praegune kellaaeg 28.06.2026 12:51:46
Lehys
12.05.2014 11:38:27
Kart Racing Pro |
Sai selline asi siis enda jaoks avastatud,tegemist siis nagu pealkirigi ütleb kardisõidu simulaatoriga.
Kart Racing Pro is a realistic karting simulator.
The aim is to create a software useful as a training tool for real drivers, based on a scratch built physics engine that accurately simulates kart dynamics and setup options.
As such a steering wheel is strongly recommended, although keyboard, joysticks and gamepads are fully supported.
Kart Racing Pro also allows to host and join online races, with an integrated matchmaking server. During events data is collected, to provide statistics for drivers' comparison.
More features:
- automotive industry-standard tyre model
- dynamic track surface groove buildup
- wet track simulation and dynamic drying
- dynamic marbles generation
- tyres pickup of marbles, grass and dirt, affecting grip
- output of CSV files with telemetry data to analyze driving sessions
- a plugins interface allows external programs to receive realtime data from the simulated kart
- LAN and online racing. Dedicated server available
- support of custom paint schemes for kart, helmet and suit
- advanced users can build new tracks and integrate them with the provided tools
- user-selectable driver gestures
Mängul on ka Demo olemas saab vabalt proovida,sisaldab ühte masinat ja ühte rada.
Täisversioonis masinaid rohkem ja radu jagub millel sõita.
Link: http://www.kartracing-pro.com/?page=about
| Kommentaarid: 11 loe/lisa |
Launger
109 |
Lehys
13.05.2014 06:55:03
Arendust võiks veidi rohkem tõesti olla aga tundub selline ühiskonna arendatud teema olevat,paljud rajad kasutajate loodud ja rotax sarjad sama moodi.
Võrgus olen teinud mõned võistlused aga rahvast suhteliselt vähe ikka sees 2-4 inimest rajal.
Füüsika on suhteliselt hea mängus olles sõitnud ise siin hiljaaegu retro klassi võistlus masinaga ja rotax max kardiga siis 5+ selle kohapealt.
Launger
13.05.2014 11:33:25
Nõustun, see KZ1 klass mängus on sisuliselt täpselt sama mis rotax max. Seadistada on ka lahe, saab muuta täpselt neid asju mida päriskardil ja näiteks rataste max laius üksteisest on sama, mis päriseluski reeglitega piiratud
Btw kas seda ei saa maha võtta, et kui keeran rooli siis sõitja keerab pead? Realismi settingutest juba võtsin kõik kummardamised maha, aga natuke vaatab ikka.
109 |
Lehys
14.05.2014 07:00:45
Saab ikka maha võtta,hetkel peast ei mäleta kust seda teha sai aga selline valik on olemas täitsa seal.
KZ1 peaks siiski eraldi sarja masin olema(käikudega) ja KF1,KF3 siis rotax max ja rotax jun.
Kasutajate tehtud mod-idega on ka eraldi välja toodud muidu rotax sarja masinad.
