praegune kellaaeg 30.06.2026 17:59:27
P2ppin
28.08.2014 20:01:17
Arvuti viskab blue screeni |
Sai eelmine reede välja vahetatud emaplaat ning protsessor (samuti sai tehtud format c) ning täna on juba kaks korda netis ringi töllerdades visanud blue screeni ja restardi teinud.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1061
Additional information about the problem:
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF8800F10329C
BCP3: FFFFF8800A0E6950
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\082814-13306-01.dmp
C:\Users\Priit\AppData\Local\Temp\WER-49187-0.sysdata.xml
Milles võiks probleem olla ? Esimese asjana hetkel lasen AMD beta driverid maha ja lasen viimase täisversiooni peale.
A.S.
| Kommentaarid: 34 loe/lisa |
34 |
P2ppin
28.08.2014 20:22:37
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (http://www.osr.com)
Online Crash Dump Analysis Service
See http://www.osronline.com for more information
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18409.amd64fre.win7sp1_gdr.140303-2144
Machine Name:
Kernel base = 0xfffff800`02e0c000 PsLoadedModuleList = 0xfffff800`0304f890
Debug session time: Thu Aug 28 12:54:44.539 2014 (UTC - 4:00)
System Uptime: 0 days 6:13:11.741
* Bugcheck Analysis *
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8800f10329c, Address of the instruction which caused the bugcheck
Arg3: fffff8800a0e6950, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
FAULTING_IP:
atikmdag+b129c
fffff880`0f10329c 488b02 mov rax,qword ptr [rdx]
CONTEXT: fffff8800a0e6950 -- (.cxr 0xfffff8800a0e6950)
rax=fffff8800f27e610 rbx=0000000000000000 rcx=fffffa80088f5028
rdx=0000000000000000 rsi=fffff8800a0e794c rdi=fffff8800f27dfe0
rip=fffff8800f10329c rsp=fffff8800a0e7330 rbp=fffff8800a0e7461
r8=000000004f8ebc53 r9=0000000000000001 r10=0000000000000008
r11=0000000000000000 r12=fffffa800a84f900 r13=0000000000000051
r14=0000000000000000 r15=fffffa8007cc8240
iopl=0 nv up ei ng nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00210286
atikmdag+0xb129c:
fffff880`0f10329c 488b02 mov rax,qword ptr [rdx] ds:002b:00000000`00000000=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: FlashPlayerPlu
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff8800f10329c
STACK_TEXT:
fffff880`0a0e7330 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : atikmdag+0xb129c
FOLLOWUP_IP:
atikmdag+b129c
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: atikmdag+b129c
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 53e97e01
STACK_COMMAND: .cxr 0xfffff8800a0e6950 ; kb
FAILURE_BUCKET_ID: X64_0x3B_atikmdag+b129c
Followup: MachineOwner
Mmm, kas ma nüüd saan õigesti aru, et atikmdag.sys failiga miskit ?
A.S.
28.08.2014 20:25:49
| Tundub jah, justkui mingi FlashPlayerPlugin annaks videokaardi draiverile jalaga sinnasamusesse...
34 |
P2ppin
28.08.2014 21:19:06
Lasin teised driverid peale hetkel, aga kahtlen ise, et kasu. Netist leitu põhjal tundub ikka Flashi probleem olevat. AMD Catalystis kuidagi sellest Flashist kõrvale ei saa minna, et kasutaks oma settinguid vms ? Nt hetkel panin Catalystis video colori alt, et kasutaks AMD standard settinguid.
E: Jõudsin nii kaugele, et minu probleem kuulub ilmselt siia: https://foorum.hinnavaatlus.ee/viewtopic.php?t=43200&postdays=0&postorder=asc&start=5425
