gemini
24.02.2004 18:20:49
| Mr.T.Y.Y.T kirjutas: |
| Ma ei mängi AA-d aga ma küsin kas see 203 on granaadi heitia M16 küljes? V6in ka puuse panna... |
You got it right
| Kommentaarid: 75 loe/lisa |
61 |
.leraak
24.02.2004 19:07:20
Kui ma tapan oma meeskonnakaaslase, kas siis -1 honorit on kindel laks?
Kaks korda on juba hoorit vähendatud
_________________ Parim enne: 07.06.2006 |
| Kommentaarid: 19 loe/lisa |
16 |
devean
24.02.2004 19:15:45
| ei ole kindel laks saad mingi umbes 200 miinus punkti honori vähendamiseks on vaja 500 miinust
| Kommentaarid: 41 loe/lisa |
38 |
gemini
24.02.2004 22:13:29
| kjogeva, miks ma sind trackeris [HV] tiimist ei leia? Whoaa...Mis ajast mul Private auaste on? Ja mis valemiga seda üldse määratakse?
61 |
.leraak
25.02.2004 00:36:36
Nüüd leiad .
16 |
vilkuur
25.02.2004 01:54:01
(Experience + Activity + Popularity) / 3 - nii need auastmed tulevad
Required Stats Rank Title Rank Image
0% Recruit
5% Private
10% Private First Class
15% Specialist
20% Corporal
25% Sergeant
30% Staff Sergeant
35% Sergeant First Class
40% Master Sergeant
45% First Sergeant
50% Sergeant Major
55% Second Lieutenant
60% First Lieutenant
65% Captain
70% Major
75% Colonel
80% Major General
85% Lieutenant General
90% General
Nii et paguneid teenima
95 |
vilkuur
25.02.2004 02:03:44
Activity Bar: The onlinetime in hours multiplies with your FragRate.
Calculated: (Onlinetime * FragRate) = Activity in percent
Popularity Bar: For the popularity bar you need Leader- and Goalscore, not so much ROE and a good FragRate
Calculated: ((Leaderscore + Goalscore - ROE)/500) * FragRate = Popularity in percent
Experience Bar: The experience is calculated by your total score and Fragrate
Calculated: Total Score / (FragRate * 100) = Experience in percent
Vot siuke värk.
95 |
Troll
25.02.2004 03:26:33
Kas ma nüüd sain õieti aru:
1)Onlinetime (34,1) X FragRate (2,91) = 99,23% ?
2)Leaderscore (3180) + Goalscore (7523) - ROE (497) : 500 = 20.41%
3)Total Score (13273) : Fragrate (2,91) X 100 = 45,61%
Ning kokku siis 99,23+20,41+45,61 : 3 = 55,08%
Sel juhul oleks mu auaste Second Lieutenant !?
Aga selle esimese arvutusega on midagi mäda, näiteks leidsin Trackeri TOP-listis kuti, kelle Fragrate on 5,3 ja mänginud 1043 tundi, temal tuleks see arvutus 5527% ? Või sain mina millestki valesti aru?
_________________ TÜMPA, TÜMPA...EEST ÄRA, TROLL TULEB!!! |
121 |
Le Inc
25.02.2004 09:39:12
Mul ütleb et 99% on järgmise "auni", aga ROE võtab pidevalt punne alla ...
| Kommentaarid: 56 loe/lisa |
54 |
vilkuur
25.02.2004 10:18:35
The Activity, Popularity and Experience Bars in your AAO Profile are the average statistics of your detailed Map Stats! So you must earn Activity, Popularity and Experience on every Map when you want a high bar and a high user rank. When you only playing two or three Maps you will not get a high userrank.
Selle lõigu jätsin tähelepanuta, aga annab vastuse. Peab lahmima ühteviisi hästi kõiki mappe ja siis juba fragratet kõrge naljalt ei hoia.
_________________ The first principle is that you must not fool yourself — and you are the easiest person to fool. |
95 |
gemini
25.02.2004 13:32:05
| Btw, ärge seda trackeri honori-asja uskuge. Valetab jubedalt. Mul vahepeal tracker väitis, et järgmise honorini 218p, tegelt oli aga 802p vaja.
61 |
vilkuur
25.02.2004 13:58:57
Honor küll, aga see selle kohta, mismoodi seda auastmete värki aetakse.
8.23 honoriga vend on näit. ainult specialist.
Generale on aint 41, trackeris a´300 päeva ja panevad enamasti kõiki mappe.
95 |
DigeBeni
| Kommentaarid: 194 loe/lisa |
160 |
.leraak
04.03.2004 16:58:01
Head uudised, varsti peaks Stockholmis AAO official server käima minema.
Loodetavasti saab siis mängida normaalsema pingiga .
http://aaotracker.4players.de/
16 |
vaits (est
04.03.2004 18:24:51
| kas uus eesti server jälle tulnud gamespy näitab (KATSELOOMA)
Killer007
05.03.2004 15:00:48
selline küsimus et kas ma ainuke kellel AA fullscreenis 60Hz? vahet pole kas eraldusvõime on 800*600 või 1280*960
see natuke segab. aknas on ikka nagu windowsis - 85Hz..
| Kommentaarid: 7 loe/lisa |
.leraak
05.03.2004 16:22:23
Kasuta RefreshForce'i .
16 |
MadMan
05.03.2004 16:25:43
RefreshLock ka abx, kuid viimasel ajal on nVidia driverist pandav Override refresh rates kah täitsa töötav lahendus. Näpid sealt ühe korra paika kõik ja voila.
_________________ Ikka Saab
~~NetMusique~~ |
| Kommentaarid: 31 loe/lisa |
29 |
Killer007
05.03.2004 21:08:10
tänan..sain korda
mul oli tglt juba olemasolevate nvidia draiveritega võimalus Refresh Rate Overrides'i muuta
silmadel kohe parem elu
HDvurle
HV pensionär
08.03.2004 22:45:39
Proovisin KATSELOOMA, ping töllerdas 120 kuni 400.
Asub eestis, aga pelada korralikult ei saa , mõnel vennal oli ping 1024 .
Kuidagi saast tundub.
_________________ Teie küsimused on vastatavad, kuid meie vastused on küsitavad.
IT uudissõnad. Pihuarvuti - pihkar, pihuarvuti kasutaja - pihkur. |
| Kommentaarid: 21 loe/lisa |
16 |
Matzz
09.03.2004 19:16:47
Tekkis mul siis üks päris loll kysimus et kus see SF SandStorm mapp asub ??
Endal on nagu k6ik treeningud läbi tehtud aga seda mappi ma ei leia w6i on tal siis mingisugune teine nimi ?
Pildid siis minu mappide menyyst: 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 .
| Kommentaarid: 9 loe/lisa |
9 |
HDvurle
HV pensionär
09.03.2004 19:20:37
Mis Versioon Sul on? 2.0.0 või 2.0.0a?
SF Sandstorm peaks olema ver. 2.0.0a-ga.
16 |
Matzz
09.03.2004 19:22:00
| Linnavurle kirjutas: |
SF Sandstorm peaks olema ver. 2.0.0a-ga. |
peaks ikka olema 2.0.0a aga kohe vaatan järgi
Nujah ja ongi 2.0.0 , lihtsalt olin liiga kindel et mul on 2.0.0a kuna installimisel nagu ütles seda aga jah....
9 |
HDvurle
HV pensionär
09.03.2004 21:55:23
Tiri AA lehelt patch 2.0.0 -> 2.0.0a. Jõudu.
16 |
MorRAW
Ei ole Guru
09.03.2004 22:15:57
1) Kas kuidagi saab muuta teadete värvi? Hetkel see haige heleroheline, seda on ikka VÄGA raske näha. Ja pea keeramine võib kaasa tuua surma
Pidi saama kuskild HUD'i alt...eks kaen. Tänud klemm.
2) Kuidas saab raporteerida vaenlase asukohast? Nii et tekib sinna teadete alla korralik mängu poolne stamp väljend.
_________________ https://www.instagram.com/morrowshoots/
http://www.morrowshoots.com |
| Kommentaarid: 372 loe/lisa |
314 |
