uus teema   vasta Tarkvara »  Tarkvara »  KB2686509 error märgi kõik teemad loetuks
taix11
sõnum 21.05.2014 10:37:15 KB2686509 error vasta tsitaadiga
win ei taha KB2686509 allalaadida mis tegema peaks
tänud
sõnum 21.05.2014 12:09:39 vasta tsitaadiga
Paigalda käsitsi.
http://www.microsoft.com/en-us/download/details.aspx?id=29804
Kommentaarid: 765 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 571
taix11
sõnum 21.05.2014 15:02:49 vasta tsitaadiga
Viskab ikka errori ja logi aga ei oska selle logiga peale hakata
[KB2686509.log]
6.078: ================================================================================
6.078: 2014/05/20 09:16:40.437 (local)
6.172: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
6.281: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
6.281: Failed To Enable SE_SHUTDOWN_PRIVILEGE
6.344: Hotfix started with following command line: -q -z -er /ParentInfo:f1db6044a41337469457767f37fba559
6.609: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
7.922: Return Value From IsMachineSafe = 0
7.922: IsMachineSafe returned 441092
7.922: Fist Condition in Prereq.IsMachineSafe.Section Failed
7.922: Condition Check for Line 1 of PreRequisite returned FALSE
7.953: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
7.953: KB2686509 Setup encountered an error: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
7.969: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
7.969: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
7.969: Update.exe extended error code = 0xf0f4
16.156: ================================================================================
16.187: 2014/05/21 03:00:47.765 (local)
16.218: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
17.078: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
17.078: Failed To Enable SE_SHUTDOWN_PRIVILEGE
17.078: Hotfix started with following command line: -q -z -er /ParentInfo:5c909226d993b143bfb41d46c6b40cc0
17.109: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
18.187: Return Value From IsMachineSafe = 0
18.187: IsMachineSafe returned 441092
18.187: Fist Condition in Prereq.IsMachineSafe.Section Failed
18.187: Condition Check for Line 1 of PreRequisite returned FALSE
18.218: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
18.218: KB2686509 Setup encountered an error: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
18.234: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
18.234: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
18.234: Update.exe extended error code = 0xf0f4
0.828: ================================================================================
0.844: 2014/05/21 11:18:30.078 (local)
0.844: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
0.860: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
0.860: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.860: Hotfix started with following command line: -q -z -er /ParentInfo:36f9d73678bc9f46bfa29fb4298518ff
0.875: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
1.875: Return Value From IsMachineSafe = 0
1.875: IsMachineSafe returned 441092
1.875: Fist Condition in Prereq.IsMachineSafe.Section Failed
1.875: Condition Check for Line 1 of PreRequisite returned FALSE
1.938: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
1.938: KB2686509 Setup encountered an error: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
1.938: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
1.938: Update.exe extended error code = 0xf0f4
0.750: ================================================================================
0.750: 2014/05/21 11:21:47.625 (local)
0.750: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
0.765: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
0.765: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.765: Hotfix started with following command line: -q -z -er /ParentInfo:0a1b9f3dda52a84cbf5dad350d3a4388
0.765: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
0.812: Return Value From IsMachineSafe = 0
0.812: IsMachineSafe returned 441092
0.812: Fist Condition in Prereq.IsMachineSafe.Section Failed
0.812: Condition Check for Line 1 of PreRequisite returned FALSE
0.812: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
0.812: KB2686509 Setup encountered an error: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
0.828: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
0.828: Update.exe extended error code = 0xf0f4
0.828: 2014/05/21 11:31:15.125 (local)
0.828: c:\0adc8adfaeed85d84c7a2f\update\update.exe (version 6.3.13.0)
0.843: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
0.843: Hotfix started with following command line:
0.859: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
0.859: CreateUserInterface: GetProcAddress for DefineInstallCustomUI failed: 0x7f
0.953: Return Value From IsMachineSafe = 0
0.953: IsMachineSafe returned 506628
0.953: Fist Condition in Prereq.IsMachineSafe.Section Failed
0.953: Condition Check for Line 1 of PreRequisite returned FALSE
0.953: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
0.953: KB2686509 Setup encountered an error: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
0.953: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
12.797: Message displayed to the user: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
12.797: User Input: OK
12.797: Update.exe extended error code = 0xf0f4
12.797: Update.exe return code was masked to 0x643 for MSI custom action compliance.
1.140: ================================================================================
1.187: 2014/05/21 16:00:09.406 (local)
1.187: c:\2e45bdfa2cea806468306d7b596a2a\update\update.exe (version 6.3.13.0)
1.187: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
1.187: Hotfix started with following command line:
1.187: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
1.234: CreateUserInterface: GetProcAddress for DefineInstallCustomUI failed: 0x7f
1.921: Return Value From IsMachineSafe = 0
1.921: IsMachineSafe returned 506628
1.921: Fist Condition in Prereq.IsMachineSafe.Section Failed
1.921: Condition Check for Line 1 of PreRequisite returned FALSE
1.921: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
1.921: KB2686509 Setup encountered an error: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
1.937: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
1.937: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
sõnum 21.05.2014 17:43:31 vasta tsitaadiga
http://answers.microsoft.com/en-us/windows/forum/windows_xp-windows_update/security-update-kb2686509-will-not-install-error/1df6306a-1bb1-47ac-941b-5779415b2e95
