We would like to thank you for your purchase of the Arma 3 Supporter Edition on the day of its release. As you can surely remember, we experienced some serious problems with store stability at the time, which makes your dedication even more admirable.
Out of appreciation for your support of the Arma series, and also as an apology for all the trouble you experienced, we would like to offer you this one time gift code for 25€ which you can use on Store.bistudio.com.
To prevent similar problems from occurring in the future, we are currently exploring (and consequently implementing) several new features. Once again, we apologize for the inconvenience this situation may have caused you.
Päris vahva
See oli jah päris hea üllatus põhimõtteliselt läks kogu supporter edition maksma mingi €20.-
Päris vahva
Äkki saab ka DayZ SA bistore kaudu otsa, siis tn oleks mäng tasuta käes
Kui nii saaks, siis oleks paganama hea küll saaks Dayz ka supporter editioniga kaasa. Tuju läheb kohe rõõmsaks, ei mäleta, et oleks palju firmasid kes selliseid kingitusi teeks.
-Kaivo-, ametlik variant võib kunagi tulla, kuid kindel olla ei saa - kõikidele vanadele sõidukitele tuleb siis physx külge pookida.
Lovvi, Arma2Free võib kah töötada.
Asset audio overhaul: volume balancing, WAV to WSS conversion and more (details to be posted) - WIP
Known issue: Pop-up errors in the Stratis world scene (on start-up and when returning from other content)
Known issue: A fair few errors related to missing files - due to large (audio) data overhaul
Fixed: Hard limit usage while performing light sorting
Fixed: Audio distance curve
Fixed: MX UGL had a displaced crosshair
-showScriptErrors enabled by default
Author's name in scenario overview is formatted like "by %s". If undefined "by Unknown Community Author" is displayed
Increased light intensity of muzzle flashes (due to global lighting changes)
Fixed: AI will not eject before player
Fixed: Taking additional ammo for pistol would play reloading sound
Fixed: Certain magazines could not be moved to another container from backpacks
Audio: Radio filter / effect (not applied yet)
Loiter waypoint added (untested)
Fixed: RMB in inventory (moving from backpack to your own backpack) lost the item
Added tooltips to CListBox and key presets
Fixed: Texture flickering on wrecks
Fixed: Tooltip crash in MP sessions listbox
Fixed: http://feedback.arma3.com/view.php?id=7673 (crash when trying to bind controls (drag and drop))
Updated to Physx3.2.4
Added lbSetTooltip script command
Improved ‘fording depth’ for helicopters to deal with ‘landing’ on water better
Added: BIS_fnc_log enabled in public version when 'allowFunctionsLog = 1;' is set in description.ext
Fixed: BIS_fnc_sideColor can now load non-number values
Fixed: BIS_fnc_functionMeta was not working with scenario and campaign functions
Added: Scenario / campaign functions now support 'forced' param, allowing them to be executed automatically upon scenario start
Added: BIS_fnc_spawn
Added: Ability to execute BIS_fnc_execVM and BIS_fnc_execFSM without arguments
Fixed: BIS_fnc_error was not working correctly
Changed: Splendid Camera roll speed decreased, users should no longer be inclined to take screens with too extreme roll
Added: Communication menu manager
Added: A notification is displayed when a new communication menu item is added
Fixed: allowFunctionsRecompile description.ext param had no effect
Added: BIS_fnc_loadInventory throws an error when non-existent uniform is added
Added: BIS_fnc_MP now accepts SIDE type as a target. Function will be executed on computers of all players on the given side.
Optimized: BIS_fnc_selectRandomWeighted
Added: Variable header added to local functions
Fixed: BIS_fnc_sortBy ignored entries with duplicate values
Removed hand grenades from helicopter pilots and crew
Danger FSM: Script command setUnitPosWeak used instead of setUnitPos. Priority of event DCCanFire is higher now.
Continued lighting tweaks for wheeled vehicles
Fixed: http://feedback.arma3.com/view.php?id=7584 (top-speed gear change for the Hunter)
Fixed: Tweaked fire geometry (mostly glasses) for the Hunter
Alarm sound now also configured under CfgSounds, as “Alarm”
Various (missile) ammunition behavior tweaks (maneuvering, locking, etc.)
Launcher AI settings and weapon performance configuration tweaked
-How to install ACRE for ArmA 3?
You need to download CBA_A3, ACRE, JayArmA3Lib. Extract these to your ArmA 3 installation folder which is located in your Steam steamapps\common folder. Take keys from each mod folder and put them in the 'Keys' folder. Copy/cut 'userconfig' folder from '@ACRE' and paste it in ArmA 3 folders root. Now you will need to add modline (-mod=@CBA_A3;@ACRE;@JayArmA3Lib) to ArmA 3 launch options in Steam.
For TeamSpeak to work you have to take the appropriate (32 or 64bit) TS plugin from @ACRE folder and place it in TS plugin folder.
-How do I use radio if I find one?
You speak into your radio by pressing your CAPSLOACK key. Press it, say what you need to say, and release the key.
It is possible to take multiple radios with you. You can switch between radios by pressing CTRL + SHIFT + A.
You can pull up your radio interface by pressing CTRL + SHIFT + X.
-How do I communicate with someone who is really far away?
For this, you will need either the PRC119 or the PRC117F . On the PRC119, change to it by pressing CTRL + SHIFT + A. Change the PWR (power) mode to HI (high) or, if you are in a vehicle, to PA (Power Amplified). This will make the signal much stronger.
-I already bound my CAPSLOCK key to my Teamspeak 3 push to talk button. Is it possible to set another key for my ACRE radio?
Go to your ArmA2 directory and open the file userconfig\acre\acre_keys.hpp
Change the key found under 'class PTTRadio { key = 58 ... }'
58 is the CAPSLOCK key. If you scroll all the way down in the acre_keys.hpp file, you will see a list of all keys and their codes.
Ma ykspäev installisin ka ära ja proovisin mingit esimest ettejuhtuvat online serverit...pidi miskises baasis jooksma ja yksteist nottima ... krt osad controlid peab vist yle vaatama...häiris ukse avamine spacega ja geari ma ka ette ei saanud _________________ Every version of the garment appears to be sold out online, with prospective shoppers given the opportunity to join a waitlist.
Kui keegi tahab niisama laskmist harjutada. Tegin väikse SP missiooni.
Esimese hooga proovisin 1st personiga. Sain sumpsi nii mis kole
Kui päris aus olla, siis ma pole seda isegi veel läbi suutnud teha. Mõtled küll, et peaks kõik vaenlased otsas olema, aga siis kuskilt tuleb ikka laks sisse.
Deem! Keegi on Dev buildi uusi sounde ja lightingut proovinud ve? Päris lahe
Öö on küll nüüd hetkel selle tulemusena veidike valgem aga uus valguse süsteem annab oluliselt juurde ikka
Also, juba vihjati, et paari nädala pärast on BETA infot oodta _________________ Bawse
Sniper Package (WIP) staged for testing
1 x BLUFOR sniper and spotter duo
1 x BLUFOR sniper rifle
1 x OPFOR sniper and spotter duo
1 x OPFOR sniper rifle
Known issue: missing firing sounds
Currently the reload after every shot for bolt action rifles like M320 is wrong. We are looking into it.
1 x Rangefinder
Field Manual records
et siis kumbki pool sai omale snaiprid koos ghillie suitide, rangefinderite ja täpsuspüssidega.
Keegi on kursis kuidas on lood arma 3 serveri hostimisega.
ainult winni alt, või unix süsteemid ka toetatud vms? Dedicated masinatega kuidas on jms?
E: Tundub et dedi serverit pole veel ja steami installiga koos a3'mega linux masinasse konsoolis on vist üsna raske. _________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
1 x Rangefinder
Korralik kraam Uus snaipri sihik on ka palju tõetruum kui senine: http://i.imgur.com/WiVawm2.jpg
Eks nüüd peaks vaikselt Beta contenti tulema hakkama, ilmselt E3 näeb ka nii mõndagi _________________ Bawse
1 x Rangefinder
Varem oli ju ainult ACOG ?
Anyway, kuidagi proovida seda ka saab või ? _________________ 🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr
1 x Rangefinder
Ee jah aga ma mõtlesin pigem nagu Arma 2 oma, mis on sarnane ACOG-le, kus terve ekraan on must ja siis mingi osa on sihik seal. Selline mitte kogu vaatevälja piirav lahendus meeldib rohkem, isegi kui sihiku ümbrus on ka zoomitud (vastasel juhul tuleks ümbris ja sihik eraldi renderdada ja see näeks välja nagu auto peeglid, mis oleneks sinu PIP seadetest).
Proovida saab kui sa liitud Dev build/branch-ga. Ehk sa saad igapäev WIP uuendusi, mis võivad olla vigased ning need jõuavad hiljem kunagi Stable buildi _________________ Bawse
Minu arvutil ilmselt jõnksutab... ootan arma4 _________________ Every version of the garment appears to be sold out online, with prospective shoppers given the opportunity to join a waitlist.
