7 :: |
360 |
madest
02.10.2013 11:47:10
Ainus süü on siis see et mingil rakenduse puhul ei lasta prosel idle minna . Hull optimeering
| Kommentaarid: 13 loe/lisa |
02.10.2013 16:18:08
Nojah, aga olgem ausad - paljud suurtootjad on oma reklaamides ydini ausad? Ykskoik millises vallas, mitte ainult elektroonika.
_________________ MÜÜA: Xbox 360 E 250GB (UUS) |
313 |
Braien
02.10.2013 16:21:24
Ilma boostita ikka kiirem kui sama chipsetiga LG G2
90 |
arm2004
97 |
ricom2ger
03.10.2013 19:07:33
Ju sihtgrupp ajab numbreid taga
_________________ Kamehameha in your face! |
111 |
arm2004
97 |
05.10.2013 10:08:14
Samast uudislõigust:
| The South Korean manufacturer gave a similar explanation when the company was accused for improving the benchmark results with its Galaxy S4 flagship. However, the explicitly mentioned benchmarks in the Galaxy Note 3 code suggest that some apps that require high performance are treated different from others. |
Nii et võta siis kinni
HV valuutakalkulaator |
7 :: |
360 |
