olavsu1
külaline
17.04.2014 10:36:55
Opensuse 13.1::N68PV-GS::Jookseb külmboodil suvalisel hetkel kinni enne X'i käivitust. |
On selline masin:
Mobo: N86PV-GS
Video: Geforce GT440
OS: Opensuse 13.1
400W Fortron PSU
Jookseb külmboodil kinni , enne X'i käivitust. Pilt jääb seisma ja klaviatuur ning hiir ei tööta. Probleemi kõrvaldab reset nupp. Pärast seda töötab masin korralikult kuni järgmise külma käivituseni.
Logides vaid kaks viga:
17.04.2014 09:33:27 2014-04-17T09:31:05.859045+03:00 linux-zgzk kernel: [ 10.229031] nvidia: probe of 0000:00:12.0 failed with error -1
17.04.2014 09:33:27 2014-04-17T09:32:15.564459+03:00 linux-zgzk pcscd[2334]: Error: can't open /var/run/openct/status: No such file or directory
ja üks hoiatus:
| 17.04.2014 09:33:27 2014-04-17T09:31:08.537578+03:00 linux-zgzk ModemManager[584]: <warn> Couldn't find support for device at '/sys/devices/pci0000:00/0000:00:0a.0': not supported by any plugin |
mõned ignoreerimised:
17.04.2014 09:33:27 2014-04-17T09:31:05.859040+03:00 linux-zgzk kernel: [ 10.208260] NVRM: information. The 331.67 NVIDIA driver will ignore
17.04.2014 09:33:27 2014-04-17T09:31:05.859044+03:00 linux-zgzk kernel: [ 10.225831] NVRM: ignoring the legacy GPU 0000:00:12.0
lspci näitab järgmist:
su -c lspci
Parool:
00:00.0 RAM memory: NVIDIA Corporation MCP67 Memory Controller (rev a2)
00:01.0 ISA bridge: NVIDIA Corporation MCP67 ISA Bridge (rev a2)
00:01.1 SMBus: NVIDIA Corporation MCP67 SMBus (rev a2)
00:02.0 USB controller: NVIDIA Corporation MCP67 OHCI USB 1.1 Controller (rev a2)
00:02.1 USB controller: NVIDIA Corporation MCP67 EHCI USB 2.0 Controller (rev a2)
00:04.0 USB controller: NVIDIA Corporation MCP67 OHCI USB 1.1 Controller (rev a2)
00:04.1 USB controller: NVIDIA Corporation MCP67 EHCI USB 2.0 Controller (rev a2)
00:06.0 IDE interface: NVIDIA Corporation MCP67 IDE Controller (rev a1)
00:08.0 PCI bridge: NVIDIA Corporation MCP67 PCI Bridge (rev a2)
00:09.0 IDE interface: NVIDIA Corporation MCP67 AHCI Controller (rev a2)
00:0a.0 Ethernet controller: NVIDIA Corporation MCP67 Ethernet (rev a2)
00:0b.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2)
00:0c.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2)
00:0d.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2)
00:0e.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2)
00:0f.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2)
00:10.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2)
00:11.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2)
00:12.0 VGA compatible controller: NVIDIA Corporation C68 [GeForce 7050 PV / nForce 630a] (rev a2)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Link Control
01:08.0 Multimedia audio controller: Creative Labs SB X-Fi
02:00.0 VGA compatible controller: NVIDIA Corporation GF108 [GeForce GT 440] (rev a1)
02:00.1 Audio device: NVIDIA Corporation GF108 High Definition Audio Controller (rev a1)
võimalik et probleemi põhjus on GeForce 7050 PV / nForce 630a, mis ei ole uutes nVidia draiverites toetatud? Seda ei saa BIOS'e abil välja lülitada, seal saab valida vaid primaarset graafika kaarti, milleks on valitud pci-e.
Sama nali kordub win7 all.. seal jõuab masin enne kokkujooksu graafilise töölaua ette manada.
Mida soovitate järgmiseks?
obundra
17.04.2014 14:35:16
Kuna opsüsteemist olenemata viga kordub, siis ilmselt riistvara vigane.Kontrolli üle mälu, konded emaplaadil, toites ja videol, kettal bad sectorid, testiks külge teine toitekas jne.
_________________ Hold the heathen hammer high! |
| Kommentaarid: 27 loe/lisa |
25 |
olavsu1
külaline
17.04.2014 17:41:46
Mitte mingeid silmaga nähtavaid probleeme ei kusagil. Jahutuspastad uuendatud, originaal jahutuse asemel riputasin külge Arctic freezer A30 jahutuse.
hetkel sättisin bioses graafikakaardi tuvastuse vabriku vaikinisi sätte "PCI" peale, seal kolm valikut ongi (Onboard, PCI ja PCI-E)
näis mis järgmisel külmkäivitusel teeb.
17.04.2014 19:14:21
Ja ära värise toiteploki ees - see pole selline õel kast, mis kallale tuleb.
Ning sellised 400W Fortronid ongi need, väga tihti sellised, õnnetud mis igasugu jama kokku keeta suudavad.
Ja kui julged, vaata talle kaane alla - väga tihti on neil sees ka paisunud-lõhkised kondensaatorid. Sel juhul laenad naabrinaiselt jootekolvi ning vahetad need katkised kondekad välja.
211 |
olavsu1
külaline
17.04.2014 19:28:22
See fortron mis mul praegu, on üks töökindlamaid. Ma olen seda mitu korda lammutanud. peale tolmu pole seal muid probleeme olnud
töötand juba aastaid seitse. kui tal oleks mingi probleem siis ta enam ei käiks.
kaabakas
17.04.2014 21:17:27
Töökindel == probleeme ei esine Mul just läks üks soc939 masin, väga töökindla ~10 aastase vanakooli chiefteci plokiga. Ei saa ka öelda, et ta enam ei käinud, lihtsalt 12v oli ennast upgradenud 15v peale ja graafikakaart selle peale enam pilti ei joonistanud.
Mida ma tahan sellega öelda, midagi on sul katki, kiindumus või sisetunne saab määrata ainult järjekorda, milles juppidele otsa vaadatakse, mitte seda, et mõni jupp võiks järjekorrast välja jääda
95 |
17.04.2014 22:08:50
Ja kui sa vaid teaksid kui palju mul on surnud toiteplokkide kastis kõiksugu FSP tooteid, Fortrone on seejuures ikka väga suur virn. Fortron on selline odava skeemilahendusega tavatoide ja nende lemmikveaks on siis seesama, et nad kaotavad aja jooksul suure osa oma võimsusest ning siis kas lähevad kuidagimoodi veel tööle või ei lähe enam üleüldse tööle.
Nii, et võta prooviks mõni töökorras, vajalikku võimsust omav alternatiiv-toiteplokk ja kontrolli sellega üle.
Ja aga sul sellise käimamineku-veaga eriti valida pole - kas toiteplokk või emaplaat. Ise valid, kumba eelistad. Mina eelistaks igatahes toite kontroll-vahetust.
Ja veel - iga riigikorra ajal ning terves maailmas kehtib elektroonikamaailmas reegel, et vigade otsimist alustatakse alati toiteplokist ning see reegel sobib ideaalselt ka arvutiraua-maailma.
211 |
olavsu1
külaline
aht0
28.04.2014 15:30:50
Odavam oleks vast kohe olnud osta mõni vajaliku võimsusega SeaSonic.. Platinumid on kõige kallimad, aga kaasa saad ka 7a tehasegarantii.
| Kommentaarid: 82 loe/lisa |
71 |
olavsu1
külaline
29.04.2014 06:42:43
aht0, noh nende seasonicute jaoks peaksin kasutama liisingu teenuseid. Seega jäävad ära toiteplokid, mis maksavad üle 50€. või te arvate, et kõrge hind kaitseb praagi eest?
probleemi põhjuseks tundub olema BIOS. Biose reset kõrvaldas probleemi, iseasi kui kauaks.
29.04.2014 09:13:30
| olavsu1 kirjutas: |
probleemi põhjuseks tundub olema BIOS. Biose reset kõrvaldas probleemi, iseasi kui kauaks. |
Juba oma 100 aastat - või kauem - tagasi leiutati selline töövahend nagu tester ja see oskab oivaliselt mõõta toitepingeid.
Ja kui endal pole, siis naabrinaisel on see köögisahtlis täiesti olemas ja laenab seda sulle kui talle tordi viid.
211 |
olavsu1
külaline
29.04.2014 15:27:38
tahanteada, mul on olemas UNI-T M890G, DCM266L, Philips PM3217. missugust soovitad ?
ehk loed uuesti: käivitumise probleemid on toitest mitteolenevad.
kui lollitab, siis lollitab kõikide toidetega. ka tutika xilence XP550 plokiga.
