| Millises serveris ja miks hakkad mängima? |
| PVP, sest ... (täpsustan teemas) |
42% |
[ 29 ] |
| PVE, sest ... |
25% |
[ 17 ] |
| RP, sest ... |
2% |
[ 2 ] |
| RP-PVP, sest ... |
10% |
[ 7 ] |
| Vahet pole, sest ... |
19% |
[ 13 ] |
| hääli kokku : 68 |
Timberg
ööKARU
09.01.2014 02:03:23
| caramis kirjutas: |
| Krizto kirjutas: |
| L6in maha need kes ette juhtusid. |
ja selle eest suspension? päris lolliks on Blizzard läinud |
Möla. Blizzard ei bänni pvp pärast.
272 |
caramis
09.01.2014 04:38:27
| Timberg kirjutas: |
| caramis kirjutas: |
| Krizto kirjutas: |
Möla. Blizzard ei bänni pvp pärast. |
kui seda nö. varjupaiga alas teha, siis loobivad hea meelega banaaniga
_________________ Teen 3D-skännist päris-asju, 3D-prindin (ühes tükis kuni 350x350x433mm) ja joonestan-modelleerin. Küsi julgelt. |
| Kommentaarid: 172 loe/lisa |
149 |
Krizto
09.01.2014 06:48:30
C. Rules Related to Game Play. Game play is what World of Warcraft is all about, and Blizzard strictly enforces the rules that govern game play. Blizzard considers most conduct to be part of the Game, and not harassment, so player-killing the enemies of your race and/or alliance, including gravestone and/or corpse camping, is considered a part of the Game. Because the Game is a "player vs. player" game, you should always remember to protect yourself in areas where the members of hostile races can attack you, rather than contacting Blizzard's in-game customer service representatives for help when you have been killed by an enemy of your race. Nonetheless, certain acts go beyond what is "fair" and are considered serious violations of these Terms of Use. Those acts include, but are not necessarily limited to, the following:
(i) Using or exploiting errors in design, features which have not been documented, and/or "program bugs" to gain access that is otherwise not available, or to obtain a competitive advantage over other players;
(ii) Conduct prohibited by the EULA or elsewhere in these Terms of Use; and
(iii) Anything that Blizzard considers contrary to the "essence" of the Game.
Selle j2rgi ei tohiks nad küll b2nnida kui Timeless Isle "varjupaigas" kellegi maha l66d. Isegi corpse campimine on lubatud.
| Kommentaarid: 58 loe/lisa |
54 |
D3vil.ee
09.01.2014 12:55:50
Defineeri varjupaik.
Blizzard mõtleb, ilmselt seda selle külakese all, ehk kui sa passid flightmasteri kõrval ja kütad afkivatele saabujatele molli, siis saad (peaksid saama) ise guardide käest vastu ka.
Samas kui sa ronid sinna flightpathi kõrval oleva kemmergu otsa kuhu guardid ei ulata, siis tegu on exploidiga.
| Kommentaarid: 41 loe/lisa |
38 |
freestyler
09.01.2014 14:22:46
| Üritasin ka neid blood coine saada, aga no kõik lihtsalt tuima näoga eiravad mind ja ei ole lihtsalt kedagi tappa. Ainuke variant on pugeda rahva sekka, kes celestiale tapavad ja loota, et mõni kogemata su ära tagib...
Timberg
ööKARU
09.01.2014 15:25:29
| Krizto kirjutas: |
RÄägi, mida sa tegelikult/kuidas tegid?
272 |
xonix
11.01.2014 23:55:30
| Uuriks, et kuidas see WoW ostmine nüüd toimib, ennist müüdi mingit battle pack moodi asja, mida enam ei leidnud, oli vaid WoW ja Mists of Pandaria. Soov oleks siis osta koos kõikide expansionitega, nagu siin jõulude aeg oli 15€ see pakett(?), palju see nüüd siis maksab. Samuti, kas on kuskil soodsam kui battle.netis ning kui pea uued soodukad on tulemas?
| Kommentaarid: 74 loe/lisa |
68 |
Psych0
12.01.2014 00:15:42
| xonix kirjutas: |
| Uuriks, et kuidas see WoW ostmine nüüd toimib, ennist müüdi mingit battle pack moodi asja, mida enam ei leidnud, oli vaid WoW ja Mists of Pandaria. Soov oleks siis osta koos kõikide expansionitega, nagu siin jõulude aeg oli 15€ see pakett(?), palju see nüüd siis maksab. Samuti, kas on kuskil soodsam kui battle.netis ning kui pea uued soodukad on tulemas? |
Nüüd ongi kaks valikut: WoW, mis koosneb kõigest kuni Cataclysmini (kaasaarvatud) või siis Mists of Pandaria.
| Kommentaarid: 61 loe/lisa |
57 |
xonix
12.01.2014 00:22:29
| Psych0, kuid see esimene peab olemas olema, et MoP muretseda, right?
68 |
eShelobik
12.01.2014 00:35:51
| xonix, jah.
| Kommentaarid: 295 loe/lisa |
262 |
seeMees
Timberg
ööKARU
29.01.2014 16:36:32
Igavad numbrid. Tahan f2p wowi microtransaactionitega või classic serverit
272 |
caramis
29.01.2014 16:54:24
| Timberg kirjutas: |
Igavad numbrid. Tahan f2p wowi microtransaactionitega või classic serverit  |
ehk privaserverit?
149 |
Psych0
29.01.2014 17:44:30
| caramis kirjutas: |
| Timberg kirjutas: |
ehk privaserverit? |
Ma arvan, et ta ei taha vigast ning lagivat mängu.
57 |
caramis
29.01.2014 18:18:44
| Psych0 kirjutas: |
| caramis kirjutas: |
| Timberg kirjutas: |
Ma arvan, et ta ei taha vigast ning lagivat mängu.  |
server, kus ise 3a nüüd olnud olen (WotLK, 3.3.5a patch), on vaid osa queste vigased (puusalt pakun, 15%). ICC, RS, ToC 10/25(HC) skriptitud, paralleelis tehakse ka Catat (4.3.4 vist oli). Lich Kingi patchis lubati ka Ulduari script ette võtta. PvP toimib, mitu suurt YouTuberit ka võistluste livestreamis kommenteerimas olnud. Molten-WoW, pesitsen ise Deathwingi realmis ehk siis 3.3.5. 4.3.4 pidi warrioritele üsna õudukas olema..
149 |
Priido
29.01.2014 22:07:17
| caramis kirjutas: |
| Psych0 kirjutas: |
| caramis kirjutas: |
| Timberg kirjutas: |
server, kus ise 3a nüüd olnud olen (WotLK, 3.3.5a patch), on vaid osa queste vigased (puusalt pakun, 15%). ICC, RS, ToC 10/25(HC) skriptitud, paralleelis tehakse ka Catat (4.3.4 vist oli). Lich Kingi patchis lubati ka Ulduari script ette võtta. PvP toimib, mitu suurt YouTuberit ka võistluste livestreamis kommenteerimas olnud. Molten-WoW, pesitsen ise Deathwingi realmis ehk siis 3.3.5. 4.3.4 pidi warrioritele üsna õudukas olema..  |
Puhas saast. Tean väga hästi kuidas see harrastajate skriptimine käib. Ühelgi privaserveril pole isegi korralikku pathfindingut, rääkimata siis bossidest. Mingi aeg otsisin ka ise classik servereid taga ja on see molten wow ka ära proovitud. On küll parem PVE alal kui teised, aga originaalile jäädakse ikka 95% alla. Asi lihtsalt algab elementaarsetest asjadest nagu pathfinding, kui see ei tööta siis jookseb see boss sul ka saalis edasi-tagasi ja sujuvast mängust on asi kaugel. Pealegi enamus bossi abiliteid peale meleed ei tööta. Mõned kergemad töötavad. See "scripted bosses" töötab ainult nende jaoks kes pole kunagi wowis samu bosse näinud. Probleem on selles, et koodiga tegelevad mitmed inimesed, kes eriti omavahel ei suhtle. Ehk siis 1 vend parandab midagi nii, et mõne muu asja samal ajal perse keerab ja siis teine vend üritab sama asja parandada ja keerab jälle omakorda midagi piixu.
Questid on ka sellised et kui mingi escort quest on siis tule taevas appi.
Pane korralik scrtiped ICC tööle privas ja vean kihla et kulub aastaid enne kui keegi maha saadakse heroicus.
Parem lahendus on leida mõni twink guild, kas siis level 80 või 85 või mis parasjagu meeldis. WOTLK ja Cataclysm on täitsa lähedal vanadele aegadele õige geariga. TBC on muidugi paras joke ja BT jookseb ilusti näiteks viielise level 70 grupiga. Muidugi tuleb arvestada sellega et teatud klassid on teatud levelil väga overpowered.
| Kommentaarid: 17 loe/lisa |
caramis
29.01.2014 22:50:08
| Priido kirjutas: |
| caramis kirjutas: |
| Psych0 kirjutas: |
| caramis kirjutas: |
| Timberg kirjutas: |
Puhas saast. Tean väga hästi kuidas see harrastajate skriptimine käib. Ühelgi privaserveril pole isegi korralikku pathfindingut, rääkimata siis bossidest. Mingi aeg otsisin ka ise classik servereid taga ja on see molten wow ka ära proovitud. On küll parem PVE alal kui teised, aga originaalile jäädakse ikka 95% alla. Asi lihtsalt algab elementaarsetest asjadest nagu pathfinding, kui see ei tööta siis jookseb see boss sul ka saalis edasi-tagasi ja sujuvast mängust on asi kaugel. Pealegi enamus bossi abiliteid peale meleed ei tööta. Mõned kergemad töötavad. See "scripted bosses" töötab ainult nende jaoks kes pole kunagi wowis samu bosse näinud. Probleem on selles, et koodiga tegelevad mitmed inimesed, kes eriti omavahel ei suhtle. Ehk siis 1 vend parandab midagi nii, et mõne muu asja samal ajal <b>piix</b> keerab ja siis teine vend üritab sama asja parandada ja keerab jälle omakorda midagi piixu.
Parem lahendus on leida mõni twink guild, kas siis level 80 või 85 või mis parasjagu meeldis. WOTLK ja Cataclysm on täitsa lähedal vanadele aegadele õige geariga. TBC on muidugi paras joke ja BT jookseb ilusti näiteks viielise level 70 grupiga. Muidugi tuleb arvestada sellega et teatud klassid on teatud levelil väga overpowered. |
natukene muigama ajab. kuna sa seda Moltenit proovisid? teiseks, mis puudutab Heroicuid, siis retail on lihtsam ja seda on korduvalt kinnitanud need, kes on retailist tulnud või mängivad seal senini. olen retaili peale korduvalt mõelnud, aga no.. milleks. mingid pandad, mingi base resilience, talentid on ära huiatud, world PvP pea et puudub. isegi Hearthstone ei ahvatle, sest see on samasugune läila jama nagu WoW viimasel ajal
149 |
sten260
30.01.2014 19:46:35
hearthstone on kaardimäng ju üldse
Priido
30.01.2014 21:59:03
| caramis kirjutas: |
natukene muigama ajab. kuna sa seda Moltenit proovisid? teiseks, mis puudutab Heroicuid, siis retail on lihtsam ja seda on korduvalt kinnitanud need, kes on retailist tulnud või mängivad seal senini. olen retaili peale korduvalt mõelnud, aga no.. milleks. mingid pandad, mingi base resilience, talentid on ära huiatud, world PvP pea et puudub. isegi Hearthstone ei ahvatle, sest see on samasugune läila jama nagu WoW viimasel ajal  |
Ma olen Moltenil ja üleüldse privaserveritel silma peal hoidnud juba ammu ja proovin neid regulaarselt, sest ka ennast eriti need pandad ei huvita ja tahaks väikest nostalgia laksu saada. Need kes räägivad, et originaal on liiga kerge, on seda kuulnud lihtsalt teistelt mängijatelt, kes pole kunagi heroicut proovinud. Või siis võrreldakse praegust LFR vana HC-ga. Ma pole ausaltöeldes näinud ühtegi bossi spelli Moltenis, mis töötaks 100% identselt originaali omaga. Igal spellil on mingi kiiks, paljud on üldse puudu, klassi mehaanikad on suhteliselt katki, korralikku patching süsteemi pole ja iga fix patchiga keeratakse midagi uut vussi. Puudub korralik pathfinding ning statide ja buffide/proccide skaleerumine on kaugel õigest asjast. Asi hõlmab lihtsalt natukene rohkemat kui lihtsalt neid valemeid ja numbreid mis wowwikis kirjas on.
Vb selles mõttes oli originaal WOTLK kergem, et oli lihtsam leida gruppe, lihtsam saada raidi ja lihtsam leveldada kuna kõik töötas perfektselt ja populatsioon oli suur. Lihtsalt iga kord kui priva saab proovitud siis kaob isu suhteliselt ruttu ära sest nii paljud asjad lihtsalt töötavad poolpiduselt või ei tööta üldse.
Muidugi harjub kõigega ära ja inimesed, kes on privas alustanud, on muidugi on rahul.
Kui sa oled mängija, kes on harjunud mängima viimase piiri peal originaalis, siis kõik need privaservude puudused (mis paljudele võivad tunduda tühised) lihtsalt ei võimalda sul oma mängu mängida.
Silvermoonis on 1 guild kes hooajati WOTLK contenti laseb level 80 ja level 80 geariga. Pole küll päris see, mis ta aastaid tagasi oli, aga igal juhul parem kogemus kui kuskil privas poolpiduse koodiga mängida.
Ja muidu kuidas sa tead, et kõik wowis on viimane "läila" kui sa retaili peale ainult mõelnud oled? Need jutud tulevadki sellest, et keegi räägib kellelegi ja tema räägib kellelegi edasi jne. Asi on lihtsalt muutunud kasutajasõbralikumaks, see ei tähenda et asi kohe jama on. Minule endale viimased muudatused ei meeldi, aga tegelikult ma saan aru, et mäng ise muutub järjest paremaks, kiiremaks ja stabiilsemaks. Encounterid on arenenud märgatavalt ja lisatud on palju keerulisemaid spelle ja mehaanikat. Teemadega on lihtsalt natukene mööda pandud.
Talente igatsen mina ka, aga ausaltöeldes on need alati suht pointless olnud kuna kõige parem oli alati 1 teatud spec. Praegu on rohkem valikut, kuidas sa oma klassi mängida tahad.
Base resilience ei ole üldse halb asi. Kui seda poleks siis oleks suht ebavõrdne seis hetkel kus näiteks mõni kehvema pvp geariga vend saaks pidevalt oneshotte sisse. Mis lõbu see oleks?
caramis
31.01.2014 15:45:03
| sten260 kirjutas: |
hearthstone on kaardimäng ju üldse  |
erinev bulls**t, sama tootja
mõelnud ei ole mitte ainult, vaid ka proovinud. sai korra mindud trial kontoga, edasi sai sõbra juureski proovitud. tol hetkel oli veel Cata viimane sats ja no warriorite olukord ajas nutma lihtsalt. ilmselt nüüd parem, aga eks näis, kui leian hea hinnaga starter chesti, siis viskan retailile pilgu peale ja proovin. Moltenis paar kunagist guildikaaslast logivad vahest sisse, kes paralleelis retaili mängivad ja üks neist lubas mind ka veidi aidata nii leveldamisel kui ka korraliku guildi saamisel olles ise ohvitser, seega hea algus on garanteeritud.
149 |
Vihmausss
| Kommentaarid: 13 loe/lisa |
caramis
01.02.2014 22:50:40
jep, ainult need. jaanuari alguses/eelmise aasta lõpus oli esimene pack 5 rutsi ja MoP mingi kümnekas vist.
149 |
Vihmausss
01.02.2014 23:03:17
Tänud sulle, tahtsin veel küsida, et mulle jäi silma, et on vaja kedagi kes aitaks leveldada, kas tõesti on see xp rate nii low? Eiusu, et nii hull see asi on Silkroad Online'st ikka hullem ju eisaa olla Ja ma ei ole veel saanud aru sellest asjast, et kui enam neid Talente eiole mis nüüd siis on? Kas on suur muutus edasi läinud Cata-MOP'i vahel? Kaua nende kahe pakiga mänguaega on?
viimati muutis Vihmausss 01.02.2014 23:03:33, muudetud 1 kord |
l3mpz
01.02.2014 23:03:31
| Vihmausss kirjutas: |
Tänud sulle, tahtsin veel küsida, et mulle jäi silma, et on vaja kedagi kes aitaks leveldada, kas tõesti on see xp rate nii low? Eiusu, et nii hull see asi on Silkroad Online'st ikka hullem ju eisaa olla Ja ma ei ole veel saanud aru sellest asjast, et kui enam neid Talente eiole mis nüüd siis on? Kas on suur muutus edasi läinud Cata-MOP'i vahel? |
Aga tee endale uus konto Battle.neti ja vaata ise järgi (esimesed 20 levelit on tasuta)
| Kommentaarid: 54 loe/lisa |
48 |
kikaskilla
01.02.2014 23:30:26
| Kusjuures, ei ole tõsi, et kõik privaatserverid saastad on. Sellega olen nõus, et Molten saast on, kuid leidsin ühe päris hea vanilla serveri. Kõik asjad on korralikult scriptitud, kõik questid töötavad korralikult. Serveril lausa mitu realmi. Ise mängin blizzlike realmis. Tavaline arv inimesi, kes on sisse logitud jääb mingi 2k juurde. Õhtuti on lausa server täis. Kellel rohkem huvi siis www.wow-one.com
| Kommentaarid: 20 loe/lisa |
20 |
