25.08.2014 21:10:37
Sharp Aquos Crystal nutitelefon üllatab ekraaniga |
Tõenäoliselt on enamus lugejaid üllatunud juba sellest, et Sharp üldse telefone teeb. Teeb küll, aga peamiselt Aasia turule. Sharp Aquos Crystal aga suudab oma ekraaniga üllatada isegi sealsel nõudlikul ja ärahellitatud turul.
Tegu pole siiski mitte 4K, 8K resolutsiooni või mõne muu imeviguriga. Lihtsalt Aquos Crystali 5-tolline ekraan ulatub praktiliselt telefoni servadeni, mis teeb sellest kõige kitsamate ekraaniservadega (bezel) telefoni maailmas.
Loe edasi Photopointi ajaveebist.
7 :: |
364 |
25.08.2014 21:18:27
| This is not a GSM device, it will not work on any GSM network worldwide. |
| Kommentaarid: 85 loe/lisa |
7 :: |
364 |
sooty
25.08.2014 23:30:16
| Panin igati puusse. Hoopis kaks mudelit, nägin esialgu ainult seda ühte. Lisaks 4G kõned, mis meil veel kauge tulevikuteema?
| Kommentaarid: 12 loe/lisa |
12 |
kriimsilm
26.08.2014 18:43:32
Ilus aga nüüd on kadunud buffertsoon nurga peale kukkumisel...
Kommentaar GSMArena-st:
Sharp is calling its technology "Direct Wave Receiving", which transfers sound through vibrations of display.
Kyocera introduced Tissue Conduction Technology over 2 years ago.
"When you hold a device to your ear or head, the sound bypasses the eardrum and puts those vibrations into your inner ear," said John Chier, Kyocera's director of corporate communications.
http://www.cnet.com/news/kyocera-unveils-its-new-audio-boosting-technology/
"Rather than operating with a traditional earpiece, the display itself vibrates to create sound waves. The end result is an aural experience that can be perceived with your facial tissues and bones. It dramatically improves perceived audio quality within noisy environments."
http://www.engadget.com/2012/05/07/kyocera-teases-bone-conduction-audio-technology-for-mobile-phone/
Later, in January 2013, Kyocera announced the Torque E6710, a device that utilizes its Smart Sonic Receiver. The receiver's a ceramic piezoelectric actuator that takes the place of a phone's speaker to let listeners hear phone calls in even the loudest environments. See (and hear) the results in the video below.
Amazing Outcome
http://youtu.be/h9MyW0CHofM
The Torque was released in March 2013.
http://www.gsmarena.com/kyocera_torque_e6710-5270.php |
12 |
211 |
entr0cks
| Kommentaarid: 8 loe/lisa |
A5DK
27.08.2014 15:53:27
| Kui nüüd keegi teeks samas stiilis(ilma pikema külje servadeta ekraaniga) ja HTC One moodi eesmiste kõlaritega seadme siis see oleks juba midagi. Puhas Android(või Cyanogen, kuigi see on suurte tootjate puhul vist olematu lootus) sinna otsa siis jookseks kohe ostma.
Marie
27.08.2014 20:34:26
| Lihtsalt Aquos Crystali 5-tolline ekraan ulatub praktiliselt telefoni servadeni, mis teeb sellest kõige kitsamate ekraaniservadega (bezel) telefoni maailmas. |
Alumine äär võiks ka 5mm väiksem olla ja ekraan IPS
| Kommentaarid: 83 loe/lisa |
74 |
06.09.2014 02:11:47
kriimsilm, wow ulme.
182 |
kaurxxl
20.01.2015 22:38:41
Kaevan vana teema üles.
Kas seda kusagilt eestist saada ka võiks olla?
