uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [X360/X1/PS3/PS4] Grand Theft Auto V märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 6, 7, 8 ... 50, 51, 52  järgmine
Riddim
Riddim
sõnum 18.08.2013 19:32:45 vasta tsitaadiga
rocky-b kirjutas:
Loodame, et GTA Vl on mänguna midagi GOTY väärilist siis pakkuda ka, kuigi kindlasti mingid väljaanded talle selle tiitli omastavad lihtsalt sellepärast et tegu on GTA Vga.
LEVEL1.EE - Videomängudest eesti keeles!
rocky-b
rocky-b
sõnum 18.08.2013 20:19:41 vasta tsitaadiga
Riddim, Selle pärast küll nüüd muretsema ei pea, ma arvan.
roltz418
roltz418
sõnum 19.08.2013 21:44:01 vasta tsitaadiga
To bumer: Inimene näeb kohe kindlasti rohkem kui 24 kaadrit sekundis.Uuri netist selle 24 fpsi kohta , see ei ole päris sama fps mis kuvaril kuvatud.Mina teen ilusti vahet kui 60 fpsi on ja siis järsku läheb 30 peale , päris palju aeglasemaks läheb.
The most common "frame rate" on a television set is 24, with ranges that can go from 18-30 (these are approximations). I use quotes because TVs don't work the same way as computer screens. A television set doesn't render individual frames; instead it provides a range. Everything appears fluid because everything is blurred. Notice how still shots of action scenes aren't the most crisp images in the world? Wonder why. But then how come you can make out static details on a screen? Why can you see the same cracks in stones watching The Matrix as you can playing Q3A? See below.
FPS in Games
This is of course, all about games. The reason you can't run them smoothly at 24fps is because each frame is just that: a still frame; not a blurred range. Now, let me dig up a random number out of the blue, say 40fps. Ok, so 40fps is sufficient, right? Yes and no. Let's say you're the proud owner of a Geforce4 Ti4600. You don't care about 200fps so crank up the resolution to 1600x1200, turn on 4x FSAA and 16x Anisotropic Filtering. Plus all the in-game candy you can throw at it. Your rates drop from 150 down to 40. Naturally, it looks like crap. Why? Several reasons.
The more detail you have the more "sampling" your eye does automatically (or, more accurately, you strain it more). Try this: find an older video card (or underclock what you currently have) that will only run 1600x1200 at 40fps without any special features. Chances are it'll look smoother because you don't have anisotropic filtering enabled. More importantly, however, is adaptation. If you've played games at 40fps all your life and haven't seen otherwise, it'll look pretty good to you.
The same goes for the person who's had the luxury of 100. Now swap their positions. The 40fps person won't notice much, because to them 40fps was smooth as is. The unlucky person will be the one who's downgrading; to him/her a dramatic difference is in store. This is one reason why a lot of people claim that anything over 60fps doesn't matter: because they've never been significantly over 60fps for long. I bet if you play at 250fps (possible, but only with older games at low resolutions) for a couple weeks and then go down to 125, you will see a difference.
So is there a limit?
Technically, yes. Practically, no. The technical "limit" would be anything ranging from the speed of light to how long it takes it to reach your eyes to how fast your brain can interpret it. Other things like internal chemical reactions and the state of developed neural connections should also be considered. But still, 300,000,000m/s is pretty fast. What am I trying to say? This:
THERE IS NO PROVEN LIMIT TO THE FRAME RATE THE HUMAN EYE CAN PERCEIVE.
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 53
Bumer
sõnum 19.08.2013 22:09:01 vasta tsitaadiga
roltz418, Eks 60 ja 30 teeb tõesti vahet, aga nii super-hüper arvutit ikka pole, kus GTA 60FPS jookseks. Kui PS3 jooksis 30 ja minu arvuti peal tol ajal, mingi 40 heal juhul hea graafikaga, siis ega ju suurt vahet sellest ei olnud.
Õnneks pole ma selline olnud, kes eluaeg saanud end 60FPS mängudel hellitada lasta, hea graafikaga tavaliselt ikka sinna 40 kanti jäänud(uuemad mängud) ja seetõttu arvatavasti ei teegi erilist vahet ja saan rahulikult mängida ilma et kõik mängud tunduksid timelapse seeriana.
Kommentaarid: 51 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 48
roltz418
roltz418
sõnum 20.08.2013 21:47:24 vasta tsitaadiga
Ega ma pole ka 60 + koguaeg mängida saanud icon_biggrin.gif üldiselt ikka sätteid alla , kui mingi 30 fpsi jookseb , endal lihtsalt mõnusam mängida kui sujuvam.
Siim159
Siim159
sõnum 21.08.2013 12:34:15 vasta tsitaadiga
Kõikidel GTA V sõpradel on võimalus reedest Day1 digitaalversiooni eeltellimus sisse anda PSN-st, millega kaasnevad ka mõningad boonused: http://gtaveeb.ee/v/435
Bumer
sõnum 23.08.2013 07:39:44 vasta tsitaadiga
- 6 main heists;
- Mission(-s), in which you will need to use torture to extract information;
- There will not be complete, all-sufficient missions under water, but many heists will be connected to it. You can use the underwater world for escaping from arrest.
- Police can swim.
Heists
- More than 20+ types of masks for the heists;
- If the police will see you in masks with guns, they'll arrest you. When you take off the mask, you're no longer recognized by police or pedestrians.
For example, if you wear a mask, pedestrians will start to panic, to be afraid, to call the police, and even take pictures with their cameras.
When you take off your mask, they'll continue to panic, but they no longer recognize you.
- Some of the heists are so difficult that you have to seek help from mercenaries. Some of the mercenaries are: goon, sniper, hacker, pickpocket.
Activities
- Secondary activities: golf, shooting, triathlon, jumps with parachute, ROPEJUMPING(new), tennis, hunting, underwater hunting , hunting for criminals, armwrestling, yoga.
- You can improve your skills in yoga and at some point you can even have a class where you'll teach other people.
- You can pay 2$ and take a tour of the richest places of this mysterious city.
- You can buy a prostitute on the road.
- You can order a lap dance at a strip club.
- You can go into the woods on a trailer, taking the necessary camouflage and weapons and check your hunting skills. But remember that you're not alone. There are robbers, murderers, drug addicts who'll bring you problems.
- Very huge amount of animals.
- In the wild: deer, rabbits, squirrels, mountain goats.
- In the countryside - animals of rural type.
- You'll not be able to defeat bear and lynx barehanded.
- Pumas, coyotes, wolves, turtles.
- Working ecosystem. Animals prey on each other. Animals not only on the ground, but in the sky and under water as well.
- When you jump with a parachute, you can see flocks of birds.
- Sharks get in packs.
- You'll not be able to defeat a shark with a knife only. You'll not be able to shoot under water using ordinary assault rifle.
- Sharks attack not only you, but other people as well.
- In the underwater world you can find sunken ships, planes, containers, cars, sunken oil rigs and even 12-storey plant.
- You can't go fishing in GTA V. Only pedestrians can.
- Rats in the dirty parts of the city.
- Dog customization.
Weapon Customization
-Sniper, collimator sight, additional handles, flashlights, laser pointer, silencer, extended magazine, changing of colors
Car Customization
- More than 200+ vehicles. Including, four-engine bombers, bikes, sportcars, trailers, tank.
- More than 1000+ customization options.
Character customization:
- More than 30+ types of clothes.
- Accessories: watches, chains, bracelets.
- Tatoos.
- More than 15+ hairstyles.
Durin
sõnum 23.08.2013 13:33:48 vasta tsitaadiga
http://www.gtaforums.com/index.php?s=84d128fa3e009e42df6a69ddf2156816&showtopic=576041&st=0
Kui mäng on 18 gb suur, siis 12 gigase PS3-ga ei saagi seda mängida ?
Getomees
Getomees
sõnum 23.08.2013 13:35:25 vasta tsitaadiga
Plaadiversiooni saab, kohustuslik install on umbes 8GB.
Sinikiir: Blu-ray temaatiline foorum
Kommentaarid: 59 loe/lisa Kasutajad arvavad:  :: 7 :: 2 :: 30
iir
iir
sõnum 23.08.2013 13:50:52 vasta tsitaadiga
12 gigane PS3 polegi mängimiseks mõeldud, selle jaoks tuleb ketas juurde osta
Status0
Status0
sõnum 23.08.2013 14:37:18 vasta tsitaadiga
Tõsiselt suur mänguelamus saab olema, hakka või ps4 ostu pisut edasi lükkama icon_smile.gif
Ahjaa, keegi paar lehte tagasi küsis, et kas amazon.co.uk-st saab PS3 (500GB)+GTA 5 komplekti (bundle), <-- jah, nüüd juba saab thumbs_up.gif
Slaz
sõnum 24.08.2013 11:06:22 vasta tsitaadiga
http://imgur.com/DchQTpI
nivoo
nivoo
sõnum 24.08.2013 17:12:28 vasta tsitaadiga
Igasugused asjad lekivad praegu. GTA Forums ja "GTA V" Reddit on igasugust soga täis, isegi lõpp oli kuskil ette ära räägitud (mingitest helifailidest saadi jälile vist). Parem neist vist ennast eemale hoida, kui ei taha enda jaoks mängu ära rikkuda. Asi sai vist alguse sellest, et PSN-ist sai mängu mingi aeg pre-loadida.
rocky-b
rocky-b
sõnum 24.08.2013 17:24:26 vasta tsitaadiga
Eks igal pool on keegi, kes rikub teiste jaoks lõbu ära.
Durin
sõnum 24.08.2013 18:07:07 vasta tsitaadiga
Kellele INTRO (Loading...) nägemine midagi ära ei riku, siis vaadake. Pigem tekitab rohkem ootusärevust icon_lol.gif
Volum
sõnum 25.08.2013 09:50:32 vasta tsitaadiga
Tellin originaal A-varuosasi saksast. 15-70% soodsamalt kui esindustes!
Teostan diagonstikat tehasetasemel: BMW, VAG (Audi, VW, Seat, Skoda ja kaubikud), Volvo (sõiduautod), Scania - Tartus, Põlvas ja lisatasu eest Võrus.
Siim159
Siim159
sõnum 26.08.2013 19:31:33 vasta tsitaadiga
Äsja RG avalikustas taas veidike infot Special ja Collector`s Editioni boonustest: http://gtaveeb.ee/v/441-miks-soetada-gta-v-special-voi-collectors-edition
iir
iir
sõnum 26.08.2013 19:50:43 vasta tsitaadiga
Siim159
http://www.rockstargames.com/newswire/article/50061/announcing-the-grand-theft-auto-v-special-edition-and-collectors.html
Siim159
Siim159
sõnum 26.08.2013 19:57:42 vasta tsitaadiga
iir, Eks suurem osa infot tõesti varem selle artiliga nad välja lasknud, kuid viimases teadaandes, mille kohta ka too GTAveebi artikkel tehti, on siiski mõningad uued infokillud ja pildid sees.
See siis: http://www.rockstargames.com/newswire/article/51257/more-details-and-screens-from-the-grand-theft-auto-v-special-and.html
battlear
battlear
sõnum 26.08.2013 23:04:56 vasta tsitaadiga
Kui game.co.uk preorderi teen, millal see kohale jõuab ? Panevad alles mingi 16-17 posti ?
Siim159
Siim159
sõnum 26.08.2013 23:19:57 vasta tsitaadiga
Ega keegi garantiid ju anda ei saa, kuid ma kuulnud, et nemadki panevad ikka varem teele. Arvatavasti 1 päev varem.
//Aga miks mitte kohe Eesti poest 50€-ga? Uus kasutaja vms Gamestarist saab GTA V soodushinnaga 50€-ga, tasuta saatmine. Nemad panevad 1 päev varem teele.
S.I.L.L.U
sõnum 27.08.2013 00:16:34 vasta tsitaadiga
Siim159 kirjutas:
Tegin nagu konto aga hind ei lange, mingi kood panna?
Kommentaarid: 96 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 90
Bumer
sõnum 27.08.2013 09:42:38 vasta tsitaadiga
S.I.L.L.U kirjutas:
Siim159 kirjutas:
Ostukorvis tuleb jah kood panna.
battlear
battlear
sõnum 27.08.2013 11:11:42 vasta tsitaadiga
Siim159 kirjutas:
Eesti poodides juba kasutajad ja esimesed ostud tehtud. Game.co.uk tuleb 6€ odavam ja saab mingi õhupalliga ka sõita vms. icon_smile.gif
iir
iir
sõnum 27.08.2013 11:31:41 vasta tsitaadiga
Euronicsist saab Limited ed. 71.-
weasel
weasel
sõnum 27.08.2013 11:58:07 vasta tsitaadiga
Mis selle PSN-i versiooni "erilised omadused" on täpselt?
PSN: weaselEST
iir
iir
sõnum 27.08.2013 11:59:48 vasta tsitaadiga
Polegi. Kallim kui plaadiversioon ju ja sama raha eest saab selle lim.edt. juba... +karp ja võimalus pärast edasi müüa...
weasel
weasel
sõnum 27.08.2013 12:04:21 vasta tsitaadiga
iir kirjutas:
Mulle ei jõua see hinnapoliitika ikkagi kohale. Kuidas saab olla digiversioon kallim kui plaadiversioon.. kopp.gif
PSN: weaselEST
iir
iir
sõnum 27.08.2013 12:07:42 vasta tsitaadiga
Mugavus... Ajuvaba ikka jah.
20 päeva veel, hakkasin 4 uuesti läbi tegema, kuskil jäi pooleli ja trophyde jaoks tuli ka uuesti hakata, ei tea kaugele jõuan?
Siim159
Siim159
sõnum 27.08.2013 12:17:47 vasta tsitaadiga
On küll PSN versioonil eelised. Selle "õhupalliga" saab lennata icon_biggrin.gif, saab GTA V theme PS3-le ning 75%-lise allahindluse kupongi, mis kehtib kõikidele RG mängudele PSN-s.
iir
iir
sõnum 27.08.2013 12:32:54 vasta tsitaadiga
Nojah, plaadi versiooni saab kätte 50.- PSN oma 69.95 ja saad valitud asjadelt soodust. Aga, kas on mingit asja mis seda väärt oleks?
Limited edt. 71.- ja saad kaasa:
Full retail copy of Grand Theft Auto V
Collectible SteelBook with Exclusive Artwork
This special SteelBook features double-sided, never-before-seen artwork of Michael, Trevor and Franklin. Custom color and metallic treatments bring out the detail of the artwork created exclusively for this SteelBook.
Blueprint Map
This exclusive, additional 21.5” x 26.75” map displays a blueprint view of Los Santos and Blaine County. Cryptic markings indicate locations for fast cash and other points of interest for the up-and-coming entrepreneur.
Special Ability Boost
Michael, Franklin and Trevor each have a unique special ability. With this boost, the special ability bar will generate 25% faster.
Stunt Plane Trials
Single player Stunt Plane Trials let you take on additional aerial challenges spread throughout Los Santos and Blaine County.
Bonus Outfits, Tattoos and More
Michael, Franklin and Trevor get bonus outfits in their wardrobes, character specific tattoos at tattoo parlors, and special deals from shopkeepers across Los Santos and Blaine County.
Additional Weapons
When visiting Ammunation stores in single player, merchants will have special weapons in their inventory available for free: the Pistol .50, Bullpup Shotgun and melee Hammer.
aise
aise
sõnum 27.08.2013 12:51:28 vasta tsitaadiga
PSN versiooni saab osta 2 peale, 28-29€ nägu.
Kommentaarid: 189 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
Flacko
Joonistusmaniakk!
Flacko
sõnum 27.08.2013 14:24:11 vasta tsitaadiga
Ma ise vahetasin ka enda GTA V selle Special Editioni vastu.
Flacko, the nutty weasel who loves blue cheese, Blyth's Reed Warblers, Thrush Nightingales and Devin Townsend!
Kommentaarid: 199 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 166
Electrical
Electrical
sõnum 27.08.2013 14:54:03 vasta tsitaadiga
battlear kirjutas:
Siim159 kirjutas:
Progames vähemalt lubas, et Atomic Blimp tuleb eeltellimustega kaasa.
Neil on hetkel Special ja Collectors editionid väljamüüdud, jäin hiljaks icon_sad.gif
Amazon.co.uk pakub hetkel kõige soodsamalt pre-orderit: £34.99, aga postikuluks näitab £9 thumbs_down.gif
weasel
weasel
sõnum 27.08.2013 14:57:18 vasta tsitaadiga
Ma ei kannata seda plaatidega jamamist. Äkki see on seda väärt, et 70 välja käia. Rockstari poistele ikka abiks.
PSN: weaselEST
S.I.L.L.U
sõnum 27.08.2013 15:17:14 vasta tsitaadiga
Bumer kirjutas:
S.I.L.L.U kirjutas:
Siim159 kirjutas:
Ja see kood oleks mis?
Bumer
sõnum 27.08.2013 15:21:06 vasta tsitaadiga
S.I.L.L.U kirjutas:
Bumer kirjutas:
S.I.L.L.U kirjutas:
Siim159 kirjutas:
Ei kus mina mäletan, ma kasutasin oma koodi ära mitu aastat tagasi. Ju see ikka registreerimisel kirjas oli või siis meili peale ka tuli, ise seda välja mõtlema ei pidanud.
Siim159
Siim159
sõnum 27.08.2013 15:23:55 vasta tsitaadiga
Jap, peale kasutaja registreerimist tuleb see kood meili peale. Kinkekaart väärtuses 6,4€ ning kehtib alates 32€ ostu puhul, ehk ka GTA V omal.
S.I.L.L.U
sõnum 27.08.2013 15:27:54 vasta tsitaadiga
Sai jah mailile regamis kirja selle koodi icon_smile.gif ei osand sealt seda otsida, lootsin, et mingi üldkood tuleb panna icon_smile.gif
iir
iir
sõnum 27.08.2013 17:36:01 vasta tsitaadiga
aise kirjutas:
Õigus jah. 30.- on päris hea hind ju mängu eest. Tuleb ainult teada kellega osta, ma siin ostsin GTA 4 lisapakid mis enam ei tööta...
Getomees
Getomees
sõnum 27.08.2013 20:01:08 vasta tsitaadiga
http://www.rockstargames.com/newswire/article/51272/grand-theft-auto-v-the-official-trailer-coming-this-thursday.html
kikaskilla
kikaskilla
sõnum 29.08.2013 09:45:08 vasta tsitaadiga
Electrical kirjutas:
Euronicsist saab veel Special editioneid eeltellida 71 euri eest.
Labukana
Labukana
sõnum 29.08.2013 13:29:18 vasta tsitaadiga
Oskate ehk soovitada kust osta/tellida? Ei tahaks väga kaua oodata, ja vaja oleks 3 ühikut.
17 september poodidesse otsima minna ei julge.
Mõtesin amazonist kallima postiga, kuid seal lubatakse 1 koopiat kliendi kohta, shopto's vist sama teema. (Ülejäänud vist veidi liiga aeglased, et neile lootma jääda)
Ideid?
viimati muutis Labukana 29.08.2013 22:22:41, muudetud 1 kord
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 30
Bumer
sõnum 29.08.2013 13:38:47 vasta tsitaadiga
Labukana, on ju ka Progames ja Euronics ja tont teab mis Eesti poed veel.
Vici
sõnum 29.08.2013 13:59:28 vasta tsitaadiga
Gamestar.ee on veel saadaval,pole veel kirja,et läbimüüdud,sama ka progamesis saabumise all,see tavaline versioon
Labukana
Labukana
sõnum 29.08.2013 14:57:40 vasta tsitaadiga
Bumer kirjutas:
Pole Eestist aastaid ühtegi mängu ostnud, Progames ja Euronics head soovitused, saab neist õigel ajal kätte ka?
Bumer
sõnum 29.08.2013 15:22:59 vasta tsitaadiga
Labukana kirjutas:
Bumer kirjutas:
Kuna sa Tallinna inimene, siis ProGames lubab sul lausa tund aega enne poodide avamist kontorisse ise järgi minna mängule etteteatamisel õigel päeval. Vähemalt oma foorumis nad nii lubavad.
Euronics lubab ka mängu ikka õigel päeval. Eks see siis näha ole.
Mina kui postiga tellija, ei saa küll mängu õigel päeval kuna see Smartpost on nii mõttetu firma. (Ise tellisin Gamestarist ja seal lubatakse eelneval päeval teele panna postiga tellijatele)
Siim159
Siim159
sõnum 29.08.2013 15:26:22 vasta tsitaadiga
Minul on küll Smartpostiga vaid positiivsed kogemused ja need hulk pakke, mis ma saanud, on kiirelt kohale tulnud, kui postitaja paneb paki teele ikka enne tühjendamist. Kui enne tühjendamist on pakk teele pandud, siis jõuab too sinuni juba järgmisel päeval.
Bumer
sõnum 29.08.2013 15:28:50 vasta tsitaadiga
Siim159 kirjutas:
Mina asun Saarel ja Smartpost lubab saarele toimetada ülejärgmisel tööpäeval. Samas Post24 on isegi Võrust teele pannes järgmise päeval hommikul juba 9 ajal Saares kohal olnud.
RaPTiLE
RaPTiLE
sõnum 29.08.2013 15:47:06 vasta tsitaadiga
Ei teagi kuhu see makse teha ja ära tellida nüüd.
Euronics tundub kindlaim variant, gamestar pidi olema välja müüdud juba, progames ei lase üldse teha tellimust.
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 55
uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [X360/X1/PS3/PS4] Grand Theft Auto V mine lehele eelmine  1, 2, 3 ... 6, 7, 8 ... 50, 51, 52  järgmine
