Vael
11.04.2014 16:53:34
| Windows Update 8.1: Väike parandus, tuleb välja, et kui arvuti lihtsalt mitu korda shut downi lasta, siis ei toimugi update. Tuleb CP "Restart nuppu" ikka vajutada. Nüüd Update peal ja uuendusi ikka näha oma silmaga ka. Desktop ja Start menüü hakkavad vaikselt ühtseks sulama.
11.04.2014 23:18:00
Ehk on kellelgi kasu järgnevast:
Microsoft’s Windows 8.1 WIMBoot Lets You Install The OS In Only 3GB Of Disk Space
Microsoft just made it feasible to install Windows on a small capacity solid state drive (SSD) or hard drive with not much space left. Using a new deployment option called Windows Image Boot, or WIMBoot, users can install Windows 8.1 in just 3GB of space. This is an option that could come in handy if you're rocking a system with a 16GB SSD or eMMC storage -- by using WIMBoot, you'd be left with more than 12GB of free space (after accounting for the size of WIM plus a little extra for overhead), versus only around 7GB if installing Windows the traditional way.
Read more: http://hothardware.com/News/Microsofts-Windows-81-WIMBoot-Lets-You-Install-The-OS-In-Only-3GB-Of-Disk-Space/#ixzz2yamDhEhU
Edit: Paistab, et on ka t6sisemad probleemid välja ujunud:.
Windows 8.1 Update woes pile up: Errors 80070020, 80073712, 800F081F, 80242FFF, 800F0922
WSUS is still down, as general update failures and complaints flow in the two days since the release of Windows 8.1 Update
Kogu teema lingil:
http://www.infoworld.com/t/microsoft-windows/windows-81-update-woes-pile-errors-80070020-80073712-800f081f-80242fff-800f0922-240249
MrAndu
12.04.2014 01:49:33
| VisaHinGG kirjutas: |
| Tomorrow kirjutas: |
| VisaHinGG, Paremklikk toimib siiani seal. Selles osas pole midagi muutunud. |
Hmm. Huvitav, mis siis uuendusega valesti läks, et minul selline kala praegu.
// Pole vist ainuke ( nagu alati ). Googeldades on nii mõnelgi 8.1 kasutajatal sama case olnud ja isegi enne Kevad Update-i. |
Kiire fix tuleb välja, et on uue kasutaja tegemine
_________________ Ma pole mingi spetsialist kuigi võiks ju olla... |
Oracle
12.04.2014 13:07:55
Win 8.1 uuenduse KB2919355 tõrked:
kood 80070005
kood 800F0902
kood 80073712
Vaatasin, et netis on päris paljudel probleeme selle uue uuendusega. Kogemus on näidanud, et mingi susimine ei tee asja paremaks vaid hullemaks. Ootan lihtsalt MS poolseid fixe.
12.04.2014 13:56:44
| Oracle kirjutas: |
kood 80070005
kood 800F0902
kood 80073712
Vaatasin, et netis on päris paljudel probleeme selle uue uuendusega. Kogemus on näidanud, et mingi susimine ei tee asja paremaks vaid hullemaks. Ootan lihtsalt MS poolseid fixe. |
MS väidab netis, et parandused on juba kättesaadavad, käsitsi allalaetavad.
Ning et Autoupdatesse jõuavad maikuus.
Oracle
12.04.2014 15:18:09
Oracle, MS poolne fix on Win8.1 ISO kuhu Update 1 sisse integreeritud. Kummaline see uuendamine ikka. U1 tuleb, et parandada kasutuskogemust. Osa inimesi ei saa seda peale ja peavad ootama parandusi selle jaoks, et saaksid paranduse peale lasta  |
Kui ISO-ga peale lased siis resetib ju settingud ja installitud programmid ära.
| tahanteada kirjutas: |
| MS väidab netis, et parandused on juba kättesaadavad, käsitsi allalaetavad. |
Oskad äkki linke anda?
12.04.2014 19:04:01
| Oracle kirjutas: |
Oskad äkki linke anda? |
Üks link näiteks ja sellele siis viitavad mitmed netilehed. Ehk abiks.
Error 0x80071a91 when installing update 2919355 in Windows
http://support.microsoft.com/kb/2939087/en-us
Oracle
12.04.2014 20:55:53
http://support.microsoft.com/kb/2939087/en-us |
Ehh, see uuendus on juba installitud. Ei aita.
kusti85
Tavaline kasutaja
13.04.2014 09:48:57
| Oracle kirjutas: |
Ehh, see uuendus on juba installitud. Ei aita. |
Ma oma errorist lahti ei saanudki, lõpuks läksin clean installi teed. Settingud on mul windowsis naguniii default valdaval juhul ja programmidki sellised, mille saab rahulikult postimehe lugemise kõrvale ära installitud.
_________________ Rockmuusikateemaline viktoriin Tallinnas - https://www.facebook.com/groups/rocktoriintallinn/
Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER |
13.04.2014 11:43:52
Sellest on siin juba juttu olnud, et W8Pro võtmega ei saa ametlikult W8.1Pro ISO faili alla laadida microsofti lehelt.
Mingi trikk oli aga W8.1Pro installimiseks W8Pro võtmega. Ei hakka see jutuke kusagilt hetkel silma. Kas keegi teadja saaks sellele viidata.
Ei taha seda 8.1 uuendust eraldi installida, vaid juba kohe õige asi paigaldada. Arvuti, kus mul see 8 peal, ei suutnudki seda uuendust peale lasta, alati oli mingi probleem 8.1 paigaldamisega. Videokaardi draiveri uuendus lõhkus nüüd midagi täitsa ära ja mõtlesin, et lihtsam on siis juba süsteem uuesti paigaldada.
allavett
13.04.2014 12:38:38
jägaja, kui 8.1 välja tuli siis mina tegin omale puhta installi 8.1 isoga. Installi ajal 8 võti ei sobinud, kasutasin üldvõtit (või kuidas iganes seda nimetada). Peale installi võttis aktiveerimisel ilusasti minu 8 võtme vastu.
_________________ Twitch.tv/allavett |
13.04.2014 12:57:49
8.1 paigaldad netist leitava "Generic key" abil ja peale paigaldust aktiveerid juba oma legaalse v8 võtmega.
Gizmoz
13.04.2014 16:10:13
| Kas 8.1 Enterprise on juba kusagilt saadaval ka ? Mõtlen iso kus see update 1 juba integreeritud?
pinTero
13.04.2014 16:23:47
Huvitav küll - peale keelepaketi installi on Avakuva parema klõpsu menüüd ikka osaliselt inglise keeles. Bug?
Mis puudutab Win8.1 installi Win8 võtme omanikele, siis selle jaoks on üks lihtne nipp:
Installikausta alamkausta Sources tuleb tekitada fail nimega ei.cfg. Või kui see fail juba on olemas (nagu oli nt. lekkinud MSDN ISO failil), siis tuleb seda lihtsalt natuke muuta - kustutades [EditionID] tagant ära versiooni rea.
Sel juhul võtit ei küsita ning saab aktiveerida peale installi W8 võtmega. [Channel] ja [VL] rida peavad ka muidugi olema võtmele vastavad.
Näiteks OEM versiooni installimiseks tuleb teha selline ei.cfg:
[EditionID]
[Channel]
OEM
[VL]
0
Forss
d3t
13.04.2014 18:17:25
pinTero, reboot. Mul toimib normaalselt tõlge.
_________________ IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
olafsand
13.04.2014 18:24:05
| Oskab keegi palun aidata, et kuidas saaks vbs scripti adminni õigustega w8.1-ga käima?
14.04.2014 09:34:00
| olafsand kirjutas: |
| Oskab keegi palun aidata, et kuidas saaks vbs scripti adminni õigustega w8.1-ga käima? |
CMD adminni õigustes käima ja siis sealtkaudu...
olafsand
14.04.2014 11:47:30
| Etz kirjutas: |
CMD adminni õigustes käima ja siis sealtkaudu...  |
Kui CMD adminnina käima panna, siis drag&drop ei tee teist nägu ka. Kui CMD kaudu käsuridadega asi käima panna, siis annab veateate, et script on katki
Aga sain muu lahenduse teistsuguste failidega juba ja asi korras.
d3t
pinTero
14.04.2014 17:41:53
Kas keegi oskab seletada, miks see Windows 8.1 Update hetkeseisuga automaatselt üheski arvutis peale ei lähe?
Windows Update kenasti näitab, et on 1 oluline uuendus, kuid mingil põhjusel tuleb see ikkagi käsitsi märkida ning alles siis hakkab tirima ja installima. Sama seisu olen näinud vähemalt kümnes erinevas masinas ja ei aita ka restardid ega midagi..
Võibolla läheb automaatselt siis alles mingil kindlal kuupäeval?
olafsand
14.04.2014 17:43:36
pinTero, inimestele on jäetud valikuvõimalus, väga normaalne ju. Igaüks ei taha vb metro äppe taskbarile jne
pinTero
14.04.2014 17:46:29
pinTero, inimestele on jäetud valikuvõimalus, väga normaalne ju. Igaüks ei taha vb metro äppe taskbarile jne  |
Valikuvõimalust ma mõistan aga kuna tegu on uuendusega, millel juures kiri Tähtis ning väidetavalt veel nõutud uuendusega Win 8.1 süsteemidele, et üldse edaspidi uuendusi saada, siis natuke loogikavastane, et asi automaatselt peale ei lähe..
Aga ju ta millaski läheb ka ilma käsitsi sekkumiseta.
14.04.2014 18:41:21
microsofti strateegia läbi aegade. service packid ja muu selline kraam on alguses mõnda aega valikuline, hiljem surutakse kõvemini peale. eks seal taga ilmselt potentsiaalsete putukate tagaajamine on.
kui pole seatud nii, et "tähtsad" uuendused koos "kriitilistega" peale ei lähe, siis hetkel ei lähegi.
_________________ - londiste
d3t
pinTero
15.04.2014 23:27:31
d3t, sedasama ma ju rääkisin ise ka, et on nii oluline asi, aga automaatselt peale ei lähe. Manuaali peale ei ole ma ka üheski masinas uuendusi keeranud..
Eks saab nüüd jälgida - enne maikuu paikasid ilmselt see ikka automaatselt ära märgitakse ja peale lastakse.
Rääkides bugidest, siis neid ikka leidub. Puhas värske install Win 8.1 koos Update'ga meedialt, + värske Office 2013 Home & Studenti paigaldus ja aktiveerimine - peale mingit viimast Update'i enam ükski Ohvitsi rakendus käima ei lähe Ei tule mingit veateadet ka mitte - lihtsalt ikoon läheb korra aktiivseks ning siis taastub. Restart muidugi ei aita, ega ka quick repair. Asi taastub, kui teha ohvitsale Online Repair, mis on vist sisuliselt netti mööda reinstall..
Microsofti maailm on vahest ikka sürr
Dave20
15.04.2014 23:43:22
| Mis tähtsust sellel on kas Windows 8.1 Update läheb automaatselt peale või mitte? Hea on, et automaatselt ei lähe, sest paljud äkki ei taha seda installida, ise ka kahetsen, et peale panin selle.
kusti85
Tavaline kasutaja
15.04.2014 23:44:54
| Dave20 kirjutas: |
| Mis tähtsust sellel on kas Windows 8.1 Update läheb automaatselt peale või mitte? Hea on, et automaatselt ei lähe, sest paljud äkki ei taha seda installida, ise ka kahetsen, et peale panin selle. |
Miks kahetsed?
Dave20
15.04.2014 23:48:40
| kusti85 kirjutas: |
| Dave20 kirjutas: |
Miks kahetsed? |
Windowsi ikoonid desktopis peale selle Update installimast mitu korda kinni jäänud, et ei saa midagi teha. Äkki on muidugi mingi teine teema sellega...
Vael
16.04.2014 04:31:43
| Dave20 kirjutas: |
| kusti85 kirjutas: |
| Dave20 kirjutas: |
Miks kahetsed? |
Windowsi ikoonid desktopis peale selle Update installimast mitu korda kinni jäänud, et ei saa midagi teha. Äkki on muidugi mingi teine teema sellega... |
Mul kiilus just enne uuendust pidevalt kinni;)
WäntWõll
make.believe
16.04.2014 10:33:46
tahanteada, 5 posti üleval on lingitud ametlik allikas ise, milleks jälle kolmanada osapoole pläma
16.04.2014 10:46:26
| WäntWõll kirjutas: |
tahanteada, 5 posti üleval on lingitud ametlik allikas ise, milleks jälle kolmanada osapoole pläma  |
Vaat ikka see, mida maailma suurimad ja parimad meediad kirjutavad, pole mingi pläma. Seda enam, et inimesed ei külasta MS-i ametlikke lehti, küll loetakse usinasti seda, mida laiatarbe-meedia - ja lahtiseletatuna - kätte toob.
Kas näed väikest vahet? Selles suhtes teeb välismeedia igatahes väga õigesti, et selle MS-i "ähvarduse" lugejatele lihtsaks ning arusaadavaks "tõlgib". Ja mille järel inimesed teavad, mis neid ees ootab või ei oota.
Ja vana tuntud nähtus, kus MS-i fännid ja Fännklubid ainult omaette nokitsevad ja ei taha midagi kuulda sellest kui meedia nende käes oleva info massideni toob.
16.04.2014 10:57:10
tahanteada, ehk siis tühi sääsest elevandiks puhumine on hea asi?
WäntWõll
make.believe
16.04.2014 11:02:51
Ja vana tuntud nähtus, kus MS-i fännid ja Fännklubid ainult omaette nokitsevad ja ei taha midagi kuulda sellest kui meedia nende käes oleva info massideni toob.  |
Ajasid Postimehe kommentaariumi ja HV foorumi segamini
Dijital
16.04.2014 11:04:57
Kasutaja X - LINK UUDISELE
Kasutaja Y - LINK UUDISELE
tahanteada, miks sa arvad, et Kasutaja Y link parem on ja rahvas just seda klikkima läheb? Kes loeb MS uudiseid, loeb selle uudise juba MS lehelt; kes loeb Forbes'i, loeb selle uudise sealt. Kui sa paned sama infoga lingi, siis ütle kohe ära koos põhjendustega, miks see parem on. Või kui sa seda teha ei taha, siis jäägi vaid oma uudisvihjete foorumisse, kus saad lihtsalt niisama oma linke toppida.
joffe
16.04.2014 11:33:25
| On ehk kellelgi aega ja tahtmist välja uurida ja avalikult teada anda, kas win8.1- s on teostatav sellise teenuse installimine, nagu oli winXP- s Outlook Express. Tunnen kohutavalt puudust! Tänud ette!
16.04.2014 11:38:13
Edit: Vaatasin Eesti ajalehe- ja Delfi-meedia hoolega läbi, kusagil pole MS-i fännid ja MS-i fännklubid sõna võtnud, et maikuust Windows 8.1 enam turvaparandusi ei saa.
Nii, et igati OK, et Forbes, kui maailma üks kuulsamaid meediaid, selle teema üles tõstis ja maalähedalselt kõik lahti selgitas.
Aga loodan, et selle Forbesi loo baasil ka nüüd nii mõnigi kohalik meedia ka vastava loo kirjutab.
UrmoZ
16.04.2014 11:39:52
Outlook Express - ei.
MS-ilt endalt Windows Live Mail (2012), mis on Windows Essentials (2012) paketis.
Või Mozilla Thunderbird.
_________________ Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri! |
napoleon
Unknown virus
Pikkkõrv
16.04.2014 12:08:05
| joffe kirjutas: |
| On ehk kellelgi aega ja tahtmist välja uurida ja avalikult teada anda, kas win8.1- s on teostatav sellise teenuse installimine, nagu oli winXP- s Outlook Express. Tunnen kohutavalt puudust! Tänud ette! |
Win 8.1-s asendab seda Microsofti app Mail. Kui see ei meeldi võib kasutada aga näiteks tasuta Thunderbirdi. Ei usu, et see Outlook Express midagi asendamatut sisaldaks. Asi ilmselt rohkem harjumuses kinni aga selle kord ületanud paneb vahel ka ennast imestama, et miks ma juba varem uuemat või alternatiivset tarkvara ei vaevunud proovima!
Mnator
16.04.2014 12:24:30
Pikkkõrv, sisseharjunud kasutusmugavus on tähtis tegur
joffe
16.04.2014 13:48:22
Hädised on nad kõik minu silmis- aadressiraamatut ega ka kontakte üksikult ei anna ühelegi kopeerida, kontodega on samuti nutune lugu-üks ei lase vabaversioonil üle kahe konto vormistada, Thunderbird ei tuvasta mail.ee kontode seadeid. Jama üldiselt.
libe
kvaliteetne mees
1dumbpcuser
20.04.2014 12:38:54
Kas sleepist/long idle-st üles tulles ekraani mitte ette manamine on mingi "feature"?
Lauaarvutil HD7970-ga on mure W8.1-l, kui mingit koormust (jooksev torrent, yt video pausil vms) arvutil pole, siis peale pikka seismist ei võta monitor enam pilti ette. Algselt arvasin, et tegu on 7970 kalaga (proovitud 2-3 erinevat tüürelit), aga kui ka mu 7-8 aastat vanal rüperaalil, millel Win8.1 Update1 pealevägistatud nVidia tüürelitega mõned tunnid monitor kustus olekus seisis, ei saanud pärast samuti pilti ette (ilma hard restardita), siis kipub olema Win probleem. Või on mul miski linnuke power settingute vms alt märkamata jäänud. Lauaarvutil Inteli lõimitud HD graphics-iga muret ei olnud...
_________________ M: MSI B660M MORTAR
O: AM5 ITX emaplaat |
Q.
20.04.2014 12:51:14
| Selles osas tundub tõesti 8.1 üsna jonniv olevat. Mitmete erinevate masinatega sama probleemi otsa komistanud.
1dumbpcuser
22.04.2014 20:55:07
Sahinat ka natuke, ehk kui nii läheb, siis augustis-septembris saab Windows 8.1 järgmist uuendust ( update 2 ) näha ja katsuda.
Russian leaker WZor is claiming that there will be an update 2 for Windows 8.1 coming this September. My sources say that date could be August. In either case, a second update looks like it will hit just five or six months after Microsoft made Windows 8.1 Update available.
Jutt ise siis lingil:
http://www.cnet.com/news/microsoft-to-further-speed-up-windows-release-cycle/
