Vants...
02.10.2013 17:12:15
| Pihv kirjutas: |
| Karl0len kirjutas: |
Ei tea kust see siia sai? Eile kukkus selline pilvelõhkuja otsast ka alla ning nägin mitut tükki keset linna seismas  |
Graafika bug sul, et kõik selline hall või näebki nii jube low peal vms välja? |
Jah, low ongi selline.
Aga oli kui palju mäng ressursi oskab kasutada, et sellist koledust ette manada...
Karl P.
| Kommentaarid: 34 loe/lisa |
30 |
bitCON
02.10.2013 17:33:02
| ugly
caarel123
02.10.2013 17:36:57
ha see näeb nagu alpha välja.
pole ime miks nii hullult kirutakse
| Kommentaarid: 83 loe/lisa |
74 |
02.10.2013 17:40:28
https://en.wikipedia.org/wiki/Software_release_life_cycle
| The alpha phase of the release life cycle is the first phase to begin software testing (alpha is the first letter of the Greek alphabet, used as the number 1). In this phase, developers generally test the software using white box techniques. Additional validation is then performed using black box or gray box techniques, by another testing team. Moving to black box testing inside the organization is known as alpha release.[2] Alpha software can be unstable and could cause crashes or data loss. |
| Beta, named after the second letter of the Greek alphabet, is the software development phase following alpha. It generally begins when the software is feature complete. Software in the beta phase will generally have many more bugs in it than completed software, as well as speed/performance issues and may still cause crashes or data loss. |
ja again, beeta põhjal väljanägemises osas põhjapanevaid järeldusi tehes saab näidata vaid enda vigast arusaamist asjadest.
_________________ - londiste
217 |
KuriVaiM1
66 |
RadeonHD-
02.10.2013 18:09:21
link :: Battlefield 4 Beta montage
Vaadake see BF4 beta montage lõpuni See andis mulle uuesti viitsimist BF4 pelada
_________________ Battlefield 4: J4GGER
Vabandan segase jutu pärast !
Arvuti siis hetkel GPU: Gigabyte GTX 660 OC 2GB, CPU: i5 4670, DDR3 8GB 1600MHz |
Nimetu112
02.10.2013 18:18:16
| Ma ei mõista kuidas kõikidel see asi selline hall käkk on. Mul on küll kõik tiptop. Aga eks 90% siinsetest pakuvad haigelt üle ka. Isiklikult commander modest suhtelist savi , sest minimapi vahtimine väga pinget ei paku. Oleks küll võinud see teine map beetas olla aga minu isiklik maitse.
| Kommentaarid: 4 loe/lisa |
trip
02.10.2013 18:29:58
| Nimetu112, aga sa mine ja mängi conquesti, näed halli käkki ka.
303 |
Karl P.
02.10.2013 20:07:46
| RadeonHD- kirjutas: |
Vaadake see BF4 beta montage lõpuni See andis mulle uuesti viitsimist BF4 pelada  |
Muusika annab ka palju juurde
Üks tema vanem video:
Parim koht on kui pilvelõhkuja kokku kukub, muusika sobib väga hästi selle kõrvale
30 |
X-Tream99
| Kommentaarid: 6 loe/lisa |
trip
02.10.2013 20:47:19
sul nagu google ei toimi või
re: Invalid License. Reason code = Missing DLL: [MSVCP110.dll] Error: 0xC1
Options
10-01-2013 03:51 AM
go to ur BF4 game location:
Battlefield 4 Beta\__Installer\vc\vc2012Update3\redist. you will find vcredist_x64.exe
run it and if u already install it before repare it. worked for me |
303 |
lopes39
02.10.2013 21:01:16
Kahtlane täna. Proovisin mingisse rootsi serverisse ja algul viskas mingi stoped working errori, siis järgmine proov on loading screen aint mis vahepeal viskab pildi mustaks ja siis on saving ja jälle loading. Hääle järgi vahepeal tundub nagu oleks juba mängus see ja sõda käib.
Ja seda nii erinevates serverites.
| Kommentaarid: 10 loe/lisa |
trip
02.10.2013 21:18:37
| lopes39, proovi terve "pb" kausta sisu kustutada, Battlefield 4 Beta\pb\ ja installi pb uuesti, installer asub siin Battlefield 4 Beta\__Installer\punkbuster\redist\pbsvc.exe
303 |
sannukas00
02.10.2013 21:22:07
| lopes39 kirjutas: |
Ja seda nii erinevates serverites. |
Jap, endal ka pidevalt sama jama. Nii vigast betat pole ma veel varem mänginud.
| Kommentaarid: 16 loe/lisa |
14 |
lopes39
02.10.2013 21:32:48
ei ma lõpuks pikema ootamise järel sain ikka sisse ka. 6GB beta suuruse mõttes oleks ikka võind rohkem mäppe olla ja rohkem asju mida teha saab. selles kaardi peal pole nagu eriti mingeid tanke ega koptereid ja lennukeid nii palju et see mäng nii suur peaks olema.
Enamus mänge 6GB kandis sisaldab ikka story teemat ja muid igasugu asju.
Pihv
02.10.2013 22:22:50
| Valige ka serverit hoolega, mõni server jookseb nagu kolme jalaga koer ja mõni jälle väga ilusti.
94 |
lopes39
02.10.2013 23:13:05
No see rootsi server oli hea ping 27 vms. Aga mäp oli miski 5-10min pmst. ei saand mängu õieti sissegi elada kui asi juba läbi oli.
Põlve kõrgused elemendid jäävad pidevalt ette millest üle ei taha hüppada või siis mingi majja sisenemisel läbi akna on äär maast mingi 5-10cm kõrge ja ei hüppa üle ja on selle taga kinni.
Igal relval on ka koguaeg need krt toe jalad küljes mis ajavad kohati närvi. Lähed mingi ääre juurde ja tahad mingit tegelast ülevalt poolt maha võtta aga ei saa kuna viskab jalad maha ja siis on aim kinni. Pidevalt unustan neid ära võtta.
Mingi settingu muutmine on ka haiglane, kuna kui ära muudad siis viskab nagu alt+enter windowed teemasse. Colorblind maha ON, on ka miski 2 variandi vahel valida. ja kuidas siis aru saada millist valida ?
Selles mängus on kõik jube hall ja tolmune ja udune. Kohati wi saa midagi aru mis toimub.
heretic666
02.10.2013 23:59:49
Hall udune environment on ju siis kui see hiigelsuur pilvelõhkuja on kokku varisenud ja terve map nn betoonitolmu täis. Levolution.
Hardcore mode servude puudumisest on tõsiselt kahju, liiga palju laske peab kulutama ühe sõduri mahanottimiseks. BF3's HC mode ei mõjutanud vehicle haavatavust, nii et kui tankile krae vahele peab normal modes 4-5 lasku tegema, on see tõenäoliselt nii ka HC modes. Pead ahtrisse laskma tankile.
| Kommentaarid: 73 loe/lisa |
Nika0
03.10.2013 00:07:14
| heretic666 kirjutas: |
Hardcore mode servude puudumisest on tõsiselt kahju, liiga palju laske peab kulutama ühe sõduri mahanottimiseks. BF3's HC mode ei mõjutanud vehicle haavatavust, nii et kui tankile krae vahele peab normal modes 4-5 lasku tegema, on see tõenäoliselt nii ka HC modes. Pead ahtrisse laskma tankile. |
Jeap just mängisin ka ja kohutavalt häiris ennastki see betoonitolm
_________________ Motomehed täidavad kõhtu suu lahti sõites |
| Kommentaarid: 217 loe/lisa |
185 |
Karl P.
03.10.2013 01:09:54
Ikka kui tankiga helikopterit lasta siis ei juhtu vahel mitte midagi, masinad hakkavad üksteise kõrval sõites teleportima ning kui mingi õhku lastud helikopteri tüki otsa sõita siis hakkab tank samuti teleportima Seega võib seda tõesti Battlefield 3.5ks nimetada
30 |
Scart
03.10.2013 01:27:21
Iseenesest lõhkumist on kõvasti juures. B juures saab tankiga näiteks üleval platsil olevate majade esimesed korrused puhtaks sõita jne.
Tundub, et tõkkamist tekitab kõige rohkem füüsika. Lasin Nvidia beetad maha, eelmised tagasi ja FPS on tavaolukorras 60+ aga füüsika tööle rakenduses kukub köhima.
101 |
03.10.2013 06:10:20
Scart, beetades on physx sama. isegi kui seda ei kasutata, siis elab asi prose seljas, mis taas ei puutu videodraiveritesse.
217 |
heretic666
03.10.2013 09:58:13
| RPG otsetabamus kopterile ei tõmba ka maha kohati :/ .
Scart
03.10.2013 10:39:42
| londiste kirjutas: |
| Scart, beetades on physx sama. isegi kui seda ei kasutata, siis elab asi prose seljas, mis taas ei puutu videodraiveritesse. |
Kuidas sa siis seletad seda, et eelmiste ajuritega jookseb mäng tuntavalt puhtamalt?
101 |
Johan11
03.10.2013 10:43:17
| Enamus probleemseid masinaid kasutab i5 proset (4tuuma, 4 threadi), i7-tel tundub probleem puuduvat (4tuuma, 8 threadi).
| Kommentaarid: 43 loe/lisa |
37 |
renekas
03.10.2013 11:30:47
| Johan11 kirjutas: |
| Enamus probleemseid masinaid kasutab i5 proset (4tuuma, 4 threadi), i7-tel tundub probleem puuduvat (4tuuma, 8 threadi). |
i5 2500k ja jookseb veatult
| Kommentaarid: 22 loe/lisa |
21 |
KoldK
03.10.2013 12:11:45
| Johan11 kirjutas: |
Ei pea see paika. Pigem on asi kinni driverites ja äärmiselt kehvas open betas ikkagi. Täheldanud olen seda, et väga palju oleneb serverist endast.
Nagu ennegi keegi mainis, et osad serverid jooksevad nagu kolme jalaga koerad, teised tunduvalt normaalsemalt (see ei olene serveri pingist).
Vahepeal vapsee mingi 2x vähemalt serverit vahetama, et üldse mängu sisse roomaks, lihtsalt jääbki loadima jne.
viimati muutis KoldK 03.10.2013 12:15:44, muudetud 2 korda |
| Kommentaarid: 46 loe/lisa |
40 |
Braien
03.10.2013 12:15:03
No mul üks tuttav oli closed betas, ütles, et open beta build on sama mis closed beta oma.
90 |
trip
03.10.2013 12:24:55
misasja
closed beta - see mis hetkel käib
muide, rpg betas töötab nagu javelin , recon + pld vaja leida.
303 |
Braien
03.10.2013 12:25:45
Hetkel ei ole closed beta, praegu on exclusive beta, closed-beta oli enne seda.
90 |
trip
03.10.2013 12:27:48
| enne oli closed alpha, ära aja.
303 |
Braien
03.10.2013 12:30:58
No vahet pole kes kuidas seda nimetab...
90 |
trip
03.10.2013 12:35:54
| ja see jutt et sama build ei vasta tõele.
303 |
Braien
03.10.2013 12:43:17
No ta ütles mulle igatahes, et build sama, aga build number muudetud....
90 |
xonix
03.10.2013 13:31:57
| Sellist allikat väga ei usaldaks, "üks tuttav, "ta ütles".
| Kommentaarid: 74 loe/lisa |
68 |
renekas
03.10.2013 13:33:18
| Dice enda jutu järgi neil on iga paari päeva tagant uus build testimisel
21 |
03.10.2013 13:37:54
täna mul ära ei loadi enam igatahes..
laadimisscreenil kaovad ülemised ja alumised ääred ära, kus on näha udust maailma + ühe maja sõrestikku ja midagi edasi ei toimu. mingihetk tuleb ette must screen loadingu tekstiga ja jääbki nii.
edit: tirin uuesti. kiirus märgatavalt parem. 21,43 mb/sec... preload tuli 3'ga
182 |
parm
| Kommentaarid: 57 loe/lisa |
56 |
trip
03.10.2013 13:46:36
| tundub et mingi jama, mul vapsee kriipsud pingi asemel, näen ainult 4 servu kus inimesed on, ja laadimisega sama jama nagu üleval.
303 |
03.10.2013 13:56:43
trip, peale loadimise failimist on mulgi kriipsud pingi asemel, restardin battlelogi - toimib... proovin erinevaid hostereid nüüd... järgmisena vene hosti.
edit: i3d.net töötab
viimati muutis rmc 03.10.2013 13:58:15, muudetud 1 kord |
182 |
madness
03.10.2013 13:58:13
Hakkab pihta
| Kommentaarid: 13 loe/lisa |
03.10.2013 14:06:14
"error
Game disconnected: your connection to the server timed out."
ei viitsi eriti enam
182 |
A-Circus.
03.10.2013 15:22:42
| Kas too beta AMD 13.9 driveritega ka jookseb? Ei tahaks nagu väga betasid panna.
| Kommentaarid: 50 loe/lisa |
48 |
03.10.2013 15:27:18
A-Circus., peaks jooksma.. mõtlen ise just beta driverite peale.. praegu on ebastabiilne.
182 |
XD
03.10.2013 16:17:34
Üleeile ja eile proovides oli fps nii 720p ja low peal kui ka 1080p ja ultra peal samad. Samuti oli serverite lõikes perf erinev. DICE töötajad redditis mainisid et osa nendest spikedest võib panna heavy debuggingu süüks, samas paistab et saast performance tuli ka neile üllatusena.
Samas mäng ise, bf nagu bf ikka
_________________ "Kui inimene ei ole rahul tarkvaraga, siis on probleem tõenäoliselt inimeses" M.J. |
| Kommentaarid: 35 loe/lisa |
29 |
lauri23
| Kommentaarid: 29 loe/lisa |
29 |
parm
03.10.2013 18:47:39
| lauri23 kirjutas: |
Üleöö tekkinud selline jama, et mäng jääbki loadima  |
proovisi teisi servereid, teise teenusepakkuja omasid
_________________ | SPARCO toolid https://www.carshop.ee/et/2374-sparco | Tuuningosad mootorsõidukitele - www.carshop.ee | |
56 |
lauri23
29 |
Lehys
03.10.2013 19:35:57
Peale mitmekordset proovimist peale loading screen jama sain ikka lõpuks mängu,esimesel päeval seda jura polnud ilmnes mul teisel päeval.
See konkreetne map eriti ei istu,ootan täis versiooni rohkem.
| Kommentaarid: 11 loe/lisa |
