| Kui tihti teha HV serveris wipe? |
| Iga 1 nädala tagant |
19% |
[ 26 ] |
| Iga 2 nädala tagant |
12% |
[ 17 ] |
| Iga 3 nädala tagant |
7% |
[ 10 ] |
| Iga kuu tagant |
31% |
[ 43 ] |
| Mitte kunagi |
28% |
[ 39 ] |
| hääli kokku : 135 |
sander989
08.01.2014 00:22:06
Mingi vihavaenlane sul
| Kommentaarid: 78 loe/lisa |
66 |
argottt
08.01.2014 00:30:50
kolmas kord, panen quiti 2ra kui george sisse ei tule, mu asju tagasi ei anna ja vennale permabani ei pane. proovib kirkaga praegu meallseinast l2bi toksida ennast et v2lja saada.
nüüd pääses niipalju edasi, et magamiskottidega samas, ruumis, ei saa isegi respawnida, ilma et surma saaks.
| Kommentaarid: 35 loe/lisa |
34 |
allavett
| Kommentaarid: 50 loe/lisa |
47 |
argottt
08.01.2014 00:43:37
kiviga enam ei tee midagi, k6ik mu relvad tema k2es
_________________ www.simracing.ee |
34 |
pohmakas,
käed värisevad
08.01.2014 01:34:34
Jah, tõepoolest juhtus nii, et eilne ban ei aktiveerunud, kuna ta oli offline. Nüüd sai uus ban jälle peale, kui ta online oli.
Ning kui keegi veel raidimas käib, siis killige ära, lammutage maja maha, sleepingbagid sodiks.
| Kommentaarid: 166 loe/lisa |
137 |
Syncmahv
102 |
Revan
08.01.2014 10:56:28
Nii...tere hommikust ja natuke uudiseid ka.
Esiteks hea uudis Multiplay poolt:
Rust User Inventory Access Added.
Last updated on 1/8/2014 3:56:00 AM by Elliott
Hi guys just wanted to let you know that you can now access User Inventories via Clanforge -> Server Dashboard -> Files.
This is a temporary measure until full world and inventory support is completed, and there's currently no easy way to identify which users file is which, but it your performing a full reset it provided the ability to reset all user inventories using the following procedure:
Stop Your Server
Select all User Inventory Files
Click Delete
Restart Your Server
Again this is a temporary measure until the full world / inventory support is ready as we know you wanted this option ASAP
Update @ 00:56 - Also added to Oxide Mod for those testing that too. See below.
To gain access to Oxide early (before we make available for everyone) submit your MH here - https://forums.multiplay.com/rust/97690-oxide-support simply login to forums with your Clanforge/Multiplay account.
Ühtlasi olen lisanud HV serveri ka Oxide mod järjekorda, et serverile see peale saada. Oxide modist võib rohkem lugeda siin ja siin
Kolmanda uudisena toon välja, et need kes ei tea, siis täna on lootust näha uus content patch, väike aga kasulik. Muudab research kitide käitumist ja lisab trellid, mida saab majade akendele ette panna, Võimalik, et midagi veel kuid hetkel pole siis veel avalikustatud. Seoses selle patchiga võib oodata lähipäevil ehk ka full server wipe, kuna content mida lisatakse/muudetakse ei pruugi kõigile muidu mõjuda (Näiteks mul enadl pole research kitiga midagi teha, kõik õpitud juba) aga kindlasti hoian kõiki kursis täpsema ajakavaga.
| Kommentaarid: 21 loe/lisa |
21 |
pohmakas,
käed värisevad
08.01.2014 14:52:20
Oxide koha pealt - selle vajalikkus on kaheldav. Tavamängijale lisab see vaid uste jagamise võimaluse ning laseb serveri haldajal automaatse spamboti chati panna, mida enamik peavad häirivaks. Esimene neist on praegu juba Facepunchi poolt tegemisel ja kuulujuttude järgi kohe-kohe välja tulemas, teine on selline asi, mida ma väga ei kannata. Üldiselt räägitakse chatis niigi palju, vaja siis igasugu jama sinna veel jooksma panna. Samuti reeglid mahutab serveri nimesse ära, mis on ka kasulikum (Friendly, PVP, PVE, jne), kuna see on see, mis mängijaid tõmbab.
Ainuke enam-vähem asi on adminisüsteemi muudatused, kuid see tavamängijat ei mõjuta.
Miinuste koha pealt veel viib sellise modi kasutamine ka selle serveri 'Modded' serverite lahtrisse (mille vastumina olen) ning kuna alpha staadiumis olevale mängule kohane, tuleb pidevalt mängule uuendusi, mis võib aga säänse modifikatsiooniga konflikti sattuda ning ebastabiilsusi tekitada.
Seoses selle väikese content update saabumisega mõtisklesin kõvasti selle üle, kas server wipe teha või mitte. Jõudsin otsusele, et hetkel pole server wipe veel vajalik, kuna uuendus lisab vaid seda, et saab oma maja veidikene turvalisemaks teha ja saab ühe research kitiga mitu eset ära õppida, kumbki neist ei muuda üldist gameplay'd nõndapalju, et kõik mängijate ehitised ning varustus järjekordselt ära kustutada.
Lisaks näitas ka eelmine nö kaardi kustutamine, kuidas selline asi serveri aktiivsust mõjutab, ning nagu sina ise, Likwid, statistikast näha saad, on aktiivsus langenud.
Seega, minu seisukoht hetkeseisuga mõlema punkti osas - kindel ei.
137 |
Revan
08.01.2014 15:18:57
| pohmakas, kirjutas: |
Seega, minu seisukoht hetkeseisuga mõlema punkti osas - kindel ei. |
No esiteks tasuks tänase õhtuni oodata, et üldse näha mis muudatused täpsemalt content updatega tulevad. Research kit muudatus ja metal bars on kindel aga võib ka muid asju koos sellega tulla, mida pole üldsegi mainitud. Pärast kogu info teada saamist juba hakata wipe ja sellistest asjadest mõtlema. Tõin eelmises postis lihtsalt välja, et full wipe on nüüd tehniliselt võimalik. Serveri aktiivsus on jah kahjuks langenud aga seda mõjutas samapalju või rohkem ka see, et üks vend tuleb hackima või raidima või lihtsalt inimesi jahtima, annad banaane ja lükkad uksest välja või karistad ükskõik mis muudmoodi ning ta võtab ka kõik oma sõbrad kaasa ja lahkub.
Me küll teeme oma tööd ja üritame jälgida, et reegleid ei rikutaks aga eri inimesed mõistavad eri asju erinevalt ja mõned on lihtsalt idioodid kes midagi ei mõista.
Oxide modi kohalt ütlen niipalju, et shared doors facepunchi devide poolt on istunud kuu aega "Gameplay improvements" lahtris ja alates eilsest on ta nüüd "Doing" lahtris, niiet ta on jah tulemas aga millal, seda veel teada pole. Oxidega saaks selle kohe. Tekstide kohapealt on kõik täpselt nii nagu ise seadistad. Ainus tõeline miinus on jah see, et server läheb modded lahtrisse. Samas modded servereid on vähem, neid on nimekirjas vähem, seega lihtsam leida ja ehk saaks oxidest endast juba päris hea tõmbenumber.
Natuke ilusat ka...uue revolveri animations on valmis:
21 |
Paukus6
08.01.2014 20:13:08
| Matisxx kirjutas: |
Kellel soovi rohkem PVP serveris mängida siis on teretulnud järgnevasse serverisse! PVP, Raiding allowed. No Sleep. Instacraft
ohoh rahvast voolab, mingid uued asjad ka servusse lisatud, oxide vms, seni pole häkkereid ka näinud! mingi 20 sees praegu
argottt
08.01.2014 20:27:26
| Paukus6 kirjutas: |
| Matisxx kirjutas: |
ohoh rahvast voolab, mingid uued asjad ka servusse lisatud, oxide vms, seni pole häkkereid ka näinud! mingi 20 sees praegu |
Kolin ka sinna ümber. Murti jälle sisse ja tehti täiesti tühjaks. PVP serveris võin vähemalt ise vastu nussida.
34 |
lazynator
08.01.2014 20:35:42
| Paukus6 kirjutas: |
| Matisxx kirjutas: |
täpsem info siin: https://facepunch.com/showthread.php?t=1345090
_________________ el Bambito |
Syncmahv
08.01.2014 20:37:05
| See uste jagamine oleks küll kasulik, aga mis ülim oleks, oleks see kui kaugelt näeksid ära oma tuttava/sõbra kasutaja, mitte et lased kogemata maha.
102 |
xpander
08.01.2014 22:12:38
| Syncmahv kirjutas: |
| See uste jagamine oleks küll kasulik, aga mis ülim oleks, oleks see kui kaugelt näeksid ära oma tuttava/sõbra kasutaja, mitte et lased kogemata maha. |
uste jagamine tuleb varsti... koodiga uksed nagu aru olen saanud.
sõprade ära tundmine kaugelt on nii ja naa.. mingil määral võiks jah lihtsamaks teha tundmist..samas liialt mitte.. teeb asja huvitavamaks..peab kordineerima jne.
eks kui character customisation kunagi sisse tuuakse siis see asi paraneb..
_________________ Linux Gaming Videos: Xpander69 |
| Kommentaarid: 18 loe/lisa |
16 |
siven
08.01.2014 22:57:51
| ei saa enam sisse logida...? timed out
149 |
pohmakas,
käed värisevad
08.01.2014 23:19:05
| Server täiesti üleval ja mängijad sees.
137 |
Paukus6
09.01.2014 01:58:08
| xpander kirjutas: |
eks kui character customisation kunagi sisse tuuakse siis see asi paraneb.. |
uste jagamine täitsa serveris olemas juba.
pohmakas,
käed värisevad
09.01.2014 18:28:15
Mängule tuli välja ka väike uuendus, mis kuuldavasti lisas siis aknatrellide võimaluse, research kiti korduvkasutamise ning uue 9mm püstoli koos animatsioonidega.
Küll aga serveri teenusepakkuja uimerdab järjekordselt ning uuendust veel peal pole.
137 |
Lordlesta
09.01.2014 18:43:52
| Võta nüüd hoogu maha, steam ei paku hetkel mingit uuendust.
| Kommentaarid: 31 loe/lisa |
xonix
09.01.2014 19:36:21
| Kuskilt Rusti soodsamalt ka saab/keegi müüb?
| Kommentaarid: 74 loe/lisa |
68 |
Syncmahv
09.01.2014 19:53:45
| Paukus6 kirjutas: |
| xpander kirjutas: |
uste jagamine täitsa serveris olemas juba. |
Mismoodi?
102 |
mtv0308
Teaq
09.01.2014 20:12:03
| Otsustasin ka, siis ära proovida. Varem 7 days to die mänginud. Siin jagati miskit serverit, kuid kui play game vajutada siis lööb mustmiljon serverit ette ning kuskil mingit custom connecti ei leia.
siven
09.01.2014 20:13:12
| Teaq kirjutas: |
| Otsustasin ka, siis ära proovida. Varem 7 days to die mänginud. Siin jagati miskit serverit, kuid kui play game vajutada siis lööb mustmiljon serverit ette ning kuskil mingit custom connecti ei leia. |
vajuta f1
149 |
Lordlesta
09.01.2014 20:25:45
| Ja konsooli kirjuta "net.connect AADRESS".
pohmakas,
käed värisevad
09.01.2014 21:27:23
Hoog on täiesti maas, kuid väike minu ämber, jah. Facepunchi foorumit lugedes said ka päris mitmed teised juba praegu uuenduse. Mängus sees näitab ka, et tänase kuupäevaga build.
| Lordlesta kirjutas: |
| Võta nüüd hoogu maha, steam ei paku hetkel mingit uuendust. |
Ning nüüd serveri hostilt
A new Rust update has been released, which we'll be rolling out shortly.
Update @ 19:16 - This is now rolling out, all servers will restart to apply this update. |
viimati muutis pohmakas, 09.01.2014 22:20:34, muudetud 1 kord |
137 |
Evil14
09.01.2014 21:37:05
| mtv0308 kirjutas: |
LMFAO:
Mida veel välja ei mõelda. Sain hea kõhutäie naerda.
| Kommentaarid: 226 loe/lisa |
197 |
argottt
09.01.2014 21:42:36
| Evil14 kirjutas: |
| mtv0308 kirjutas: |
LMFAO:
Mida veel välja ei mõelda. Sain hea kõhutäie naerda.  |
Palvetas hästi pikalt ja siis ohverdas ennast jumalatele? sain ma asjast õigesti aru?
34 |
Evil14
09.01.2014 22:21:20
| argottt, mulle küll tundus nii. Kui mängus nii palju pulli saab, siis võiks täitsa osta selle.
197 |
pohmakas,
käed värisevad
09.01.2014 22:46:48
| HV serveril viimane uuendus peal.
137 |
allavett
47 |
pohmakas,
käed värisevad
10.01.2014 04:57:51
HV serveris sai tehtud full wipe.
Kindlasti mitmed on sellele vastu, kuid märgin ära ka kaks peamist põhjust.
Aastavahetuse wipe ajal sai teenusepakkuja piirangute tõttu teha vaid map wipe, ehk kogu mängijate varustus jäi alles. See aga tähendas seda, et mängijad olid kohe algusest peale hea varustusega ning ainukeseks lõbuks jäigi veel ehitamine. Nüüdseks oli pea igal mängijal juba mitu maja, mängulust polnud enam nii suur ning aktiivsus vähenes.
Välja on tulnud paar uuendust, lisatud/muudetud varustust, mis muudavad uute varustuse elementide hankimist ning majade ehitamist.
137 |
mkutt
10.01.2014 15:09:45
| Naljakas revolveri bug, kui talle flashlight mod lisada. Näitab kuhugi suvaliselt lakke.
pohmakas,
käed värisevad
10.01.2014 15:29:17
Sama bug on ka Bolt Action Rifle'ga. Kui silencer peale panna, siis töötab korralikult, ehk siis parandab taskulambi ja laseri ära.
| mkutt kirjutas: |
| Naljakas revolveri bug, kui talle flashlight mod lisada. Näitab kuhugi suvaliselt lakke. |
137 |
argottt
10.01.2014 19:11:56
Välja on tulnud paar uuendust, lisatud/muudetud varustust, mis muudavad uute varustuse elementide hankimist ning majade ehitamist. |
ikka no pvp ja no raiding?
34 |
-Kaivo-
10.01.2014 19:33:13
| Kommentaarid: 16 loe/lisa |
15 |
pohmakas,
käed värisevad
12.01.2014 19:59:09
Teen kõigile teatavaks, et mänguhuviliste soovil on HV serveris nüüd lubatud PVP ning reidimine.
Rustis on tulevahetused ikka päris pingelised. Täisvarustuses läksin airdropi jahtima, 3 meest oli seal ees. Ühe niitsin maha ja jooksin ligi, järsku lendasid 2 veel peale. Suutsin imekombel need ka maha saada, 12 elu jäi alles. Süda kloppis nii, mis segane
137 |
Karl P.
12.01.2014 21:02:06
Mitu korda juba ära unustanud, et Rust all mängib Praegu kuulsin kuidas keegi mu maja ust peksis ja siis tuli alles meelde, et mäng veel käib hüppasin alla ja tapsin ta kirvega ära
| Kommentaarid: 34 loe/lisa |
30 |
Maska
13.01.2014 11:40:29
| Kui server nüüd PVP, siis äkki oleks üks full wipe veel kohane?
| Kommentaarid: 32 loe/lisa |
pohmakas,
käed värisevad
13.01.2014 16:28:46
Full wipe oli paar päeva tagasi ju
137 |
dohc-48v12
Aeg maha 1p
13.01.2014 19:52:55
on kellelgi ka probleeme rustis grafika kaardiga ?
Et paned mängu käima ja üldiselt suht menus blue screen et videoks gtx570hd evga uued driverid ning ka jahutab Arctic Cooling Accelero Hybrid VGA Cooler, tembid korras ! ja overclockitud pole !
_________________ Ime tala, Nagu ime kepike.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid! |
6 :: |
85 |
allavett
47 |
dohc-48v12
Aeg maha 1p
13.01.2014 21:50:58
originaal kellad ka seal !
6 :: |
85 |
Evil14
13.01.2014 22:03:23
| Mis veakoodi bluescreen annab? Minidump fail vaata üle.
197 |
Timberg
ööKARU
13.01.2014 22:20:42
| dohc-48v12 kirjutas: |
Et paned mängu käima ja üldiselt suht menus blue screen et videoks gtx570hd evga uued driverid ning ka jahutab Arctic Cooling Accelero Hybrid VGA Cooler, tembid korras ! ja overclockitud pole ! |
Proovi beta draivereid. Proovi vsynci (pead käsitsi sättima nvidia control paneli alt), steam launch options "-force-d3d11".
Kui video draivereid paned, tee clean install, mitte "Overwrite või update või repair."
272 |
dohc-48v12
Aeg maha 1p
13.01.2014 23:45:01
paistab viga dxgkrnl dxgmm ja nvlddmkm -is
Ühesõnaga mõeldu mäng vanarauale !
6 :: |
85 |
pohmakas,
käed värisevad
13.01.2014 23:59:58
| Viitab ju graafikadraiverite veale, mis vanarauast sa jahud?
137 |
Markz
17.01.2014 20:26:11
Ehk keegi teab, kust saaks Eestist odavamalt, kui Steamist? Sõpradega crackedit mänginud umbes nädalakese, nüüd soov HV serverisse mängima asuda
| Kommentaarid: 13 loe/lisa |
pohmakas,
käed värisevad
17.01.2014 21:00:51
| Markz kirjutas: |
Ehk keegi teab, kust saaks Eestist odavamalt, kui Steamist? Sõpradega crackedit mänginud umbes nädalakese, nüüd soov HV serverisse mängima asuda  |
Väga paha
Kõige odavam SIIN
137 |
Rauno266
17.01.2014 21:06:21
Oppaa, avastasin, et mul on ka Steamis olemas see. Ei tea kust sain, vist humblebundlest.
| Kommentaarid: 45 loe/lisa |
41 |
