Go Kane!
18.08.2014 21:13:27
Tanel kirjutas: |
Asi juba lahenduse leidnud. |
Kiirelt oli lahendus olemas jep
Tänud Tanel
_________________ wuerth.ee. Vajad midagi, küsi julgelt 😉 |
Kommentaarid: 1839 loe/lisa |
1343 |
LiivaneLord
Sõpradele "Olavi"
Kommentaarid: 20 loe/lisa |
19 |
Kommentaarid: 195 loe/lisa |
181 |
raixxx
Kommentaarid: 75 loe/lisa |
69 |
olavsu1
külaline
23.08.2014 23:13:02
raixxx, korras nüüd.
iir
27.08.2014 21:21:01
hetk tagasi...
phpBB : Critical Error
Could not connect to the database
Kommentaarid: 90 loe/lisa |
Siim159
27.08.2014 21:27:04
Seda vahel ikka juhtub.
Kommentaarid: 22 loe/lisa |
21 |
27.08.2014 21:56:07
see häirib ikka räigelt.
181 |
iir
27.08.2014 21:59:23
eee...
https://www.hinnavaatlus.ee/products/S%C3%BClearvutid/Kasutatud+s%C3%BClearvutid/455074/
mis jama see nüüd on?
Apollo Electronics/ PC tablets/ Android 4.0/ 7 inches/ 800 x 480 pixels/ CCFL/ Yes/ Capacitive/ 4 GB/ 512 MB/ Yes/ Micro SecureDigital (microSD), Micro SecureDigital eXtended Capacity (microSDXC), Micro SecureDigital High-Capacity (microSDHC)/ ARM Cortex-A9 Dual Core/ 1.2 GHz/ Wi-Fi (802.11a/b/g/n)/ No/ 1 x mini USB, 1 x headphone out/ No/ Yes/ 0,3 mill. pixels/ No/ Accelerometer, alarm clock, built-in 2 digital microphones, Built-in digital camera, built-in games, Calculator, Calendar, Calendar and Contacts, Clock, FM Radio, Gyroscope, touch control panel/ polish, multi-language/ Built-in rechargeable lithium ion battery/ 2400 mAh/ 1x AC adapter, manual (user quide), Warranty card/ white-black/ 122 mm/ 200 mm/ 13 mm/ 0.3 kg/ 0.6 kg/ 10 Hr./ Empik 25% discount coupon/ Mini PC/ Apple Mac Mini/ Full-HD (1920 x 1080)/ 1 Pcs/ 1 Pcs/ Intel Core i5/ 5 GT/s/ 3 MB/ 1 Pcs/ 1 Pcs/ 500 GB/ 5400 rpm/ 4096 MB/ 8192 MB/ DDR3/ Non-ECC/ 1600 MHz/ 2 Pcs/ 0 Pcs/ no data/ no data/ Yes/ AMD Radeon HD 8850M/ 1024 MB/ Yes/ Yes/ 10/100/1000 Mbit/s/ Yes/ IEEE 802.11a/b/g/n/ Yes/ 0 Pcs/ 0 Pcs/ 0 Pcs/ 0 Pcs/ 1 x HDMI, 4 x USB 2.0, 1 x RJ-45 (LAN), 1 x FireWire 800 (IEEE 1394), 1 x headphone out, 1 x Microphone input, 1 x Thunderbolt (Mini DisplayPort combo)/ 4 x USB 2.0 (rear)/ N/A/ Mac OS X Lion/ memory card reader/ no data/ Intel HD Graphics 4000/ 85 Watt/ Apple MacBook Air/ 1.3 GHz, 2.6 GHz/ 3 MB/ Yes/ No/ 128 GB/ SSD |Solid State Disc| (FLASH memory)/ 4 GB/ On-board DDR3/ 8 GB/ 13 inches/ TFT HD [LED]/ 1440 x 900/ Intel HD Graphics 5000/ Shared video memory/ integrated/ N/A/ Touchpad/ No/ Li-Poly/ 12 Hr./ 1x Thunderbolt, 1 x Mini DisplayPort, 1x Line Out (headphones output), 2x USB 3.0/ No/ No/ Web Camera, Stereo speakers built-in, microphone, Backlit keyboard/ Mac OS X Mountain Lion/ 1600 MHz/ no/ RK3066/ High Definition Audio 7.1/ 1/ yes (multi-touch)/ 1 MB/ TFT IPS/ 2/ Mali-400/ 250 cd/m2/ 14 ms/ SATA II (3 Gb/s), SATA III (6 Gb/s)/ Active/ 3 Pcs/ 3 Pcs/ 2 Pcs/ 2 Pcs/ 0 Pcs/ 0 Pcs/ 2 Pcs/ 2 Pcs/ 0 Pcs/ 0 Pcs/ 0 Pcs/ 0 Pcs/ 1 x slot
Kommentaarid: 465 loe/lisa |
12 :: |
7 :: |
358 |
27.08.2014 22:03:24
Tanel, kuna dreamline'i paljude toodete kirjelduses on sees "mac" erinevate variantidena (mac os x lion, mac mini, jne.) ,siis võiks nende viited eemaldada keskkonnast kuni nad oma tootekirjeldused korda teevad,
vt. mu postitatud linki natuke üleval pool.
181 |
12 :: |
7 :: |
358 |
27.08.2014 23:08:59
Tanel,
aega võttis, saab ehk asja
#puhtamhv
181 |
StarLight
28.08.2014 11:42:01
HV esileht peabki oleme selline kilomeeter pikk scrollitav "ei tahaks küll halvasti öelda" aga pornograafia ?
_________________ Make no mistake. Despite every good thing i've ever done... I'm still a bad person |
Kommentaarid: 152 loe/lisa |
143 |
12 :: |
7 :: |
358 |
Rosper'
10.09.2014 17:48:05
Olles sisse logitud HV foorumisse, ei ole võimalik pääseda ligi HV hinnalistidele. Annab järgneva teate:
http://prntscr.com/4lht6d
Oletan, et probleem võib olla tingitud minu nimes olevast ülakomast?
Kommentaarid: 11 loe/lisa |
2korda2
12.09.2014 10:47:28
Here comes Bobby Tables. Sellist jama on raske kommenteerida.
Kommentaarid: 7 loe/lisa |
12 :: |
7 :: |
358 |
12 :: |
7 :: |
358 |
Rosper'
12.09.2014 14:01:25
Logisin foorumisse sisse, kasutajanimi siis Rosper' (ülakomaga). Kui konto on sisse logitud, lähen näiteks www.hv.ee ja seejärel kuvab vastava probleemi.
Kuigi ma spets ei ole, arvan et ülakoma tähistab midagi siis SQLis ja seepärast ta ei saa õiget kontot kätte andmebaasist ja jääbki toppama tolle erroriga.
2korda2 tundub probleemi rohke kursis olevat, ehk seletab edasi
Probleemi saaks ilmselt parandatud kõige kergemini mu kasutajanime muutes, aga see töötab seni kuni tuleb järgmine inimene, kes on endale kasutajanimesse sisestanud keelatud sümboli
12 :: |
7 :: |
358 |
Gap
Kommentaarid: 21 loe/lisa |
17 |
14.09.2014 18:45:35
Gap, kliki vastavuse i nupul ja näed, et vale vastavus
Neid valesid vastavusi aeg-ajalt ikka juhtub. Sellest ka klausel iga tootelehe all, et hinnapakkumised on indikatiivsed.
EDIT: kustutasin selle vale vastavuse ära.
HV valuutakalkulaator
viimati muutis Tanel 14.09.2014 18:49:04, muudetud 1 kord |
12 :: |
7 :: |
358 |
Gap
14.09.2014 18:48:23
poes on gt630, aga miks ta siis gtx780 lahtris oli ? mul ükskõik lihtsalt otsinguga tuli nii ...
ok selge. ma mõtlesin juba et ongi midagi valesti ja leidsin vea
viimati muutis Gap 14.09.2014 18:52:19, muudetud 1 kord |
17 |
12 :: |
7 :: |
358 |
