps UL, 300 Mbps (N910S), 150 Mbps (N910C) DL
WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, DLNA, Wi-Fi hotspot
Bluetooth v4.1, A2DP, EDR, LE
NFC
Infrared port
USB
microUSB v2.0 (MHL 2), USB Host
CAMERA
Primary 16 MP, 3456 x 4608 pixels, optical image stabilization, autofocus, LED flash
Features Dual Shot, Simultaneous HD video and image recording, geo-tagging, touch focus, face and smile detection, image stabilization, panorama, HDR
Video 2160p@30fps, 1080p@60fps, optical stabilization
Secondary 3.7 MP, 1080p@30fps
FEATURES
OS Android OS, v4.4.4 (KitKat)
Chipset
Qualcomm Snapdragon 805 (SM-N910S)
Exynos 5433 (SM-N910C)
CPU
Quad-core 2.7 GHz Krait 450 (SM-N910S)
Quad-core 1.3 GHz Cortex-A53 & 1.9GHz quad-core Cortex-A57 (SM-N910C)
GPU
Adreno 420 (SM-N910S)
Mali-T760 (SM-N910C)
Accelerometer, gyro, proximity, compass, barometer, gesture, UV, heart rate, SpO2
SMS(threaded view), MMS, Email, Push Mail, IM
HTML5
Radio TBC
GPS with A-GPS, GLONASS, Beidou
Java via Java MIDP emulator
Colors Frosted white, Charcoal black, Bronze Gold, Blossom Pink
- ANT+ support
- S-Voice natural language commands and dictation
- Air gestures
- SNS integration
- Active noise cancellation with dedicated mic
- TV-out (via MHL A/V link)
- MP4/DivX/XviD/WMV/H.264/H.263 player
- MP3/WAV/eAAC+/AC3/FLAC player
- Organizer
- Photo/video editor
- Document viewer(Word, Excel, PowerPoint, PDF)
- Google Search, Maps, Gmail, YouTube, Calendar, Google Talk, Picasa
- Voice memo/dial/commands
- Predictive text input (Swype)
BATTERY
3,220 mAh battery
DigeBeni
DigeBeni
sõnum 04.09.2014 10:44:33 vasta tsitaadiga
... pixliralli võiks nüüd külla ära lõpetada, 1080p reso oleks sellise ekraani jaoks enam, kui küll. Akusurm on selline ekraan ja mille nimel täpselt ?
Braien
Braien
sõnum 04.09.2014 10:59:14 vasta tsitaadiga
Kõrge pikslikogus ilmselt sellepärast:
http://www.gsmarena.com/samsung_ifa_2014-review-1126p4.php
DigeBeni
DigeBeni
sõnum 04.09.2014 11:38:10 vasta tsitaadiga
... ühesõnaga lauslollus, millest võidavad väga vähesed aga kaotavad kõik icon_confused.gif
pwn13
pwn13
sõnum 04.09.2014 11:39:55 vasta tsitaadiga
DigeBeni kirjutas:
pWn
Kommentaarid: 73 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
DigeBeni
DigeBeni
sõnum 04.09.2014 12:37:43 vasta tsitaadiga
... ma ei näe siin midagi koomilist icon_rolleyes.gif Note pole olnud just mänguritele suunatud telefon ja seega see väike hulk inimesi, kes sellest aksessuaarist mingit rõõmu tunneks, jääb ikka võrdselt kaotajaks sest tänu meeletule resole kulutab ekraan tublisti rohkem akut, kui see mõistlik oleks. Pealegi, ma ei kujuta ette, kui palju ja mida sellise vidinaga üldse reaalselt mängida saakski. Lauarvutiteltki nõuavad sarnased lahendused päris tublisti jõudlust, jõudlus omakorda tähendab aga suurt energiakulu. Juba telefoni wifi hotspotina jooksutamine kurnab seda rohkem, kui otse stepslist peale laadida suudetakse, mis juhtub veel säärase 3D lahenduse jooksutamisel ?
Xender
sõnum 04.09.2014 19:29:15 vasta tsitaadiga
Võrreldes eelkäija Note 3mega on enamik sama :
1. Ekraani suurus
2. Resolutsioon on kõrgem, kuid mina ei suutnud LG G2 ja G3mel vahet teha selles osas ...
3. Võimsust on natuke rohkem ... kuid seoses suurema resolutsiooniga on vaja ka rohkem piksleid ringi keerutada, mis sööb selle võimsuse kasvu suures jaos ära.
4. Aku sama ja arvatavasti samasse suurusjärku jääb ka kasutusiga
Reaalselt on parem ainult kaamera, ülejäänud uuendused on küsitavad ja väheolulised nagu : metallraam, UV sensor, sõrmejäljelugeja, pulsimõõdik.
Samas on ka tagasiminekuid usb 3 pealt tagasi usb 2he peale.
Note 3 omanikuna kindlasti uuendama Note 4 peale ei hakkaks ... kuid Note 2 omanikuna täitsa kaaluks ... samsungil ongi mõistlik mudeleid üle ühe soetada.
Kommentaarid: 59 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
Cyberlord
sõnum 04.09.2014 19:32:35 vasta tsitaadiga
Homme saab näppida:)
Kommentaarid: 546 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 449
Sammalhabe
Sammalhabe
sõnum 05.09.2014 15:43:33 vasta tsitaadiga
Ma olen oma kolme aastase Note 1'ga väga rahul, ainult selle tarkvara 4.1.2 on nii vana (uuendust ei pakuta), et näiteks Waze peab iga kord käsitsi sisse logima, ei jäta kasutajat meelde. Muus osas OK, isegi aku kestab 2 päeva nagu alguses. icon_smile.gif
Cyber, kas saad korra enda kätte, näita mulle ka?
Lauri0112
Lauri0112
sõnum 06.09.2014 12:07:59 vasta tsitaadiga
Hind pidi suht kõrge tulema. Arvan, et ei lähe note2 pealt 4 peale üle. Esialgu vähemalt.
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 61
Braien
Braien
sõnum 06.09.2014 12:13:31 vasta tsitaadiga
Kuskil räägiti 799€ hinnast.
Xender
sõnum 08.09.2014 13:31:37 vasta tsitaadiga
Tuttav kes sai selle endale juba ( töötab arvustajana ) rääkis, et pidi olema - tunduma rohkem Note 3.1 versioonina, et natuke parem siit ja sealt aga milleski olulist vahet pole. Muidu kiitis küll igat pidi, et parim Androidi telefon mida seniajani näppinud. Tõi veel välja, et Galaxy Gear VR pidi suht hea olema, eriti kui sellele mingeid spets mänge peaks tulema hakkama.
taavi
sõnum 08.09.2014 21:10:31 vasta tsitaadiga
Galaxy Gear VR tundub mulle nagu pliiats. ma ei kasutanud pliiatsit ei note 1 peal ega praegu note 3 peal.
Kommentaarid: 69 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 60
Mõttetumees
sõnum 29.10.2014 00:31:23 vasta tsitaadiga
Võtsin siis täna Note4 ligi Note3 asemele. Õnnestus kohe kenasti ühe imepisikese surnud piksliga aparaat saada. Nii paljukest siis seda rõõmu oligi. Ühe õhtu jagu. Eks läheb garantiisse.
Kommentaarid: 656 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 533
Lauri0112
Lauri0112
sõnum 29.10.2014 11:02:19 vasta tsitaadiga
Mõttetu mees, Igal juhul välja vahetada. Aga, kas tõesti annab seda ühte pikslit näha? Ei suuda ette kujutadagi, kui väike see olla võib, kuna pikslite tihedus suht suur siiski.
Vaatasin EMT lehel 699€. Võibolla kui mõnihetk saab osta pakett+telefon isegi mõtleks. icon_rolleyes.gif
Mõttetumees
sõnum 29.10.2014 12:51:33 vasta tsitaadiga
Pimedas, tumeda ekraaniga särab ikka korralikult näkku see pikslike, kuna helendab arvatavasti maksimumi peal. Värvus on "sõbral" roheline. Väikene on see tõesti, aga häirib ikka.
tytan
sõnum 02.11.2014 17:20:54 vasta tsitaadiga
Sai ka föön väljavahetatud selle note 4 vastu. Esmamulje on thumbs_up.gif kuid veidi harjumatult suur kui tulla iphone 5 pealt.
titaan82
sõnum 03.11.2014 00:13:10 vasta tsitaadiga
sai siis kasutatud nädal aega ja nüüd remonti minek. tel pidevalt väga kuum ja aku peab max 3 tundi vastu. ekraan näitab et kasutab 47% akust ja pluss veel muud asjad. äkki oskab keegi kommenteerida
Jiffy
Jiffy
sõnum 23.11.2014 23:32:06 vasta tsitaadiga
titaan82 kirjutas:
Hei, kumma versiooniga sul note 4 puhul tegemist on? Kas SM-N910C ehk siis Exynose octacore või SM-N910F snapdragoni quadcore? Eestist C varianti leiab Elisast ja Tele 2st, mujal kõik F variandid (Soomes puhtalt F variandid)
Lauri0112
Lauri0112
sõnum 02.12.2014 13:31:06 vasta tsitaadiga
Nii, täna tõin endale ka Note4 ära. Veel pakk lahti võtmata. Nagu jõuluõhtu. icon_cool.gif
Valitud sai siis musta värvi isend.
EDIT: Kas kellegi on aimu, kust tagavaraks tagakorpust saada? On vaja tagavaraks ühte.
blackhawk
blackhawk
sõnum 09.01.2015 16:10:09 vasta tsitaadiga
Lauri0112 kirjutas:
Starcom äkki. Ise tellisin paari euri eest metallist kaane ebayst.
Kommentaarid: 98 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 88
hkurujo88r
sõnum 11.01.2015 22:02:07 vasta tsitaadiga
Keegi Samsung Edge-t ka on proovind?
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 120
Jiffy
Jiffy
sõnum 13.01.2015 16:00:43 vasta tsitaadiga
Key test findings
The Edge screen sacrifices grip and can't be operated single-handedly with a left hand; we used it more for glancing status info, interacting with it is limited to TouchWiz apps for now
The main display is as good as they come, but dimmer than the Galaxy Note 4
Battery life is unimpressive, and noticeably worse than the Note 4
Superb performance, proper benchmark champion
Loudspeaker loudness is great, slightly quieter than the Galaxy Note 4
Audio quality is excellent
16MP camera is a stellar performer, OIS is good but not the best
4K videos are the best in business
see nüüd gsmarenast.
tonis12
sõnum 22.01.2015 08:48:32 vasta tsitaadiga
No nõndaviisi. Nüüd ka mina õnnelik (loodetavasti õnnelik ) note 4 omanik. Peres oli varemalt note 3 ja jättis väga hea mulje, sestap ka sai endale siis see neli valitud.Olin sügavalt kahevahel, kas võtta nexus 6 või note4 ja kes seda teab, kumb nüüd õige valik oleks olnud aga no nüüd sai nii. Aga laadimise kohapealt, kas tal ongi vaid kiirlaadimine, et tava laadimist ta ei rakendagi ? Mõtlen sellega seda, kas kiirlaadimine kiiremini aku eluiga ei lõpeta ? Kiirelt küll täis aga aku läheb sedavõrd kiiremini ka läbi ? Tegelikult kolmel ja neljal väga erilist vahet ei ole minumeelest. Hinnavahe muidugi välja arvata, kuid suhteliselt soodsalt saadud, las ta siis olla.
Lauri0112
Lauri0112
sõnum 22.01.2015 10:34:13 vasta tsitaadiga
Pole küll Note3 omanud, aga niipalju kui näppinud olen, siis Note4 on ikka tunduvalt kvaliteetsem. Seda just raua koha pealt. Tarkvara kohta kaasa rääkida ei oska.
Kiirlaadimine toimub ainult kaasas oleva orginaal adapteriga, mis seda võimaldab. Mõne teise laadijaga ( nt note2 laadijaga ) kiirlaadimist ei toimu. Minu teada vähemalt.
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Samsung Galaxy Note 4 mine lehele 1, 2, 3, 4, 5, 6, 7, 8, 9  järgmine
