05.06.2014 11:01:20
Ehk väikseks abiks koduneti ehitajatele: Trendnet unveils two new speedy Powerline 1200 AV2 adapter kits |
Trendnet announces today two new powerline adapter kits, the TPL-420E2K and the TPL-421E2K that supports the Powerline 1200 AV2 standard to offer gigabit-class data rates. Both kits are set to be on the market by September this year.
Home Powerline connection is set to get a big boost this year.
Trendnet announced today two new adapter kits the Powerline 1200 AV2 (model TPL-420E2K), and the Powerline 1200 AV2 (model TPL-421E2K.) Both kits include two identical adapters that use the snap-on design, but the latter' adapters also have a pass-through socket allowing user to re-use the wall socket they occupy.
Trendnet says both kits support the latest Powerline 1200 AV2 standard. This means technically they can offers up to 1,200Mbps. In reality the sustained speed will be around 500Mbps, which is a huge improvement from existing adapters on the market.
Adapters in both kits come with one Gigabit network port and can create a reliable connection between two wall sockets as far as 980 feet (300m) apart and can work in homes as large as 5,000 sq. feet (465 sq. meters).
Both the TPL-420E2K kit (that includes two TPL-420E adapters) and the TPL-421E2K kits (that includes two TPL-421E adapters) will be available in North American, European, and UK outlet/plug models this September at the estimated cost of $99 and $109, respectively (pricing for other markets is not available at this time).
http://www.cnet.com/news/trendnet-unveils-two-new-speedy-powerline-1200-av2-adapter-kits/
211 |
Max Powers
05.06.2014 11:04:14
| Ehitajal on mõistlik vedada võrgukaabel
182 |
loox
05.06.2014 11:36:53
| Raadioeetri saastamise vahendid.
oliver.
05.06.2014 12:43:43
| loox kirjutas: |
| Raadioeetri saastamise vahendid. |
Kuidas see seade raadioeetrit saastab?
| Kommentaarid: 280 loe/lisa |
239 |
05.06.2014 13:02:26
Mis raadioeetrisse puutub, siis selline lahendus on justnimelt kohtadesse kus WiFi-võrkude signaalidest on õhk paks ning võrgud segavad üksteist kuidas suudavad.
Ma ei saa ise ka seetõttu WiFi-võrku tööle panna kuna "ringilendlevate" WiFi-võrkude arv on nii a 15-20 võrku.
Ja teine eesmärk on siis majad või korterid kus pole võimalik teha lammutus-ehitustöid, et siis mööda maja uusi kaableid vedada. Näiteks kasvõi üürikorter kus omanik ei luba mingite kaablite vedamist tubade vahel.
Üks asi veel, mida tegelikult see uudis näitab, et järjest uuemad standardid ning tehnlised lahendused võimaldavad kasutada suuremaid kiiruseid.
211 |
Max Powers
05.06.2014 13:06:33
https://pood.elion.ee/productInfo/57/elektrivorguadapteri-komplekt-comtrend-pg-9020/PG9020
kui selline seade on yhendatud vooluvõrku siis on selle seadme poolt genereeritud signaali terve 60 korteriga maja jyhtmestik täis ja raadiosagedused alates 2-29 on täis pahna mille intervall on ca 30-40kHz ja raadiokuulamist pole võimalik teostada antud eelpoolmainitud sagedusalas, mõõdetud signaali(müra) tugevus on vahemikus 20-50mikrovolti, täielik saast seade!!! |
Kopeerisin toote kommentaaridest
182 |
loox
06.06.2014 02:18:28
| oliver. kirjutas: |
| loox kirjutas: |
Kuidas see seade raadioeetrit saastab? |
See elektrivoolukaabel, mida mööda need seadmed oma signaali edastavad, ei ole kõrgsageduse jaoks tehtud. Seetõttu toimib ta samaaegselt nii kehva kaabli kui ka kehva antennina. Nagu Max tsiteeris, pritsivad nad terve lühilaineala 2-30 MHz, ja arvatavasti rohkemgi, oma mürataolist signaali täis. Raadioamatöörid terves maailmas on tigedad ja kirjutavad järelvalve- ja sertifitseerimisametitele petitsioone.
mryx
07.06.2014 09:40:43
Sarnast tehnoloogiat kasutatakse ka elektrienergia arvestite kauglugemiseks.
Huvitav, kas need siis ka ajavad lühilaineala müra täis?
Või teistpidi, kas need Powerline adapterid hakkavad segama arvestite kauglugemist?
loox
11.06.2014 00:10:26
Ma seda kauglugemise tehnoloogiat täpsemalt ei tea, aga seal on andmemahud nii väikesed, et põhimõtteliselt saab väga kitsa sagedusribaga hakkama.
Powerline asjade kohta lugesin kunagi, et elektrikilpides on filtrid sees, nii et see väljapoole ei peaks eriti kostma.
ab79
17.06.2014 17:39:09
| tahanteada kirjutas: |
Üks asi veel, mida tegelikult see uudis näitab, et järjest uuemad standardid ning tehnlised lahendused võimaldavad kasutada suuremaid kiiruseid.  |
enne kui sa selle gigabitise elektrikaabeldusel põhineva sisevõrgu välja ehitad, peab see kusagilt sellisel kiirusel ka tuppa tulema,et sellest kasu oleks. Sisevõrk pole mingi probleem,pole kunagi olnud. Küsimus meie mõistes on, kust gigabitist netti sisse saada mida koduvõrgus laiali jagada? Lõvi toob või arvad, et hakkad LTE-A kiirusi mööda kodust elektrivõrku laiali jagama? Mis asja point on, kui sul on võimalus kasutada vastavat 4G ruuterit ja nagunii reaalset gigabitist kiirust ei saavuta vaid niipalju, kui torust sisse lastakse, ehk kuni 0,3Gb/s
