(PC version)
Taking off bug : the jet can't seem to take off before getting to the end of the runway.
Was especially hilarious in a game today as both pilots in gulf of Oman started their engines at the same and ended in a metal blaze a few seconds after.
Vot selle peale panin küll hea kajaka maha. Siiani kõikides kaartides alustasid lennukid kohe õhust. Nüüd kus nad maale tagasi pandi, avastati, et üks featuur lennukitest on lihtsalt koodimata jäetud? _________________ www.oggym.ee // OG Gym // Pärnu, Roheline 74
Ahhaaa isegi caspianis võtsin lennuki krt ei tõusnud õhku mõtlesin et fly invert panemata jäänud kurja sellega teist korda ka ei tõusnud õhku no on ikka parajad jebid sellega,ausalt öeldes ei viisti isegi pelada seda enam,mitte enne kui korda tehtud see möga.
Nii kauaks võtan kaamera kätte ja lähen õue pilti tegema,jääb mõni närv vähemalt alles.
Using IRNV does not always trigger the infrared vision. Sometimes you need to switch to handgun and then back to primary weapon. Mostly noticed it with MG4.
Being revived makes your bipod un-deployable.
Ugly textures on all new maps. (DLC tegi DICE L.A, mis on keskendunud konsoolimängudele)
Assignments are bugged : you still get notifications about them when they are completed and the game forgets that you have already completed a task, like getting ribbons, getting a 10 men kill streak or landing in top of the tower.
Joining Operation Metro on any game mode results in an instant sound-loop freeze forcing to kill the bf4 process with the task manager
Random FPS drops and rubberbanding/lag on all SA maps
PC [Admin] - Map changing is bugged. Sometimes even switching maps mid game. Sometimes it doesnt run both rounds of Rush, sometimes it does, even on the same map.
On Gulf of Oman all of the water appears as bright or "hot" in IRNV/thermal in tanks/IFV. Haven't tried weapon attachment versions.
Being revived, and dying shortly afterwards now causes the game to fuck up and stop you respawning or redeploying - the only option is to quit and rejoin.
Sound loop crash on Metro, only happens during levolution (i.e. collapsing parts of ceiling)
I don't know how regular it is, but last night on Oman CTF, the 'end of the game' music started playing about halfway through the match. No big deal but it got pretty annoying after 20 mins of it.
Freeze Display Sound Loop Crash
cant knife people out of stationary guns
cant kill a counter knifer with bullets until the animation has ended
Ja see list ei lõppe siin, vaid on veel kordades pikem. Noppisin need millega endal kokkupuudet on olnud.
Võibolla tõesti kui sa ühte kahte mappi mängid ja koguaeg ühe relvaga, siis tõenäoliselt ei satugi bugide otsa aga need kes mängust tahavad 100% ära kasutada (kõike proovida), leiavad need pikemalt otsimata üles. _________________ | SPARCO toolid https://www.carshop.ee/et/2374-sparco | Tuuningosad mootorsõidukitele - www.carshop.ee |
Lehys, äki on mingit abi minu infost. Kunagi vahetasin operaatorit ja samas neti yhendust kiiremaks (soomes). Peale seda muutus ping lubamatult suureks. Helistasin ja sealt öeldi, et pean kodus oma juhtmeid ja arvutit kontrollima jne. Paar päeva uurisin ja kui olin veendunud, et minul köik korras, vötsin yhendust ja palusin asjale selgust. Samas ka andsin möista, et arvatavasti vahetan operaatori endiseks, kuna neil see asi ei tööta nagu minule vaja.
Järgmine päev oli asi korras! Selgus, et neil oli midagi väga valesti. Vabandati ja tänaseni pingiga probleeme ei ole olnud.
Mina ei ole BF4-a puhul pingi töusu märganud. Soome, rootsi, eest ping umbes 12-25, saksa, venemaa 45+ ...
Ega kui nüüd Starman tegutsema ei hakka (ning nagu tuli välja, isegi Lehysele nad olid pmst öelnud, et all 70 pingiga nad ei hakka lillegi liigutama), siis tuleb vist "ähvardused" teele panna operaatori vahetuse suhtes. Tea, kas see ka neid kotib.
No hetkel pole muud probleemi Starmaniga esinenud. Ausaltöeldes ei viitsiks väga hetkel vaid selle pärast vahetust ette võtta. Hetkel veel ma väga loodan, et Starman seesugustele mitmetele kaebustele ka reageerib ning võtab midagi ette, et "vana seisukord" taastada. Kui nad ei suvatse midagi teha, siis paraku tõesti tuleb vaadata muud teenusepakkujat.
Vaatasin seda videot : http://www.youtube.com/watch?v=cVuHzSx5zSo, viive on. Aga kas ikkagi nii paha, et karvu peast peaks kiskuma? Loomulikult on rumal kui alles nurga taga pihta saad jne. aga....
Lohutan ennast sellega, et päris kuulil kulub ka aega A - B punkti jöudmiseks. Kas sellega vörreldes, on kui suur see viive, või tuleb see viive veel sellele lisaks ? Kindlasti rumal lohutus ja kysimus enda jaoks aga andke jullgelt kriitikal tulla
viimati muutis Avot 20.02.2014 17:19:43, muudetud 1 kord
Mina juba mainisin starmanile saadetud kirjas, et kui nad midagi ei tee, siis vahetan operaatorit! Ma ei saa aru kuidas see teema just mingi 1kuu jooksul on tulnud... Kordan veel, et varem oli ping väga hea näiteks HV serveris 5 nüüd 45, täielik jura ju
Dave20, proovi sellega http://www.speedtest.net/ . Kas ei ole vöimalik et see oleneb mängust, mitte operaatorist? Mina märkasin oma pingi jubeda töusu just selle programmiga. Aga see oli mingi paar aastat tagasi.
viimati muutis Avot 20.02.2014 17:24:00, muudetud 1 kord
Avot, Ka seal on Rootsi serveriga ping 40-50 juures. Siiski nagu siin teemaski välja tuleb, siis väga paljudel Starmani klientidel see probleem Rootsi/Soome ja ehk mõndade serveritega veel.
Siim159, Minul siit idasoomest on rootsiga 20- max 30. Soomel ja rootsil minule palju vahet pole. Tihti isegi ainult 15 (öösel). Pean silmas just BF4 mängu pingi.
Dave20, selle programmiga peaks minu meelest Tallinnas - Helsingisse ping olema max 15-20, kui rohkem siis mingi pidur peal.
viimati muutis Avot 20.02.2014 17:42:39, muudetud 2 korda
Dave20, julgen amatöörina nendes asjades soovitada, tee restart oma modeemile ja mööda uuesti, vaata kas on abi.
Mängudes tulevad teised serverid veel vahele, nagu selles teises videos näitas/seletas, seega ping töuseb vörreldes selle programmiga, millega just möötsid.
Ei olnud abi modemi restardist. See probleem juba ju nüüd paljudel, varem oli korras kõik....
Ma jällegi leian, et ruuteri restart ei tohiks kuidagi aidata. _________________
Tahtsin pärida ka, et mis on foorumlaste arvates parim Bolt on sniper (kaugus, täpsus, kiirus)?
Pole veel SRR-61 proovida saanud aga GOL Magnum ajab hetkel asja ära. Muidu kasutasin M40A5, kiireima tulega bolt-action Betalfield4-jas _________________ | SPARCO toolid https://www.carshop.ee/et/2374-sparco | Tuuningosad mootorsõidukitele - www.carshop.ee |
No vabsjee nalja, lasi täna M1911 püstoliga vastasele 2 lasku rindkerre(hardcore servus) ta oli minust umbes 7m kaugusel, lõpuks lasi tema minu maha ja tal oli 100% elusi vabsjee lõbus ju.
Starmani kaitseks ütlen seda, et 5 a. siiani pole olnud mitte ühtegi probleemi ja ping on olnud kõikidest elioni sõpradest oluliselt parem igale poole! Okei.. on servereid kus võibolla starmaniga +5 vs elion aga thats it kah.
Nüüd viimase kuu jooksul on hakand igast jama toimuma, disconnectid.. lossid, rootsi ping 15 asemel 50 jne...
Võtan vist ise kah homme nendega ühendust, et natuke survestada vms.
Kahju, et starmanil mingit foorumit ei ole...
Minu teada ükski ISP ei garanteeri sulle kindlat "latentsi" suvalisse maailma punkti... _________________ ...life is random...so am I...
viimati muutis Etz 20.02.2014 19:49:25, muudetud 1 kord
Heh, tahaks ka uut dlc proovida ja nüüd vast mõtet premiumit kah omada mis ennem oli nagu täiesti mõttetu kui china oli olemas. Et kui kellelgi on juhuslikult üle siis ootan sõnumit
(kasutaja Defon50 pole kaua käinud foorumis )
Kindlasti võta ühendust nendega. Need jamad ongi just viimase kuu jooksul hakanud, muidu oli starmani ping parem kui elionil.
starman pakub ju 2x suuremad downloadikiirust kui elion, logish et ping peaks suts parem olema.
aht0, ei ole loogiline 2x suurem kiirus võib vabalt olla 2x suurema pingiga ühendus.
ping ja pakettide suurused mida põrgatatakse serveri ja kliendi vahel arvutimängudes on nii väikesed, et põhimõtteliselt piisab 5-se pingi jaoks <1mbs down ja 512kbs up.
kõige suurem pingi mõjutaja on teekond serverini, ilmselt starmani ühendus ei jõua rootsi serveriteni sama teed pidi kui see oli siin mõned nädalad tagasi _või_ on starmanil kuskil võrgus mingi jama.
Samas ei pruugi see ka olla starmani võimuses kuna see mis teedpidi kellegi ühendus suunatakse läbi värgu ei ole alati ISP teha.
Teekond minu kodust webhalleni bf4 serverisse:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 6 ms 7 ms 6 ms 10.160.0.1
3 * * * Request timed out.
4 7 ms 7 ms 15 ms 213.242.123.5
5 49 ms 51 ms 48 ms ae-14-14.ebr2.Berlin1.Level3.net [4.69.143.122]
6 49 ms 52 ms 51 ms ae-1-100.ebr1.Berlin1.Level3.net [4.69.148.205]
7 45 ms 49 ms 50 ms ae-214-3604.bar1.Stockholm1.Level3.net [4.69.159.13]
8 50 ms 51 ms 53 ms AVAILO-NETW.bar1.Stockholm1.Level3.net [213.242.110.42]
9 52 ms 55 ms 56 ms ae6.se.sto.dch.cr0.port80.se [82.96.1.101]
10 48 ms 53 ms 51 ms po2.se.sto.dch.dr1.port80.se [82.96.1.34]
11 55 ms 49 ms 53 ms 82.96.62.68
nagu siit näha siis vahepeal on mingit totaalne porr.. Berlin1? wut? Põhimõtteliselt käime me starmaniga läbi saksamaa rootsi...
varem oli webhallenisse 7 hoppi vms :\
Niimoodi läheb starman netonnet-i kus oli mul viimati ping 12, nüüd on 50+
viimati muutis ottf 20.02.2014 22:55:19, muudetud 1 kord
võrdluseks:
Tracing route to 82.96.62.68 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.1.1
2 <1 ms <1 ms <1 ms 192.168.66.1
3 2 ms 1 ms 2 ms jhv-sr1-irb-1004.ee.estpak.ee [194.106.101.81]
4 1 ms 1 ms 2 ms jhv-bb2-xe-7-2-0-0.ee.estpak.ee [90.190.134.120]
5 4 ms 4 ms 4 ms kjj-bb2-xe-1-1-0-0.ee.estpak.ee [195.250.191.76]
6 4 ms 4 ms 4 ms kjj-bb3-xe-1-0-0-0.ee.estpak.ee [194.126.123.97]
7 13 ms 12 ms 12 ms netnod-ix-ge-a-sth-1500.port80.se [194.68.123.143]
8 12 ms 12 ms 12 ms vl1301.se.sto.dch.dr1.port80.se [82.96.1.245]
9 12 ms 12 ms 12 ms 82.96.62.68
kohalik micro internetipakkuja, aga elion peab olema põhivõrguks.
okei, minu (Elioni) traceroute võrdluseks
traceroute to 82.96.62.68 (82.96.62.68), 30 hops max, 60 byte packets
1 90.191.160.2 (90.191.160.2) 0.474 ms 0.382 ms 0.375 ms
2 the-bb1-xe-7-2-0-0.ee.estpak.ee (90.190.134.90) 0.716 ms trt-bb1-xe-2-2-0-0.ee.estpak.ee (90.190.134.232) 0.654 ms the-bb1-xe-7-2-0-0.ee.estpak.ee (90.190.134.90) 0.703 ms
3 jhv-bb1-xe-8-0-0-0.ee.estpak.ee (195.250.191.124) 2.588 ms prn-bb2-xe-7-3-0-0.ee.estpak.ee (195.250.191.37) 2.925 ms jhv-bb1-xe-7-0-0-0.ee.estpak.ee (195.250.191.97) 2.622 ms
4 kjj-bb2-xe-11-0-4-0.ee.estpak.ee (195.250.191.29) 4.983 ms noe-bb1-xe-0-2-4-0.ee.estpak.ee (195.250.191.25) 5.100 ms kjj-bb2-xe-11-0-2-0.ee.estpak.ee (195.250.191.89) 5.677 ms
5 kjj-bb3-xe-1-1-0-0.ee.estpak.ee (194.126.123.99) 22.709 ms kjj-bb3-xe-8-1-0-0.ee.estpak.ee (194.126.123.107) 22.441 ms kjj-bb3-xe-8-0-0-0.ee.estpak.ee (194.126.123.105) 22.323 ms
6 netnod-ix-ge-a-sth-1500.port80.se (194.68.123.143) 14.138 ms 13.206 ms 13.158 ms
7 vl1301.se.sto.dch.dr1.port80.se (82.96.1.245) 13.516 ms 13.447 ms 13.296 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
DNS servereid käsitsi vahetades ei ole mingit muutust?
Peale vahetust tee ipconfig /flushdns ka
ottf kirjutas:
väga huvitav, miks kogu starmani jama läbi USA käib? level3.net -i?
et NSA saaks pealt kuulata?
delfi.ee - otse
delfi.lv - läbi usa
ukraina webid - läbi usa.
hmmmmmmmmmm whats going on?
peaaegu kõik käib läbi usa mis ei ole meie riigi sisene
vaevalt, nad kuulavad rootslaste raadioluure abiga seda Läänemere kaablit niikuinii pealt.
