| Kommentaarid: 92 loe/lisa |
27.08.2014 08:26:09
link :: Seagate Ships World’s First 8 Terabyte Hard Drive
"The 8TB HDD comes five months after Western Digital had released the first ever 6TB HDD. Up until then, Seagate’s highest capacity HDD had been shipping only to select enterprise clients. The 8TB HDD comes in the 3.5-inch form factor and, according to the manufacturer, features a SATA 6Gbps interface and multi-drive RV tolerance which makes it suitable for data centers. It's unclear what technology the drive is based on, or if PMR (Perpendicular Magnetic Recording) or low-resistance helium technology was employed, though it's more likely PMR."
147 |
pots4t4j4
27.08.2014 08:47:39
varsti tuleb oma 3TB junnid põõsasse visata
401 |
SurfData
27.08.2014 11:59:40
| Mark0 kirjutas: |
| "The 8TB HDD comes five months after Western Digital had released the first ever 6TB HDD. Up until then, Seagate’s highest capacity HDD had been shipping only to select enterprise clients. The 8TB HDD comes in the 3.5-inch form factor and, according to the manufacturer, features a SATA 6Gbps interface and multi-drive RV tolerance which makes it suitable for data centers. It's unclear what technology the drive is based on, or if PMR (Perpendicular Magnetic Recording) or low-resistance helium technology was employed, though it's more likely PMR." |
ai kurjam, seda tahaks...kuid hind on nagunii üle mõistuse. Ka 6tb olid 500€ tk kui välja tulid (ja need serveriseeria omad on siiani), wd red on seal 250€ kandis. Peab hakkama silma peal hoidma millal artikkel tekib
| Kommentaarid: 84 loe/lisa |
74 |
kaspar00
27.08.2014 12:50:17
| Tomorrow kirjutas: |
| kaspar00, Kõvaketastel on enamasti Jumperi võimalus senini olemas. Kas ka SATA1 peale piiramist toetab peab uurima huvipakkuva kõvaketta manuaalist mille saad tootja lehelt. |
tundub, et sata III ketastel enam sata I-ks piiramst pole nagu sata II omadel sageli leidus, uurisin üsnagi mitme tootja manuale.
küll aga leidsin huvitava SSD mudeli, mis paistab olema sata I ja võiks eeldada, et töötab ka VIA8237 chipsetiga
link
102 |
27.08.2014 12:51:37
Tomorrow, pesade arv pole "kummist". Kui NAS-s on 2 pesa siis võtad vajadusel selle mis suuremat mahtu pakub sõltumata rahast.
158 |
27.08.2014 14:06:46
Tomorrow, suurema nasi ostmine on teatud hetkest väga kallis ettevõtmine.
aga üldiselt tasub ennast lohutada sellega, et cutting edge raua soetamine pole kunagi olnud rahaliselt mõistlik.
su enda loogikat jätkates on ka 6gb kettad mõttetud, sest 3gb ketastega saab sama mahu jälle odavamalt.
_________________ - londiste
217 |
SurfData
74 |
03.09.2014 16:53:19
SurfData, oled samas masinas wd 3tb ka testinud? tulemused alles ka?
182 |
SurfData
03.09.2014 17:12:44
| rmc kirjutas: |
| SurfData, oled samas masinas wd 3tb ka testinud? tulemused alles ka? |
kõik testid mis olen teinud peaks selles samas teemas olema. Kas 3TB Redi testinud olen ei mäleta, üldiselt esimesi suuremaid kettaid alati olen üritanud testida Seekord lihtsalt on sattunud 6tb seagate, 6tb hitachi ja oma odavuse tõttu ka 6tb wd red
74 |
kaabakas
96 |
SurfData
04.09.2014 16:13:37
siis nad võiks crucialist eeskuju võtta, seal mahud ei loe
74 |
kaspar00
05.09.2014 22:07:04
kui ma algul ostan ühe ketta ja hiljem teise samasuguse kas ma saan nad sedasi raidi panna et formatit ei tee ja nullist ei alusta?
102 |
06.09.2014 00:43:10
kaspar00, vahepeal sisu mujale kloonides võib-olla. samade ketastega - ei.
217 |
kaabakas
07.09.2014 14:29:53
Kui kontroller/soft lubab teha puuduva kettaga array, siis jah.
96 |
211 |
DVDRW
10.09.2014 10:15:25
| ~4 aastat pole GB hind odavamaks läind. Nii jääbki?
| Kommentaarid: 28 loe/lisa |
10.09.2014 10:36:46
Värsked tooted , sp ka kallid
211 |
DVDRW
10.09.2014 12:29:45
Kui nii edasi, siis näiteks kui tuleb 60TB ketas välja maksab see ~2500€
SurfData
10.09.2014 13:00:32
nüüd tuleb oodata enter price klassi asemel ka tavaklassi omasid
74 |
kaabakas
96 |
-FoX-
10.09.2014 15:23:09
Uurisin mis mul PC kõige rohkem heli teeb ... ja nii kummaline kui see ka ei ole siis kui HDD välja lülitada on masin peaaegu hääletu.
Kuna aga HDD vaja on aga samas tahaks nii vaikseks kui võimalik saada siis olen uue HDD otsinguil.
Kas WD Red peale selle et tal vist vibra vähem jne. on ka vaikne või näiteks aeglasemini pöörlev Green on veel vaiksem?
Tegu ei ole siis lugemisel tekkiva heliga mida ma taga ajan vaid lihtsalt mootori heli vms ... seagate 3TB hdd.
_________________ Aita suve, söö lund! |
| Kommentaarid: 367 loe/lisa |
6 :: |
307 |
10.09.2014 15:35:01
-FoX-, ssd.
green ja red on suures osas samad kettad, mõlemad on eeldatavasti 5900 rpm. vahe on firmwares ja garantii pikkuses.
nende võistlejateks olevad 5400/5900 rpm kettad on ka muudel tootjatel ilusasti olemas, enamasti mingi rohelise vms marketingijutuga.
217 |
-FoX-
10.09.2014 15:35:27
Siis vast üldse väline ketas
6 :: |
307 |
10.09.2014 15:48:19
| -FoX- kirjutas: |
| Siis vast üldse väline ketas :roll: |
Väline ketas teeb ikka häält, seda saab küll panna vähe kaugemale. Kusagile eemale peitupandud võrguketas on üks võimalik lahendus.
147 |
DVDRW
10.09.2014 16:22:57
| Kuskile kappi mingi svammi peale.
10.09.2014 16:23:20
| Mark0 kirjutas: |
| -FoX- kirjutas: |
Siis vast üldse väline ketas  |
Väline ketas teeb ikka häält, seda saab küll panna vähe kaugemale. Kusagile eemale peitupandud võrguketas on üks võimalik lahendus. |
Pigem niimoodi, et erinevate firmade kettad teevad erineva valjususega häält. Osade ketaste korral on töötamine kenasti kuulda ja osade ketaste korral peab "k6rva vastu ketast" panema, et kuulda kas ikka töötab.
Nii, et ehk peab vaikse masina ehitamise korral ütlema müüjale, et ma tahan osta vaikselt töötavat ketast.
211 |
-FoX-
6 :: |
307 |
11.09.2014 20:01:14
kirjas on quiet drive, pildil on himuro...
kui ma õigesti mäletan, siis oli summutamise osas vahe quiet drive kasuks (näiteks siin).
juhul kui actually quiet drive tellisid - kust sa selle kätte said?
217 |
-FoX-
12.09.2014 08:22:29
Sain selle kasutatult ebayts 5 öörot + post miski 3 oli vist.
Peale selle on muidu veel miskeid taolisi silencer lahendusi teistelt tootjatelt vms?
6 :: |
307 |
von Wu
12.09.2014 08:35:47
Mingeid silikoonpuksidega variante on jah, aga Quiet Drive on kõige parem. Samas Himuro ei summuta müra peaaegu üldse.
| Kommentaarid: 901 loe/lisa |
675 |
-FoX-
12.09.2014 14:15:04
Mootori enda hääl on ka kuulda ... ei tea see WD Red peaks vist keskmisest vaiksem ka olema ju?
6 :: |
307 |
von Wu
12.09.2014 19:02:33
Keskmisest vaiksem ja aeglasem. Andmete hoidmiseks sobib, operatsioonisüsteemi jaoks mitte.
Kavalam variant oleks osta vaikne 2TB (suuremaid minu teada ei müüda) 2,5" ketas, panna see Quiet Drive'i sisse ja see omakorda suurema Quiet Drive'i sisse.
675 |
-FoX-
12.09.2014 19:03:15
Mul 2 SSD olemas kus elu toimub ... vaja HDD mis pidevalt töös on lihtsalt hoiab asju, et saaksin alati ligi jne.
Kuna masin käib 24/7 ja pean samas toas magama ka siis iga natuke mis vaiksemaks saab seda parem
6 :: |
307 |
DVDRW
13.09.2014 12:28:38
Mul läheb HDD automaatselt magama. Ja käima kui ligi vaja saada. ~4x päevas.
Huvitav kas nii pikeneb või hoopis lüheneb HDD eluiga?
Voolusääst igaljuhul.
17.09.2014 18:56:10
http://en.wikipedia.org/wiki/S.M.A.R.T.
184 (0xB8) End-to-End error / IOEDC
This attribute is a part of Hewlett-Packard's SMART IV technology, as well as part of other vendors' IO Error Detection and Correction schemas, and it contains a count of parity errors which occur in the data path to the media via the drive's cache RAM. |
Mis see inimkeeli peaks tähendama? Üks HP kast tõstis selle attribuudi kohta hädakisa bootimisel.
158 |
s6dalane
22.09.2014 12:07:18
| Soov lähiajal väline kõvaketas osta. 1 TB või 500 GB (oleneb kumb 1 GB hinna suhtes mõistlikum on), igatahes peab olema 2.5'' ja USB3. Oskab keegi soovitusi anda?
| Kommentaarid: 15 loe/lisa |
15 |
217 |
SurfData
14.10.2014 12:21:10
8TB hgst ultrastari artikkel on tekkinud saadavust veel ei ole
0F23267 HGST Ultrastar HE8 8TB HDD 7200rpm SATA 6Gb/s 128MB cache 24x7 enhanced availability 8,9cm 3,5inch HUH728080ALE600
0F23268 HGST Ultrastar HE8 8TB HDD 7200rpm SAS 12Gb/s 128MB cache 24x7 enhanced availability 8,9cm 3,5inch HUH728080AL5200
hind on põmst 100€ per tb
74 |
DVDRW
14.10.2014 14:42:53
| Tobe jah, 3TB ketta GB jääbki igavesti vist kõige odavamaks.
SurfData
27.10.2014 17:30:39
WD purple on nüüd 5TB ja 6TB ka välja kuulutatud:
Features:
Up to 6TB capacity and designed for up to 8-bay Surveillance Systems
Exclusive AllFrame™ Technology
Optimized for 24/7 Surveillance Operations
Supports up to 32 High - Definition Camera Surveillance Environments
ATA Streaming for Reduced Frame Loss and Improved Playback
3-Year Limited Warranty
Veel ei ole artikleid siinkandi ladudesse tekkinud, kuid eks varsti tekivad ka need.
74 |
27.10.2014 17:39:11
| DVDRW kirjutas: |
| Tobe jah, 3TB ketta GB jääbki igavesti vist kõige odavamaks. |
Küll aja jooksul alla tulevad. Ega see 3TB välja tulles maksis kh ju põhimõtteliselt 100€ tb
| Kommentaarid: 39 loe/lisa |
DVDRW
28.10.2014 17:24:40
GB hind ei jõua vist ealeski 2011 a enne ujutusi tasemeni (2TB ketas 54€) kuna toimub inflatsioon.
SSD-ga ka suht nutune olukord. Mais otsin 480GB 185€ SSD (mSATA) nüüd sama mahuga 210€
28.10.2014 18:00:47
mx100 maksab alla 200 512gb.
182 |
SurfData
30.10.2014 12:38:07
8TB vist sel aastal ei tule:
availability on Q1 as fastest, MOQ restrictions as well
pole välistatud et tuleb ka varem, kuid arvestades et jõulude paiku on suuremad turud tähtsamad siis....ei panustaks selle peale. Kuid hind on 650€ kandis Reaalse saadavuse ajaks võibolla isegi odavam...loodan vähemalt
74 |
