trip
303 |
RPG16
01.10.2013 21:26:03
| HL3 oleks ainus põhjus, miks ma mõne PC omale ostaks.
| Kommentaarid: 203 loe/lisa |
166 |
xonix
01.10.2013 22:29:15
| Can't wait. Tahaks juba näha ja kuulda kuidas Gabe seda ütleb.
| Kommentaarid: 74 loe/lisa |
68 |
ahvilõust
01.10.2013 22:57:28
| RPG16 kirjutas: |
| HL3 oleks ainus põhjus, miks ma mõne PC omale ostaks. |
Milleks? Tuleb kindlasti ka su sexkastile!
_________________ Gdesainer |
| Kommentaarid: 8 loe/lisa |
kriist
01.10.2013 23:02:16
Ei imesta kui: "SteamOS only".
93 |
Leinö
| Kommentaarid: 35 loe/lisa |
34 |
aap14
02.10.2013 07:07:21
Poleks paremat viisi Steam Box-i ja Steam OS-i promoda kui Half Life 3
_________________ Slow is smooth and smooth is fast |
| Kommentaarid: 41 loe/lisa |
38 |
pots4t4j4
02.10.2013 07:28:05
| aap14 kirjutas: |
| Poleks paremat viisi Steam Box-i ja Steam OS-i promoda kui Half Life 3 |
Ma tahan halflife3 hiire ja klaveriga mängida mitte mingi puldiga, samas see eelarvamus tuleneb sellest et pole antud pulti lihtsalt proovinud ja s*tamaitse on eelmiste pultidega shooterite mängimisest
401 |
Andykas
02.10.2013 08:04:16
| Ma loodan, et hl3 on linuxile timed exclusive, nt kuu aega varem kui windowsile. Oleks kena lüke linuxi kommuunile.
| Kommentaarid: 25 loe/lisa |
22 |
KrisVr
02.10.2013 15:16:55
http://www.rockpapershotgun.com/2013/10/02/cautious-hooray-half-life-3-being-actively-developed/
There is a thing called Jira that Valve uses for project management. Everything they do is tracked on it, and last night it accidentally went public and OHMYGOD THERE’S A HALF-LIFE 3 TEAM ON IT! No Ricochet 2 team, however.
It’s the second indication in as many days that suggests Valve has decided to focus on Gordon’s journey, following the discovery of a trademark registration. The list has a core of ten developers (called “Half-Life 3 Core, that has Minerva modder Adam Foster, Counter-Strike’s Jesse Cliffe and others, as well as a further 46 in the “Half-Life 3″ group. I borrowed some fingers and toes in the RPS Forbidden Chatroom of Mystery and came up with 56 developers. All those eyes and minds and fingers and elbows probably modelling crowbars as you read this. |
Ei näe probleemi kui tuleks esialgu ainult SteamOS'ile, nagu Valve ütles, siis saad SteamOS'i igale arvutile tõmmata ja peale gamepad'ide töötab ka hiir/klaviatuur ilusti!
| Kommentaarid: 30 loe/lisa |
Psych0
02.10.2013 17:26:38
Jälgin teemat. Tõenäoliselt läheb siin veel 10 aastat, enne kui mõni gameplay video välja tuleb.
| Kommentaarid: 61 loe/lisa |
57 |
Lovvi
02.10.2013 17:28:31
| DefXtreme kirjutas: |
Ei näe probleemi kui tuleks esialgu ainult SteamOS'ile, nagu Valve ütles, siis saad SteamOS'i igale arvutile tõmmata ja peale gamepad'ide töötab ka hiir/klaviatuur ilusti! |
"accidentally"
| Kommentaarid: 64 loe/lisa |
60 |
Scammy
02.10.2013 20:40:00
Lõpuks ometi Half-Life 3
Teised seeriad mulle meeldisid.
Nüüd võiks Portal 3 ka tulla, siis oleks veel parem
renhoelder
02.10.2013 20:48:24
| Minu 2 kopikat on selle peal, et Half-Life 3'st tuleb Steam OS'i /Steam Box'i tõmbe number, ehk siis kui saab teada millal need aparaadid/OS "letti" jõuab, võib ka tõsisemalt mängu ootama hakata.
| Kommentaarid: 75 loe/lisa |
71 |
pots4t4j4
02.10.2013 20:50:55
| kui tavapc saab steamosi multibootima panna siis by all means tulgu sinna
401 |
nolifer
02.10.2013 21:06:34
| RPG16 kirjutas: |
the last of us , oli ainuke põhjus miks ma sõbralt ps 3 laenasin;P
Altas
jõrr
03.10.2013 17:13:16
Ehk saabub asi nii, et kui ostad reaalselt endale Steam Machine siis saad HL3 kaubapeale... Kerge turundusnipp endale kliente leida. muidu tuleb HL3 umbes 50euri per copy
| Kommentaarid: 13 loe/lisa |
Qufi
03.10.2013 17:37:10
No kui midagi siis vast tuleb see f2p steamOS peal ja mujal maksab. Siiralt kahtlen et see tulen ainult steamOS peale ja mujale ei tule, oleks väga loll lüke nende poolt.
_________________ Origin: Qufi |
renhoelder
03.10.2013 17:51:02
| Qufi, kas mitte Half-Life 2 polnud Steam'i eksklusiiv, alguses vähemalt?
71 |
Diesel157
03.10.2013 17:56:28
| HL3 tuleb kindlasti steamplay, võibolla lihtsalt lastake samal ajal välja, kui OS või box.
| Kommentaarid: 162 loe/lisa |
146 |
Qufi
03.10.2013 18:06:38
| renhoelder kirjutas: |
| Qufi, kas mitte Half-Life 2 polnud Steam'i eksklusiiv, alguses vähemalt? |
No üks asi on steam ekslusiiv teine asi on steamOS eksklusiiv.
renhoelder
03.10.2013 18:33:13
| Qufi kirjutas: |
No üks asi on steam ekslusiiv teine asi on steamOS eksklusiiv. |
Tol ajal oli Steam enamvähem sama uus/tülikas kui Steam OS võib tulla. Ja mis sa arvad kui suur oleks Steam OS'i downloadide arv kui oleks OS'iga seotud? Päris eepiline ma pakun.
71 |
xonix
03.10.2013 18:39:51
Võiks pigem konsoolidele tulla viivutus nagu praegu GTA V-ga on.
Igastahes tiimid on paika pandud ja hämmastav lisauudis, Left 4 Dead 3
As mentioned in yesterday’s highly speculative Half-Life 3 news, people have been scurrying through Valve’s project management database JIRA again. Now, NeoGAF user ‘angular graphics’ has posted the full list of Valve staff assigned to the still unconfirmed Half-Life 3 and Left 4 Dead 3 development teams. If nothing else, it’s a rare glimpse into the company’s internal working, and what happens to its employees after they’re sworn to the Valve code of silence.
The Half-Life 3 team contains lead writer Marc Laidlaw, series composer Kelly Bailey (seemingly having returned to Valve after leaving in 2011), and series designer Steve Bond. It also lists Adam Foster, the creator of Minerva (as well as the Portal 2 announcement ARG). The other instantly recognisable name is Portal writer Erik Wolpaw, who appears on both Half-Life 3 and Left 4 Dead 3′s lists.
If anything, the Left 4 Dead 3 team is the more surprising. It contains not only familiar Valve names like Chet Faliszek and composer Mike Morasky, but some of their more notable newer hires. Both Clint Hocking, of Far Cry 2 fame, and Doug Church, of System Shock 2 and Thief fame, are attached to the project. Now more than ever, I’m pretty damn excited about the possibility of shooting up some zombies.
Standard caveats still apply, the most notable of which is that we don’t know how accurate this data is. At best, it could represent a single moment in time for each project, as Valve plays its endless game of musical chairs. And, of course, people working on a project is now indication of when that game might be announced. |
68 |
ottf
03.10.2013 20:47:37
| Qufi kirjutas: |
Tol ajal oli Steam enamvähem sama uus/tülikas kui Steam OS võib tulla. Ja mis sa arvad kui suur oleks Steam OS'i downloadide arv kui oleks OS'iga seotud? Päris eepiline ma pakun. |
ilmselt.. sest mängud on ainuke asi mis mind veel windoosal hoiab. Paraku pole ma üksi kes sellises olukorras on
| Kommentaarid: 6 loe/lisa |
rewer
04.10.2013 12:41:25
Eks Valve vajab SteamOS/Boxi jaoks killer appi ja mida neil paremat pakkuda oleks kui HL3 Seda ei usu et tuleb ainult SOSile, kuigi algul võibolla küll.
| Kommentaarid: 1312 loe/lisa |
922 |
pohmakas,
käed värisevad
| Kommentaarid: 167 loe/lisa |
138 |
trip
303 |
pots4t4j4
06.10.2013 11:40:15
what a bummer
401 |
aap14
06.10.2013 12:01:54
eieieieieieieieieEEIEIIEIIEIIEIIIIIIIIIIIIIII!!!!
RIP lootused:
38 |
Scammy
06.10.2013 20:05:14
Oh well.. järgmine 5 aastat ootamist
Kapitan
Kaevur
| Kommentaarid: 26 loe/lisa |
21 |
margus27
24.01.2016 19:34:03
Kui steamDB-s oleks ta kirjas kui Half-Life 3, siis võiks isegi lootust olla
91 |
sooty
24.01.2016 21:37:53
| Mõni töötaja pani alkoholi mõjul ajaviiteks üles.
| Kommentaarid: 12 loe/lisa |
12 |
heretic666
24.01.2016 22:57:16
| Kommentaarid: 73 loe/lisa |
147 |
rewer
01.04.2016 09:06:19
Rikkusid kõik ilusa ära
922 |
Kapitan
Kaevur
21 |
-Kaivo-
18.01.2017 16:18:47
| Lord Gaben saab selle teoga maailma rikkkamaiks meheks.
| Kommentaarid: 16 loe/lisa |
15 |
Archangel
18.01.2017 17:24:10
Gaben suutis teha AMA, kus 90% tema vastustest ei vastanud tegelikult midagi.
25 |
labidas
| Kommentaarid: 34 loe/lisa |
34 |
CnZ
18.01.2017 18:11:25
| Tegemist ei ole ei HL ega Portaliga. Uus IP, mis on samas universumis. Õppige lugema.
| Kommentaarid: 14 loe/lisa |
heretic666
18.01.2017 18:42:52
| Tehakse headcrabi kauge sugulase visual novel game.
Gap
18.01.2017 20:20:51
piiksu miks nad krt ei või teha HL3-e või tehku siis kasvõi näiteks episode 3 Milles siis asi on üldse ? kas asi seisab raha taga või pole piisavalt häid ideid millega laineid lüüa ? Igasugu criisisieid ja duume trükitakse metsikult Tänapäeva graafika ja tehnika arengu juures oleks ju võimalik luua metsikult ilusa graafika ja atmosfääriga mäng Mäletan kui mängisin aasta oli vist 2004 Half Life 2-te, siis see oli mäng mille tagant ei saanud üldse ära, see oli ikka mega mäng ja on siiani,siis arvan et nad peaksid suutma küll midagi taolist teha ,ja kui pole ideid krt võtku siis mingi muu stuudio appi kes on teinud edukaid mänge .. .witcher 3 näiteks
| Kommentaarid: 21 loe/lisa |
17 |
CnZ
18.01.2017 20:29:44
Mäletan, et 2004 HL2 endale midagi erakordset ei pakkunud. Meenub vaid see, et levelite disainimisega hoiti üksjagu aega kokku sellega, et pidid pool mängu mingi bagiga sõitma suurtel lagedatel aladel mitte midagi tarka tehes HL1+opposing force+blue shifti kompott igal juhul põnevam
DigeBeni
19.01.2017 10:36:49
... kui see on tõsi, siis peab vist õnnelik olema, et Valve üldse midagi teha viitsib, pangas saab niimoodi ju veel raha jaoks ruum otsa
163 |
rewer
19.01.2017 11:22:03
HL3 küsimus pole miks ei tehta vaid pigem miks Valve peaks tegema?
Esiteks ükskõik kui hea mäng ka ei tuleks enamuse ootustele ikka ei vastaks
Raha pärast nad seda tegema ei hakka ja kindlasti ka mitte mingit poolkõva mängu ehk lihtsam üldse mitte teha.
HL2 on/oli tõesti hea mäng. Suhteliselt hiljuti sai uuesti mängitud ja ka täna tasemel va need story osad kus lihtsalt passid(esimest/teist korda huvitav aga hiljem igav ja tahaks skippida).
See video muidugi naljana mõeldud aga tundub päris hästi pihta läinud olevat
922 |
Gap
19.01.2017 13:03:09
rewer, kui võib küsida,siis miks sul selline arvamus või kus sa seda võtad et ükskõik kui hea mäng ei tule ei vasta ikka ootustele ? Tänapäeval on enamus mängud välja tulnud, mis ei vasta ootustele seda juhul jah kui sa liiga palju ootad ja luuakse sed n.ö haipi.
17 |
labidas
19.01.2017 13:44:53
eks vaikne HL3 ootus hoiab huvi Valve vastu paremini kui mäng ise.
10 aastat ep2'st ja nüüd Gabe teeb AMA
Sounds like hl3 confirmed to me
34 |
486
19.01.2017 14:56:02
valvel pole enam meeskonda kes suudaks mängu teha. Raske uskuda, et neil progejad, joonistajad jne seal k6ik need aastad istuvad niisama ilma, et kunagi midagi välja oleks lastud.
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
Anna tooli
| Kommentaarid: 367 loe/lisa |
301 |
