28.04.2014 16:33:43
Eemaldasin DSL kaabli restardi teostumiseks juba tund tagasi. Nüüd süsteemilogi kaebleb pikemat aega millegi mitteõnnestumisest. Mingi protsess muudkui üritab uuesti ja uuesti.
Apr 28 16:52:36 Inteno miniupnpd[8647]: cannot read /sys/class/net/ptm0.1/speed file : No such file or directory
Apr 28 16:52:42 Inteno miniupnpd[8647]: cannot read /sys/class/net/ptm0.1/speed file : No such file or directory
Apr 28 16:54:55 Inteno udhcpc[8361]: Sending renew...
Apr 28 16:54:55 Inteno udhcpc[8361]: Lease of 176.46.288.200 obtained, lease time 300
Apr 28 16:55:02 Inteno crond[2298]: crond: USER root pid 11679 cmd /bin/sh /root/brcm_monitor.sh > /dev/null
Apr 28 16:57:25 Inteno udhcpc[8361]: Sending renew...
Apr 28 16:57:25 Inteno udhcpc[8361]: Lease of 176.46.288.200 obtained, lease time 300
Apr 28 16:57:49 Inteno miniupnpd[8647]: cannot read /sys/class/net/ptm0.1/speed file : No such file or directory
Apr 28 16:57:50 Inteno miniupnpd[8647]: cannot read /sys/class/net/ptm0.1/speed file : No such file or directory
Apr 28 16:59:55 Inteno udhcpc[8361]: Sending renew...
Apr 28 16:59:55 Inteno udhcpc[8361]: Lease of 176.46.288.200 obtained, lease time 300
Apr 28 16:59:59 Inteno kernel: [ 1200.838000] nand_write: Attempt to write not page aligned data
Apr 28 16:59:59 Inteno kernel: [ 1200.845000] brcmnandCET: flush_memcet Error writing to page 7f00000
Apr 28 17:00:01 Inteno crond[2298]: crond: USER root pid 11763 cmd /bin/sh /root/brcm_monitor.sh > /dev/null
Apr 28 17:02:25 Inteno udhcpc[8361]: Sending renew... |
129 |
28.04.2014 16:53:54
| jägaja kirjutas: |
juhin tähelepanu sõnale reset.
parandan ennast, pordisuunamised taastatakse vaid elioni poolsel tarkvara uuendamisel. kliendipoolse resetiga vaid voip ja wifi juhul kui wifi nime või parooli on muudetud.
| Kommentaarid: 261 loe/lisa |
227 |
Six
28.04.2014 17:04:45
Täpselt nii juhtuski - suunamised lendasid, DHCP staticud lendasid jne.
| indrekp kirjutas: |
parandan ennast, pordisuunamised taastatakse vaid elioni poolsel tarkvara uuendamisel. kliendipoolse resetiga vaid voip ja wifi juhul kui wifi nime või parooli on muudetud. |
viimati muutis Six 28.04.2014 17:32:53, muudetud 2 korda |
| Kommentaarid: 40 loe/lisa |
39 |
harakas
28.04.2014 17:05:38
| jägaja kirjutas: |
| Eemaldasin DSL kaabli restardi teostumiseks juba tund tagasi. Nüüd süsteemilogi kaebleb pikemat aega millegi mitteõnnestumisest. Mingi protsess muudkui üritab uuesti ja uuesti. |
Kaabli eemaldamisega ei juhtu midagi, pidin reset nuppu vajutama siis sain 2.3.11. wifi sai vana SSID tagasi, selle pidin uuesti ära muutma.
Vahur
28.04.2014 18:16:09
| Tehniline tugi väitis, et NAT loopback uue tarkvaraga töötab.
388 |
28.04.2014 18:18:59
| vipu kirjutas: |
| Mark0 kirjutas: |
| Hoia ruuteri mark igaks juhuks salajas, muidu võib äkki kellelgi ideid tekkida. |
Mul on see vana Thomson TG585 v7 pann. |
Siis on jah märkimisväärne tõenäosus, et ruuter on väsimas. Võib küll proovida lahti võtta, puhastada, jahutada... aga kui 30/10 ühendus huvi pakub siis uus ruuter muudab elu kindlasti mõnusamaks.
146 |
vipu
28.04.2014 19:31:11
| Mark0 kirjutas: |
| vipu kirjutas: |
| Mark0 kirjutas: |
Siis on jah märkimisväärne tõenäosus, et ruuter on väsimas. Võib küll proovida lahti võtta, puhastada, jahutada... aga kui 30/10 ühendus huvi pakub siis uus ruuter muudab elu kindlasti mõnusamaks. |
Käisin Elionis ära ja saadavad 6. mail tehniku vaatama kas valguskaablit üldse saab panna. Näis siis.
28.04.2014 21:54:43
| harakas kirjutas: |
| jägaja kirjutas: |
Kaabli eemaldamisega ei juhtu midagi, pidin reset nuppu vajutama siis sain 2.3.11. wifi sai vana SSID tagasi, selle pidin uuesti ära muutma. |
Ma seda resetti ei taha teha, kui just ei saa vana konfi salvestada ja siis uuele uuesti selga lasta.
129 |
Anti112
113 |
jt234
28.04.2014 23:05:35
Jep, tegi kohe tuju "heaks" nähes, et 30/10 on viie maja kaugusel, kuid mu kaabel tuleb hoopis mujalt
E: Et liiga negatiivne post ei oleks, siis lisan, et uuendus ise on tore.
_________________ Dima oli siin
viimati muutis jt234 28.04.2014 23:31:36, muudetud 1 kord |
122 |
oncleuno
28.04.2014 23:10:03
| indrekp kirjutas: |
Tänasest saavad uued Inteno ruuterid võrku tulles uue tarkvara versiooni 2.3.11 mis parandab hulga suuremaid ja väiksemaid probleeme.
Kiiremad poisid kellel oli vana tarkvaraga probleeme, saavad uue tarkvara laadida tehes ruuterile reseti. Peale uuendust toimub paar alglaadimist ning taastatakse, wifi, voip ja pordisuunamised. |
Sai ka uuendus ära tehtud (ilma probleemideta mõni minut), tänud info eest!
Ega mingitest tähtsamatest uuendustest nimekirja pole lisada?
| Kommentaarid: 34 loe/lisa |
33 |
aht0
29.04.2014 06:57:02
| bladerunner kirjutas: |
vipu, vaata et su torrentiklient ühenduste arvuga ruuterit kooma ei tõmbaks.
Seadista mingi max 80-100 ühendust per torrent ja max 3-5 torrentit korraga aktiivseks.
Sel juhul peaks kõik OK olema.
Kiirusepiirangud oleks mõttekas selliselt seada, et max 80% UL/DL oleks täidetud.
UL või isegi madalamaks, 60% peale seadistada.
Sel juhul saavad ka muud paketid võrgus normaalselt liigelda. |
sea ISP ruuter DHCP reziimil internetiühendust sildama.S.t Ühest ruuteriväljundist DigiTV digiboksi, teisest väljundist tuleb avalik WAN IP. Elioni ADSL laseb tegelikult kasutada DHCP'd pppoe asemel. WAN IP suunad omakorda mõnesse väiksema võimsustarbega PC baasil "ruuterisse".
Isegi iidse P3-450 protsessori ressursist piisab ca 5000-8000 üheaegse ühenduse ülalhoidmiseks. Asja saad veel optimeerida, kasutades võrgukaarte kus on peal oma IO protsessor, mis võtavad süsteemi keskprotsessorilt koormust maha. Intel Pro 1000 PT/MT jms..
p3 on lihtsalt budget näide. selline ront ei tohiks maksta midagi. Kui paned kokku vähegi kaasaegsema süsteemi, koos vähegi viisaka protsessori ja võrgukaartidega siis võid pmst igasuguse torrentide ühendusearvude piiramise unustada.
| Kommentaarid: 82 loe/lisa |
71 |
29.04.2014 06:59:25
Minu kodukohas on sama pilt nagu 100mbit yhenduse kaardil. Ainuke roheline punkt kaardil on elioni enda "maja"
Kuigi jägaja siin mingi aeg oli vist Jõelähtmes saanud vdsl yhenduse ka?
Edit: okei, yks teine maja on ka ikka roheline seal läheduses.
| Kommentaarid: 92 loe/lisa |
79 |
jepi
29.04.2014 08:46:56
| Mark0 kirjutas: |
| Samuti iga jumala nurgatagust konfist ei varundata - vaid see, mis on 95% juhtudest/kasutajatele vajalik. Niiet kui ikka on tähtis konf kokku joonistatud siis tasub enne varukoopia teha. |
Kas DHCP static leases on nurgatagune? Seda ju ei taastata...
Ja kuidas saab kasutaja ise Inteno'st backup'i teha või seda taastada? Vastav osa kasutajaliidesest on ju kinni keeratud...
Six
29.04.2014 09:09:14
Static leases läheb update käigus kaduma.
Intenost backupi vana softiga ei saagi teha.
Uus soft tuleb peale lasta, siis üks kord veel portide suunamised, static leases jms käsitsi sisestada ning siis saab juba uue softiga konfist backupi teha.
| jepi kirjutas: |
| Mark0 kirjutas: |
Ja kuidas saab kasutaja ise Inteno'st backup'i teha või seda taastada? Vastav osa kasutajaliidesest on ju kinni keeratud... |
39 |
jepi
29.04.2014 09:19:43
| indrekp kirjutas: |
Juhi tähelepanu ka sellele, et wifi parooli ennast ja ka kasutaja sisselogimisparooli ei taastata, need jäävad default'i (Wifi-Key ruuteri põhja alt).
Kui sellest võiks järeldada, et Elion ei salvesta neid enda süsteemis kasutaja privaatsuse/turvalisuse huvides, siis oleks see isegi positiivne.
Six
29.04.2014 09:51:41
Wifi SSID ja parool taastatakse automaatselt. Samuti Voice seaded kui on telefon kasutuses.
Sisselogimiseks peab keyd kasutama.
| jepi kirjutas: |
| indrekp kirjutas: |
Kui sellest võiks järeldada, et Elion ei salvesta neid enda süsteemis kasutaja privaatsuse/turvalisuse huvides, siis oleks see isegi positiivne. |
39 |
olafsand
29.04.2014 16:24:04
| Kuskohas seda versiooninumbrit menüüs näeb (kas see punane kiri kõige all?) ja kas uue softiga usb pesas nüüd ketas ka toimib nagu kunagi selle ruuteri tulekuga lubati.
| Kommentaarid: 62 loe/lisa |
59 |
29.04.2014 16:28:45
Ruuterisse logimisel avanenud lehel on olemas: iopsys Version DG301-W7P2U_ELION1.6.5RC1-131115_1731
Vist on see.
129 |
Six
29.04.2014 16:31:20
Just. Uus on iopsys Version DG301-W7P2U_ELION2.3.11RC1-140422_1519
| jägaja kirjutas: |
Vist on see.  |
39 |
olafsand
29.04.2014 16:37:16
Suured tänud!!! Oma peaga ma poleks osanud sealt küll vaadata
Lihtsalt restart ei anna uuendust veel igatahes. Kui ükskord hakkab kõigile tulema, siis teavitatakse restardi vajadusest või tuleb ise iga päev korra restart teha, et ruuter "uuesti võrku tulles" saaks uuenduse?
59 |
Six
29.04.2014 16:46:55
Reset on vaja teha, mitte restart.
| olafsand kirjutas: |
Lihtsalt restart ei anna uuendust veel igatahes. Kui ükskord hakkab kõigile tulema, siis teavitatakse restardi vajadusest või tuleb ise iga päev korra restart teha, et ruuter "uuesti võrku tulles" saaks uuenduse? |
39 |
olafsand
29.04.2014 16:47:52
| Six, hetkel jah, aga ega see nii ei jää ju? Normaalne on ikkagi uus soft ilma resetita saada. Hetkel resettijad saavad lihtsalt rutem, nii olen mina aru saanud.
59 |
Six
29.04.2014 16:55:21
Eks varem või hiljem hakatakse Elioni poolt peale pushima, mis sisuliselt tähendab ka resetti, ainult et portide suunamised (kui neid on) taastatakse Elioni poolt. Muu (nt DHCP static leases jms) läheb nagunii kaduma. Minu arust on parem asi ise ära teha, kui avastada üks hommik, et midagi ei tööta.
Aga valik on sinu...
| Six, hetkel jah, aga ega see nii ei jää ju? Normaalne on ikkagi uus soft ilma resetita saada. Hetkel resettijad saavad lihtsalt rutem, nii olen mina aru saanud. |
39 |
harakas
29.04.2014 19:24:23
| Varem oli juttu, et uue tarkvaraga tuleb võimalus Intenole USB kõvaketas lisada. Proovisin, aga kõvaketast võrgus näha pole. Või tuleb see Intenos kuidagi seadistada. Kuidas?
