uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Motorola Moto X märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4  järgmine
renhoelder
renhoelder
sõnum 05.08.2013 21:36:07 vasta tsitaadiga
Esimesed ülevaated ka:
The Verge
Engadget
Phone Arena
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 70
pal
sõnum 11.09.2013 11:19:07 vasta tsitaadiga
Kas kellelgi on ideed kuidas Moto X-i Maarjamaal omandada?
villu70
villu70
sõnum 15.09.2013 10:24:09 vasta tsitaadiga
pal kirjutas:
Kommentaarid: 141 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 121
sõnum 02.10.2013 12:00:01 vasta tsitaadiga
Jäi silma "sahin", et Moto X saab endale 2xMIMO antennisüsteemi. icon_razz1.gif Kui nii, siis see saab olema ISP-dele peagi suurem peavalu, kuidas hakata ehitama, nutitelefonide tarbeks, ultramoodsat 2XMIMO levisüsteemi. icon_razz1.gif
The device, which Motorola has been touting heavily over the July 4 holiday, will boast dual LTE MIMO (Multiple-Input, Multiple-Output) antennas, so says Taylor Wimberley, founder of Android and me.
The tech, more commonly associated with high-speed Wi-Fi, means there'd be two antennas pulling in and spitting out downloads and uploads at the same time, increasing speeds for owners of the device.
Could the Moto X smartphone sport the fastest LTE speeds on the block?
http://leandrahallis.blogspot.com/2013/09/could-moto-x-smartphone-sport-fastest.html
Ja samalaadne "sahin" ka veidi varasemast ajast:
In a nutshell as well as in regular English, the dual LTE MIMO smart antenna would mean a couple of LTE-capable antennas which will be able to receive and send data simultaneously, where the logical conclusion would be experiencing a faster data exchange. You could more or less equate that to widening a 2-lane highway into a 4-lane one. Are you stoked by this particular rumor should it actually turn out to be true?:
Moto X Could Come With Dual LTE MIMO Smart Antenna:
http://www.ubergizmo.com/2013/07/moto-x-could-come-with-dual-lte-mimo-smart-antenna/
ewil-apple
ewil-apple
sõnum 26.10.2013 21:36:35 vasta tsitaadiga
Ning selle soetamine siinmail on veel võimatu?
somnambuul
sõnum 14.01.2014 15:29:48 vasta tsitaadiga
Moto X tuleb Euroopasse - http://www.e24.ee/2660716/motorola-lipulaeva-soovituslikuks-hinnaks-saab-euroopas-399-eurot
kami
sõnum 14.01.2014 21:42:40 vasta tsitaadiga
Kohalikud operaatorid seda Eestis müüma ei hakka.
viimati muutis kami 15.01.2014 15:10:56, muudetud 1 kord
ants40
sõnum 15.01.2014 14:54:58 vasta tsitaadiga
somnambuul kirjutas:
Soovituslikud hinnad - 380£(457€) ja 429€
Motorola's Moto X officially announced for Europe, high price tag attached
Draqula
sõnum 15.01.2014 15:09:56 vasta tsitaadiga
kami kirjutas:
Kohalikud opetaatorid seda Eestis müüma ei hakka.
... ja väidetavalt on põhjuseks, et keegi ei tee neile siin ametlikku hooldust (Motorola'dele st).
arm2004
arm2004
sõnum 15.01.2014 15:50:20 vasta tsitaadiga
üksvahe ju müüsid tolasid küll siin, sõber ostis ~1,5a tagasi EMT-st RAZR MAXX-i. et kui keegi neid ei hoolda, tea mis siis saab kui see peaks nüüd garantiid vajama? saadavad kuskile välismaale? icon_confused.gif
nooope!
marxmacher
sõnum 18.01.2014 22:21:35 vasta tsitaadiga
Draqula kirjutas:
kami kirjutas:
Suhtlesin alles hiljuti MTTC Eestiga , kuna toon maale Moto G telefone ning nende vastus oli, et nende kaudu käib garantii remont. Ei oska muidui öelda, kuidas asi on amazonist tellitud isenditega.
Kommentaarid: 84 loe/lisa Kasutajad arvavad:  :: 8 :: 2 :: 61
ninzor
sõnum 12.02.2014 13:47:49 vasta tsitaadiga
Täitsa saadaval:
http://www.amazon.co.uk/Moto-16GB-Sim-Free-Smartphone/dp/B00HU2KSSK/ref=sr_1_1?ie=UTF8&qid=1392202005&sr=8-1&keywords=moto+x
Kommentaarid: 222 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 192
koby
koby
sõnum 08.04.2014 09:28:31 vasta tsitaadiga
Eilsest siis moto X omanik. Soetasin Klickist 359€ eest.
warsteine
sõnum 09.04.2014 12:34:57 vasta tsitaadiga
Kuidas aku on? Osad vinguvad, et halvem kui nexustel.
koby
koby
sõnum 14.04.2014 10:44:06 vasta tsitaadiga
kuna nexuse kogemus puudub siis ei oska kommenteerida (kuigi youtubis võrdlusi enne ostu vaatasin siis jah nexusel numbinäit aku osas parem, aga tegelik elu vastupidine. Seal öeldi, et motorola vennad on teineud väga hea arhitekti töö). Aga reaalsus mul endal igapäevane kasutus, siis aku 2 päeva peab vastu hetkel.
kalaluu
kalaluu
sõnum 12.06.2014 12:06:07 vasta tsitaadiga
Järgmisel nädalal saabub mulle üks, mis on usa võrku lukustatud. Eks näis kas saab lahti selle icon_razz.gif
Khimilch
sõnum 08.07.2014 10:31:43 vasta tsitaadiga
koby kirjutas:
vaatan et seda netis enam müügil pole?
kaks kuud on möödas, kuidas rahul oled?
kalaluu, kust sa tellisid?
koby
koby
sõnum 09.07.2014 12:59:43 vasta tsitaadiga
endiselt rahul, ainuke mille kallal võib nuriseda on pildikvaliteet.
Asi mis mulle väga meeldib on see, et taskust võttes ilma nupule vajutamatta näed kas sul on meil tulnud vms. Vaatasin uut androidi esitlust ja tundub et Android L-ile pannakse ka miskit sarnast külge. Õnneks on X-il OLED ehk siis kasutab ainult väikest osast displayd ehk siis akut ei söö.
kalaluu
kalaluu
sõnum 13.07.2014 11:49:48 vasta tsitaadiga
Kurat, panin mööda täiega. Telefon on LTE/CDMA only icon_lol.gif
Tegin bootloaderi lahti ja proovisin mingit patchi, aga asjatult vist. Pole nii pädev selles teemas...
koby
koby
sõnum 07.08.2014 12:24:22 vasta tsitaadiga
Tänasest sain siis softi uuenduse peale.
ninzor
sõnum 07.09.2014 17:31:39 vasta tsitaadiga
kalaluu kirjutas:
XT1060? icon_confused.gif Sel juhul Eestis pole suurt peale hakata.XT1052 oleks parim, Euroopa mudel, millel ka 4G LTE töötab.
XT1058'l peaks töötama kõik peale 4G LTE, sagedused ei klapi, vähemalt Elisa puhul.Vähemalt kättejuhtunud eksemplaril on ekraan ebameeldivalt sinakam kui Moto G'l.Active Display ning telefoni suutlikus sleep'ist ise välja tulla laualt/taskust võttes on vägagi märkimisväärne lisamugavus.
prtv
sõnum 19.09.2014 16:52:50 vasta tsitaadiga
Moto X 2014
Link
koby
koby
sõnum 26.09.2014 15:59:28 vasta tsitaadiga
a ah, goot to know. kahju et nad suuremaks ka läinud. Kuigi seni veel eelmise X rahul nii et vahetama ei jookse.
Tarts5
sõnum 23.10.2014 20:40:37 vasta tsitaadiga
Kas kuskilt veel Euroopa XT1052 varianti ka saada on? Ebay pakub vaid mõnd üksikut ning need ligi 300 EURi, Aliexpressis on vaid XT1058 mudel kuid üsna hea hinnaga - kuskil 180.-
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 34
somnambuul
sõnum 23.10.2014 21:05:32 vasta tsitaadiga
Aga palun - http://www.expansys-ee.com/motorola-moto-x-16gb-walnut-fiinish-267659/
Aga kolmsada tuleb sealtki ära.
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Motorola Moto X mine lehele eelmine  1, 2, 3, 4  järgmine
