uus teema   vasta Raud »  Protsessorid »  AMD Fusion APU arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 17, 18, 19 ... 31, 32, 33  järgmine
itmynk
sõnum 04.05.2013 14:25:06 vasta tsitaadiga
1.Miks Gigabyte FM2 emaplaatidel on protsessori toide enamusel 8pin? Kas see on kuidagi triple-monitoridega seotud ning töötab asi ka 4piniga?
2.Kas FM2 emaplaadile on uusi prose/APU mudeleid tulemas?
Kommentaarid: 75 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 70
Chidori
Chidori
sõnum 04.05.2013 15:13:49 vasta tsitaadiga
itmynk kirjutas:
Ei ole seotud triple monitoriga - 8pin on soovituslik 125W protsessorite puhul.
itmynk kirjutas:
Ax 6xxx peaks millalgil välja tulema
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 99
One
sõnum 04.05.2013 19:22:20 vasta tsitaadiga
link :: AMD Richland Desktop APUs Pictured, Coming This June
Desktop variants of AMD "Richland" APUs in the socket FM2 package, will arrive this June. Three of the first models to be released to the market,
the A10-6800K, the A10-6700, and the A4-4400, could already be in stock with certain retailers, and were pictured. The A10-6800K (AD680KWOA44HL)
features four x86-64 cores based on the "Piledriver" micro-architecture, 4.10 GHz core clock speed, 4.40 GHz maximum Turbo Core frequency, and Radeon
HD 8670D graphics, clocked at 844 MHz. It features an unlocked base-clock multiplier.
The A10-6700 (AD6700OKA44HL) features the same graphics core as the A10-6800K, but features 3.70 GHz CPU clock speed, 4.30 GHz maximum
Turbo Core frequency, and an upwards locked base-clock multiplier. The A4-4400 (AD4400OKA23HL), on the other hand, is an entry-level dual-core chip
with 3.70 GHz core, 3.90 GHz Turbo Core, and Radeon HD 8370D graphics.
Optimist
Optimist
sõnum 06.05.2013 15:19:44 vasta tsitaadiga
http://www.theinquirer.net/inquirer/news/2266131/amd-says-hsa-will-cut-latency-bottleneck-in-gpu-processing
http://semiaccurate.com/2013/04/29/a-look-at-intels-opencl-performance/ Kabini peab natuke siputama, et Intelilt veenvalt eest ära saada.
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
kaspar00
kaspar00
sõnum 13.05.2013 21:54:38 vasta tsitaadiga
https://www.hinnavaatlus.ee/products/Arvutiriistvara/Protsessorid/315642/ tundub, et esimene richland müügis
Kommentaarid: 114 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 102
Braien
Braien
sõnum 13.05.2013 21:55:28 vasta tsitaadiga
kaspar00, Kommihinnaga käes.
kaspar00
kaspar00
sõnum 13.05.2013 21:58:14 vasta tsitaadiga
nojah, lowend kah, eks paistab millega 6800k tuleb icon_biggrin.gif ja kuipalju arengut olnud on icon_rolleyes.gif
One
sõnum 17.05.2013 18:43:54 vasta tsitaadiga
Vaevalt, et midagi väga drastilist tuleb sest prose osa jääb ju samaks.
Eks nad videole miski 20-30% lükkavad powerit juurde.
Need odavad dualcore jne junnid võiks ka kõige vingema grafaga olla.
Siis oleks igasugustel inteli ai end int grafadel küll surm uksetaga.
Kristoferr
Kristoferr
sõnum 23.05.2013 08:42:37 vasta tsitaadiga
http://www.techpowerup.com/184343/amd-amplifies-the-mobile-experience.html
Palju ilusat juttu jälle...
Aga seda tabletit tahaks küll näppida:
Up to 172 percent more CPU performance per watt and up to 212 percent better graphics performance per watt than its predecessor, and up to 12 hours of resting battery life.
Up to 45 percent longer battery life and nearly five times more GPU performance than the competition.
Full support for 1080p touch display capability and full Microsoft Windows compatibility, including support for "Windows Blue."
Liitu Z.ai soodsa coding plaaniga
Liitu Wise'ga!
Kommentaarid: 264 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 215
Denkeš
Denkeš
sõnum 23.05.2013 12:05:13 vasta tsitaadiga
http://www.anandtech.com/show/6974/amd-kabini-review Ülevaade reaalsest Kabini aparaadist
a.k.a Ummikummi
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
One
sõnum 05.06.2013 11:15:34 vasta tsitaadiga
link :: AMD Richland Review; A10-6800K & A10-6700 Benchmarked
Muidu suht lahja edasiminek võrreldes vana viienda seeriaga.
Prose oc on vähemalt kenamaks saadud, vähemalt seal Canucksis arvas et õhuga saab 5.2GHz stabiilseks icon_biggrin.gif
Denkeš
Denkeš
sõnum 05.06.2013 18:43:56 vasta tsitaadiga
No ega midagi väga muudetud pole ka, pmst. sama vana trinity väikeste tweakidega. Aga muidu pole paha selliste väheste muudatuste kohta.
a.k.a Ummikummi
Kristoferr
Kristoferr
sõnum 05.06.2013 19:21:12 vasta tsitaadiga
http://www.techpowerup.com/reviews/AMD/A10-6800K/6.html
TPU graafikud.
Liitu Wise'ga!
Chidori
Chidori
sõnum 05.06.2013 22:22:06 vasta tsitaadiga
paar genni veel ja võib täitsa kesktaseme mänguarvutina kasutada.
sõnum 08.06.2013 20:18:35 vasta tsitaadiga
Aga GPU+GPU klokk ja siis paras häving.
kaspar00
kaspar00
sõnum 10.06.2013 11:31:21 vasta tsitaadiga
http://www.1a.ee/arvutikomponendid/protsessorid/amd_aseries_a106800k_x4_sfm2_box_ad680kwohlbox
6800k eestis ka poodi jõudnud
TT
sõnum 11.06.2013 13:09:38 vasta tsitaadiga
Keegi võiks testida samadel klokkidel 5800K.d. Tõenäoliselt jäävad tulemused väga 6800K kanti.
5800K vs 6800K vahe tundub peamiselt klokid olevat. Samuti tarbib mitme review väitel 6800K rohkem voolu.
Things ThaT You own end up Owning you!
Vaata kasutaja äripakkumisi
M: Kaks Delli sülearvutit SSD hinnaga 6503
M: 2x16GB 2666 DDR4 ECC 0189
Kommentaarid: 309 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 273
kaspar00
kaspar00
sõnum 17.06.2013 16:36:41 vasta tsitaadiga
tsiteerin bulldozeri teemast
Optimist kirjutas:
http://flyingsuicide.net/news/amd-fix-unleashes-x87-performance-greatly-improves-superpi-performance/ Mulle meeldib sissejuhatus aga numbrit jäävat +18-30% kanti.
tegelt ju päris kena kui ilma suuremate muudatusteta 20% singlecore perfomanceit saab tõsta icon_biggrin.gif jääb vaid oodata, kuna proovida saab
sõnum 17.06.2013 17:49:52 vasta tsitaadiga
Krt ma ikka mõtlen, et ehk peaks uue läppari asemel miski AMD APU põhjal odava väikse kasti kokku viskama icon_rolleyes.gif
Mis neil veel kunagi miski uus generatsioon välja tulemas?
A-Circus.
A-Circus.
sõnum 20.06.2013 05:31:01 vasta tsitaadiga
salatoimik kirjutas:
Aasta lõpupoole juba peaks tulema Kaveri, millel on 4 Steamroller tuuma, 512GCN graafikashaderit ja valmistatud 28nm tehnoloogial. Eeldustele tuginedes peaks perf tõus nii CPU kui GPU jõudlus praeguste APU'dega võrreldes suht märgatav olema.
itmynk
sõnum 21.06.2013 21:11:23 vasta tsitaadiga
Leia pildilt Dual core APU A6-6400K
http://www.tomshardware.com/reviews/gaming-cpu-review-overclock,3106-5.html
E: Tõsteti phenom II X4 lahtrist alla, oma õigele kohale icon_smile.gif
viimati muutis itmynk 03.09.2013 18:23:09, muudetud 2 korda
kaspar00
kaspar00
sõnum 24.06.2013 23:07:29 vasta tsitaadiga
http://flyingsuicide.net/news/amd-bulldozer-conditioner-patch-for-superpi-made-public/
single core jõudlust parandav patch nüüd avalik thumbs_up.gif download link artiklis
EDIT: kuna link hetkel ei tööta siis, http://www.upload.ee/files/3402673/BDC_R1.00B.zip.html
corpy
sõnum 30.06.2013 23:30:56 vasta tsitaadiga
Tervist, plaanin siin arvutit kokku panna tuttavale - jäin aga hetkel toppama komplekti juures just emaplaadi ja uue Richlandi A6-6400k kokkusobimisel.
Probleemiks nimelt see, et Gigabyte GA-F2A55M-DS2 (rev. 1.0) tuleb saatanas teab mis BIOS versiooniga (Arvatavasti F2). Seda Richlandi toetab see emaplaat aga alates F5 BIOS versioonist.
Kas selle Richlandiga saaksin ma vähemalt POST/BIOS'eni et läbi Q-Flashi BIOS ära uuendada. Iseenesest Richland ei ole eriti suur uuendus baseerub nagu Trinity'gi Piledriveril ju.
Või tõesti vajan vanemat versiooni, selleks et uuendada BIOS ära?
Tänud ette!
1dumbpcuser
sõnum 01.07.2013 06:02:28 vasta tsitaadiga
Võib, aga ei pruugi.
M:
Kommentaarid: 101 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 96
One
sõnum 01.07.2013 06:18:36 vasta tsitaadiga
Usun, et võtab pildi ette ka vanema biosiga ja saad ise uuenduse ära tehtud.
uus teema   vasta Raud »  Protsessorid »  AMD Fusion APU arutelu mine lehele eelmine  1, 2, 3 ... 17, 18, 19 ... 31, 32, 33  järgmine
